7. Service Broker 安全性
Open Service Broker API 规范中未指定 Service Broker 端点的身份验证和授权,但某些平台要求或允许在将 Service Broker 注册到平台时提供基本身份验证OAuth2 凭据。spring-doc.cadn.net.cn
Spring Cloud Open Service Broker 项目不实施任何安全配置。 通过使用路径匹配模式将安全性应用于应用程序端点,可以使用 Spring SecuritySpring Boot 安全配置来保护 Service Broker 应用程序端点:/v2/**.spring-doc.cadn.net.cn
7.1. 示例配置
以下示例在 Spring MVC 中实现安全配置,即阻塞 webstack。Spring WebFlux 反应式堆栈的类似配置是必要的,请参阅 Spring Security webFlux 支持spring-doc.cadn.net.cn
package com.example.servicebroker;
import org.springframework.security.config.Customizer;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.EnableWebSecurity;
import org.springframework.security.config.annotation.web.configurers.AbstractHttpConfigurer;
import org.springframework.security.core.userdetails.User;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.provisioning.InMemoryUserDetailsManager;
import org.springframework.security.web.SecurityFilterChain;
@EnableWebSecurity
public class ExampleSecurityConfig {
		return http.csrf(AbstractHttpConfigurer::disable)
				.authorizeHttpRequests(httpRequests -> httpRequests.requestMatchers("/v2/**").hasRole("ADMIN"))
				.httpBasic(Customizer.withDefaults())
	public InMemoryUserDetailsManager userDetailsService() {
		return new InMemoryUserDetailsManager(adminUser());
	private UserDetails adminUser() {
		return User
				.withUsername("admin")
				.password("{noop}supersecret")
				.roles("ADMIN")
