Configuration
8. Maven
If you want to override specific Maven configuration properties (remote repositories, proxies, and others) or run the Data Flow Server behind a proxy, you need to specify those properties as command-line arguments when you start the Data Flow Server, as shown in the following example:
$ java -jar spring-cloud-dataflow-server-2.9.6.jar --spring.config.additional-location=/home/joe/maven.yml
The preceding command assumes a maven.yaml
similar to the following:
maven:
localRepository: mylocal
remote-repositories:
repo1:
url: https://repo1
auth:
username: user1
password: pass1
snapshot-policy:
update-policy: daily
checksum-policy: warn
release-policy:
update-policy: never
checksum-policy: fail
repo2:
url: https://repo2
policy:
update-policy: always
proxy:
host: proxy1
port: "9010"
auth:
username: proxyuser1
password: proxypass1
By default, the protocol is set to http
. You can omit the auth properties if the proxy does not need a username and password. Also, by default, the maven localRepository
is set to ${user.home}/.m2/repository/
As shown in the preceding example, you can specify the remote repositories along with their authentication (if needed). If the remote repositories are behind a proxy, you can specify the proxy properties, as shown in the preceding example.
You can specify the repository policies for each remote repository configuration, as shown in the preceding example.
The key policy
is applicable to both the snapshot
and the release
repository policies.
See the Repository Policies topic for the list of supported repository policies.
As these are Spring Boot @ConfigurationProperties
you need to specify by adding them to the SPRING_APPLICATION_JSON
environment variable. The following example shows how the JSON is structured:
$ SPRING_APPLICATION_JSON='
"maven": {
"local-repository": null,
"remote-repositories": {
"repo1": {
"url": "https://repo1",
"auth": {
"username": "repo1user",
"password": "repo1pass"
"repo2": {
"url": "https://repo2"
"proxy": {
"host": "proxyhost",
"port": 9018,
"auth": {
"username": "proxyuser",
"password": "proxypass"
8.1. Wagon
There is a limited support for using Wagon
transport with Maven. Currently, this
exists to support preemptive authentication with http
-based repositories
and needs to be enabled manually.
Wagon-based http
transport is enabled by setting the maven.use-wagon
property
to true
. Then you can enable preemptive authentication for each remote
repository. Configuration loosely follows the similar patterns found in
HttpClient HTTP Wagon.
At the time of this writing, documentation in Maven’s own site is slightly misleading
and missing most of the possible configuration options.
The maven.remote-repositories.<repo>.wagon.http
namespace contains all Wagon
http
related settings, and the keys directly under it map to supported http
methods — namely, all
, put
, get
and head
, as in Maven’s own configuration.
Under these method configurations, you can then set various options, such as
use-preemptive
. A simpl preemptive configuration to send an auth
header with all requests to a specified remote repository would look like the following example:
maven:
use-wagon: true
springRepo:
url: https://repo.example.org
wagon:
http:
all:
use-preemptive: true
auth:
username: user
password: password
Instead of configuring all
methods, you can tune settings for get
and head
requests only, as follows:
maven:
use-wagon: true
springRepo:
wagon:
http:
get:
head:
use-default-headers: true
connection-timeout: 1000
read-timeout: 1000
headers:
sample1: sample2
params:
http.socket.timeout: 1000
http.connection.stalecheck: true
auth:
username: user
password: password
There are settings for use-default-headers
, connection-timeout
read-timeout
, request headers
, and HttpClient params
. For more about parameters,
see Wagon ConfigurationUtils.
9. Security
By default, the Data Flow server is unsecured and runs on an unencrypted HTTP connection. You can secure your REST endpoints as well as the Data Flow Dashboard by enabling HTTPS and requiring clients to authenticate with OAuth 2.0.
Appendix Azure contains more information how to setup Azure Active Directory integration. |
By default, the REST endpoints (administration, management, and health) as well as the Dashboard UI do not require authenticated access. |
While you can theoretically choose any OAuth provider in conjunction with Spring Cloud Data Flow, we recommend using the CloudFoundry User Account and Authentication (UAA) Server.
Not only is the UAA OpenID certified and is used by Cloud Foundry, but you can also use it in local stand-alone deployment scenarios. Furthermore, the UAA not only provides its own user store, but it also provides comprehensive LDAP integration.
9.1. Enabling HTTPS
By default, the dashboard, management, and health endpoints use HTTP as a transport.
You can switch to HTTPS by adding a certificate to your configuration in
application.yml
server:
port: 8443 (1)
ssl:
key-alias: yourKeyAlias (2)
key-store: path/to/keystore (3)
key-store-password: yourKeyStorePassword (4)
key-password: yourKeyPassword (5)
trust-store: path/to/trust-store (6)
trust-store-password: yourTrustStorePassword (7)
1 | As the default port is 9393 , you may choose to change the port to a more common HTTPs-typical port. |
2 | The alias (or name) under which the key is stored in the keystore. |
3 | The path to the keystore file. You can also specify classpath resources, by using the classpath prefix - for example: classpath:path/to/keystore . |
4 | The password of the keystore. |
5 | The password of the key. |
6 | The path to the truststore file. You can also specify classpath resources, by using the classpath prefix - for example: classpath:path/to/trust-store |
7 | The password of the trust store. |
If HTTPS is enabled, it completely replaces HTTP as the protocol over which the REST endpoints and the Data Flow Dashboard interact. Plain HTTP requests fail. Therefore, make sure that you configure your Shell accordingly. |
Using Self-Signed Certificates
For testing purposes or during development, it might be convenient to create self-signed certificates. To get started, execute the following command to create a certificate:
$ keytool -genkey -alias dataflow -keyalg RSA -keystore dataflow.keystore \
-validity 3650 -storetype JKS \
-dname "CN=localhost, OU=Spring, O=Pivotal, L=Kailua-Kona, ST=HI, C=US" (1)
-keypass dataflow -storepass dataflow
1 | CN is the important parameter here. It should match the domain you are trying to access - for example, localhost . |
Then add the following lines to your application.yml
file:
server:
port: 8443
ssl:
enabled: true
key-alias: dataflow
key-store: "/your/path/to/dataflow.keystore"
key-store-type: jks
key-store-password: dataflow
key-password: dataflow
This is all you need to do for the Data Flow Server. Once you start the server,
you should be able to access it at localhost:8443/
As this is a self-signed certificate, you should hit a warning in your browser, which
you need to ignore.
Never use self-signed certificates in production. |
Self-Signed Certificates and the Shell
By default, self-signed certificates are an issue for the shell, and additional steps are necessary to make the shell work with self-signed certificates. Two options are available:
Add the self-signed certificate to the JVM truststore.
Skip certificate validation.
