This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Netflix 4.2.1! |
Spring Cloud Netflix Features
Service Discovery: Eureka Clients
Service Discovery is one of the key tenets of a microservice-based architecture. Trying to hand-configure each client or some form of convention can be difficult to do and can be brittle. Eureka is the Netflix Service Discovery Server and Client. The server can be configured and deployed to be highly available, with each server replicating state about the registered services to the others.
How to Include Eureka Client
To include the Eureka Client in your project, use the starter with a group ID of org.springframework.cloud
and an artifact ID of spring-cloud-starter-netflix-eureka-client
See the Spring Cloud Project page for details on setting up your build system with the current Spring Cloud Release Train.
Registering with Eureka
When a client registers with Eureka, it provides meta-data about itself — such as host, port, health indicator URL, home page, and other details. Eureka receives heartbeat messages from each instance belonging to a service. If the heartbeat fails over a configurable timetable, the instance is normally removed from the registry.
The following example shows a minimal Eureka client application:
@SpringBootApplication
@RestController
public class Application {
@RequestMapping("/")
public String home() {
return "Hello world";
SpringApplication.run(CustomerServiceTestApplication.class, args);
Note that the preceding example shows a normal Spring Boot application.
By having spring-cloud-starter-netflix-eureka-client
on the classpath, your application automatically registers with the Eureka Server. Configuration is required to locate the Eureka server, as shown in the following example:
eureka: client: serviceUrl: defaultZone: http://localhost:8761/eureka/
In the preceding example, defaultZone
is a magic string fallback value that provides the service URL for any client that does not express a preference (in other words, it is a useful default).
The defaultZone property is case sensitive and requires camel case because the serviceUrl property is a Map<String, String> . Therefore, the defaultZone property does not follow the normal Spring Boot snake-case convention of default-zone .
The default application name (that is, the service ID), virtual host, and non-secure port (taken from the Environment
) are ${spring.application.name}
, ${spring.application.name}
and ${server.port}
, respectively.
Having spring-cloud-starter-netflix-eureka-client
on the classpath makes the app into both a Eureka “instance” (that is, it registers itself) and a “client” (it can query the registry to locate other services).
The instance behaviour is driven by eureka.instance.*
configuration keys, but the defaults are fine if you ensure that your application has a value for spring.application.name
(this is the default for the Eureka service ID or VIP).
See EurekaInstanceConfigBean and EurekaClientConfigBean for more details on the configurable options.
To disable the Eureka Discovery Client, you can set eureka.client.enabled
to false
. Eureka Discovery Client will also be disabled when spring.cloud.discovery.enabled
is set to false
Specifying the version of the Spring Cloud Netflix Eureka server as a path parameter is not currently supported. This means you cannot set the version in the context path (eurekaServerURLContext ). Instead, you can include the version in the server URL (for example, you can set defaultZone: localhost:8761/eureka/v2 ).
Authenticating with the Eureka Server
HTTP basic authentication is automatically added to your eureka client if one of the eureka.client.serviceUrl.defaultZone
URLs has credentials embedded in it (curl style, as follows: user:password@localhost:8761/eureka
For more complex needs, you can create a @Bean
of type DiscoveryClientOptionalArgs
and inject ClientFilter
instances into it, all of which is applied to the calls from the client to the server.
When Eureka server requires client side certificate for authentication, the client side certificate and trust store can be configured via properties, as shown in following example:
eureka:
client:
tls:
enabled: true
key-store: <path-of-key-store>
key-store-type: PKCS12
key-store-password: <key-store-password>
key-password: <key-password>
trust-store: <path-of-trust-store>
trust-store-type: PKCS12
trust-store-password: <trust-store-password>
The eureka.client.tls.enabled
needs to be true to enable Eureka client side TLS. When eureka.client.tls.trust-store
is omitted, a JVM default trust store is used. The default value for eureka.client.tls.key-store-type
and eureka.client.tls.trust-store-type
is PKCS12. When password properties are omitted, empty password is assumed.
Because of a limitation in Eureka, it is not possible to support per-server basic auth credentials, so only the first set that are found is used. |
If you want to customize the RestTemplate used by the Eureka HTTP Client you may want to create a bean of EurekaClientHttpRequestFactorySupplier
and provide your own logic for generating a ClientHttpRequestFactory
instance.
