5. Kubernetes PropertySource implementations
The most common approach to configuring your Spring Boot application is to create an application.properties
or application.yaml
or
an application-profile.properties
or application-profile.yaml
file that contains key-value pairs that provide customization values to your
application or Spring Boot starters. You can override these properties by specifying system properties or environment
variables.
5.1. Using a ConfigMap
PropertySource
Kubernetes provides a resource named ConfigMap
to externalize the
parameters to pass to your application in the form of key-value pairs or embedded application.properties
or application.yaml
files.
The Spring Cloud Kubernetes Config project makes Kubernetes ConfigMap
instances available
during application bootstrapping and triggers hot reloading of beans or Spring context when changes are detected on
observed ConfigMap
instances.
The default behavior is to create a Fabric8ConfigMapPropertySource
based on a Kubernetes ConfigMap
that has a metadata.name
value of either the name of
your Spring application (as defined by its spring.application.name
property) or a custom name defined within the
bootstrap.properties
file under the following key: spring.cloud.kubernetes.config.name
However, more advanced configuration is possible where you can use multiple ConfigMap
instances.
The spring.cloud.kubernetes.config.sources
list makes this possible.
For example, you could define the following ConfigMap
instances:
spring:
application:
cloud:
kubernetes:
config:
namespace: default-namespace
sources:
# Spring Cloud Kubernetes looks up a ConfigMap named c1 in namespace default-namespace
- name: c1
# Spring Cloud Kubernetes looks up a ConfigMap named default-name in whatever namespace n2
- namespace: n2
# Spring Cloud Kubernetes looks up a ConfigMap named c3 in namespace n3
- namespace: n3
In the preceding example, if spring.cloud.kubernetes.config.namespace
had not been set,
the ConfigMap
named c1
would be looked up in the namespace that the application runs.
See Namespace resolution to get a better understanding of how the namespace
of the application is resolved.
Any matching ConfigMap
that is found is processed as follows:
Apply individual configuration properties.
Apply as
yaml
the content of any property namedapplication.yaml
Apply as a properties file the content of any property named
The single exception to the aforementioned flow is when the ConfigMap
contains a single key that indicates
the file is a YAML or properties file. In that case, the name of the key does NOT have to be application.yaml
or
(it can be anything) and the value of the property is treated correctly.
This features facilitates the use case where the ConfigMap
was created by using something like the following:
kubectl create configmap game-config --from-file=/path/to/app-config.yaml
Assume that we have a Spring Boot application named demo
that uses the following properties to read its thread pool
configuration.
pool.size.core
pool.size.maximum
This can be externalized to config map in yaml
format as follows:
kind: ConfigMap
apiVersion: v1
metadata:
data:
pool.size.core: 1
pool.size.max: 16
Individual properties work fine for most cases. However, sometimes, embedded yaml
is more convenient. In this case, we
use a single property named application.yaml
to embed our yaml
, as follows:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yaml: |-
pool:
size:
core: 1
max:16
The following example also works:
kind: ConfigMap
apiVersion: v1
metadata:
data:
custom-name.yaml: |-
pool:
size:
core: 1
max:16
You can also configure Spring Boot applications differently depending on active profiles that are merged together
when the ConfigMap
is read. You can provide different property values for different profiles by using an
or application.yaml
property, specifying profile-specific values, each in their own document
(indicated by the ---
sequence), as follows:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
greeting:
message: Say Hello to the World
farewell:
message: Say Goodbye
spring:
profiles: development
greeting:
message: Say Hello to the Developers
farewell:
message: Say Goodbye to the Developers
spring:
profiles: production
greeting:
message: Say Hello to the Ops
In the preceding case, the configuration loaded into your Spring Application with the development
profile is as follows:
greeting:
farewell:
However, if the production
profile is active, the configuration becomes:
greeting:
farewell:
If both profiles are active, the property that appears last within the ConfigMap
overwrites any preceding values.
Another option is to create a different config map per profile and spring boot will automatically fetch it based on active profiles
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
greeting:
farewell:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
spring:
greeting:
farewell:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
spring:
greeting:
farewell:
To tell Spring Boot which profile
should be enabled at bootstrap, you can pass SPRING_PROFILES_ACTIVE
environment variable.
To do so, you can launch your Spring Boot application with an environment variable that you can define it in the PodSpec at the container specification.