Adding the Self-signed Certificate to the JVM Truststore
In order to use the JVM truststore option, you need to export the previously created certificate from the keystore, as follows:
$ keytool -export -alias dataflow -keystore dataflow.keystore -file dataflow_cert -storepass dataflow
Next, you need to create a truststore that the shell can use, as follows:
$ keytool -importcert -keystore dataflow.truststore -alias dataflow -storepass dataflow -file dataflow_cert -noprompt
Now you are ready to launch the Data Flow Shell with the following JVM arguments:
$ java -Djavax.net.ssl.trustStorePassword=dataflow \
-Djavax.net.ssl.trustStore=/path/to/dataflow.truststore \
-Djavax.net.ssl.trustStoreType=jks \
-jar spring-cloud-dataflow-shell-2.9.6.jar
If you run into trouble establishing a connection over SSL, you can enable additional
logging by using and setting the |
Do not forget to target the Data Flow Server with the following command:
dataflow:> dataflow config server https://localhost:8443/
Skipping Certificate Validation
Alternatively, you can also bypass the certification validation by providing the
optional --dataflow.skip-ssl-validation=true
command-line parameter.
If you set this command-line parameter, the shell accepts any (self-signed) SSL certificate.
If possible, you should avoid using this option. Disabling the trust manager defeats the purpose of SSL and makes your application vulnerable to man-in-the-middle attacks. |
9.2. Authentication by using OAuth 2.0
To support authentication and authorization, Spring Cloud Data Flow uses OAuth 2.0. It lets you integrate Spring Cloud Data Flow into Single Sign On (SSO) environments.
As of Spring Cloud Data Flow 2.0, OAuth2 is the only mechanism for providing authentication and authorization. |
The following OAuth2 Grant Types are used:
Authorization Code: Used for the GUI (browser) integration. Visitors are redirected to your OAuth Service for authentication
Password: Used by the shell (and the REST integration), so visitors can log in with username and password
Client Credentials: Retrieves an access token directly from your OAuth provider and passes it to the Data Flow server by using the Authorization HTTP header
Currently, Spring Cloud Data Flow uses opaque tokens and not transparent tokens (JWT). |
You can access the REST endpoints in two ways:
Basic authentication, which uses the Password Grant Type to authenticate with your OAuth2 service
Access token, which uses the Client Credentials Grant Type
When you set up authentication, you really should enable HTTPS as well, especially in production environments. |
You can turn on OAuth2 authentication by adding the following to application.yml
or by setting
environment variables. The following example shows the minimal setup needed for
CloudFoundry User Account and Authentication (UAA) Server:
spring:
security:
oauth2: (1)
client:
registration:
uaa: (2)
client-id: myclient
client-secret: mysecret
redirect-uri: '{baseUrl}/login/oauth2/code/{registrationId}'
authorization-grant-type: authorization_code
scope:
- openid (3)
provider:
uaa:
jwk-set-uri: http://uaa.local:8080/uaa/token_keys
token-uri: http://uaa.local:8080/uaa/oauth/token
user-info-uri: http://uaa.local:8080/uaa/userinfo (4)
user-name-attribute: user_name (5)
authorization-uri: http://uaa.local:8080/uaa/oauth/authorize
resourceserver:
opaquetoken:
introspection-uri: http://uaa.local:8080/uaa/introspect (6)
client-id: dataflow
client-secret: dataflow
1 | Providing this property activates OAuth2 security. |
2 | The provider ID. You can specify more than one provider. |
3 | As the UAA is an OpenID provider, you must at least specify the openid scope.
If your provider also provides additional scopes to control the role assignments,
you must specify those scopes here as well. |
4 | OpenID endpoint. Used to retrieve user information such as the username. Mandatory. |
5 | The JSON property of the response that contains the username. |
6 | Used to introspect and validate a directly passed-in token. Mandatory. |
You can verify that basic authentication is working properly by using curl, as follows:
curl -u myusername:mypassword http://localhost:9393/ -H 'Accept: application/json'
As a result, you should see a list of available REST endpoints.
When you access the Root URL with a web browser and
security enabled, you are redirected to the Dashboard UI. To see the
list of REST endpoints, specify the application/json Accept header. Also be sure
to add the Accept header by using tools such as
Postman (Chrome)
or RESTClient (Firefox).
Besides Basic Authentication, you can also provide an access token, to access the REST API. To do so, retrieve an OAuth2 Access Token from your OAuth2 provider and pass that access token to the REST Api by using the Authorization HTTP header, as follows:
$ curl -H "Authorization: Bearer <ACCESS_TOKEN>" http://localhost:9393/ -H 'Accept: application/json'
9.3. Customizing Authorization
The preceding content mostly deals with authentication — that is, how to assess the identity of the user. In this section, we discuss the available authorization options — that is, who can do what.
The authorization rules are defined in dataflow-server-defaults.yml
(part of
the Spring Cloud Data Flow Core module).
Because the determination of security roles is environment-specific,
Spring Cloud Data Flow, by default, assigns all roles to authenticated OAuth2
users. The DefaultDataflowAuthoritiesExtractor
class is used for that purpose.
Alternatively, you can have Spring Cloud Data Flow map OAuth2 scopes to Data Flow roles by
setting the boolean property map-oauth-scopes
for your provider to true
(the default is false
For example, if your provider’s ID is uaa
, the property would be
spring.cloud.dataflow.security.authorization.provider-role-mappings.uaa.map-oauth-scopes
For more details, see the chapter on Role Mappings.
You can also customize the role-mapping behavior by providing your own Spring bean definition that
extends Spring Cloud Data Flow’s AuthorityMapper
interface. In that case,
the custom bean definition takes precedence over the default one provided by
Spring Cloud Data Flow.
The default scheme uses seven roles to protect the REST endpoints that Spring Cloud Data Flow exposes:
ROLE_CREATE: For anything that involves creating, such as creating streams or tasks
ROLE_DEPLOY: For deploying streams or launching tasks
ROLE_DESTROY: For anything that involves deleting streams, tasks, and so on.
ROLE_MANAGE: For Boot management endpoints
ROLE_MODIFY: For anything that involves mutating the state of the system
ROLE_SCHEDULE: For scheduling related operation (such as scheduling a task)
ROLE_VIEW: For anything that relates to retrieving state
As mentioned earlier in this section, all authorization-related default settings are specified
, which is part of the Spring Cloud Data Flow Core
Module. Nonetheless, you can override those settings, if desired — for example,
in application.yml
. The configuration takes the form of a YAML list (as some
rules may have precedence over others). Consequently, you need to copy and paste
the whole list and tailor it to your needs (as there is no way to merge lists).
Always refer to your version of the application.yml file, as the following snippet may be outdated.
