This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud OpenFeign 4.2.1! |
Spring Cloud OpenFeign Features
Declarative REST Client: Feign
Feign is a declarative web service client.
It makes writing web service clients easier.
To use Feign create an interface and annotate it.
It has pluggable annotation support including Feign annotations and JAX-RS annotations.
Feign also supports pluggable encoders and decoders.
Spring Cloud adds support for Spring MVC annotations and for using the same HttpMessageConverters
used by default in Spring Web.
Spring Cloud integrates Eureka, Spring Cloud CircuitBreaker, as well as Spring Cloud LoadBalancer to provide a load-balanced http client when using Feign.
How to Include Feign
To include Feign in your project use the starter with group org.springframework.cloud
and artifact id spring-cloud-starter-openfeign
. See the Spring Cloud Project page
for details on setting up your build system with the current Spring Cloud Release Train.
Example spring boot app
@SpringBootApplication
@EnableFeignClients
public class Application {
SpringApplication.run(Application.class, args);
@FeignClient("stores")
public interface StoreClient {
@RequestMapping(method = RequestMethod.GET, value = "/stores")
List<Store> getStores();
@GetMapping("/stores")
Page<Store> getStores(Pageable pageable);
@PostMapping(value = "/stores/{storeId}", consumes = "application/json",
params = "mode=upsert")
Store update(@PathVariable("storeId") Long storeId, Store store);
@DeleteMapping("/stores/{storeId:\\d+}")
void delete(@PathVariable Long storeId);
In the @FeignClient
annotation the String value ("stores" above) is an arbitrary client name, which is used to create a Spring Cloud LoadBalancer client.
You can also specify a URL using the url
attribute
(absolute value or just a hostname). The name of the bean in the
application context is the fully qualified name of the interface.
To specify your own alias value you can use the qualifiers
value
of the @FeignClient
annotation.
The load-balancer client above will want to discover the physical addresses
for the "stores" service. If your application is a Eureka client then
it will resolve the service in the Eureka service registry. If you
don’t want to use Eureka, you can configure a list of servers
in your external configuration using SimpleDiscoveryClient
Spring Cloud OpenFeign supports all the features available for the blocking mode of Spring Cloud LoadBalancer. You can read more about them in the project documentation.
To use @EnableFeignClients annotation on @Configuration -annotated-classes, make sure to specify where the clients are located, for example:
@EnableFeignClients(basePackages = "com.example.clients")
or list them explicitly:
@EnableFeignClients(clients = InventoryServiceFeignClient.class) .
In order to load Spring Feign client beans in a multi-module setup, you need to specify the packages directly.
Since FactoryBean objects may be instantiated before the initial context refresh should take place, and the instantiation of Spring Cloud OpenFeign Clients triggers a context refresh, they should not be declared within FactoryBean classes.
Attribute resolution mode
While creating Feign
client beans, we resolve the values passed via the @FeignClient
annotation. As of 4.x
, the values are being resolved eagerly. This is a good solution for most use-cases, and it also allows for AOT support.
If you need the attributes to be resolved lazily, set the spring.cloud.openfeign.lazy-attributes-resolution
property value to true
For Spring Cloud Contract test integration, lazy attribute resolution should be used. |
Overriding Feign Defaults
A central concept in Spring Cloud’s Feign support is that of the named client. Each Feign client is part of an ensemble of components that work together to contact a remote server on demand, and the ensemble has a name that you give it as an application developer using the @FeignClient
annotation. Spring Cloud creates a new ensemble as an
ApplicationContext
on demand for each named client using FeignClientsConfiguration
. This contains (amongst other things) an feign.Decoder
, a feign.Encoder
, and a feign.Contract
It is possible to override the name of that ensemble by using the contextId
attribute of the @FeignClient
annotation.
Spring Cloud lets you take full control of the Feign client by declaring additional configuration (on top of the FeignClientsConfiguration
) using @FeignClient
. Example:
@FeignClient(name = "stores", configuration = FooConfiguration.class)
In this case the client is composed from the components already in FeignClientsConfiguration
together with any in FooConfiguration
(where the latter will override the former).
