This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud OpenFeign 4.2.0!spring-doc.cn
Spring Cloud OpenFeign Features
Declarative REST Client: Feign
Feign is a declarative web service client. It makes writing web service clients easier. To use Feign create an interface and annotate it. It has pluggable annotation support including Feign annotations and JAX-RS annotations. Feign also supports pluggable encoders and decoders. Spring Cloud adds support for Spring MVC annotations and for using the same HttpMessageConverters used by default in Spring Web. Spring Cloud integrates Eureka, Spring Cloud CircuitBreaker, as well as Spring Cloud LoadBalancer to provide a load-balanced http client when using Feign.spring-doc.cn
How to Include Feign
To include Feign in your project use the starter with group org.springframework.cloud and artifact id spring-cloud-starter-openfeign. See the Spring Cloud Project page for details on setting up your build system with the current Spring Cloud Release Train.spring-doc.cn
Example spring boot appspring-doc.cn
@SpringBootApplication
@EnableFeignClients
public class Application {
		SpringApplication.run(Application.class, args);
StoreClient.java
@FeignClient("stores")
public interface StoreClient {
	@RequestMapping(method = RequestMethod.GET, value = "/stores")
	List<Store> getStores();
	@GetMapping("/stores")
	Page<Store> getStores(Pageable pageable);
	@PostMapping(value = "/stores/{storeId}", consumes = "application/json",
				params = "mode=upsert")
	Store update(@PathVariable("storeId") Long storeId, Store store);
	@DeleteMapping("/stores/{storeId:\\d+}")
	void delete(@PathVariable Long storeId);
In the @FeignClient annotation the String value ("stores" above) is an arbitrary client name, which is used to create a Spring Cloud LoadBalancer client. You can also specify a URL using the url attribute (absolute value or just a hostname). The name of the bean in the application context is the fully qualified name of the interface. To specify your own alias value you can use the qualifiers value of the @FeignClient annotation.spring-doc.cn
The load-balancer client above will want to discover the physical addresses for the "stores" service. If your application is a Eureka client then it will resolve the service in the Eureka service registry. If you don’t want to use Eureka, you can configure a list of servers in your external configuration using SimpleDiscoveryClient.spring-doc.cn
Spring Cloud OpenFeign supports all the features available for the blocking mode of Spring Cloud LoadBalancer. You can read more about them in the project documentation.spring-doc.cn
To use @EnableFeignClients annotation on @Configuration-annotated-classes, make sure to specify where the clients are located, for example: @EnableFeignClients(basePackages = "com.example.clients") or list them explicitly: @EnableFeignClients(clients = InventoryServiceFeignClient.class).
In order to load Spring Feign client beans in a multi-module setup, you need to specify the packages directly.spring-doc.cn
Since FactoryBean objects may be instantiated before the initial context refresh should take place, and the instantiation of Spring Cloud OpenFeign Clients triggers a context refresh, they should not be declared within FactoryBean classes.
Attribute resolution mode
While creating Feign client beans, we resolve the values passed via the @FeignClient annotation. As of 4.x, the values are being resolved eagerly. This is a good solution for most use-cases, and it also allows for AOT support.spring-doc.cn
If you need the attributes to be resolved lazily, set the spring.cloud.openfeign.lazy-attributes-resolution property value to true.spring-doc.cn
For Spring Cloud Contract test integration, lazy attribute resolution should be used.
Overriding Feign Defaults
A central concept in Spring Cloud’s Feign support is that of the named client. Each Feign client is part of an ensemble of components that work together to contact a remote server on demand, and the ensemble has a name that you give it as an application developer using the @FeignClient annotation. Spring Cloud creates a new ensemble as an ApplicationContext on demand for each named client using FeignClientsConfiguration. This contains (amongst other things) an feign.Decoder, a feign.Encoder, and a feign.Contract. It is possible to override the name of that ensemble by using the contextId attribute of the @FeignClient annotation.spring-doc.cn
Spring Cloud lets you take full control of the Feign client by declaring additional configuration (on top of the FeignClientsConfiguration) using @FeignClient. Example:spring-doc.cn
@FeignClient(name = "stores", configuration = FooConfiguration.class)
In this case the client is composed from the components already in FeignClientsConfiguration together with any in FooConfiguration (where the latter will override the former).spring-doc.cn
FooConfiguration does not need to be annotated with @Configuration. However, if it is, then take care to exclude it from any @ComponentScan that would otherwise include this configuration as it will become the default source for feign.Decoder, feign.Encoder, feign.Contract, etc., when specified. This can be avoided by putting it in a separate, non-overlapping package from any @ComponentScan or @SpringBootApplication, or it can be explicitly excluded in @ComponentScan.