The default rules are as follows:
spring:
cloud:
dataflow:
security:
authorization:
enabled: true
loginUrl: "/"
permit-all-paths: "/authenticate,/security/info,/assets/**,/dashboard/logout-success-oauth.html,/favicon.ico"
rules:
# About
- GET /about => hasRole('ROLE_VIEW')
# Audit
- GET /audit-records => hasRole('ROLE_VIEW')
- GET /audit-records/** => hasRole('ROLE_VIEW')
# Boot Endpoints
- GET /management/** => hasRole('ROLE_MANAGE')
# Apps
- GET /apps => hasRole('ROLE_VIEW')
- GET /apps/** => hasRole('ROLE_VIEW')
- DELETE /apps/** => hasRole('ROLE_DESTROY')
- POST /apps => hasRole('ROLE_CREATE')
- POST /apps/** => hasRole('ROLE_CREATE')
- PUT /apps/** => hasRole('ROLE_MODIFY')
# Completions
- GET /completions/** => hasRole('ROLE_VIEW')
# Job Executions & Batch Job Execution Steps && Job Step Execution Progress
- GET /jobs/executions => hasRole('ROLE_VIEW')
- PUT /jobs/executions/** => hasRole('ROLE_MODIFY')
- GET /jobs/executions/** => hasRole('ROLE_VIEW')
- GET /jobs/thinexecutions => hasRole('ROLE_VIEW')
# Batch Job Instances
- GET /jobs/instances => hasRole('ROLE_VIEW')
- GET /jobs/instances/* => hasRole('ROLE_VIEW')
# Running Applications
- GET /runtime/streams => hasRole('ROLE_VIEW')
- GET /runtime/streams/** => hasRole('ROLE_VIEW')
- GET /runtime/apps => hasRole('ROLE_VIEW')
- GET /runtime/apps/** => hasRole('ROLE_VIEW')
# Stream Definitions
- GET /streams/definitions => hasRole('ROLE_VIEW')
- GET /streams/definitions/* => hasRole('ROLE_VIEW')
- GET /streams/definitions/*/related => hasRole('ROLE_VIEW')
- POST /streams/definitions => hasRole('ROLE_CREATE')
- DELETE /streams/definitions/* => hasRole('ROLE_DESTROY')
- DELETE /streams/definitions => hasRole('ROLE_DESTROY')
# Stream Deployments
- DELETE /streams/deployments/* => hasRole('ROLE_DEPLOY')
- DELETE /streams/deployments => hasRole('ROLE_DEPLOY')
- POST /streams/deployments/** => hasRole('ROLE_MODIFY')
- GET /streams/deployments/** => hasRole('ROLE_VIEW')
# Stream Validations
- GET /streams/validation/ => hasRole('ROLE_VIEW')
- GET /streams/validation/* => hasRole('ROLE_VIEW')
# Stream Logs
- GET /streams/logs/* => hasRole('ROLE_VIEW')
# Task Definitions
- POST /tasks/definitions => hasRole('ROLE_CREATE')
- DELETE /tasks/definitions/* => hasRole('ROLE_DESTROY')
- GET /tasks/definitions => hasRole('ROLE_VIEW')
- GET /tasks/definitions/* => hasRole('ROLE_VIEW')
# Task Executions
- GET /tasks/executions => hasRole('ROLE_VIEW')
- GET /tasks/executions/* => hasRole('ROLE_VIEW')
- POST /tasks/executions => hasRole('ROLE_DEPLOY')
- POST /tasks/executions/* => hasRole('ROLE_DEPLOY')
- DELETE /tasks/executions/* => hasRole('ROLE_DESTROY')
# Task Schedules
- GET /tasks/schedules => hasRole('ROLE_VIEW')
- GET /tasks/schedules/* => hasRole('ROLE_VIEW')
- GET /tasks/schedules/instances => hasRole('ROLE_VIEW')
- GET /tasks/schedules/instances/* => hasRole('ROLE_VIEW')
- POST /tasks/schedules => hasRole('ROLE_SCHEDULE')
- DELETE /tasks/schedules/* => hasRole('ROLE_SCHEDULE')
# Task Platform Account List */
- GET /tasks/platforms => hasRole('ROLE_VIEW')
# Task Validations
- GET /tasks/validation/ => hasRole('ROLE_VIEW')
- GET /tasks/validation/* => hasRole('ROLE_VIEW')
# Task Logs
- GET /tasks/logs/* => hasRole('ROLE_VIEW')
# Tools
- POST /tools/** => hasRole('ROLE_VIEW')
The format of each line is the following:
HTTP_METHOD URL_PATTERN '=>' SECURITY_ATTRIBUTE
where:
HTTP_METHOD is one HTTP method (such as PUT or GET), capital case.
URL_PATTERN is an Ant-style URL pattern.
SECURITY_ATTRIBUTE is a SpEL expression. See Expression-Based Access Control.
Each of those is separated by one or whitespace characters (spaces, tabs, and so on).
Be mindful that the above is a YAML list, not a map (thus the use of '-' dashes
at the start of each line) that lives under the spring.cloud.dataflow.security.authorization.rules
key.
Authorization — Shell and Dashboard Behavior
When security is enabled, the dashboard and the shell are role-aware, meaning that, depending on the assigned roles, not all functionality may be visible.
For instance, shell commands for which the user does not have the necessary roles are marked as unavailable.
Currently, the shell’s |
Conversely, for the Dashboard, the UI does not show pages or page elements for which the user is not authorized.
Securing the Spring Boot Management Endpoints
Spring Boot HTTP Management Endpoints
are secured in the same way as the other REST endpoints. The management REST endpoints
are available under /management
and require the MANAGEMENT
role.
The default configuration in dataflow-server-defaults.yml
is as follows:
management:
endpoints:
web:
base-path: /management
security:
roles: MANAGE
Currently, you should not customize the default management path. |
9.4. Setting up UAA Authentication
For local deployment scenarios, we recommend using the CloudFoundry User Account and Authentication (UAA) Server, which is OpenID certified. While the UAA is used by Cloud Foundry, it is also a fully featured stand alone OAuth2 server with enterprise features, such as LDAP integration.
Requirements
You need to check out, build and run UAA. To do so, make sure that you:
Use Java 8.
Have Git installed.
Have the CloudFoundry UAA Command Line Client installed.
Use a different host name for UAA when running on the same machine — for example,
uaa/
If you run into issues installing uaac, you may have to set the GEM_HOME
environment
variable:
export GEM_HOME="$HOME/.gem"
You should also ensure that ~/.gem/gems/cf-uaac-4.2.0/bin
has been added to your path.
Prepare UAA for JWT
As the UAA is an OpenID provider and uses JSON Web Tokens (JWT), it needs to have a private key for signing those JWTs:
openssl genrsa -out signingkey.pem 2048
openssl rsa -in signingkey.pem -pubout -out verificationkey.pem
export JWT_TOKEN_SIGNING_KEY=$(cat signingkey.pem)
export JWT_TOKEN_VERIFICATION_KEY=$(cat verificationkey.pem)
Later, once the UAA is started, you can see the keys when you access uaa:8080/uaa/token_keys
Here, the uaa in the URL uaa:8080/uaa/token_keys is the hostname.