FooConfiguration does not need to be annotated with @Configuration . However, if it is, then take care to exclude it from any @ComponentScan that would otherwise include this configuration as it will become the default source for feign.Decoder , feign.Encoder , feign.Contract , etc., when specified. This can be avoided by putting it in a separate, non-overlapping package from any @ComponentScan or @SpringBootApplication , or it can be explicitly excluded in @ComponentScan .
Using contextId attribute of the @FeignClient annotation in addition to changing the name of
the ApplicationContext ensemble, it will override the alias of the client name
and it will be used as part of the name of the configuration bean created for that client.
Previously, using the url attribute, did not require the name attribute. Using name is now required.
Placeholders are supported in the name
and url
attributes.
@FeignClient(name = "${feign.name}", url = "${feign.url}")
Spring Cloud OpenFeign provides the following beans by default for feign (BeanType
beanName: ClassName
Decoder
feignDecoder:ResponseEntityDecoder
(which wraps aSpringDecoder
Encoder
feignEncoder:SpringEncoder
Logger
feignLogger:Slf4jLogger
MicrometerObservationCapability
micrometerObservationCapability: Iffeign-micrometer
is on the classpath andObservationRegistry
is available -
MicrometerCapability
micrometerCapability: Iffeign-micrometer
is on the classpath,MeterRegistry
is available andObservationRegistry
is not available -
CachingCapability
cachingCapability: If@EnableCaching
annotation is used. Can be disabled viaspring.cloud.openfeign.cache.enabled
Contract
feignContract:SpringMvcContract
Feign.Builder
feignBuilder:FeignCircuitBreaker.Builder
Client
feignClient: If Spring Cloud LoadBalancer is on the classpath,FeignBlockingLoadBalancerClient
is used. If none of them is on the classpath, the default Feign client is used.
spring-cloud-starter-openfeign supports spring-cloud-starter-loadbalancer . However, as is an optional dependency, you need to make sure it has been added to your project if you want to use it.
To use OkHttpClient-backed Feign clients and Http2Client Feign clients, make sure that the client you want to use is on the classpath and set spring.cloud.openfeign.okhttp.enabled
or spring.cloud.openfeign.http2client.enabled
to true
respectively.
When it comes to the Apache HttpClient 5-backed Feign clients, it’s enough to ensure HttpClient 5 is on the classpath, but you can still disable its use for Feign Clients by setting spring.cloud.openfeign.httpclient.hc5.enabled
to false
You can customize the HTTP client used by providing a bean of either org.apache.hc.client5.http.impl.classic.CloseableHttpClient
when using Apache HC5.
You can further customise http clients by setting values in the spring.cloud.openfeign.httpclient.xxx
properties. The ones prefixed just with httpclient
will work for all the clients, the ones prefixed with httpclient.hc5
to Apache HttpClient 5, the ones prefixed with httpclient.okhttp
to OkHttpClient and the ones prefixed with httpclient.http2
to Http2Client. You can find a full list of properties you can customise in the appendix.
If you can not configure Apache HttpClient 5 by using properties, there is an HttpClientBuilderCustomizer
interface for programmatic configuration.
Starting with Spring Cloud OpenFeign 4, the Feign Apache HttpClient 4 is no longer supported. We suggest using Apache HttpClient 5 instead. |
Spring Cloud OpenFeign does not provide the following beans by default for feign, but still looks up beans of these types from the application context to create the Feign client:
Logger.Level
Retryer
ErrorDecoder
Request.Options
Collection<RequestInterceptor>
SetterFactory
QueryMapEncoder
Capability
(MicrometerObservationCapability
andCachingCapability
are provided by default)
A bean of Retryer.NEVER_RETRY
with the type Retryer
is created by default, which will disable retrying.