All default timeout-related properties for RestTemplate and RestClient used by the Eureka HTTP Client are set to 3 minutes (in keeping with Apache HC5 default RequestConfig
and SocketConfig
). Therefore, to specify the timeout values, you must specify the value directly with the properties in eureka.client.rest-template-timeout
or eureka.client.restclient.timeout
. All timeout properties are in milliseconds.
eureka:
client:
restclient:
timeout:
connect-timeout: 5000
connect-request-timeout: 8000
socket-timeout: 10000
rest-template-timeout:
You can also customise the RequestConfig
for the underlying Apache HttpClient 5 by creating a bean of type EurekaClientHttpRequestFactorySupplier.RequestConfigCustomizer
public class RestClientConfiguration {
EurekaClientHttpRequestFactorySupplier.RequestConfigCustomizer requestConfigCustomizer() {
return builder -> builder.setProtocolUpgradeEnabled(false);
Status Page and Health Indicator
The status page and health indicators for a Eureka instance default to /info
and /health
respectively, which are the default locations of useful endpoints in a Spring Boot Actuator application.
You need to change these, even for an Actuator application if you use a non-default context path or servlet path (such as server.servletPath=/custom
). The following example shows the default values for the two settings:
eureka: instance: statusPageUrlPath: ${server.servletPath}/info healthCheckUrlPath: ${server.servletPath}/health
These links show up in the metadata that is consumed by clients and are used in some scenarios to decide whether to send requests to your application, so it is helpful if they are accurate.
In Dalston it was also required to set the status and health check URLs when changing that management context path. This requirement was removed beginning in Edgware. |
Registering a Secure Application
If your app wants to be contacted over HTTPS, you can set two flags in the EurekaInstanceConfigBean
eureka.instance.[nonSecurePortEnabled]=[false]
eureka.instance.[securePortEnabled]=[true]
Doing so makes Eureka publish instance information that shows an explicit preference for secure communication.
The Spring Cloud DiscoveryClient
always returns a URI starting with https
for a service configured this way.
Similarly, when a service is configured this way, the Eureka (native) instance information has a secure health check URL.
Because of the way Eureka works internally, it still publishes a non-secure URL for the status and home pages unless you also override those explicitly. You can use placeholders to configure the eureka instance URLs, as shown in the following example:
eureka: instance: statusPageUrl: https://${eureka.hostname}/info healthCheckUrl: https://${eureka.hostname}/health homePageUrl: https://${eureka.hostname}/
(Note that ${eureka.hostname}
is a native placeholder only available
in later versions of Eureka. You could achieve the same thing with
Spring placeholders as well — for example, by using ${eureka.instance.hostName}
If your application runs behind a proxy, and the SSL termination is in the proxy (for example, if you run in Cloud Foundry or other platforms as a service), then you need to ensure that the proxy “forwarded” headers are intercepted and handled by the application. If the Tomcat container embedded in a Spring Boot application has explicit configuration for the 'X-Forwarded-\*` headers, this happens automatically. The links rendered by your app to itself being wrong (the wrong host, port, or protocol) is a sign that you got this configuration wrong. |
Eureka’s Health Checks
By default, Eureka uses the client heartbeat to determine if a client is up. Unless specified otherwise, the Discovery Client does not propagate the current health check status of the application, per the Spring Boot Actuator. Consequently, after successful registration, Eureka always announces that the application is in 'UP' state. This behavior can be altered by enabling Eureka health checks, which results in propagating application status to Eureka. As a consequence, every other application does not send traffic to applications in states other then 'UP'. The following example shows how to enable health checks for the client:
eureka: client: healthcheck: enabled: true
eureka.client.healthcheck.enabled=true should only be set in application.yml . Setting the value in bootstrap.yml causes undesirable side effects, such as registering in Eureka with an UNKNOWN status.
If you require more control over the health checks, consider implementing your own com.netflix.appinfo.HealthCheckHandler
Eureka Metadata for Instances and Clients
It is worth spending a bit of time understanding how the Eureka metadata works, so you can use it in a way that makes sense in your platform.
There is standard metadata for information such as hostname, IP address, port numbers, the status page, and health check.
These are published in the service registry and used by clients to contact the services in a straightforward way.
Additional metadata can be added to the instance registration in the eureka.instance.metadataMap
, and this metadata is accessible in the remote clients.
In general, additional metadata does not change the behavior of the client, unless the client is made aware of the meaning of the metadata.
There are a couple of special cases, described later in this document, where Spring Cloud already assigns meaning to the metadata map.
Using Eureka on Cloud Foundry
Cloud Foundry has a global router so that all instances of the same app have the same hostname (other PaaS solutions with a similar architecture have the same arrangement).
This is not necessarily a barrier to using Eureka.