Download and Start UAA
To download and install UAA, run the following commands:
git clone https://github.com/pivotal/uaa-bundled.git
cd uaa-bundled
./mvnw clean install
java -jar target/uaa-bundled-1.0.0.BUILD-SNAPSHOT.jar
The configuration of the UAA is driven by a YAML file uaa.yml
, or you can script the configuration
using the UAA Command Line Client:
uaac target http://uaa:8080/uaa
uaac token client get admin -s adminsecret
uaac client add dataflow \
--name dataflow \
--secret dataflow \
--scope cloud_controller.read,cloud_controller.write,openid,password.write,scim.userids,sample.create,sample.view,dataflow.create,dataflow.deploy,dataflow.destroy,dataflow.manage,dataflow.modify,dataflow.schedule,dataflow.view \
--authorized_grant_types password,authorization_code,client_credentials,refresh_token \
--authorities uaa.resource,dataflow.create,dataflow.deploy,dataflow.destroy,dataflow.manage,dataflow.modify,dataflow.schedule,dataflow.view,sample.view,sample.create\
--redirect_uri http://localhost:9393/login \
--autoapprove openid
uaac group add "sample.view"
uaac group add "sample.create"
uaac group add "dataflow.view"
uaac group add "dataflow.create"
uaac user add springrocks -p mysecret --emails [email protected]
uaac user add vieweronly -p mysecret --emails [email protected]
uaac member add "sample.view" springrocks
uaac member add "sample.create" springrocks
uaac member add "dataflow.view" springrocks
uaac member add "dataflow.create" springrocks
uaac member add "sample.view" vieweronly
The preceding script sets up the dataflow client as well as two users:
User springrocks has have both scopes:
sample.view
andsample.create
User vieweronly has only one scope:
sample.view
Once added, you can quickly double-check that the UAA has the users created:
curl -v -d"username=springrocks&password=mysecret&client_id=dataflow&grant_type=password" -u "dataflow:dataflow" http://uaa:8080/uaa/oauth/token -d 'token_format=opaque'
The preceding command should produce output similar to the following:
* Trying 127.0.0.1...
* TCP_NODELAY set
* Connected to uaa (127.0.0.1) port 8080 (#0)
* Server auth using Basic with user 'dataflow'
> POST /uaa/oauth/token HTTP/1.1
> Host: uaa:8080
> Authorization: Basic ZGF0YWZsb3c6ZGF0YWZsb3c=
> User-Agent: curl/7.54.0
> Accept: */*
> Content-Length: 97
> Content-Type: application/x-www-form-urlencoded
* upload completely sent off: 97 out of 97 bytes
< HTTP/1.1 200
< Cache-Control: no-store
< Pragma: no-cache
< X-XSS-Protection: 1; mode=block
< X-Frame-Options: DENY
< X-Content-Type-Options: nosniff
< Content-Type: application/json;charset=UTF-8
< Transfer-Encoding: chunked
< Date: Thu, 31 Oct 2019 21:22:59 GMT
* Connection #0 to host uaa left intact
{"access_token":"0329c8ecdf594ee78c271e022138be9d","token_type":"bearer","id_token":"eyJhbGciOiJSUzI1NiIsImprdSI6Imh0dHBzOi8vbG9jYWxob3N0OjgwODAvdWFhL3Rva2VuX2tleXMiLCJraWQiOiJsZWdhY3ktdG9rZW4ta2V5IiwidHlwIjoiSldUIn0.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.bqYvicyCPB5cIIu_2HEe5_c7nSGXKw7B8-reTvyYjOQ2qXSMq7gzS4LCCQ-CMcb4IirlDaFlQtZJSDE-_UsM33-ThmtFdx--TujvTR1u2nzot4Pq5A_ThmhhcCB21x6-RNNAJl9X9uUcT3gKfKVs3gjE0tm2K1vZfOkiGhjseIbwht2vBx0MnHteJpVW6U0pyCWG_tpBjrNBSj9yLoQZcqrtxYrWvPHaa9ljxfvaIsOnCZBGT7I552O1VRHWMj1lwNmRNZy5koJFPF7SbhiTM8eLkZVNdR3GEiofpzLCfoQXrr52YbiqjkYT94t3wz5C6u1JtBtgc2vq60HmR45bvg","refresh_token":"6ee95d017ada408697f2d19b04f7aa6c-r","expires_in":43199,"scope":"scim.userids openid sample.create cloud_controller.read password.write cloud_controller.write sample.view","jti":"0329c8ecdf594ee78c271e022138be9d"}
By using the token_format
parameter, you can request the token to be either:
opaque
jwt
10. Configuration - Local
10.1. Feature Toggles
Spring Cloud Data Flow Server offers specific set of features that can be enabled/disabled when launching. These features include all the lifecycle operations and REST endpoints (server and client implementations, including the shell and the UI) for:
Streams (requires Skipper)
Tasks
Task Scheduler
One can enable and disable these features by setting the following boolean properties when launching the Data Flow server:
spring.cloud.dataflow.features.streams-enabled
spring.cloud.dataflow.features.tasks-enabled
spring.cloud.dataflow.features.schedules-enabled
By default, stream (requires Skipper), and tasks are enabled and Task Scheduler is disabled by default.
The REST /about
endpoint provides information on the features that have been enabled and disabled.
10.2. Database
A relational database is used to store stream and task definitions as well as the state of executed tasks. Spring Cloud Data Flow provides schemas for H2, MySQL, Oracle, PostgreSQL, Db2, and SQL Server. The schema is automatically created when the server starts.
By default, Spring Cloud Data Flow offers an embedded instance of the H2 database. The H2 database is good for development purposes but is not recommended for production use.
H2 database is not supported as an external mode. |
The JDBC drivers for MySQL (through the MariaDB driver), PostgreSQL, SQL Server, and embedded H2 are available without additional configuration. If you are using any other database, then you need to put the corresponding JDBC driver jar on the classpath of the server.
The database properties can be passed as environment variables or command-line arguments to the Data Flow Server.
10.2.1. MySQL
The following example shows how to define a MySQL database connection using MariaDB driver.
java -jar spring-cloud-dataflow-server/target/spring-cloud-dataflow-server-2.9.6.jar \
--spring.datasource.url=jdbc:mysql://localhost:3306/mydb \
--spring.datasource.username= \
--spring.datasource.password= \
--spring.datasource.driver-class-name=org.mariadb.jdbc.Driver
MySQL versions up to 5.7 can be used with a MariaDB driver. Starting from version 8.0 MySQL’s own driver has to be used.
--spring.datasource.driver-class-name=com.mysql.jdbc.Driver
Due to licensing restrictions we’re unable to bundle MySQL driver. You need to add it to server’s classpath yourself. |
10.2.2. MariaDB
The following example shows how to define a MariaDB database connection with command Line arguments
--spring.datasource.url=jdbc:mariadb://localhost:3306/mydb?useMysqlMetadata=true \
Starting with MariaDB v2.4.1 connector release, it is required to also add useMysqlMetadata=true
to the JDBC URL. This is a required workaround until when MySQL and MariaDB entirely switch as two
different databases.
MariaDB version 10.3 introduced a support for real database sequences which is yet another breaking change while toolings around these databases fully support MySQL and MariaDB as a separate database types. Workaround is to use older hibernate dialect which doesn’t try to use sequences.