Notice this retrying behavior is different from the Feign default one, where it will automatically retry IOExceptions,
treating them as transient network related exceptions, and any RetryableException thrown from an ErrorDecoder.
Creating a bean of one of those type and placing it in a @FeignClient
configuration (such as FooConfiguration
above) allows you to override each one of the beans described. Example:
public class FooConfiguration {
public Contract feignContract() {
return new feign.Contract.Default();
public BasicAuthRequestInterceptor basicAuthRequestInterceptor() {
return new BasicAuthRequestInterceptor("user", "password");
This replaces the SpringMvcContract
with feign.Contract.Default
and adds a RequestInterceptor
to the collection of RequestInterceptor
@FeignClient
also can be configured using configuration properties.
application.yml
spring:
cloud:
openfeign:
client:
config:
feignName:
url: http://remote-service.com
connectTimeout: 5000
readTimeout: 5000
loggerLevel: full
errorDecoder: com.example.SimpleErrorDecoder
retryer: com.example.SimpleRetryer
defaultQueryParameters:
query: queryValue
defaultRequestHeaders:
header: headerValue
requestInterceptors:
- com.example.FooRequestInterceptor
- com.example.BarRequestInterceptor
responseInterceptor: com.example.BazResponseInterceptor
dismiss404: false
encoder: com.example.SimpleEncoder
decoder: com.example.SimpleDecoder
contract: com.example.SimpleContract
capabilities:
- com.example.FooCapability
- com.example.BarCapability
queryMapEncoder: com.example.SimpleQueryMapEncoder
micrometer.enabled: false
feignName
in this example refers to @FeignClient
value
, that is also aliased with @FeignClient
name
and @FeignClient
contextId
. In a load-balanced scenario, it also corresponds to the serviceId
of the server app that will be used to retrieve the instances. The specified classes for decoders, retryer and other ones must have a bean in the Spring context or have a default constructor.
Default configurations can be specified in the @EnableFeignClients
attribute defaultConfiguration
in a similar manner as described above. The difference is that this configuration will apply to all Feign clients.
If you prefer using configuration properties to configure all @FeignClient
, you can create configuration properties with default
feign name.
You can use spring.cloud.openfeign.client.config.feignName.defaultQueryParameters
and spring.cloud.openfeign.client.config.feignName.defaultRequestHeaders
to specify query parameters and headers that will be sent with every request of the client named feignName
application.yml
spring:
cloud:
openfeign:
client:
config:
default:
readTimeout: 5000
loggerLevel: basic
If we create both @Configuration
bean and configuration properties, configuration properties will win.
It will override @Configuration
values. But if you want to change the priority to @Configuration
you can change spring.cloud.openfeign.client.default-to-properties
to false
If we want to create multiple Feign clients with the same name or url
so that they would point to the same server but each with a different custom configuration then
we have to use contextId
in order to avoid name
collision of these configuration beans.
@FeignClient(contextId = "fooClient", name = "stores", configuration = FooConfiguration.class)
public interface FooClient {
@FeignClient(contextId = "barClient", name = "stores", configuration = BarConfiguration.class)
public interface BarClient {
It is also possible to configure FeignClient not to inherit beans from the parent context.
You can do this by overriding the inheritParentConfiguration()
in a FeignClientConfigurer
bean to return false
public class CustomConfiguration {
public FeignClientConfigurer feignClientConfigurer() {
return new FeignClientConfigurer() {
public boolean inheritParentConfiguration() {
return false;
By default, Feign clients do not encode slash / characters. You can change this behaviour, by setting the value of spring.cloud.openfeign.client.decodeSlash to false .
SpringEncoder
configuration
In the SpringEncoder
that we provide, we set null
charset for binary content types and UTF-8
for all the other ones.
You can modify this behaviour to derive the charset from the Content-Type
header charset instead by setting the value of spring.cloud.openfeign.encoder.charset-from-content-type
to true
Timeout Handling
We can configure timeouts on both the default and the named client. OpenFeign works with two timeout parameters:
connectTimeout
prevents blocking the caller due to the long server processing time. -
readTimeout
is applied from the time of connection establishment and is triggered when returning the response takes too long.