Using contextId attribute of the @FeignClient annotation in addition to changing the name of the ApplicationContext ensemble, it will override the alias of the client name and it will be used as part of the name of the configuration bean created for that client.
Previously, using the url attribute, did not require the name attribute. Using name is now required.
Placeholders are supported in the name and url attributes.spring-doc.cn
@FeignClient(name = "${feign.name}", url = "${feign.url}")
Spring Cloud OpenFeign provides the following beans by default for feign (BeanType beanName: ClassName):spring-doc.cn
  • Decoder feignDecoder: ResponseEntityDecoder (which wraps a SpringDecoder)spring-doc.cn
  • Encoder feignEncoder: SpringEncoderspring-doc.cn
  • Logger feignLogger: Slf4jLoggerspring-doc.cn
  • MicrometerObservationCapability micrometerObservationCapability: If feign-micrometer is on the classpath and ObservationRegistry is availablespring-doc.cn
  • MicrometerCapability micrometerCapability: If feign-micrometer is on the classpath, MeterRegistry is available and ObservationRegistry is not availablespring-doc.cn
  • CachingCapability cachingCapability: If @EnableCaching annotation is used. Can be disabled via spring.cloud.openfeign.cache.enabled.spring-doc.cn
  • Contract feignContract: SpringMvcContractspring-doc.cn
  • Feign.Builder feignBuilder: FeignCircuitBreaker.Builderspring-doc.cn
  • Client feignClient: If Spring Cloud LoadBalancer is on the classpath, FeignBlockingLoadBalancerClient is used. If none of them is on the classpath, the default Feign client is used.spring-doc.cn
spring-cloud-starter-openfeign supports spring-cloud-starter-loadbalancer. However, as is an optional dependency, you need to make sure it has been added to your project if you want to use it.
To use OkHttpClient-backed Feign clients and Http2Client Feign clients, make sure that the client you want to use is on the classpath and set spring.cloud.openfeign.okhttp.enabled or spring.cloud.openfeign.http2client.enabled to true respectively.spring-doc.cn
When it comes to the Apache HttpClient 5-backed Feign clients, it’s enough to ensure HttpClient 5 is on the classpath, but you can still disable its use for Feign Clients by setting spring.cloud.openfeign.httpclient.hc5.enabled to false. You can customize the HTTP client used by providing a bean of either org.apache.hc.client5.http.impl.classic.CloseableHttpClient when using Apache HC5.spring-doc.cn
You can further customise http clients by setting values in the spring.cloud.openfeign.httpclient.xxx properties. The ones prefixed just with httpclient will work for all the clients, the ones prefixed with httpclient.hc5 to Apache HttpClient 5, the ones prefixed with httpclient.okhttp to OkHttpClient and the ones prefixed with httpclient.http2 to Http2Client. You can find a full list of properties you can customise in the appendix. If you can not configure Apache HttpClient 5 by using properties, there is an HttpClient5FeignConfiguration.HttpClientBuilderCustomizer interface for programmatic configuration.spring-doc.cn
Apache HTTP Components 5.4 have changed defaults in the HttpClient relating to HTTP/1.1 TLS upgrades. Most proxy servers handle upgrades without issue, however, you may encounter issues with Envoy or Istio. If you need to restore previous behaviour, you can use HttpClient5FeignConfiguration.HttpClientBuilderCustomizer to do it, as shown in the example below.
public class FooConfiguration {
	public HttpClient5FeignConfiguration.HttpClientBuilderCustomizer httpClientBuilder() {
		return (httpClientBuilder) -> {
			RequestConfig.Builder requestConfigBuilder = RequestConfig.custom();
			requestConfigBuilder.setProtocolUpgradeEnabled(false);
			httpClientBuilder.setDefaultRequestConfig(requestConfigBuilder.build());
Starting with Spring Cloud OpenFeign 4, the Feign Apache HttpClient 4 is no longer supported. We suggest using Apache HttpClient 5 instead.