--spring.jpa.properties.hibernate.dialect=org.hibernate.dialect.MariaDB102Dialect \
10.2.3. PostgreSQL
The following example shows how to define a PostgreSQL database connection with command line arguments:
--spring.datasource.url=jdbc:postgresql://localhost:5432/mydb \
--spring.datasource.driver-class-name=org.postgresql.Driver
10.2.4. SQL Server
The following example shows how to define a SQL Server database connection with command line arguments:
--spring.datasource.url='jdbc:sqlserver://localhost:1433;databaseName=mydb' \
--spring.datasource.driver-class-name=com.microsoft.sqlserver.jdbc.SQLServerDriver
10.2.5. Db2
The following example shows how to define a Db2 database connection with command line arguments:
--spring.datasource.url=jdbc:db2://localhost:50000/mydb \
--spring.datasource.driver-class-name=com.ibm.db2.jcc.DB2Driver
Due to licensing restrictions we’re unable to bundle Db2 driver. You need to add it to server’s classpath yourself. |
10.2.6. Oracle
The following example shows how to define a Oracle database connection with command line arguments:
--spring.datasource.url=jdbc:oracle:thin:@localhost:1521/MYDB \
--spring.datasource.driver-class-name=oracle.jdbc.OracleDriver
Due to licensing restrictions we’re unable to bundle Oracle driver. You need to add it to server’s classpath yourself. |
10.2.7. Adding a Custom JDBC Driver
To add a custom driver for the database (for example, Oracle), you should rebuild the Data Flow Server and add the dependency to the Maven pom.xml
file.
You need to modify the maven pom.xml
of spring-cloud-dataflow-server
module.
There are GA release tags in GitHub repository, so you can switch to desired GA tags to add the drivers on the production-ready codebase.
To add a custom JDBC driver dependency for the Spring Cloud Data Flow server:
Select the tag that corresponds to the version of the server you want to rebuild and clone the github repository.
Edit the spring-cloud-dataflow-server/pom.xml and, in the
dependencies
section, add the dependency for the database driver required. In the following example , an Oracle driver has been chosen:
<dependencies>
<dependency>
<groupId>com.oracle.jdbc</groupId>
<artifactId>ojdbc8</artifactId>
<version>12.2.0.1</version>
</dependency>
</dependencies>
Build the application as described in Building Spring Cloud Data Flow
You can also provide default values when rebuilding the server by adding the necessary properties to the dataflow-server.yml file, as shown in the following example for PostgreSQL:
spring:
datasource:
url: jdbc:postgresql://localhost:5432/mydb
username: myuser
password: mypass
driver-class-name:org.postgresql.Driver
Alternatively, you can build a custom Spring Cloud Data Flow server with your build files. There are examples of a custom server builds in our samples repo if there is a need to add a driver jars.
10.2.8. Schema Handling
On default database schema is managed with Flyway which is convenient if it’s possible to give enough permissions to a database user.
Here’s a description what happens when Skipper server is started:
Flyway checks if
flyway_schema_history
table exists. -
Does a baseline(to version 1) if schema is not empty as Dataflow tables may be in place if a shared DB is used.
If schema is empty, flyway assumes to start from a scratch.
Goes through all needed schema migrations.
Here’s a description what happens when Dataflow server is started:
Flyway checks if
flyway_schema_history_dataflow
table exists. -
Does a baseline(to version 1) if schema is not empty as Skipper tables may be in place if a shared DB is used.
Due to historical reasons, if we detect that schema is from 1.7.x line we convert these to structures needed from 2.0.x onwards and fully continue with flyway.
We have schema ddl’s in our source code
schemas
which can be used manually if Flyway is disabled by using configuration
10.3. Deployer Properties
You can use the following configuration properties of the Local deployer to customize how Streams and Tasks are deployed.
When deploying using the Data Flow shell, you can use the syntax deployer.<appName>.local.<deployerPropertyName>
. See below for an example shell usage.
These properties are also used when configuring Local Task Platforms in the Data Flow server and local platforms in Skipper for deploying Streams.
Deployer Property Name | Description | Default Value |
workingDirectoriesRoot |
Directory in which all created processes will run and create log files. |
java.io.tmpdir |
envVarsToInherit |
Array of regular expression patterns for environment variables that are passed to launched applications. |
<"TMP", "LANG", "LANGUAGE", "LC_.*", "PATH", "SPRING_APPLICATION_JSON"> on windows and <"TMP", "LANG", "LANGUAGE", "LC_.*", "PATH"> on Unix |
deleteFilesOnExit |
Whether to delete created files and directories on JVM exit. |
true |
javaCmd |
Command to run java |
java |
shutdownTimeout |
Max number of seconds to wait for app shutdown. |
30 |
javaOpts |
The Java Options to pass to the JVM, e.g -Dtest=foo |
<none> |
inheritLogging |
allow logging to be redirected to the output stream of the process that triggered child process. |
false |
debugPort |
Port for remote debugging |
<none> |
As an example, to set Java options for the time application in the ticktock
stream, use the following stream deployment properties.
dataflow:> stream create --name ticktock --definition "time --server.port=9000 | log"
dataflow:> stream deploy --name ticktock --properties "deployer.time.local.javaOpts=-Xmx2048m -Dtest=foo"
As a convenience, you can set the deployer.memory
property to set the Java option -Xmx
dataflow:> stream deploy --name ticktock --properties "deployer.time.memory=2048m"
At deployment time, if you specify an -Xmx
option in the deployer.<app>.local.javaOpts
property in addition to a value of the deployer.<app>.local.memory
option, the value in the javaOpts
property has precedence. Also, the javaOpts
property set when deploying the application has precedence over the Data Flow Server’s spring.cloud.deployer.local.javaOpts
property.
10.4. Logging
Spring Cloud Data Flow local
server is automatically configured to use RollingFileAppender
for logging.
The logging configuration is located on the classpath contained in a file named logback-spring.xml
By default, the log file is configured to use:
<property name="LOG_FILE" value="${LOG_FILE:-${LOG_PATH:-${LOG_TEMP:-${java.io.tmpdir:-/tmp}}}/spring-cloud-dataflow-server}"/>
with the logback configuration for the RollingPolicy
<appender name="FILE" class="ch.qos.logback.core.rolling.RollingFileAppender"> <file>${LOG_FILE}.log</file> <rollingPolicy class="ch.qos.logback.core.rolling.SizeAndTimeBasedRollingPolicy"> <!-- daily rolling --> <fileNamePattern>${LOG_FILE}.${LOG_FILE_ROLLING_FILE_NAME_PATTERN:-%d{yyyy-MM-dd}}.%i.gz</fileNamePattern> <maxFileSize>${LOG_FILE_MAX_SIZE:-100MB}</maxFileSize> <maxHistory>${LOG_FILE_MAX_HISTORY:-30}</maxHistory> <totalSizeCap>${LOG_FILE_TOTAL_SIZE_CAP:-500MB}</totalSizeCap> </rollingPolicy> <encoder> <pattern>${FILE_LOG_PATTERN}</pattern> </encoder> </appender>
To check the java.io.tmpdir
for the current Spring Cloud Data Flow Server local
server,
jinfo <pid> | grep "java.io.tmpdir"
If you want to change or override any of the properties LOG_FILE
, LOG_PATH
, LOG_TEMP
, LOG_FILE_MAX_SIZE
, LOG_FILE_MAX_HISTORY
and LOG_FILE_TOTAL_SIZE_CAP
, please set them as system properties.