In case the server is not running or available a packet results in connection refused. The communication ends either with an error message or in a fallback. This can happen before the connectTimeout if it is set very low. The time taken to perform a lookup and to receive such a packet causes a significant part of this delay. It is subject to change based on the remote host that involves a DNS lookup.
Creating Feign Clients Manually
In some cases it might be necessary to customize your Feign Clients in a way that is not possible using the methods above. In this case you can create Clients using the Feign Builder API. Below is an example which creates two Feign Clients with the same interface but configures each one with a separate request interceptor.
@Import(FeignClientsConfiguration.class)
class FooController {
private FooClient fooClient;
private FooClient adminClient;
@Autowired
public FooController(Client client, Encoder encoder, Decoder decoder, Contract contract, MicrometerObservationCapability micrometerObservationCapability) {
this.fooClient = Feign.builder().client(client)
.encoder(encoder)
.decoder(decoder)
.contract(contract)
.addCapability(micrometerObservationCapability)
.requestInterceptor(new BasicAuthRequestInterceptor("user", "user"))
.target(FooClient.class, "https://PROD-SVC");
this.adminClient = Feign.builder().client(client)
.encoder(encoder)
.decoder(decoder)
.contract(contract)
.requestInterceptor(new BasicAuthRequestInterceptor("admin", "admin"))
In the above example FeignClientsConfiguration.class is the default configuration
provided by Spring Cloud OpenFeign.
PROD-SVC is the name of the service the Clients will be making requests to.
The Feign Contract object defines what annotations and values are valid on interfaces. The
autowired Contract bean provides supports for SpringMVC annotations, instead of
the default Feign native annotations. It is not recommended to mix the Spring MVC annotations and the native Feign annotations together.
You can also use the Builder`to configure FeignClient not to inherit beans from the parent context.
You can do this by overriding calling `inheritParentContext(false)
on the Builder
Feign Spring Cloud CircuitBreaker Support
If Spring Cloud CircuitBreaker is on the classpath and spring.cloud.openfeign.circuitbreaker.enabled=true
, Feign will wrap all methods with a circuit breaker.
To disable Spring Cloud CircuitBreaker support on a per-client basis create a vanilla Feign.Builder
with the "prototype" scope, e.g.:
@Scope("prototype")
public Feign.Builder feignBuilder() {
return Feign.builder();
The circuit breaker name follows this pattern <feignClientClassName>#<calledMethod>(<parameterTypes>)
. When calling a @FeignClient
with FooClient
interface and the called interface method that has no parameters is bar
then the circuit breaker name will be FooClient#bar()
As of 2020.0.2, the circuit breaker name pattern has changed from <feignClientName>_<calledMethod> .
Using CircuitBreakerNameResolver introduced in 2020.0.4, circuit breaker names can retain the old pattern.
Providing a bean of CircuitBreakerNameResolver
, you can change the circuit breaker name pattern.
public CircuitBreakerNameResolver circuitBreakerNameResolver() {
return (String feignClientName, Target<?> target, Method method) -> feignClientName + "_" + method.getName();
To enable Spring Cloud CircuitBreaker group set the spring.cloud.openfeign.circuitbreaker.group.enabled
property to true
(by default false
Configuring CircuitBreakers With Configuration Properties
You can configure CircuitBreakers via configuration properties.
For example, if you had this Feign client
@FeignClient(url = "http://localhost:8080")
public interface DemoClient {
@GetMapping("demo")
String getDemo();
You could configure it using configuration properties by doing the following
spring:
cloud:
openfeign:
circuitbreaker:
enabled: true
alphanumeric-ids:
enabled: true
resilience4j:
circuitbreaker:
instances:
DemoClientgetDemo:
minimumNumberOfCalls: 69
timelimiter:
instances:
DemoClientgetDemo:
timeoutDuration: 10s
If you want to switch back to the circuit breaker names used prior to Spring Cloud
2022.0.0 you can set spring.cloud.openfeign.circuitbreaker.alphanumeric-ids.enabled to false .