Spring Cloud OpenFeign does not provide the following beans by default for feign, but still looks up beans of these types from the application context to create the Feign client:spring-doc.cn
A bean of Retryer.NEVER_RETRY with the type Retryer is created by default, which will disable retrying. Notice this retrying behavior is different from the Feign default one, where it will automatically retry IOExceptions, treating them as transient network related exceptions, and any RetryableException thrown from an ErrorDecoder.spring-doc.cn
Creating a bean of one of those type and placing it in a @FeignClient configuration (such as FooConfiguration above) allows you to override each one of the beans described. Example:spring-doc.cn
	public Contract feignContract() {
		return new feign.Contract.Default();
	public BasicAuthRequestInterceptor basicAuthRequestInterceptor() {
		return new BasicAuthRequestInterceptor("user", "password");
This replaces the SpringMvcContract with feign.Contract.Default and adds a RequestInterceptor to the collection of RequestInterceptor.spring-doc.cn
@FeignClient also can be configured using configuration properties.spring-doc.cn
application.ymlspring-doc.cn
spring:
	cloud:
		openfeign:
			client:
				config:
					feignName:
                        url: http://remote-service.com
						connectTimeout: 5000
						readTimeout: 5000
						loggerLevel: full
						errorDecoder: com.example.SimpleErrorDecoder
						retryer: com.example.SimpleRetryer
						defaultQueryParameters:
							query: queryValue
						defaultRequestHeaders:
							header: headerValue
						requestInterceptors:
							- com.example.FooRequestInterceptor
							- com.example.BarRequestInterceptor
						responseInterceptor: com.example.BazResponseInterceptor
						dismiss404: false
						encoder: com.example.SimpleEncoder
						decoder: com.example.SimpleDecoder
						contract: com.example.SimpleContract
						capabilities:
							- com.example.FooCapability
							- com.example.BarCapability
						queryMapEncoder: com.example.SimpleQueryMapEncoder
						micrometer.enabled: false
feignName in this example refers to @FeignClient value, that is also aliased with @FeignClient name and @FeignClient contextId. In a load-balanced scenario, it also corresponds to the serviceId of the server app that will be used to retrieve the instances. The specified classes for decoders, retryer and other ones must have a bean in the Spring context or have a default constructor.spring-doc.cn
Default configurations can be specified in the @EnableFeignClients attribute defaultConfiguration in a similar manner as described above. The difference is that this configuration will apply to all Feign clients.spring-doc.cn
If you prefer using configuration properties to configure all @FeignClient, you can create configuration properties with default feign name.spring-doc.cn
You can use spring.cloud.openfeign.client.config.feignName.defaultQueryParameters and spring.cloud.openfeign.client.config.feignName.defaultRequestHeaders to specify query parameters and headers that will be sent with every request of the client named feignName.spring-doc.cn
spring:
	cloud:
		openfeign:
			client:
				config:
					default:
						readTimeout: 5000
						loggerLevel: basic
If we create both @Configuration bean and configuration properties, configuration properties will win. It will override @Configuration values. But if you want to change the priority to @Configuration, you can change spring.cloud.openfeign.client.default-to-properties to false.spring-doc.cn
If we want to create multiple Feign clients with the same name or url so that they would point to the same server but each with a different custom configuration then we have to use contextId attribute of the @FeignClient in order to avoid name collision of these configuration beans.spring-doc.cn
@FeignClient(contextId = "fooClient", name = "stores", configuration = FooConfiguration.class)
public interface FooClient {
@FeignClient(contextId = "barClient", name = "stores", configuration = BarConfiguration.class)
public interface BarClient {
It is also possible to configure FeignClient not to inherit beans from the parent context. You can do this by overriding the inheritParentConfiguration() in a FeignClientConfigurer bean to return false:spring-doc.cn
public class CustomConfiguration {
	public FeignClientConfigurer feignClientConfigurer() {
		return new FeignClientConfigurer() {
			public boolean inheritParentConfiguration() {
				 return false;
By default, Feign clients do not encode slash / characters. You can change this behaviour, by setting the value of spring.cloud.openfeign.client.decode-slash to false.
By default, Feign clients do not remove trailing slash / characters from the request path. You can change this behaviour, by setting the value of spring.cloud.openfeign.client.remove-trailing-slash to true. Trailing slash removal from the request path is going to be made the default behaviour in the next major release.
SpringEncoder configuration
In the SpringEncoder that we provide, we set null charset for binary content types and UTF-8 for all the other ones.spring-doc.cn
You can modify this behaviour to derive the charset from the Content-Type header charset instead by setting the value of spring.cloud.openfeign.encoder.charset-from-content-type to true.spring-doc.cn
Timeout Handling
We can configure timeouts on both the default and the named client. OpenFeign works with two timeout parameters:spring-doc.cn
  • connectTimeout prevents blocking the caller due to the long server processing time.spring-doc.cn
  • readTimeout is applied from the time of connection establishment and is triggered when returning the response takes too long.spring-doc.cn
In case the server is not running or available a packet results in connection refused. The communication ends either with an error message or in a fallback. This can happen before the connectTimeout if it is set very low. The time taken to perform a lookup and to receive such a packet causes a significant part of this delay. It is subject to change based on the remote host that involves a DNS lookup.