10.5. Streams
Data Flow Server delegates to the Skipper server the management of the Stream’s lifecycle. Set the configuration property spring.cloud.skipper.client.serverUri
to the location of Skipper, e.g.
$ java -jar spring-cloud-dataflow-server-2.9.6.jar --spring.cloud.skipper.client.serverUri=https://192.51.100.1:7577/api
The configuration of show streams are deployed and to which platforms, is done by configuration of platform accounts
on the Skipper server.
See the documentation on platforms for more information.
10.6. Tasks
The Data Flow server is responsible for deploying Tasks.
Tasks that are launched by Data Flow write their state to the same database that is used by the Data Flow server.
For Tasks which are Spring Batch Jobs, the job and step execution data is also stored in this database.
As with streams launched by Skipper, Tasks can be launched to multiple platforms.
If no platform is defined, a platform named default
is created using the default values of the class LocalDeployerProperties, which is summarized in the table Local Deployer Properties
To configure new platform accounts for the local platform, provide an entry under the spring.cloud.dataflow.task.platform.local
section in your application.yaml
file for via another Spring Boot supported mechanism.
In the following example, two local platform accounts named localDev
and localDevDebug
are created.
The keys such as shutdownTimeout
and javaOpts
are local deployer properties.
spring:
cloud:
dataflow:
task:
platform:
local:
accounts:
localDev:
shutdownTimeout: 60
javaOpts: "-Dtest=foo -Xmx1024m"
localDevDebug:
javaOpts: "-Xdebug -Xmx2048m"
By defining one platform as default allows you to skip using platformName where its use would otherwise be required.
When launching a task, pass the value of the platform account name using the task launch option --platformName
If you do not pass a value for platformName
, the value default
will be used.
When deploying a task to multiple platforms, the configuration of the task needs to connect to the same database as the Data Flow Server. |
You can configure the Data Flow server that is running locally to deploy tasks to Cloud Foundry or Kubernetes. See the sections on Cloud Foundry Task Platform Configuration and Kubernetes Task Platform Configuration for more information.
Detailed examples for launching and scheduling tasks across multiple platforms, are available in this section Multiple Platform Support for Tasks on dataflow.spring.io.
Start Skipper
git clone https://github.com/spring-cloud/spring-cloud-skipper.git
cd spring-cloud/spring-cloud-skipper
./mvnw clean package -DskipTests=true
java -jar spring-cloud-skipper-server/target/spring-cloud-skipper-server-2.2.0.BUILD-SNAPSHOT.jar
Start Spring Cloud Data Flow
git clone https://github.com/spring-cloud/spring-cloud-dataflow.git
cd spring-cloud-dataflow
cd ..
Create a yaml file scdf.yml with the following contents:
spring:
cloud:
dataflow:
security:
authorization:
provider-role-mappings:
uaa:
map-oauth-scopes: true
role-mappings:
ROLE_CREATE: foo.create
ROLE_DEPLOY: foo.create
ROLE_DESTROY: foo.create
ROLE_MANAGE: foo.create
ROLE_MODIFY: foo.create
ROLE_SCHEDULE: foo.create
ROLE_VIEW: foo.view
security:
oauth2:
client:
registration:
uaa:
client-id: dataflow
scope: (1)
- openid
- foo.create
- foo.view
provider:
uaa:
jwk-set-uri: http://uaa:8080/uaa/token_keys
token-uri: http://uaa:8080/uaa/oauth/token
user-info-uri: http://uaa:8080/uaa/userinfo (2)
authorization-uri: http://uaa:8080/uaa/oauth/authorize
resourceserver:
opaquetoken: (3)
introspection-uri: http://uaa:8080/uaa/introspect
client-id: dataflow
1 | If you use scopes to identify roles, please make sure to also request
the relevant scopes, e.g dataflow.view , dataflow.create and don’t forget to request the openid scope |
2 | Used to retrieve profile information, e.g. username for display purposes (mandatory) |
3 | Used for token introspection and validation (mandatory) |
The introspection-uri
property is especially important when passing an externally retrieved (opaque)
OAuth Access Token to Spring Cloud Data Flow. In that case Spring Cloud Data Flow will take the OAuth Access,
and use the UAA’s Introspect Token Endpoint
to not only check the validity of the token but also retrieve the associated OAuth scopes from the UAA
Finally startup Spring Cloud Data Flow:
java -jar spring-cloud-dataflow/spring-cloud-dataflow-server/target/spring-cloud-dataflow-server-2.4.0.BUILD-SNAPSHOT.jar --spring.config.additional-location=scdf.yml
Role Mappings
By default all roles are assigned to users that login to Spring Cloud Data Flow. However, you can set the property:
spring.cloud.dataflow.security.authorization.provider-role-mappings.uaa.map-oauth-scopes: true
This will instruct the underlying DefaultAuthoritiesExtractor
to map
OAuth scopes to the respective authorities. The following scopes are supported:
Scope
dataflow.create
maps to theCREATE
role -
Scope
dataflow.deploy
maps to theDEPLOY
role -
Scope
dataflow.destroy
maps to theDESTROY
role -
Scope
dataflow.manage
maps to theMANAGE
role -
Scope
dataflow.modify
maps to theMODIFY
role -
Scope
dataflow.schedule
maps to theSCHEDULE
role -
Scope
dataflow.view
maps to theVIEW
role
Additionally you can also map arbitrary scopes to each of the Data Flow roles:
spring:
cloud:
dataflow:
security:
authorization:
uaa:
map-oauth-scopes: true (1)
role-mappings:
ROLE_CREATE: dataflow.create (2)
ROLE_DEPLOY: dataflow.deploy
ROLE_DESTROY: dataflow.destoy
ROLE_MANAGE: dataflow.manage
ROLE_MODIFY: dataflow.modify
ROLE_SCHEDULE: dataflow.schedule
ROLE_VIEW: dataflow.view
1 | Enables explicit mapping support from OAuth scopes to Data Flow roles |
2 | When role mapping support is enabled, you must provide a mapping for all 7 Spring Cloud Data Flow roles ROLE_CREATE, ROLE_DEPLOY, ROLE_DESTROY, ROLE_MANAGE, ROLE_MODIFY, ROLE_SCHEDULE, ROLE_VIEW. |
You can assign an OAuth scope to multiple Spring Cloud Data Flow roles, giving you flexible regarding the granularity of your authorization configuration. |
10.6.4. LDAP Authentication
LDAP Authentication (Lightweight Directory Access Protocol) is indirectly provided by Spring Cloud Data Flow using the UAA. The UAA itself provides comprehensive LDAP support.