Feign Spring Cloud CircuitBreaker Fallbacks
Spring Cloud CircuitBreaker supports the notion of a fallback: a default code path that is executed when the circuit is open or there is an error. To enable fallbacks for a given @FeignClient
set the fallback
attribute to the class name that implements the fallback. You also need to declare your implementation as a Spring bean.
@FeignClient(name = "test", url = "http://localhost:${server.port}/", fallback = Fallback.class)
protected interface TestClient {
@GetMapping("/hello")
Hello getHello();
@GetMapping("/hellonotfound")
String getException();
@Component
static class Fallback implements TestClient {
public Hello getHello() {
throw new NoFallbackAvailableException("Boom!", new RuntimeException());
public String getException() {
return "Fixed response";
If one needs access to the cause that made the fallback trigger, one can use the fallbackFactory
attribute inside @FeignClient
@FeignClient(name = "testClientWithFactory", url = "http://localhost:${server.port}/",
fallbackFactory = TestFallbackFactory.class)
protected interface TestClientWithFactory {
Hello getHello();
@Component
static class TestFallbackFactory implements FallbackFactory<FallbackWithFactory> {
public FallbackWithFactory create(Throwable cause) {
return new FallbackWithFactory();
static class FallbackWithFactory implements TestClientWithFactory {
Feign and @Primary
When using Feign with Spring Cloud CircuitBreaker fallbacks, there are multiple beans in the ApplicationContext
of the same type. This will cause @Autowired
to not work because there isn’t exactly one bean, or one marked as primary. To work around this, Spring Cloud OpenFeign marks all Feign instances as @Primary
, so Spring Framework will know which bean to inject. In some cases, this may not be desirable. To turn off this behavior set the primary
attribute of @FeignClient
to false.
@FeignClient(name = "hello", primary = false)
public interface HelloClient {
// methods here
Feign Inheritance Support
Feign supports boilerplate apis via single-inheritance interfaces. This allows grouping common operations into convenient base interfaces.
public interface UserService {
@GetMapping("/users/{id}")
User getUser(@PathVariable("id") long id);
@RestController
public class UserResource implements UserService {
@FeignClient("users")
public interface UserClient extends UserService {
@FeignClient interfaces should not be shared between server and client and annotating @FeignClient interfaces with @RequestMapping on class level is no longer supported.
Feign request/response compression
You may consider enabling the request or response GZIP compression for your Feign requests. You can do this by enabling one of the properties:
spring.cloud.openfeign.compression.request.enabled=true
spring.cloud.openfeign.compression.response.enabled=true
Feign request compression gives you settings similar to what you may set for your web server:
spring.cloud.openfeign.compression.request.mime-types=text/xml,application/xml,application/json
spring.cloud.openfeign.compression.request.min-request-size=2048
These properties allow you to be selective about the compressed media types and minimum request threshold length.
When the request matches the mime type set in spring.cloud.openfeign.compression.request.mime-types
and the size set in spring.cloud.openfeign.compression.request.min-request-size
, spring.cloud.openfeign.compression.request.enabled=true
results in compression headers being added to the request.
The functionality of the headers is to signal to the server that a compressed body is expected by the client. It is the responsibility of the server-side app to provide the compressed body based on the headers provided by the client.
Since the OkHttpClient uses "transparent" compression, that is disabled if the content-encoding or accept-encoding header is present, we do not enable compression when feign.okhttp.OkHttpClient is present on the classpath and spring.cloud.openfeign.okhttp.enabled is set to true .