Deployment resource file, as follows:
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: deployment-name
spec:
replicas: 1
selector:
matchLabels:
template:
metadata:
labels:
spec:
containers:
- name: container-name
image: your-image
env:
- name: SPRING_PROFILES_ACTIVE
value: "development"
You could run into a situation where there are multiple configs maps that have the same property names. For example:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
greeting:
message: Say Hello from one
and
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
greeting:
message: Say Hello from two
Depending on the order in which you place these in bootstrap.yaml|properties
, you might end up with an un-expected result (the last config map wins). For example:
spring:
application:
cloud:
kubernetes:
config:
sources:
- name: config-map-two
- name: config-map-one
will result in property greetings.message
being Say Hello from one
There is a way to change this default configuration by specifying useNameAsPrefix
. For example:
spring:
application:
cloud:
kubernetes:
config:
useNameAsPrefix: true
sources:
useNameAsPrefix: false
Such a configuration will result in two properties being generated:
greetings.message
equal toSay Hello from one
config-map-two.greetings.message
equal toSay Hello from two
Notice that spring.cloud.kubernetes.config.useNameAsPrefix
has a lower priority than spring.cloud.kubernetes.config.sources.useNameAsPrefix
This allows you to set a "default" strategy for all sources, at the same time allowing to override only a few.
If using the config map name is not an option, you can specify a different strategy, called : explicitPrefix
. Since this is an explicit prefix that
you select, it can only be supplied to the sources
level. At the same time it has a higher priority than useNameAsPrefix
. Let’s suppose we have a third config map with these entries:
kind: ConfigMap
apiVersion: v1
metadata:
data:
application.yml: |-
greeting:
message: Say Hello from three
A configuration like the one below:
spring:
application:
cloud:
kubernetes:
config:
sources:
explicitPrefix: two
- name: config-map-three
will result in three properties being generated:
greetings.message
config-map-three.greetings.message
equal toSay Hello from three
By default, besides reading the config map that is specified in the sources
configuration, Spring will also try to read
all properties from "profile aware" sources. The easiest way to explain this is via an example. Let’s suppose your application
enables a profile called "dev" and you have a configuration like the one below:
spring:
application:
cloud:
kubernetes:
config:
sources:
Besides reading the config-map-one
, Spring will also try to read config-map-one-dev
; in this particular order. Each active profile
generates such a profile aware config map.
Though your application should not be impacted by such a config map, it can be disabled if needed:
spring:
application:
cloud:
kubernetes:
config:
includeProfileSpecificSources: false
sources:
Notice that just like before, there are two levels where you can specify this property: for all config maps or for individual ones; the latter having a higher priority.
You should check the security configuration section. To access config maps from inside a pod you need to have the correct Kubernetes service accounts, roles and role bindings. |
Another option for using ConfigMap
instances is to mount them into the Pod by running the Spring Cloud Kubernetes application
and having Spring Cloud Kubernetes read them from the file system.
This behavior is controlled by the spring.cloud.kubernetes.config.paths
property. You can use it in
addition to or instead of the mechanism described earlier.
You can specify multiple (exact) file paths in spring.cloud.kubernetes.config.paths
by using the ,
delimiter.
You have to provide the full exact path to each property file, because directories are not being recursively parsed. |
If you use spring.cloud.kubernetes.config.paths or spring.cloud.kubernetes.secrets.path the automatic reload
functionality will not work. You will need to make a POST request to the /actuator/refresh endpoint or
restart/redeploy the application.
In some cases, your application may be unable to load some of your ConfigMaps
using the Kubernetes API.
If you want your application to fail the start-up process in such cases, you can set
spring.cloud.kubernetes.config.fail-fast=true
to make the application start-up fail with an Exception.
You can also make your application retry loading ConfigMap
property sources on a failure. First, you need to
set spring.cloud.kubernetes.config.fail-fast=true
. Then you need to add spring-retry
and spring-boot-starter-aop
to your classpath. You can configure retry properties such as
the maximum number of attempts, backoff options like initial interval, multiplier, max interval by setting the
spring.cloud.kubernetes.config.retry.*
properties.
If you already have spring-retry and spring-boot-starter-aop on the classpath for some reason
and want to enable fail-fast, but do not want retry to be enabled; you can disable retry for ConfigMap PropertySources
by setting spring.cloud.kubernetes.config.retry.enabled=false .
Name | Type | Default | Description |
Enable ConfigMaps |
Sets the name of |
Client namespace |
Sets the Kubernetes namespace where to lookup |
Sets the paths where |
Enable or disable consuming |
Enable or disable failing the application start-up when an error occurred while loading a |
Enable or disable config retry. |
Initial retry interval in milliseconds. |
Maximum number of attempts. |
Maximum interval for backoff. |
Multiplier for next interval. |
5.2. Secrets PropertySource
Kubernetes has the notion of Secrets for storing
sensitive data such as passwords, OAuth tokens, and so on. This project provides integration with Secrets
to make secrets
accessible by Spring Boot applications. You can explicitly enable or disable This feature by setting the spring.cloud.kubernetes.secrets.enabled
property.