While you may use your own OAuth2 authentication server, the LDAP support documented here requires using the UAA as authentication server. For any other provider, please consult the documentation for that particular provider. |
The UAA supports authentication against an LDAP (Lightweight Directory Access Protocol) server using the following modes:
When integrating with an external identity provider such as LDAP, authentication within the UAA becomes chained. UAA first attempts to authenticate with a user’s credentials against the UAA user store before the external provider, LDAP. For more information, see Chained Authentication in the User Account and Authentication LDAP Integration GitHub documentation. |
LDAP Role Mapping
The OAuth2 authentication server (UAA), provides comprehensive support for mapping LDAP groups to OAuth scopes.
The following options exist:
ldap/ldap-groups-null.xml
No groups will be mapped -
ldap/ldap-groups-as-scopes.xml
Group names will be retrieved from an LDAP attribute. E.g.CN
ldap/ldap-groups-map-to-scopes.xml
Groups will be mapped to UAA groups using the external_group_mapping table
These values are specified via the configuration property ldap.groups.file controls
. Under the covers
these values reference a Spring XML configuration file.
During test and development it might be necessary to make frequent changes to LDAP groups and users and see those reflected in the UAA. However, user information is cached for the duration of the login. The following script helps to retrieve the updated information quickly:
LDAP Security and UAA Example Application
In order to get up and running quickly and to help you understand the security architecture, we provide the LDAP Security and UAA Example on GitHub.
This is solely a demo/example application and shall not be used in production. |
The setup consists of:
Skipper Server
Lightweight Directory Access Protocol (LDAP) Server (provided by Apache Directory Server (ApacheDS))
Ultimately, as part of this example, you will learn how to configure and launch a Composed Task using this security setup.
10.6.5. Spring Security OAuth2 Resource/Authorization Server Sample
For local testing and development, you may also use the Resource and Authorization Server support provided by Spring Security OAuth. It allows you to easily create your own (very basic) OAuth2 Server with the following simple annotations:
@EnableResourceServer
@EnableAuthorizationServer
In fact the UAA uses Spring Security OAuth2 under the covers, thus the basic endpoints are the same. |
A working example application can be found at: https://github.com/ghillert/oauth-test-server/
Clone the project and configure Spring Cloud Data Flow with the respective Client ID and Client Secret:
security:
oauth2:
client:
client-id: myclient
access-token-uri: http://127.0.0.1:9999/oauth/token
user-authorization-uri: http://127.0.0.1:9999/oauth/authorize
resource:
user-info-uri: http://127.0.0.1:9999/me
token-info-uri: http://127.0.0.1:9999/oauth/check_token
This sample application is not intended for production use |
10.6.6. Data Flow Shell Authentication
When using the Shell, the credentials can either be provided via username and password or by specifying a credentials-provider command. If your OAuth2 provider supports the Password Grant Type you can start the Data Flow Shell with:
$ java -jar spring-cloud-dataflow-shell-2.9.6.jar \
--dataflow.uri=http://localhost:9393 \ (1)
--dataflow.username=my_username \ (2)
--dataflow.password=my_password \ (3)
--skip-ssl-validation true \ (4)
1 | Optional, defaults to localhost:9393. |
2 | Mandatory. |
3 | If the password is not provided, the user is prompted for it. |
4 | Optional, defaults to false , ignores certificate errors (when using self-signed certificates). Use cautiously! |
Keep in mind that when authentication for Spring Cloud Data Flow is enabled, the underlying OAuth2 provider must support the Password OAuth2 Grant Type if you want to use the Shell via username/password authentication. |
From within the Data Flow Shell you can also provide credentials by using the following command:
server-unknown:>dataflow config server \
--uri http://localhost:9393 \ (1)
--username myuser \ (2)
--password mysecret \ (3)
2 | Mandatory.. |
3 | If security is enabled, and the password is not provided, the user is prompted for it. |
4 | Optional, ignores certificate errors (when using self-signed certificates). Use cautiously! |
The following image shows a typical shell command to connect to and authenticate a Data Flow Server:
![Target and Authenticate with the Data Flow Server from within the Shell](https://raw.githubusercontent.com/spring-cloud/spring-cloud-dataflow/master/spring-cloud-dataflow-docs/src/main/asciidoc/images/dataflow-security-shell-target.png)
Once successfully targeted, you should see the following output:
dataflow:>dataflow config info
║Credentials│[username='my_username, password=****']║
║Result │ ║
║Target │http://localhost:9393 ║
Alternatively, you can specify the credentials-provider command in order to
pass-in a bearer token directly, instead of providing a username and password.
This works from within the shell or by providing the
--dataflow.credentials-provider-command
command-line argument when starting the Shell.
When using the credentials-provider command, please be aware that your specified command must return a Bearer token (Access Token prefixed with Bearer). For instance, in Unix environments the following simplistic command can be used:
10.7. About Configuration
The Spring Cloud Data Flow About Restful API result contains a display name, version, and, if specified, a URL for each of the major dependencies that comprise Spring Cloud Data Flow. The result (if enabled) also contains the sha1 and or sha256 checksum values for the shell dependency. The information that is returned for each of the dependencies is configurable by setting the following properties:
spring.cloud.dataflow.version-info.spring-cloud-dataflow-core.name: the name to be used for the core.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-core.version: the version to be used for the core.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-dashboard.name: the name to be used for the dashboard.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-dashboard.version: the version to be used for the dashboard.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-implementation.name: the name to be used for the implementation.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-implementation.version: the version to be used for the implementation.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.name: the name to be used for the shell.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.version: the version to be used for the shell.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.url: the URL to be used for downloading the shell dependency.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.checksum-sha1: the sha1 checksum value that is returned with the shell dependency info.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.checksum-sha256: the sha256 checksum value that is returned with the shell dependency info.
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.checksum-sha1-url: if the
is not specified, SCDF uses the contents of the file specified at this URL for the checksum. -
spring.cloud.dataflow.version-info.spring-cloud-dataflow-shell.checksum-sha256-url: if the
10.7.1. Enabling Shell Checksum values
By default, checksum values are not displayed for the shell dependency. If
you need this feature enabled, set the
spring.cloud.dataflow.version-info.dependency-fetch.enabled
property to true.
10.7.2. Reserved Values for URLs
There are reserved values (surrounded by curly braces) that you can insert into the URL that will make sure that the links are up to date:
repository: if using a build-snapshot, milestone, or release candidate of Data Flow, the repository refers to the repo-spring-io repository. Otherwise, it refers to Maven Central.
version: Inserts the version of the jar/pom.
For example,
myrepository/org/springframework/cloud/spring-cloud-dataflow-shell/{version}/spring-cloud-dataflow-shell-{version}.jar
produces
myrepository/org/springframework/cloud/spring-cloud-dataflow-shell/1.2.3.RELEASE/spring-cloud-dataflow-shell-1.2.3.RELEASE.jar
if you were using the 1.2.3.RELEASE version of the Spring Cloud Data Flow Shell
11. Configuration - Cloud Foundry
This section describes how to configure Spring Cloud Data Flow server’s features, such as security and which relational database to use. It also describes how to configure Spring Cloud Data Flow shell’s features.
11.1. Feature Toggles
Data Flow server offers a specific set of features that you can enable or disable when launching. These features include all the lifecycle operations and REST endpoints (server, client implementations including Shell and the UI) for:
Streams
Tasks
You can enable or disable these features by setting the following boolean properties when you launch the Data Flow server:
By default, all features are enabled.
