For the latest stable version, please use spring-cloud-function 4.2.2! |
Deploying a Packaged Function
Spring Cloud Function provides a "deployer" library that allows you to launch a jar file (or exploded archive, or set of jar files) with an isolated class loader and expose the functions defined in it. This is quite a powerful tool that would allow you to, for instance, adapt a function to a range of different input-output adapters without changing the target jar file. Serverless platforms often have this kind of feature built in, so you could see it as a building block for a function invoker in such a platform (indeed the Riff Java function invoker uses this library).
The standard entry point is to add spring-cloud-function-deployer
to the classpath, the deployer kicks in and looks for some configuration to tell it where to find the function jar.
<dependency>
<artifactId>spring-cloud-function-deployer</artifactId>
<version>${spring.cloud.function.version}</version>
</dependency>
At a minimum the user has to provide a spring.cloud.function.location
which is a URL or resource location for the archive containing
the functions. It can optionally use a maven:
prefix to locate the artifact via a dependency lookup (see FunctionProperties
for complete details). A Spring Boot application is bootstrapped from the jar file, using the MANIFEST.MF
to locate a start class, so
that a standard Spring Boot fat jar works well, for example. If the target jar can be launched successfully then the result is a function
registered in the main application’s FunctionCatalog
. The registered function can be applied by code in the main application, even though
it was created in an isolated class loader (by default).
Here is the example of deploying a JAR which contains an 'uppercase' function and invoking it .
@SpringBootApplication
public class DeployFunctionDemo {
ApplicationContext context = SpringApplication.run(DeployFunctionDemo.class,
"--spring.cloud.function.location=..../target/uppercase-0.0.1-SNAPSHOT.jar",
"--spring.cloud.function.definition=uppercase");
FunctionCatalog catalog = context.getBean(FunctionCatalog.class);
Function<String, String> function = catalog.lookup("uppercase");
System.out.println(function.apply("hello"));
And here is the example using Maven URI (taken from one of the tests in FunctionDeployerTests
String[] args = new String[] {
"--spring.cloud.function.location=maven://oz.demo:demo-uppercase:0.0.1-SNAPSHOT",
"--spring.cloud.function.function-class=oz.demo.uppercase.MyFunction" };
ApplicationContext context = SpringApplication.run(DeployerApplication.class, args);
Function<String, String> function = catalog.lookup("myFunction");
assertThat(function.apply("bob")).isEqualTo("BOB");
Keep in mind that Maven resource such as local and remote repositories, user, password and more are resolved using default MavenProperties which
effectively use local defaults and will work for majority of cases. However if you need to customize you can simply provide a bean of type
MavenProperties
where you can set additional properties (see example below).
public MavenProperties mavenProperties() {
MavenProperties properties = new MavenProperties();
properties.setLocalRepository("target/it/");
return properties;
Supported Packaging Scenarios
Currently Spring Cloud Function supports several packaging scenarios to give you the most flexibility when it comes to deploying functions.
Simple JAR
This packaging option implies no dependency on anything related to Spring. For example; Consider that such JAR contains the following class:
public class UpperCaseFunction implements Function<String, String> {
public String apply(String value) {
return value.toUpperCase();
All you need to do is specify location
and function-class
properties when deploying such package:
--spring.cloud.function.location=target/it/simplestjar/target/simplestjar-1.0.0.RELEASE.jar
--spring.cloud.function.function-class=function.example.UpperCaseFunction
It’s conceivable in some cases that you might want to package multiple functions together. For such scenarios you can use
property to list several classes delimiting them by ;
For example,
--spring.cloud.function.function-class=function.example.UpperCaseFunction;function.example.ReverseFunction
Here we are identifying two functions to deploy, which we can now access in function catalog by name (e.g., catalog.lookup("reverseFunction");
For more details please reference the complete sample available here. You can also find a corresponding test in FunctionDeployerTests.
Component Scanning *
Since version 3.1.4 you can simplify your configuration thru component scanning feature described in [Function Component Scan]. If you place your functional class in
package named functions
, you can omit spring.cloud.function.function-class
property as framework will auto-discover functional classes loading them in function catalog.
Keep in mind the naming convention to follow when doing function lookup. For example function class functions.UpperCaseFunction
will be available in FunctionCatalog
under the name upperCaseFunction
Spring Boot JAR
This packaging option implies there is a dependency on Spring Boot and that the JAR was generated as Spring Boot JAR. That said, given that the deployed JAR runs in the isolated class loader, there will not be any version conflict with the Spring Boot version used by the actual deployer. For example; Consider that such JAR contains the following class (which could have some additional Spring dependencies providing Spring/Spring Boot is on the classpath):
As before all you need to do is specify location
and function-class
Spring Boot Application
This packaging option implies your JAR is complete stand alone Spring Boot application with functions as managed Spring beans. As before there is an obvious assumption that there is a dependency on Spring Boot and that the JAR was generated as Spring Boot JAR. That said, given that the deployed JAR runs in the isolated class loader, there will not be any version conflict with the Spring Boot version used by the actual deployer. For example; Consider that such JAR contains the following class:
public class SimpleFunctionAppApplication {
SpringApplication.run(SimpleFunctionAppApplication.class, args);
public Function<String, String> uppercase() {
return value -> value.toUpperCase();
Given that we’re effectively dealing with another Spring Application context and that functions are spring managed beans,
in addition to the location
property we also specify definition
property instead of function-class
--spring.cloud.function.location=target/it/bootapp/target/bootapp-1.0.0.RELEASE-exec.jar
This particular deployment option may or may not have Spring Cloud Function on it’s classpath. From the deployer perspective this doesn’t matter. |