Creating Feign Clients Manually
In some cases it might be necessary to customize your Feign Clients in a way that is not possible using the methods above. In this case you can create Clients using the Feign Builder API. Below is an example which creates two Feign Clients with the same interface but configures each one with a separate request interceptor.spring-doc.cn
@Import(FeignClientsConfiguration.class)
class FooController {
	private FooClient fooClient;
	private FooClient adminClient;
	@Autowired
	public FooController(Client client, Encoder encoder, Decoder decoder, Contract contract, MicrometerObservationCapability micrometerObservationCapability) {
		this.fooClient = Feign.builder().client(client)
				.encoder(encoder)
				.decoder(decoder)
				.contract(contract)
				.addCapability(micrometerObservationCapability)
				.requestInterceptor(new BasicAuthRequestInterceptor("user", "user"))
				.target(FooClient.class, "https://PROD-SVC");
		this.adminClient = Feign.builder().client(client)
				.encoder(encoder)
				.decoder(decoder)
				.contract(contract)
				.requestInterceptor(new BasicAuthRequestInterceptor("admin", "admin"))
In the above example FeignClientsConfiguration.class is the default configuration provided by Spring Cloud OpenFeign.
PROD-SVC is the name of the service the Clients will be making requests to.
The Feign Contract object defines what annotations and values are valid on interfaces. The autowired Contract bean provides supports for SpringMVC annotations, instead of the default Feign native annotations. It is not recommended to mix the Spring MVC annotations and the native Feign annotations together.
You can also use the Builder`to configure FeignClient not to inherit beans from the parent context. You can do this by overriding calling `inheritParentContext(false) on the Builder.spring-doc.cn
Feign Spring Cloud CircuitBreaker Support
If Spring Cloud CircuitBreaker is on the classpath and spring.cloud.openfeign.circuitbreaker.enabled=true, Feign will wrap all methods with a circuit breaker.spring-doc.cn
To disable Spring Cloud CircuitBreaker support on a per-client basis create a vanilla Feign.Builder with the "prototype" scope, e.g.:spring-doc.cn
	@Scope("prototype")
	public Feign.Builder feignBuilder() {
		return Feign.builder();
The circuit breaker name follows this pattern <feignClientClassName>#<calledMethod>(<parameterTypes>). When calling a @FeignClient with FooClient interface and the called interface method that has no parameters is bar then the circuit breaker name will be FooClient#bar().spring-doc.cn
As of 2020.0.2, the circuit breaker name pattern has changed from <feignClientName>_<calledMethod>. Using CircuitBreakerNameResolver introduced in 2020.0.4, circuit breaker names can retain the old pattern.
Providing a bean of CircuitBreakerNameResolver, you can change the circuit breaker name pattern.spring-doc.cn
	public CircuitBreakerNameResolver circuitBreakerNameResolver() {
		return (String feignClientName, Target<?> target, Method method) -> feignClientName + "_" + method.getName();
To enable Spring Cloud CircuitBreaker group set the spring.cloud.openfeign.circuitbreaker.group.enabled property to true (by default false).spring-doc.cn
Configuring CircuitBreakers With Configuration Properties
You can configure CircuitBreakers via configuration properties.spring-doc.cn
For example, if you had this Feign clientspring-doc.cn
@FeignClient(url = "http://localhost:8080")
public interface DemoClient {
    @GetMapping("demo")
    String getDemo();
You could configure it using configuration properties by doing the followingspring-doc.cn
spring:
  cloud:
    openfeign:
      circuitbreaker:
        enabled: true
        alphanumeric-ids:
          enabled: true
resilience4j:
  circuitbreaker:
    instances:
      DemoClientgetDemo:
        minimumNumberOfCalls: 69
  timelimiter:
    instances:
      DemoClientgetDemo:
        timeoutDuration: 10s
If you want to switch back to the circuit breaker names used prior to Spring Cloud 2022.0.0 you can set spring.cloud.openfeign.circuitbreaker.alphanumeric-ids.enabled to false.