Feign logging
A logger is created for each Feign client created. By default, the name of the logger is the full class name of the interface used to create the Feign client. Feign logging only responds to the DEBUG
level.
logging.level.project.user.UserClient: DEBUG
The Logger.Level
object that you may configure per client, tells Feign how much to log. Choices are:
NONE
, No logging (DEFAULT). -
BASIC
, Log only the request method and URL and the response status code and execution time. -
HEADERS
, Log the basic information along with request and response headers. -
FULL
, Log the headers, body, and metadata for both requests and responses.
For example, the following would set the Logger.Level
to FULL
Logger.Level feignLoggerLevel() {
return Logger.Level.FULL;
Feign Capability support
The Feign capabilities expose core Feign components so that these components can be modified. For example, the capabilities can take the Client
, decorate it, and give the decorated instance back to Feign.
The support for Micrometer is a good real-life example for this. See Micrometer Support.
Creating one or more Capability
beans and placing them in a @FeignClient
configuration lets you register them and modify the behavior of the involved client.
Capability customCapability() {
return new CustomCapability();
Micrometer Support
If all of the following conditions are true, a MicrometerObservationCapability
bean is created and registered so that your Feign client is observable by Micrometer:
feign-micrometer
is on the classpath -
A
ObservationRegistry
bean is available -
feign micrometer properties are set to
true
(by default)-
spring.cloud.openfeign.micrometer.enabled=true
(for all clients) -
spring.cloud.openfeign.client.config.feignName.micrometer.enabled=true
(for a single client)
If your application already uses Micrometer, enabling this feature is as simple as putting feign-micrometer onto your classpath.
You can also disable the feature by either:
excluding
feign-micrometer
from your classpath -
setting one of the feign micrometer properties to
false
spring.cloud.openfeign.micrometer.enabled=false
spring.cloud.openfeign.client.config.feignName.micrometer.enabled=false
spring.cloud.openfeign.micrometer.enabled=false disables Micrometer support for all Feign clients regardless of the value of the client-level flags: spring.cloud.openfeign.client.config.feignName.micrometer.enabled .
If you want to enable or disable Micrometer support per client, don’t set spring.cloud.openfeign.micrometer.enabled and use spring.cloud.openfeign.client.config.feignName.micrometer.enabled .
You can also customize the MicrometerObservationCapability
by registering your own bean:
public MicrometerObservationCapability micrometerObservationCapability(ObservationRegistry registry) {
return new MicrometerObservationCapability(registry);
It is still possible to use MicrometerCapability
with Feign (metrics-only support), you need to disable Micrometer support (spring.cloud.openfeign.micrometer.enabled=false
) and create a MicrometerCapability
bean:
public MicrometerCapability micrometerCapability(MeterRegistry meterRegistry) {
return new MicrometerCapability(meterRegistry);
Feign Caching
If @EnableCaching
annotation is used, a CachingCapability
bean is created and registered so that your Feign client recognizes @Cache*
annotations on its interface:
@GetMapping("/demo/{filterParam}")
@Cacheable(cacheNames = "demo-cache", key = "#keyParam")
String demoEndpoint(String keyParam, @PathVariable String filterParam);
You can also disable the feature via property spring.cloud.openfeign.cache.enabled=false
Spring @RequestMapping Support
Spring Cloud OpenFeign provides support for the Spring @RequestMapping
annotation and its derived annotations (such as @GetMapping
, @PostMapping
, and others) support.
The attributes on the @RequestMapping
annotation (including value
, method
, params
, headers
, consumes
, and produces
) are parsed by SpringMvcContract
as the content of the request.
Consider the following example:
Define an interface using the params
attribute.
@FeignClient("demo")
public interface DemoTemplate {
@PostMapping(value = "/stores/{storeId}", params = "mode=upsert")
In the above example, the request url is resolved to /stores/storeId?mode=upsert
The params attribute also supports the use of multiple key=value
or only one key
When
params = { "key1=v1", "key2=v2" }
, the request url is parsed as/stores/storeId?key1=v1&key2=v2
When
params = "key"
Feign @QueryMap support
Spring Cloud OpenFeign provides an equivalent @SpringQueryMap
annotation, which
is used to annotate a POJO or Map parameter as a query parameter map.