However, if you use the router (recommended or even mandatory, depending on the way your platform was set up), you need to explicitly set the hostname and port numbers (secure or non-secure) so that they use the router.
You might also want to use instance metadata so that you can distinguish between the instances on the client (for example, in a custom load balancer).
By default, the eureka.instance.instanceId
is vcap.application.instance_id
eureka: instance: hostname: ${vcap.application.uris[0]} nonSecurePort: 80
Depending on the way the security rules are set up in your Cloud Foundry instance, you might be able to register and use the IP address of the host VM for direct service-to-service calls. This feature is not yet available on Pivotal Web Services (PWS).
Using Eureka on AWS
If the application is planned to be deployed to an AWS cloud, the Eureka instance must be configured to be AWS-aware. You can do so by customizing the EurekaInstanceConfigBean as follows:
@Profile("!default")
public EurekaInstanceConfigBean eurekaInstanceConfig(InetUtils inetUtils) {
EurekaInstanceConfigBean bean = new EurekaInstanceConfigBean(inetUtils);
AmazonInfo info = AmazonInfo.Builder.newBuilder().autoBuild("eureka");
bean.setDataCenterInfo(info);
return bean;
Changing the Eureka Instance ID
A vanilla Netflix Eureka instance is registered with an ID that is equal to its host name (that is, there is only one service per host). Spring Cloud Eureka provides a sensible default, which is defined as follows:
${spring.cloud.client.hostname}:${spring.application.name}:${spring.application.instance_id:${server.port}}
An example is myhost:myappname:8080
By using Spring Cloud, you can override this value by providing a unique identifier in eureka.instance.instanceId
eureka: instance: instanceId: ${spring.application.name}:${vcap.application.instance_id:${spring.application.instance_id:${random.value}}}
With the metadata shown in the preceding example and multiple service instances deployed on localhost, the random value is inserted there to make the instance unique.
In Cloud Foundry, the vcap.application.instance_id
is populated automatically in a Spring Boot application, so the random value is not needed.
Using the EurekaClient
Once you have an application that is a discovery client, you can use it to discover service instances from the Eureka Server.
One way to do so is to use the native com.netflix.discovery.EurekaClient
(as opposed to the Spring Cloud DiscoveryClient
), as shown in the following example:
@Autowired private EurekaClient discoveryClient; public String serviceUrl() { InstanceInfo instance = discoveryClient.getNextServerFromEureka("STORES", false); return instance.getHomePageUrl(); }
Do not use the |
Underlying HTTP clients
EurekaClient
uses either RestClient
, RestTemplate
, WebClient
or JerseyClient
under the hood. In order to use the EurekaClient
, you need to have one of the supported HTTP clients on your classpath.
To use RestTemplate
or RestClient
, add spring-boot-starter-web
to your dependencies. To use WebClient
, add spring-boot-starter-webflux
to your dependencies. If both spring-boot-starter-web
and spring-boot-starter-webflux
are included in the dependencies and the eureka.client.webclient.enabled
flag is set to true
then WebClient
will be used. If that’s not the case and eureka.client.restclient.enabled
is set to true
, RestClient
will be used. Otherwise, RestTemplate
will be used.
For any of those client implementations, if there’s a builder bean available, it will be used to create the underlying client. |
We’re planning on changing the default client to RestClient with the next major release.
If you wish to use Jersey instead, you need to add the Jersey dependencies to your classpath. The following example shows the dependencies you need to add:
<dependencies>
<dependency>
<groupId>com.sun.jersey</groupId>
<artifactId>jersey-client</artifactId>
</dependency>
<dependency>
<artifactId>jersey-core</artifactId>
</dependency>
<dependency>
<groupId>com.sun.jersey.contribs</groupId>
<artifactId>jersey-apache-client4</artifactId>
</dependency>
</dependencies>
If you have JerseyClient
on the classpath but do not wish to use it in your EuerekaClient
, make sure to set eureka.client.jersey.enabled
to false
Alternatives to the Native Netflix EurekaClient
You need not use the raw Netflix EurekaClient
Also, it is usually more convenient to use it behind a wrapper of some sort.
Spring Cloud has support for Feign (a REST client builder) and Spring Cloud LoadBalancer through the logical Eureka service identifiers (VIPs) instead of physical URLs.
You can also use the org.springframework.cloud.client.discovery.DiscoveryClient
, which provides a simple API (not specific to Netflix) for discovery clients, as shown in the following example:
@Autowired private DiscoveryClient discoveryClient; public String serviceUrl() { List<ServiceInstance> list = discoveryClient.getInstances("STORES"); if (list != null && list.size() > 0 ) { return list.get(0).getUri(); } return null; }
Why Is It so Slow to Register a Service?