When enabled, the Fabric8SecretsPropertySource
looks up Kubernetes for Secrets
from the following sources:
Reading recursively from secrets mounts
Named after the application (as defined by
Matching some labels
Note:
By default, consuming Secrets through the API (points 2 and 3 above) is not enabled for security reasons. The permission 'list' on secrets allows clients to inspect secrets values in the specified namespace. Further, we recommend that containers share secrets through mounted volumes.
If you enable consuming Secrets through the API, we recommend that you limit access to Secrets by using an authorization policy, such as RBAC. For more information about risks and best practices when consuming Secrets through the API refer to this doc.
If the secrets are found, their data is made available to the application.
Assume that we have a spring boot application named demo
that uses properties to read its database
configuration. We can create a Kubernetes secret by using the following command:
kubectl create secret generic db-secret --from-literal=username=user --from-literal=password=p455w0rd
The preceding command would create the following secret (which you can see by using kubectl get secrets db-secret -o yaml
apiVersion: v1
data:
password: cDQ1NXcwcmQ=
username: dXNlcg==
kind: Secret
metadata:
creationTimestamp: 2017-07-04T09:15:57Z
namespace: default
resourceVersion: "357496"
selfLink: /api/v1/namespaces/default/secrets/db-secret
uid: 63c89263-6099-11e7-b3da-76d6186905a8
type: Opaque
Note that the data contains Base64-encoded versions of the literal provided by the create
command.
Your application can then use this secret — for example, by exporting the secret’s value as environment variables:
apiVersion: v1
kind: Deployment
metadata:
spec:
template:
spec:
containers:
- env:
- name: DB_USERNAME
valueFrom:
secretKeyRef:
key: username
- name: DB_PASSWORD
valueFrom:
secretKeyRef:
key: password
You can select the Secrets to consume in a number of ways:
By listing the directories where secrets are mapped:
-Dspring.cloud.kubernetes.secrets.paths=/etc/secrets/db-secret,etc/secrets/postgresql
If you have all the secrets mapped to a common root, you can set them like:
By setting a named secret:
-Dspring.cloud.kubernetes.secrets.name=db-secret
By defining a list of labels:
-Dspring.cloud.kubernetes.secrets.labels.broker=activemq -Dspring.cloud.kubernetes.secrets.labels.db=postgresql
As the case with ConfigMap
, more advanced configuration is also possible where you can use multiple Secret
instances. The spring.cloud.kubernetes.secrets.sources
For example, you could define the following Secret
instances:
spring:
application:
cloud:
kubernetes:
secrets:
sources:
# Spring Cloud Kubernetes looks up a Secret named s1 in namespace default-namespace
- name: s1
# Spring Cloud Kubernetes looks up a Secret named default-name in namespace n2
- namespace: n2
# Spring Cloud Kubernetes looks up a Secret named s3 in namespace n3
- namespace: n3
In the preceding example, if spring.cloud.kubernetes.secrets.namespace
had not been set,
the Secret
named s1
See namespace-resolution to get a better understanding of how the namespace
Similar to the ConfigMaps
; if you want your application to fail to start
when it is unable to load Secrets
property sources, you can set spring.cloud.kubernetes.secrets.fail-fast=true
It is also possible to enable retry for Secret
property sources like the ConfigMaps
As with the ConfigMap
property sources, first you need to set spring.cloud.kubernetes.secrets.fail-fast=true
to your classpath.
Retry behavior of the Secret
property sources can be configured by setting the spring.cloud.kubernetes.secrets.retry.*
properties.
and want to enable fail-fast, but do not want retry to be enabled; you can disable retry for Secrets PropertySources
by setting spring.cloud.kubernetes.secrets.retry.enabled=false .
Enable Secrets |
Sets the name of the secret to look up |
Client namespace |
Sets the Kubernetes namespace where to look up |
Sets the labels used to lookup secrets |
Sets the paths where secrets are mounted (example 1) |
Enables or disables consuming secrets through APIs (examples 2 and 3) |
Enable or disable secrets retry. |
Notes:
The
property behaves as defined by Map-based binding. -
The
property behaves as defined by Collection-based binding. -
Access to secrets through the API may be restricted for security reasons. The preferred way is to mount secrets to the Pod.