For example, the Params
class defines parameters param1
and param2
// Params.java
public class Params {
private String param1;
private String param2;
// [Getters and setters omitted for brevity]
The following Feign client uses the Params
class by using the @SpringQueryMap
annotation:
@GetMapping(path = "/demo")
String demoEndpoint(@SpringQueryMap Params params);
If you need more control over the generated query parameter map, you can implement a custom QueryMapEncoder
bean.
HATEOAS support
Spring provides some APIs to create REST representations that follow the HATEOAS principle, Spring Hateoas and Spring Data REST.
If your project use the org.springframework.boot:spring-boot-starter-hateoas
starter
or the org.springframework.boot:spring-boot-starter-data-rest
starter, Feign HATEOAS support is enabled by default.
When HATEOAS support is enabled, Feign clients are allowed to serialize and deserialize HATEOAS representation models: EntityModel, CollectionModel and PagedModel.
@GetMapping(path = "/stores")
CollectionModel<Store> getStores();
Spring @MatrixVariable Support
Spring Cloud OpenFeign provides support for the Spring @MatrixVariable
annotation.
If a map is passed as the method argument, the @MatrixVariable
path segment is created by joining key-value pairs from the map with a =
If a different object is passed, either the name
provided in the @MatrixVariable
annotation (if defined) or the annotated variable name is
joined with the provided method argument using =
- IMPORTANT
Even though, on the server side, Spring does not require the users to name the path segment placeholder same as the matrix variable name, since it would be too ambiguous on the client side, Spring Cloud OpenFeign requires that you add a path segment placeholder with a name matching either the
name
provided in the@MatrixVariable
annotation (if defined) or the annotated variable name.
For example:
@GetMapping("/objects/links/{matrixVars}")
Map<String, List<String>> getObjects(@MatrixVariable Map<String, List<String>> matrixVars);
Note that both variable name and the path segment placeholder are called matrixVars
Feign CollectionFormat
support
We support feign.CollectionFormat
by providing the @CollectionFormat
annotation.
You can annotate a Feign client method (or the whole class to affect all methods) with it by passing the desired feign.CollectionFormat
as annotation value.
In the following example, the CSV
format is used instead of the default EXPLODED
to process the method.
@FeignClient(name = "demo")
protected interface DemoFeignClient {
@CollectionFormat(feign.CollectionFormat.CSV)
@GetMapping(path = "/test")
ResponseEntity performRequest(String test);
Reactive Support
As at the time of active development of Spring Cloud OpenFeign, the OpenFeign project did not support reactive clients, such as Spring WebClient, such support could not be added to Spring Cloud OpenFeign either.
Since Spring Cloud OpenFeign project is now considered feature-complete, we’re not planning on adding support even if it becomes available in the upstream project. We suggest migrating over to Spring Interface Clients instead. Both blocking and reactive stacks are supported there.
Early Initialization Errors
We discourage using Feign clients in the early stages of application lifecycle, while processing configurations and initialising beans. Using the clients during bean initialisation is not supported.
Similarly, depending on how you are using your Feign clients, you may see initialization errors when starting your application. To work around this problem you can use an ObjectProvider
when autowiring your client.
@Autowired
ObjectProvider<TestFeignClient> testFeignClient;
Spring Data Support
If Jackson Databind and Spring Data Commons are on the classpath, converters for org.springframework.data.domain.Page
and org.springframework.data.domain.Sort
will be added automatically.
To disable this behaviour set
spring.cloud.openfeign.autoconfiguration.jackson.enabled=false
See org.springframework.cloud.openfeign.FeignAutoConfiguration.FeignJacksonConfiguration
for details.
Spring @RefreshScope
Support
If Feign client refresh is enabled, each Feign client is created with:
feign.Request.Options
as a refresh-scoped bean. This means properties such asconnectTimeout
andreadTimeout
can be refreshed against any Feign client instance. -
A url wrapped under
org.springframework.cloud.openfeign.RefreshableUrl
. This means the URL of Feign client, if defined withspring.cloud.openfeign.client.config.{feignName}.url
property, can be refreshed against any Feign client instance.