Feign Spring Cloud CircuitBreaker Fallbacks
Spring Cloud CircuitBreaker supports the notion of a fallback: a default code path that is executed when the circuit is open or there is an error. To enable fallbacks for a given @FeignClient set the fallback attribute to the class name that implements the fallback. You also need to declare your implementation as a Spring bean.spring-doc.cn
@FeignClient(name = "test", url = "http://localhost:${server.port}/", fallback = Fallback.class)
protected interface TestClient {
	@GetMapping("/hello")
	Hello getHello();
	@GetMapping("/hellonotfound")
	String getException();
@Component
static class Fallback implements TestClient {
	public Hello getHello() {
		throw new NoFallbackAvailableException("Boom!", new RuntimeException());
	public String getException() {
		return "Fixed response";
If one needs access to the cause that made the fallback trigger, one can use the fallbackFactory attribute inside @FeignClient.spring-doc.cn
@FeignClient(name = "testClientWithFactory", url = "http://localhost:${server.port}/",
			fallbackFactory = TestFallbackFactory.class)
protected interface TestClientWithFactory {
	Hello getHello();
@Component
static class TestFallbackFactory implements FallbackFactory<FallbackWithFactory> {
	public FallbackWithFactory create(Throwable cause) {
		return new FallbackWithFactory();
static class FallbackWithFactory implements TestClientWithFactory {
Feign and @Primary
When using Feign with Spring Cloud CircuitBreaker fallbacks, there are multiple beans in the ApplicationContext of the same type. This will cause @Autowired to not work because there isn’t exactly one bean, or one marked as primary. To work around this, Spring Cloud OpenFeign marks all Feign instances as @Primary, so Spring Framework will know which bean to inject. In some cases, this may not be desirable. To turn off this behavior set the primary attribute of @FeignClient to false.spring-doc.cn
@FeignClient(name = "hello", primary = false)
public interface HelloClient {
	// methods here
Feign Inheritance Support
Feign supports boilerplate apis via single-inheritance interfaces. This allows grouping common operations into convenient base interfaces.spring-doc.cn
UserService.java
public interface UserService {
	@GetMapping("/users/{id}")
	User getUser(@PathVariable("id") long id);
UserResource.java
@RestController
public class UserResource implements UserService {
UserClient.java
@FeignClient("users")
public interface UserClient extends UserService {
@FeignClient interfaces should not be shared between server and client and annotating @FeignClient interfaces with @RequestMapping on class level is no longer supported.
Feign request/response compression
You may consider enabling the request or response GZIP compression for your Feign requests. You can do this by enabling one of the properties:spring-doc.cn
spring.cloud.openfeign.compression.request.enabled=true
spring.cloud.openfeign.compression.response.enabled=true
Feign request compression gives you settings similar to what you may set for your web server:spring-doc.cn
spring.cloud.openfeign.compression.request.mime-types=text/xml,application/xml,application/json
spring.cloud.openfeign.compression.request.min-request-size=2048
These properties allow you to be selective about the compressed media types and minimum request threshold length.spring-doc.cn
When the request matches the mime type set in spring.cloud.openfeign.compression.request.mime-types and the size set in spring.cloud.openfeign.compression.request.min-request-size, spring.cloud.openfeign.compression.request.enabled=true results in compression headers being added to the request. The functionality of the headers is to signal to the server that a compressed body is expected by the client. It is the responsibility of the server-side app to provide the compressed body based on the headers provided by the client.spring-doc.cn
Since the OkHttpClient uses "transparent" compression, that is disabled if the content-encoding or accept-encoding header is present, we do not enable compression when feign.okhttp.OkHttpClient is present on the classpath and spring.cloud.openfeign.okhttp.enabled is set to true.
Feign logging
A logger is created for each Feign client created. By default, the name of the logger is the full class name of the interface used to create the Feign client. Feign logging only responds to the DEBUG level.spring-doc.cn
application.yml
logging.level.project.user.UserClient: DEBUG
The Logger.Level object that you may configure per client, tells Feign how much to log. Choices are:spring-doc.cn
  • NONE, No logging (DEFAULT).spring-doc.cn
  • BASIC, Log only the request method and URL and the response status code and execution time.spring-doc.cn
  • HEADERS, Log the basic information along with request and response headers.spring-doc.cn
  • FULL, Log the headers, body, and metadata for both requests and responses.spring-doc.cn
For example, the following would set the Logger.Level to FULL:spring-doc.cn
	Logger.Level feignLoggerLevel() {
		return Logger.Level.FULL;
Feign Capability support
The Feign capabilities expose core Feign components so that these components can be modified. For example, the capabilities can take the Client, decorate it, and give the decorated instance back to Feign. The support for Micrometer is a good real-life example for this. See Micrometer Support.spring-doc.cn
Creating one or more Capability beans and placing them in a @FeignClient configuration lets you register them and modify the behavior of the involved client.spring-doc.cn
	Capability customCapability() {
		return new CustomCapability();
Micrometer Support
If all of the following conditions are true, a MicrometerObservationCapability bean is created and registered so that your Feign client is observable by Micrometer:spring-doc.cn
  • feign-micrometer is on the classpathspring-doc.cn
  • A ObservationRegistry bean is availablespring-doc.cn
  • feign micrometer properties are set to true (by default)spring-doc.cn
    • spring.cloud.openfeign.micrometer.enabled=true (for all clients)spring-doc.cn
    • spring.cloud.openfeign.client.config.feignName.micrometer.enabled=true (for a single client)spring-doc.cn
If your application already uses Micrometer, enabling this feature is as simple as putting feign-micrometer onto your classpath.