Being an instance also involves a periodic heartbeat to the registry
(through the client’s serviceUrl
) with a default duration of 30 seconds.
A service is not available for discovery by clients until the instance, the server, and the client all have the same metadata in their local
cache (so it could take 3 heartbeats).
You can change the period by setting eureka.instance.leaseRenewalIntervalInSeconds
Setting it to a value of less than 30 speeds up the process of getting clients connected to other services.
In production, it is probably better to stick with the default, because of internal computations in the server that make assumptions about the lease renewal period.
Zones
If you have deployed Eureka clients to multiple zones, you may prefer that those clients use services within the same zone before trying services in another zone. To set that up, you need to configure your Eureka clients correctly.
First, you need to make sure you have Eureka servers deployed to each zone and that they are peers of each other. See the section on zones and regions for more information.
Next, you need to tell Eureka which zone your service is in.
You can do so by using the metadataMap
property.
For example, if service 1
is deployed to both zone 1
and zone 2
, you need to set the following Eureka properties in service 1
Service 1 in Zone 1
eureka.instance.metadataMap.zone = zone1
eureka.client.preferSameZoneEureka = true
Service 1 in Zone 2
eureka.instance.metadataMap.zone = zone2
Refreshing Eureka Clients
By default, the EurekaClient
bean is refreshable, meaning the Eureka client properties can be changed and refreshed.
When a refresh occurs clients will be unregistered from the Eureka server and there might be a brief moment of time
where all instance of a given service are not available. One way to eliminate this from happening is to disable
the ability to refresh Eureka clients. To do this set eureka.client.refresh.enable=false
Using Eureka with Spring Cloud LoadBalancer
We offer support for the Spring Cloud LoadBalancer ZonePreferenceServiceInstanceListSupplier
The zone
value from the Eureka instance metadata (eureka.instance.metadataMap.zone
) is used for setting the
value of spring-cloud-loadbalancer-zone
property that is used to filter service instances by zone.
If that is missing and if the spring.cloud.loadbalancer.eureka.approximateZoneFromHostname
flag is set to true
it can use the domain name from the server hostname as a proxy for the zone.
If there is no other source of zone data, then a guess is made, based on the client configuration (as opposed to the instance configuration).
We take eureka.client.availabilityZones
, which is a map from region name to a list of zones, and pull out the first zone for the instance’s own region (that is, the eureka.client.region
, which defaults to "us-east-1", for compatibility with native Netflix).
AOT and Native Image Support
Spring Cloud Netflix Eureka Client integration supports Spring AOT transformations and native images, however, only with refresh mode disabled.
If you want to run Eureka Client in AOT or native image modes, make sure to set spring.cloud.refresh.enabled to false .
Given the AOT and native image closed-world assumption, using random port with Eureka clients is not supported for ahead of time compilation or native images. |
Service Discovery: Eureka Server
This section describes how to set up a Eureka server.
How to Include Eureka Server
To include Eureka Server in your project, use the starter with a group ID of org.springframework.cloud
and an artifact ID of spring-cloud-starter-netflix-eureka-server
If your project already uses Thymeleaf as its template engine, the Freemarker templates of the Eureka server may not be loaded correctly. In this case it is necessary to configure the template loader manually: |
spring: freemarker: template-loader-path: classpath:/templates/ prefer-file-system-access: false
How to Run a Eureka Server
The following example shows a minimal Eureka server:
@EnableEurekaServer
The server has a home page with a UI and HTTP API endpoints for the normal Eureka functionality under /eureka/*
The following links have some Eureka background reading: flux capacitor and google group discussion.
Due to Gradle’s dependency resolution rules and the lack of a parent bom feature, depending on build.gradle
defaultOpenForTrafficCount
and its effect on EurekaServer warmup time
Netflix Eureka’s waitTimeInMsWhenSyncEmpty
setting is not taken into account in Spring Cloud Eureka server at the beginning. In order to enable the warmup time, set eureka.server.defaultOpenForTrafficCount=0
High Availability, Zones and Regions
The Eureka server does not have a back end store, but the service instances in the registry all have to send heartbeats to keep their registrations up to date (so this can be done in memory). Clients also have an in-memory cache of Eureka registrations (so they do not have to go to the registry for every request to a service).
By default, every Eureka server is also a Eureka client and requires (at least one) service URL to locate a peer. If you do not provide it, the service runs and works, but it fills your logs with a lot of noise about not being able to register with the peer.
