5. Service Bindings
Service brokers can provide information to a consumer of a service instance through a service binding. Service bindings are often used to expose credentials for service instance resources to an application.
If the bindable
field is set to true
for any plan in the service catalog, the service broker must provide an implementation of the ServiceInstanceBindingService
interface.
Otherwise, the binding methods of the service broker are not called by the platform, and a default implementation of this interface can be used.
Each method receives a single Java object parameter that contains all the details of the request from the platform and returns a Java object value that provides details of the operation to the platform.
The service binding create and delete operations can be performed synchronously or asynchronously.
When a service broker creates or deletes a service binding synchronously, the appropriate interface method should block and return a response to the platform only when the operation completes successfully or when a failure occurs.
When performing an operation asynchronously, the service broker can return a response to the platform before the operation is complete and indicate in the response that the operation is in progress. The platform polls the service broker to get the status of the operation when an asynchronous operation is indicated.
5.1. Service Binding Creation
The service broker must provide an implementation of the createServiceInstanceBinding()
method.
Two types of bindings are supported:
App bindings can be used to provide credentials, log drains, and volume services to applications.
Route bindings can be used to provide routes for the platform to use when proxying requests.
The response from this method lets one of two Java object types be returned, reflecting the two types of supported bindings.
Service brokers can generate one set of credentials for all binding requests or provide unique credentials for each binding request.
5.1.1. Event Registry
You can use events to further customize service binding creation. To do so:
Autowire the
CreateServiceInstanceBindingEventFlowRegistry
bean. -
Use one of the
addInitializationFlow()
,addCompletionFlow()
, oraddErrorFlow()
methods to register custom reactive flows to run during the various stages of creating a service binding.
5.2. Service Binding Deletion
The service broker must provide an implementation of the deleteServiceInstanceBinding()
method.
Any credentials provisioned in the create operation should be de-provisioned by the delete operation.
5.2.1. Event Registry
You can use events to further customize service binding deletion.
To do so:
. Autowire the DeleteServiceInstanceBindingEventFlowRegistry
bean.
Use one of the
, oraddErrorFlow()
methods to register custom reactive flows to run during the various stages of deleting a service binding.
5.3. Service Binding Operation Status Retrieval
If any create or delete operation can return an asynchronous “operation in progress” response to the platform, the service broker must provide an implementation of the getLastOperation()
method. Otherwise, this method is never called by the platform, and the default implementation in the interface can be used.
The platform polls this method of the service broker for a service instance that has an asynchronous operation in progress until the service broker indicates that the operation has completed successfully or a failure has occurred.
5.3.1. Event Registry
You can use events to further customize service binding last operation requests.
To do so:
. Autowire the AsyncOperationServiceInstanceBindingEventFlowRegistry
bean.
Use one of the
oraddErrorFlow()
methods to register custom reactive flows to run during the various stages of last operation retrieval.
5.4. Service Binding Retrieval
If the bindings_retrievable
in the services catalog, the service catalog must provide an implementation of the getServiceInstanceBinding()
method.
Service brokers are responsible for maintaining any service binding state necessary to support the retrieval operation.
5.5. Example Implementation
The following example implements a service binding:
package com.example.servicebroker;
@Service
public class ExampleServiceBindingService implements ServiceInstanceBindingService {
public Mono<CreateServiceInstanceBindingResponse> createServiceInstanceBinding(CreateServiceInstanceBindingRequest request) {
String serviceInstanceId = request.getServiceInstanceId();
String bindingId = request.getBindingId();
// create credentials and store for later retrieval
String url = new String(/* build a URL to access the service instance */);
String bindingUsername = new String(/* create a user */);
String bindingPassword = new String(/* create a password */);
CreateServiceInstanceBindingResponse response = CreateServiceInstanceAppBindingResponse.builder()
.credentials("url", url)
.credentials("username", bindingUsername)
.credentials("password", bindingPassword)
.bindingExisted(false)
.async(true)
return Mono.just(response);
public Mono<DeleteServiceInstanceBindingResponse> deleteServiceInstanceBinding(DeleteServiceInstanceBindingRequest request) {
// delete any binding-specific credentials
return Mono.just(DeleteServiceInstanceBindingResponse.builder()
.async(true)
.build());
public Mono<GetServiceInstanceBindingResponse> getServiceInstanceBinding(GetServiceInstanceBindingRequest request) {
// retrieve the details of the specified service binding
String url = new String(/* retrieved URL */);
String bindingUsername = new String(/* retrieved user */);
String bindingPassword = new String(/* retrieved password */);
GetServiceInstanceBindingResponse response = GetServiceInstanceAppBindingResponse.builder()
5.6. Example Event Flow Configuration
There are multiple ways to configure service binding event flows. One option is to autowire one or more registries and interact with the registry directly. Another option is to define beans for specific flows. These beans are automatically identified and added to the appropriate registry. A final option is to declare a new registry bean. However, be aware that defining a new registry bean overrides the provided auto-configuration.