You can also disable the feature by either:spring-doc.cn
  • excluding feign-micrometer from your classpathspring-doc.cn
  • setting one of the feign micrometer properties to falsespring-doc.cn
    • spring.cloud.openfeign.micrometer.enabled=falsespring-doc.cn
    • spring.cloud.openfeign.client.config.feignName.micrometer.enabled=falsespring-doc.cn
spring.cloud.openfeign.micrometer.enabled=false disables Micrometer support for all Feign clients regardless of the value of the client-level flags: spring.cloud.openfeign.client.config.feignName.micrometer.enabled. If you want to enable or disable Micrometer support per client, don’t set spring.cloud.openfeign.micrometer.enabled and use spring.cloud.openfeign.client.config.feignName.micrometer.enabled.
You can also customize the MicrometerObservationCapability by registering your own bean:spring-doc.cn
	public MicrometerObservationCapability micrometerObservationCapability(ObservationRegistry registry) {
		return new MicrometerObservationCapability(registry);
It is still possible to use MicrometerCapability with Feign (metrics-only support), you need to disable Micrometer support (spring.cloud.openfeign.micrometer.enabled=false) and create a MicrometerCapability bean:spring-doc.cn
	public MicrometerCapability micrometerCapability(MeterRegistry meterRegistry) {
		return new MicrometerCapability(meterRegistry);
Feign Caching
If @EnableCaching annotation is used, a CachingCapability bean is created and registered so that your Feign client recognizes @Cache* annotations on its interface:spring-doc.cn
	@GetMapping("/demo/{filterParam}")
    @Cacheable(cacheNames = "demo-cache", key = "#keyParam")
	String demoEndpoint(String keyParam, @PathVariable String filterParam);
You can also disable the feature via property spring.cloud.openfeign.cache.enabled=false.spring-doc.cn
Spring @RequestMapping Support
Spring Cloud OpenFeign provides support for the Spring @RequestMapping annotation and its derived annotations (such as @GetMapping, @PostMapping, and others) support. The attributes on the @RequestMapping annotation (including value, method, params, headers, consumes, and produces) are parsed by SpringMvcContract as the content of the request.spring-doc.cn
Consider the following example:spring-doc.cn
Define an interface using the params attribute.spring-doc.cn
@FeignClient("demo")
public interface DemoTemplate {
        @PostMapping(value = "/stores/{storeId}", params = "mode=upsert")
In the above example, the request url is resolved to /stores/storeId?mode=upsert.
