18. Contributing
Spring Cloud is released under the non-restrictive Apache 2.0 license, and follows a very standard Github development process, using Github tracker for issues and merging pull requests into master. If you want to contribute even something trivial please do not hesitate, but follow the guidelines below.
18.1. Sign the Contributor License Agreement
Before we accept a non-trivial patch or pull request we will need you to sign the Contributor License Agreement. Signing the contributor’s agreement does not grant anyone commit rights to the main repository, but it does mean that we can accept your contributions, and you will get an author credit if we do. Active contributors might be asked to join the core team, and given the ability to merge pull requests.
18.2. Code of Conduct
This project adheres to the Contributor Covenant code of conduct. By participating, you are expected to uphold this code. Please report unacceptable behavior to [email protected].
18.3. Code Conventions and Housekeeping
None of these is essential for a pull request, but they will all help. They can also be added after the original pull request but before a merge.
Use the Spring Framework code format conventions. If you use Eclipse you can import formatter settings using the
eclipse-code-formatter.xml
file from the Spring Cloud Build project. If using IntelliJ, you can use the Eclipse Code Formatter Plugin to import the same file. -
Make sure all new
.java
files to have a simple Javadoc class comment with at least an@author
tag identifying you, and preferably at least a paragraph on what the class is for. -
Add the ASF license header comment to all new
.java
files (copy from existing files in the project) -
Add yourself as an
@author
to the .java files that you modify substantially (more than cosmetic changes). -
Add some Javadocs and, if you change the namespace, some XSD doc elements.
A few unit tests would help a lot as well — someone has to do it.
If no-one else is using your branch, please rebase it against the current master (or other target branch in the main project).
When writing a commit message please follow these conventions, if you are fixing an existing issue please add
Fixes gh-XXXX
at the end of the commit message (where XXXX is the issue number).
18.4. Checkstyle
Spring Cloud Build comes with a set of checkstyle rules. You can find them in the spring-cloud-build-tools
module. The most notable files under the module are:
└── src ├── checkstyle │ └── checkstyle-suppressions.xml (3) └── main └── resources ├── checkstyle-header.txt (2) └── checkstyle.xml (1)
1 | Default Checkstyle rules |
2 | File header setup |
3 | Default suppression rules |
18.4.1. Checkstyle configuration
Checkstyle rules are disabled by default. To add checkstyle to your project just define the following properties and plugins.
<properties> <maven-checkstyle-plugin.failsOnError>true</maven-checkstyle-plugin.failsOnError> (1) <maven-checkstyle-plugin.failsOnViolation>true </maven-checkstyle-plugin.failsOnViolation> (2) <maven-checkstyle-plugin.includeTestSourceDirectory>true </maven-checkstyle-plugin.includeTestSourceDirectory> (3) </properties> <build> <plugins> <plugin> (4) <groupId>io.spring.javaformat</groupId> <artifactId>spring-javaformat-maven-plugin</artifactId> </plugin> <plugin> (5) <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-checkstyle-plugin</artifactId> </plugin> </plugins> <reporting> <plugins> <plugin> (5) <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-checkstyle-plugin</artifactId> </plugin> </plugins> </reporting> </build>
1 | Fails the build upon Checkstyle errors |
2 | Fails the build upon Checkstyle violations |
3 | Checkstyle analyzes also the test sources |
4 | Add the Spring Java Format plugin that will reformat your code to pass most of the Checkstyle formatting rules |
5 | Add checkstyle plugin to your build and reporting phases |
If you need to suppress some rules (e.g. line length needs to be longer), then it’s enough for you to define a file under ${project.root}/src/checkstyle/checkstyle-suppressions.xml
with your suppressions. Example:
<?xml version="1.0"?> <!DOCTYPE suppressions PUBLIC "-//Puppy Crawl//DTD Suppressions 1.1//EN" "https://www.puppycrawl.com/dtds/suppressions_1_1.dtd"> <suppressions> <suppress files=".*ConfigServerApplication\.java" checks="HideUtilityClassConstructor"/> <suppress files=".*ConfigClientWatch\.java" checks="LineLengthCheck"/> </suppressions>
It’s advisable to copy the ${spring-cloud-build.rootFolder}/.editorconfig
and ${spring-cloud-build.rootFolder}/.springformat
to your project. That way, some default formatting rules will be applied. You can do so by running this script:
$ curl https://raw.githubusercontent.com/spring-cloud/spring-cloud-build/master/.editorconfig -o .editorconfig
$ touch .springformat
18.5. IDE setup
18.5.1. Intellij IDEA
In order to setup Intellij you should import our coding conventions, inspection profiles and set up the checkstyle plugin. The following files can be found in the Spring Cloud Build project.
└── src ├── checkstyle │ └── checkstyle-suppressions.xml (3) └── main └── resources ├── checkstyle-header.txt (2) ├── checkstyle.xml (1) └── intellij ├── Intellij_Project_Defaults.xml (4) └── Intellij_Spring_Boot_Java_Conventions.xml (5)
4 | Project defaults for Intellij that apply most of Checkstyle rules |
5 | Project style conventions for Intellij that apply most of Checkstyle rules |
Go to File
→ Settings
→ Editor
→ Code style
. There click on the icon next to the Scheme
section. There, click on the Import Scheme
value and pick the Intellij IDEA code style XML
option. Import the spring-cloud-build-tools/src/main/resources/intellij/Intellij_Spring_Boot_Java_Conventions.xml
file.
Go to File
→ Settings
→ Editor
→ Inspections
. There click on the icon next to the Profile
section. There, click on the Import Profile
and import the spring-cloud-build-tools/src/main/resources/intellij/Intellij_Project_Defaults.xml
file.
To have Intellij work with Checkstyle, you have to install the Checkstyle
plugin. It’s advisable to also install the Assertions2Assertj
to automatically convert the JUnit assertions
Go to File
→ Settings
→ Other settings
→ Checkstyle
. There click on the +
icon in the Configuration file
section. There, you’ll have to define where the checkstyle rules should be picked from. In the image above, we’ve picked the rules from the cloned Spring Cloud Build repository. However, you can point to the Spring Cloud Build’s GitHub repository (e.g. for the checkstyle.xml
: raw.githubusercontent.com/spring-cloud/spring-cloud-build/master/spring-cloud-build-tools/src/main/resources/checkstyle.xml
). We need to provide the following variables:
checkstyle.header.file
- please point it to the Spring Cloud Build’s,spring-cloud-build-tools/src/main/resources/checkstyle-header.txt
file either in your cloned repo or via theraw.githubusercontent.com/spring-cloud/spring-cloud-build/master/spring-cloud-build-tools/src/main/resources/checkstyle-header.txt
URL. -
checkstyle.suppressions.file
- default suppressions. Please point it to the Spring Cloud Build’s,spring-cloud-build-tools/src/checkstyle/checkstyle-suppressions.xml
file either in your cloned repo or via theraw.githubusercontent.com/spring-cloud/spring-cloud-build/master/spring-cloud-build-tools/src/checkstyle/checkstyle-suppressions.xml
URL. -
checkstyle.additional.suppressions.file
- this variable corresponds to suppressions in your local project. E.g. you’re working onspring-cloud-contract
. Then point to theproject-root/src/checkstyle/checkstyle-suppressions.xml
folder. Example forspring-cloud-contract
would be:/home/username/spring-cloud-contract/src/checkstyle/checkstyle-suppressions.xml
Remember to set the Scan Scope to All sources since we apply checkstyle rules for production and test sources.