You can refresh these properties through POST /actuator/refresh
By default, refresh behavior in Feign clients is disabled. Use the following property to enable refresh behavior:
spring.cloud.openfeign.client.refresh-enabled=true
DO NOT annotate the @FeignClient interface with the @RefreshScope annotation.
OAuth2 Support
OAuth2 support can be enabled by adding the spring-boot-starter-oauth2-client
dependency to your project and setting following flag:
spring.cloud.openfeign.oauth2.enabled=true
When the flag is set to true, and the oauth2 client context resource details are present, a bean of class OAuth2AccessTokenInterceptor
is created. Before each request, the interceptor resolves the required access token and includes it as a header.
uses the OAuth2AuthorizedClientManager
to get OAuth2AuthorizedClient
that holds an OAuth2AccessToken
. If the user has specified an OAuth2 clientRegistrationId
using the spring.cloud.openfeign.oauth2.clientRegistrationId
property, it will be used to retrieve the token. If the token is not retrieved or the clientRegistrationId
has not been specified, the serviceId
retrieved from the url
host segment will be used.
- TIP
Using the
serviceId
as OAuth2 client registrationId is convenient for load-balanced Feign clients. For non-load-balanced ones, the property-basedclientRegistrationId
is a suitable approach. - TIP
If you do not want to use the default setup for the
, you can just instantiate a bean of this type in your configuration.
Transform the load-balanced HTTP request
You can use the selected ServiceInstance
to transform the load-balanced HTTP Request.
For Request
, you need to implement and define LoadBalancerFeignRequestTransformer
, as follows:
public LoadBalancerFeignRequestTransformer transformer() {
return new LoadBalancerFeignRequestTransformer() {
public Request transformRequest(Request request, ServiceInstance instance) {
Map<String, Collection<String>> headers = new HashMap<>(request.headers());
headers.put("X-ServiceId", Collections.singletonList(instance.getServiceId()));
headers.put("X-InstanceId", Collections.singletonList(instance.getInstanceId()));
return Request.create(request.httpMethod(), request.url(), headers, request.body(), request.charset(),
request.requestTemplate());
If multiple transformers are defined, they are applied in the order in which beans are defined.
Alternatively, you can use LoadBalancerFeignRequestTransformer.DEFAULT_ORDER
to specify the order.
X-Forwarded Headers Support
X-Forwarded-Host
and X-Forwarded-Proto
support can be enabled by setting following flag:
spring.cloud.loadbalancer.x-forwarded.enabled=true
Supported Ways To Provide URL To A Feign Client
You can provide a URL to a Feign client in any of the following ways:
Case | Example | Details |
The URL is provided in the |
The URL is resolved from the |
The URL is not provided in the |
The URL is resolved from configuration properties, without load-balancing. If
The URL is neither provided in the |
The URL is resolved from |
AOT and Native Image Support
Spring Cloud OpenFeign supports Spring AOT transformations and native images, however, only with refresh mode disabled, Feign clients refresh disabled (default setting) and lazy @FeignClient
attribute resolution disabled (default setting).
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, make sure to set spring.cloud.refresh.enabled to false .
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, ensure spring.cloud.openfeign.client.refresh-enabled has not been set to true .
If you want to run Spring Cloud OpenFeign clients in AOT or native image modes, ensure spring.cloud.openfeign.lazy-attributes-resolution has not been set to true .
However, if you set the url value via properties, it is possible to override the @FeignClient url value by running the image with -Dspring.cloud.openfeign.client.config.[clientId].url=[url] flag. In order to enable overriding, a url value also has to be set via properties and not @FeignClient attribute during buildtime.
Configuration properties
To see the list of all Spring Cloud OpenFeign related configuration properties please check the Appendix page.