The params attribute also supports the use of multiple key=value or only one key:
spring-doc.cn
  • When params = { "key1=v1", "key2=v2" }, the request url is parsed as /stores/storeId?key1=v1&key2=v2.spring-doc.cn
  • When params = "key", the request url is parsed as /stores/storeId?key.spring-doc.cn
Feign @QueryMap support
Spring Cloud OpenFeign provides an equivalent @SpringQueryMap annotation, which is used to annotate a POJO or Map parameter as a query parameter map.spring-doc.cn
For example, the Params class defines parameters param1 and param2:spring-doc.cn
// Params.java
public class Params {
	private String param1;
	private String param2;
	// [Getters and setters omitted for brevity]
The following Feign client uses the Params class by using the @SpringQueryMap annotation:spring-doc.cn
	@GetMapping(path = "/demo")
	String demoEndpoint(@SpringQueryMap Params params);
If you need more control over the generated query parameter map, you can implement a custom QueryMapEncoder bean.spring-doc.cn
HATEOAS support
Spring provides some APIs to create REST representations that follow the HATEOAS principle, Spring Hateoas and Spring Data REST.spring-doc.cn
If your project use the org.springframework.boot:spring-boot-starter-hateoas starter or the org.springframework.boot:spring-boot-starter-data-rest starter, Feign HATEOAS support is enabled by default.spring-doc.cn
When HATEOAS support is enabled, Feign clients are allowed to serialize and deserialize HATEOAS representation models: EntityModel, CollectionModel and PagedModel.spring-doc.cn
	@GetMapping(path = "/stores")
	CollectionModel<Store> getStores();
Spring @MatrixVariable Support
Spring Cloud OpenFeign provides support for the Spring @MatrixVariable annotation.spring-doc.cn
If a map is passed as the method argument, the @MatrixVariable path segment is created by joining key-value pairs from the map with a =.spring-doc.cn
If a different object is passed, either the name provided in the @MatrixVariable annotation (if defined) or the annotated variable name is joined with the provided method argument using =.spring-doc.cn
IMPORTANT
Even though, on the server side, Spring does not require the users to name the path segment placeholder same as the matrix variable name, since it would be too ambiguous on the client side, Spring Cloud OpenFeign requires that you add a path segment placeholder with a name matching either the name provided in the @MatrixVariable annotation (if defined) or the annotated variable name.spring-doc.cn
For example:spring-doc.cn
@GetMapping("/objects/links/{matrixVars}")
Map<String, List<String>> getObjects(@MatrixVariable Map<String, List<String>> matrixVars);
Note that both variable name and the path segment placeholder are called matrixVars.spring-doc.cn
Feign CollectionFormat support
We support feign.CollectionFormat by providing the @CollectionFormat annotation. You can annotate a Feign client method (or the whole class to affect all methods) with it by passing the desired feign.CollectionFormat as annotation value.spring-doc.cn
In the following example, the CSV format is used instead of the default EXPLODED to process the method.spring-doc.cn
@FeignClient(name = "demo")
protected interface DemoFeignClient {
    @CollectionFormat(feign.CollectionFormat.CSV)
    @GetMapping(path = "/test")
    ResponseEntity performRequest(String test);
Reactive Support
As at the time of active development of Spring Cloud OpenFeign, the OpenFeign project did not support reactive clients, such as Spring WebClient, such support could not be added to Spring Cloud OpenFeign either.spring-doc.cn
Since Spring Cloud OpenFeign project is now considered feature-complete, we’re not planning on adding support even if it becomes available in the upstream project. We suggest migrating over to Spring Interface Clients instead. Both blocking and reactive stacks are supported there.spring-doc.cn
Early Initialization Errors
We discourage using Feign clients in the early stages of application lifecycle, while processing configurations and initialising beans. Using the clients during bean initialisation is not supported.spring-doc.cn
Similarly, depending on how you are using your Feign clients, you may see initialization errors when starting your application. To work around this problem you can use an ObjectProvider when autowiring your client.spring-doc.cn
@Autowired
ObjectProvider<TestFeignClient> testFeignClient;
Spring Data Support
If Jackson Databind and Spring Data Commons are on the classpath, converters for org.springframework.data.domain.Page and org.springframework.data.domain.Sort will be added automatically.spring-doc.cn
To disable this behaviour setspring-doc.cn
spring.cloud.openfeign.autoconfiguration.jackson.enabled=false
See org.springframework.cloud.openfeign.FeignAutoConfiguration.FeignJacksonConfiguration for details.spring-doc.cn
Spring @RefreshScope Support
If Feign client refresh is enabled, each Feign client is created with:spring-doc.cn
  • feign.Request.Options as a refresh-scoped bean. This means properties such as connectTimeout and readTimeout can be refreshed against any Feign client instance.spring-doc.cn
  • A url wrapped under org.springframework.cloud.openfeign.RefreshableUrl. This means the URL of Feign client, if defined with spring.cloud.openfeign.client.config.{feignName}.url property, can be refreshed against any Feign client instance.spring-doc.cn
You can refresh these properties through POST /actuator/refresh.spring-doc.cn
By default, refresh behavior in Feign clients is disabled. Use the following property to enable refresh behavior:spring-doc.cn
spring.cloud.openfeign.client.refresh-enabled=true
DO NOT annotate the @FeignClient interface with the @RefreshScope annotation.