You can find an example of an application that uses secrets (though it has not been updated to use the new spring-cloud-kubernetes
project) at
spring-boot-camel-config
5.3. Namespace resolution
Finding an application namespace happens on a best-effort basis. There are some steps that we iterate in order to find it. The easiest and most common one, is to specify it in the proper configuration, for example:
spring:
application:
cloud:
kubernetes:
secrets:
namespace: default
sources:
# Spring Cloud Kubernetes looks up a Secret named 'a' in namespace 'default'
- name: a
# Spring Cloud Kubernetes looks up a Secret named 'secret' in namespace 'b'
- namespace: b
# Spring Cloud Kubernetes looks up a Secret named 'd' in namespace 'c'
- namespace: c
Remember that the same can be done for config maps. If such a namespace is not specified, it will be read (in this order):
from property
spring.cloud.kubernetes.client.namespace
from a String residing in a file denoted by
spring.cloud.kubernetes.client.serviceAccountNamespacePath
property -
/var/run/secrets/kubernetes.io/serviceaccount/namespace
file (kubernetes default namespace path) -
from a designated client method call (for example fabric8’s :
KubernetesClient::getNamespace
), if the client provides such a method. This, in turn, could be configured via environment properties. For example fabric8 client can be configured via "KUBERNETES_NAMESPACE" property; consult the client documentation for exact details.
Failure to find a namespace from the above steps will result in an Exception being raised.
5.4. Order of ConfigMaps and Secrets
If, for whatever reason, you enabled both configmaps and secrets, and there is a common property between them, the value from the ConfigMap will have a higher precedence. That is: it will override whatever values are found in secrets.
5.5. PropertySource
Reload
This functionality has been deprecated in the 2020.0 release. Please see the Spring Cloud Kubernetes Configuration Watcher controller for an alternative way to achieve the same functionality. |
Some applications may need to detect changes on external property sources and update their internal status to reflect the new configuration.
The reload feature of Spring Cloud Kubernetes is able to trigger an application reload when a related ConfigMap
or
Secret
changes.
By default, this feature is disabled. You can enable it by using the spring.cloud.kubernetes.reload.enabled=true
configuration property (for example, in the application.properties
file).
The following levels of reload are supported (by setting the spring.cloud.kubernetes.reload.strategy
property):
refresh
(default): Only configuration beans annotated with@ConfigurationProperties
or@RefreshScope
are reloaded. This reload level leverages the refresh feature of Spring Cloud Context. -
restart_context
: the whole SpringApplicationContext
is gracefully restarted. Beans are recreated with the new configuration. In order for the restart context functionality to work properly you must enable and expose the restart actuator endpoint
management: endpoint: restart: enabled: true endpoints: web: exposure: include: restart
shutdown
: the SpringApplicationContext
is shut down to activate a restart of the container. When you use this level, make sure that the lifecycle of all non-daemon threads is bound to theApplicationContext
and that a replication controller or replica set is configured to restart the pod.
Assuming that the reload feature is enabled with default settings (refresh
mode), the following bean is refreshed when the config map changes:
@Configuration @ConfigurationProperties(prefix = "bean") public class MyConfig { private String message = "a message that can be changed live"; // getter and setters }
To see that changes effectively happen, you can create another bean that prints the message periodically, as follows
@Component
public class MyBean {
@Autowired
private MyConfig config;
@Scheduled(fixedDelay = 5000)
public void hello() {
System.out.println("The message is: " + config.getMessage());
You can change the message printed by the application by using a ConfigMap
, as follows:
apiVersion: v1
kind: ConfigMap
metadata:
data:
application.properties: |-
bean.message=Hello World!
Any change to the property named bean.message
in the ConfigMap
associated with the pod is reflected in the
output. More generally speaking, changes associated to properties prefixed with the value defined by the prefix
field of the @ConfigurationProperties
annotation are detected and reflected in the application.
Associating a ConfigMap
with a pod is explained earlier in this chapter.
The full example is available in spring-cloud-kubernetes-reload-example
The reload feature supports two operating modes:
* Event (default): Watches for changes in config maps or secrets by using the Kubernetes API (web socket).
Any event produces a re-check on the configuration and, in case of changes, a reload.
The view
role on the service account is required in order to listen for config map changes. A higher level role (such as edit
) is required for secrets
(by default, secrets are not monitored).
* Polling: Periodically re-creates the configuration from config maps and secrets to see if it has changed.
You can configure the polling period by using the spring.cloud.kubernetes.reload.period
property and defaults to 15 seconds.
It requires the same role as the monitored property source.
This means, for example, that using polling on file-mounted secret sources does not require particular privileges.
Enables monitoring of property sources and configuration reload |
Allow monitoring changes in config maps |
Allow monitoring changes in secrets |
The strategy to use when firing a reload ( |
Specifies how to listen for changes in property sources ( |
The period for verifying changes when using the |
Notes:
* You should not use properties under spring.cloud.kubernetes.reload
in config maps or secrets. Changing such properties at runtime may lead to unexpected results.
* Deleting a property or the whole config map does not restore the original state of the beans when you use the refresh
level.