Standalone Mode
The combination of the two caches (client and server) and the heartbeats make a standalone Eureka server fairly resilient to failure, as long as there is some sort of monitor or elastic runtime (such as Cloud Foundry) keeping it alive. In standalone mode, you might prefer to switch off the client side behavior so that it does not keep trying and failing to reach its peers. The following example shows how to switch off the client-side behavior:
server: port: 8761 eureka: instance: hostname: localhost client: registerWithEureka: false fetchRegistry: false serviceUrl: defaultZone: http://${eureka.instance.hostname}:${server.port}/eureka/
Notice that the serviceUrl
is pointing to the same host as the local instance.
Peer Awareness
Eureka can be made even more resilient and available by running multiple instances and asking them to register with each other.
In fact, this is the default behavior, so all you need to do to make it work is add a valid serviceUrl
to a peer, as shown in the following example:
--- spring: profiles: peer1 eureka: instance: hostname: peer1 client: serviceUrl: defaultZone: https://peer2/eureka/ --- spring: profiles: peer2 eureka: instance: hostname: peer2 client: serviceUrl: defaultZone: https://peer1/eureka/
In the preceding example, we have a YAML file that can be used to run the same server on two hosts (peer1
and peer2
) by running it in different Spring profiles.
You could use this configuration to test the peer awareness on a single host (there is not much value in doing that in production) by manipulating /etc/hosts
to resolve the host names.
In fact, the eureka.instance.hostname
is not needed if you are running on a machine that knows its own hostname (by default, it is looked up by using java.net.InetAddress
You can add multiple peers to a system, and, as long as they are all connected to each other by at least one edge, they synchronize the registrations amongst themselves. If the peers are physically separated (inside a data center or between multiple data centers), then the system can, in principle, survive “split-brain” type failures. You can add multiple peers to a system, and as long as they are all directly connected to each other, they will synchronize the registrations amongst themselves.
eureka: client: serviceUrl: defaultZone: https://peer1/eureka/,http://peer2/eureka/,http://peer3/eureka/ --- spring: profiles: peer1 eureka: instance: hostname: peer1 --- spring: profiles: peer2 eureka: instance: hostname: peer2 --- spring: profiles: peer3 eureka: instance: hostname: peer3
When to Prefer IP Address
In some cases, it is preferable for Eureka to advertise the IP addresses of services rather than the hostname.
Set eureka.instance.preferIpAddress
to true
and, when the application registers with eureka, it uses its IP address rather than its hostname.
If the hostname cannot be determined by Java, then the IP address is sent to Eureka.
Only explict way of setting the hostname is by setting |
Securing The Eureka Server
You can secure your Eureka server simply by adding Spring Security to your
server’s classpath via spring-boot-starter-security
. By default, when Spring Security is on the classpath it will require that
a valid CSRF token be sent with every request to the app. Eureka clients will not generally possess a valid
cross site request forgery (CSRF) token you will need to disable this requirement for the /eureka/**
endpoints.
For example:
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
http.authorizeHttpRequests((authz) -> authz
.anyRequest().authenticated())
.httpBasic(withDefaults());
http.csrf().ignoringRequestMatchers("/eureka/**");
return http.build();
For more information on CSRF see the Spring Security documentation.
A demo Eureka Server can be found in the Spring Cloud Samples repo.
JDK 11 Support
The JAXB modules which the Eureka server depends upon were removed in JDK 11. If you intend to use JDK 11 when running a Eureka server you must include these dependencies in your POM or Gradle file.
<dependency>
<groupId>org.glassfish.jaxb</groupId>
<artifactId>jaxb-runtime</artifactId>
</dependency>
Spring Cloud Netflix Eureka Server does not support Spring AOT transformations or native images.
Metrics
EurekaInstanceMonitor
listens to events related to Eureka instance registration and creates/updates Gauge`s for Eureka instance information in Micrometer’s `MeterRegistry
. By default, this behavior is disabled. If you want to enable it, you need to set eureka.server.metrics.enabled
to true
By default, the Gauge`s are named `eureka.server.instances
and have the following tags:
application
: application name -
status
: instance status (UP
,DOWN
,STARTING
,OUT_OF_SERVICE
,UNKNOWN
, see:com.netflix.appinfo.InstanceInfo.InstanceStatus
You can add additional tags by injecting your own implementation of EurekaInstanceTagsProvider
Configuration properties
To see the list of all Spring Cloud Netflix related configuration properties please check the Appendix page.