OAuth2 Support
OAuth2 support can be enabled by adding the spring-boot-starter-oauth2-client dependency to your project and setting following flag:spring-doc.cn
spring.cloud.openfeign.oauth2.enabled=true
When the flag is set to true, and the oauth2 client context resource details are present, a bean of class OAuth2AccessTokenInterceptor is created. Before each request, the interceptor resolves the required access token and includes it as a header. OAuth2AccessTokenInterceptor uses the OAuth2AuthorizedClientManager to get OAuth2AuthorizedClient that holds an OAuth2AccessToken. If the user has specified an OAuth2 clientRegistrationId using the spring.cloud.openfeign.oauth2.clientRegistrationId property, it will be used to retrieve the token. If the token is not retrieved or the clientRegistrationId has not been specified, the serviceId retrieved from the url host segment will be used.spring-doc.cn
TIP
Using the serviceId as OAuth2 client registrationId is convenient for load-balanced Feign clients. For non-load-balanced ones, the property-based clientRegistrationId is a suitable approach.spring-doc.cn
TIP
If you do not want to use the default setup for the OAuth2AuthorizedClientManager, you can just instantiate a bean of this type in your configuration.spring-doc.cn
Transform the load-balanced HTTP request
You can use the selected ServiceInstance to transform the load-balanced HTTP Request.spring-doc.cn
For Request, you need to implement and define LoadBalancerFeignRequestTransformer, as follows:spring-doc.cn
public LoadBalancerFeignRequestTransformer transformer() {
	return new LoadBalancerFeignRequestTransformer() {
		public Request transformRequest(Request request, ServiceInstance instance) {
			Map<String, Collection<String>> headers = new HashMap<>(request.headers());
			headers.put("X-ServiceId", Collections.singletonList(instance.getServiceId()));
			headers.put("X-InstanceId", Collections.singletonList(instance.getInstanceId()));
			return Request.create(request.httpMethod(), request.url(), headers, request.body(), request.charset(),
					request.requestTemplate());
If multiple transformers are defined, they are applied in the order in which beans are defined. Alternatively, you can use LoadBalancerFeignRequestTransformer.DEFAULT_ORDER to specify the order.spring-doc.cn
X-Forwarded Headers Support
X-Forwarded-Host and X-Forwarded-Proto support can be enabled by setting following flag:spring-doc.cn
spring.cloud.loadbalancer.x-forwarded.enabled=true
Supported Ways To Provide URL To A Feign Client
You can provide a URL to a Feign client in any of the following ways:spring-doc.cn
Case Example Details
The URL is provided in the @FeignClient annotation.spring-doc.cn
@FeignClient(name="testClient", url="http://localhost:8081")spring-doc.cn
The URL is resolved from the url attribute of the annotation, without load-balancing.spring-doc.cn
The URL is provided in the @FeignClient annotation and in the configuration properties.spring-doc.cn
@FeignClient(name="testClient", url="http://localhost:8081") and the property defined in application.yml as spring.cloud.openfeign.client.config.testClient.url=http://localhost:8081spring-doc.cn
The URL is resolved from the url attribute of the annotation, without load-balancing. The URL provided in the configuration properties remains unused.spring-doc.cn
The URL is not provided in the @FeignClient annotation but is provided in configuration properties.spring-doc.cn
@FeignClient(name="testClient") and the property defined in application.yml as spring.cloud.openfeign.client.config.testClient.url=http://localhost:8081spring-doc.cn
The URL is resolved from configuration properties, without load-balancing. If spring.cloud.openfeign.client.refresh-enabled=true, then the URL defined in configuration properties can be refreshed as described in Spring RefreshScope Support.spring-doc.cn
The URL is neither provided in the @FeignClient annotation nor in configuration properties.spring-doc.cn
@FeignClient(name="testClient")spring-doc.cn
The URL is resolved from name attribute of annotation, with load balancing.spring-doc.cn
AOT and Native Image Support
Spring Cloud OpenFeign supports Spring AOT transformations and native images, however, only with refresh mode disabled, Feign clients refresh disabled (default setting) and lazy @FeignClient attribute resolution disabled (default setting).spring-doc.cn
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, make sure to set spring.cloud.refresh.enabled to false.
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, ensure spring.cloud.openfeign.client.refresh-enabled has not been set to true.
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, ensure spring.cloud.openfeign.lazy-attributes-resolution has not been set to true.
However, if you set the url value via properties, it is possible to override the @FeignClient url value by running the image with -Dspring.cloud.openfeign.client.config.[clientId].url=[url] flag. In order to enable overriding, a url value also has to be set via properties and not @FeignClient attribute during buildtime.
Configuration properties
To see the list of all Spring Cloud OpenFeign related configuration properties please check the Appendix page.spring-doc.cn