5.6.1. Option 1: Autowire Registries
The following example configures service binding event flows:
public class ExampleServiceBindingEventFlowsConfiguration {
private final CreateServiceInstanceBindingEventFlowRegistry createRegistry;
private final DeleteServiceInstanceBindingEventFlowRegistry deleteRegistry;
private final AsyncOperationServiceInstanceBindingEventFlowRegistry asyncRegistry;
public ExampleServiceBindingEventFlowsConfiguration(
CreateServiceInstanceBindingEventFlowRegistry createRegistry,
DeleteServiceInstanceBindingEventFlowRegistry deleteRegistry,
AsyncOperationServiceInstanceBindingEventFlowRegistry asyncRegistry) {
this.createRegistry = createRegistry;
this.deleteRegistry = deleteRegistry;
this.asyncRegistry = asyncRegistry;
prepareCreateEventFlows()
.then(prepareDeleteEventFlows())
.then(prepareLastOperationEventFlows())
.subscribe();
private Mono<Void> prepareCreateEventFlows() {
return Mono.just(createRegistry)
.map(registry -> registry.addInitializationFlow(new CreateServiceInstanceBindingInitializationFlow() {
public Mono<Void> initialize(CreateServiceInstanceBindingRequest request) {
// do something before the instance is created
return Mono.empty();
.then(registry.addCompletionFlow(new CreateServiceInstanceBindingCompletionFlow() {
public Mono<Void> complete(CreateServiceInstanceBindingRequest request,
CreateServiceInstanceBindingResponse response) {
// do something after the instance is created
.then(registry.addErrorFlow(new CreateServiceInstanceBindingErrorFlow() {
public Mono<Void> error(CreateServiceInstanceBindingRequest request, Throwable t) {
// do something if an error occurs while creating an instance
.then();
private Mono<Void> prepareDeleteEventFlows() {
return Mono.just(deleteRegistry)
.map(registry -> registry.addInitializationFlow(new DeleteServiceInstanceBindingInitializationFlow() {
public Mono<Void> initialize(DeleteServiceInstanceBindingRequest request) {
// do something before the instance is deleted
.then(registry.addCompletionFlow(new DeleteServiceInstanceBindingCompletionFlow() {
public Mono<Void> complete(DeleteServiceInstanceBindingRequest request,
DeleteServiceInstanceBindingResponse response) {
// do something after the instance is deleted
.then(registry.addErrorFlow(new DeleteServiceInstanceBindingErrorFlow() {
public Mono<Void> error(DeleteServiceInstanceBindingRequest request, Throwable t) {
// do something if an error occurs while deleting an instance
.then();
private Mono<Void> prepareLastOperationEventFlows() {
return Mono.just(asyncRegistry)
.map(registry -> registry.addInitializationFlow(new AsyncOperationServiceInstanceBindingInitializationFlow() {
public Mono<Void> initialize(GetLastServiceBindingOperationRequest request) {
.then(registry.addCompletionFlow(new AsyncOperationServiceInstanceBindingCompletionFlow() {
public Mono<Void> complete(GetLastServiceBindingOperationRequest request,
GetLastServiceBindingOperationResponse response) {
.then(registry.addErrorFlow(new AsyncOperationServiceInstanceBindingErrorFlow() {
public Mono<Void> error(GetLastServiceBindingOperationRequest request, Throwable t) {
.then();
5.6.2. Option 2: Event Flow Beans
Optionally, you can configure beans for the individual flows, as follows:
public class ExampleServiceBindingEventFlowsConfiguration2 {
// Create Service Instance Binding flows
public CreateServiceInstanceBindingInitializationFlow createServiceInstanceBindingInitializationFlow() {
return new CreateServiceInstanceBindingInitializationFlow() {
// do something before the service instance binding completes
public CreateServiceInstanceBindingCompletionFlow createServiceInstanceBindingCompletionFlow() {
return new CreateServiceInstanceBindingCompletionFlow() {
// do something after the service instance binding completes
public CreateServiceInstanceBindingErrorFlow createServiceInstanceBindingErrorFlow() {
return new CreateServiceInstanceBindingErrorFlow() {
// do something if an error occurs while creating a service instance binding
// Delete Service Instance Binding flows
public DeleteServiceInstanceBindingInitializationFlow deleteServiceInstanceBindingInitializationFlow() {
return new DeleteServiceInstanceBindingInitializationFlow() {
// do something before the service instance binding is deleted
public DeleteServiceInstanceBindingCompletionFlow deleteServiceInstanceBindingCompletionFlow() {
return new DeleteServiceInstanceBindingCompletionFlow() {
// do something after the service instance binding is deleted
public DeleteServiceInstanceBindingErrorFlow deleteServiceInstanceBindingErrorFlow() {
return new DeleteServiceInstanceBindingErrorFlow() {
// do something if an error occurs while deleting a service instance binding
// Get Last Service Instance Binding Operation flows
public AsyncOperationServiceInstanceBindingInitializationFlow getLastOperationServiceInstanceBindingInitializationFlow() {
return new AsyncOperationServiceInstanceBindingInitializationFlow() {
// do something before getting the last operation
public AsyncOperationServiceInstanceBindingCompletionFlow getLastOperationServiceInstanceBindingCompletionFlow() {
return new AsyncOperationServiceInstanceBindingCompletionFlow() {
// do something after getting the last operation
public AsyncOperationServiceInstanceBindingErrorFlow getLastOperationServiceInstanceBindingErrorFlow() {
return new AsyncOperationServiceInstanceBindingErrorFlow() {
// do something if an error occurs while getting the last operation