The REST endpoint (/features
) provides information on the enabled and disabled features.
11.2. Deployer Properties
You can use the following configuration properties of the Data Flow server’s Cloud Foundry deployer to customize how applications are deployed.
When deploying with the Data Flow shell, you can use the syntax deployer.<appName>.cloudfoundry.<deployerPropertyName>
These properties are also used when configuring the Cloud Foundry Task platforms in the Data Flow server and and Kubernetes platforms in Skipper for deploying Streams.
services |
The names of services to bind to the deployed application. |
<none> |
host |
The host name to use as part of the route. |
hostname derived by Cloud Foundry |
domain |
The domain to use when mapping routes for the application. |
<none> |
routes |
The list of routes that the application should be bound to. Mutually exclusive with host and domain. |
<none> |
buildpack |
The buildpack to use for deploying the application. Deprecated use buildpacks. |
buildpacks |
The list of buildpacks to use for deploying the application. |
memory |
The amount of memory to allocate. Default unit is mebibytes, 'M' and 'G" suffixes supported |
1024m |
disk |
The amount of disk space to allocate. Default unit is mebibytes, 'M' and 'G" suffixes supported. |
1024m |
healthCheck |
The type of health check to perform on deployed application. Values can be HTTP, NONE, PROCESS, and PORT |
PORT |
healthCheckHttpEndpoint |
The path that the http health check will use, |
/health |
healthCheckTimeout |
The timeout value for health checks in seconds. |
120 |
instances |
The number of instances to run. |
1 |
enableRandomAppNamePrefix |
Flag to enable prefixing the app name with a random prefix. |
true |
apiTimeout |
Timeout for blocking API calls, in seconds. |
360 |
statusTimeout |
Timeout for status API operations in milliseconds |
5000 |
useSpringApplicationJson |
Flag to indicate whether application properties are fed into |
true |
stagingTimeout |
Timeout allocated for staging the application. |
15 minutes |
startupTimeout |
Timeout allocated for starting the application. |
5 minutes |
appNamePrefix |
String to use as prefix for name of deployed application |
The Spring Boot property |
deleteRoutes |
Whether to also delete routes when un-deploying an application. |
true |
javaOpts |
<none> |
pushTasksEnabled |
Whether to push task applications or assume that the application already exists when launched. |
true |
autoDeleteMavenArtifacts |
Whether to automatically delete Maven artifacts from the local repository when deployed. |
true |
env.<key> |
Defines a top level environment variable. This is useful for customizing Java build pack configuration which must be included as top level environment variables in the application manifest, as the Java build pack does not recognize |
The deployer determines if the app has Java CfEnv in its classpath. If so, it applies the required configuration. |
Here are some examples using the Cloud Foundry deployment properties:
You can set the buildpack that is used to deploy each application. For example, to use the Java offline buildback, set the following environment variable:
cf set-env dataflow-server SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_BUILDPACKS java_buildpack_offline
Setting
buildpack
is now deprecated in favour ofbuildpacks
which allows you to pass on more than one if needed. More about this can be found from How Buildpacks Work. -
You can customize the health check mechanism used by Cloud Foundry to assert whether apps are running by using the
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_HEALTH_CHECK
environment variable. The current supported options arehttp
(the default),port
, andnone
You can also set environment variables that specify the HTTP-based health check endpoint and timeout: SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_HEALTH_CHECK_ENDPOINT
and SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_HEALTH_CHECK_TIMEOUT
, respectively. These default to /health
(the Spring Boot default location) and 120
seconds.
You can also specify deployment properties by using the DSL. For instance, if you want to set the allocated memory for the
http
application to 512m and also bind a mysql service to thejdbc
application, you can run the following commands:
dataflow:> stream create --name mysqlstream --definition "http | jdbc --tableName=names --columns=name"
dataflow:> stream deploy --name mysqlstream --properties "deployer.http.memory=512, deployer.jdbc.cloudfoundry.services=mysql"
You can configure these settings separately for stream and task apps. To alter settings for tasks,
substitute
11.3. Tasks
As with Skipper, Tasks can be launched to multiple platforms.
When Data Flow is running on Cloud Foundry, a Task platfom must be defined.
To configure new platform accounts that target Cloud Foundry, provide an entry under the spring.cloud.dataflow.task.platform.cloudfoundry
In the following example, two Cloud Foundry platform accounts named dev
and qa
are created.
The keys such as memory
and disk
are Cloud Foundry Deployer Properties.
spring:
cloud:
dataflow:
task:
platform:
cloudfoundry:
accounts:
dev:
connection:
url: https://api.run.pivotal.io
org: myOrg
space: mySpace
domain: cfapps.io
username: [email protected]
password: drowssap
skipSslValidation: false
deployment:
memory: 512m
disk: 2048m
instances: 4
services: rabbit,mysql
appNamePrefix: dev1
qa:
connection:
org: myOrgQA
space: mySpaceQA
domain: cfapps.io
password: drowssap
skipSslValidation: true
deployment:
memory: 756m
disk: 724m
instances: 2
services: rabbitQA,mysqlQA
appNamePrefix: qa1
, the value default
will be used.
You can configure the Data Flow server that is on Cloud Foundry to deploy tasks to Cloud Foundry or Kubernetes. See the section on Kubernetes Task Platform Configuration for more information.
11.4. Application Names and Prefixes
To help avoid clashes with routes across spaces in Cloud Foundry, a naming strategy that provides a random prefix to a
deployed application is available and is enabled by default. You can override the default configurations
and set the respective properties by using cf set-env
commands.
For instance, if you want to disable the randomization, you can override it by using the following command:
cf set-env dataflow-server SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_ENABLE_RANDOM_APP_NAME_PREFIX false
11.5. Custom Routes
As an alternative to a random name or to get even more control over the hostname used by the deployed apps, you can use custom deployment properties, as the following example shows:
dataflow:>stream create foo --definition "http | log"
sdataflow:>stream deploy foo --properties "deployer.http.cloudfoundry.domain=mydomain.com,
deployer.http.cloudfoundry.host=myhost,
deployer.http.cloudfoundry.route-path=my-path"
The preceding example binds the http
app to the myhost.mydomain.com/my-path
URL. Note that this
example shows all of the available customization options. In practice, you can use only one or two out of the three.
11.6. Docker Applications
Starting with version 1.2, it is possible to register and deploy Docker based apps as part of streams and tasks by using Data Flow for Cloud Foundry.
If you use Spring Boot and RabbitMQ-based Docker images, you can provide a common deployment property
to facilitate binding the apps to the RabbitMQ service. Assuming your RabbitMQ service is named rabbit
, you can provide the following:
cf set-env dataflow-server SPRING_APPLICATION_JSON '{"spring.cloud.dataflow.applicationProperties.stream.spring.rabbitmq.addresses": "${vcap.services.rabbit.credentials.protocols.amqp.uris}"}'
For Spring Cloud Task apps, you can use something similar to the following, if you use a database service instance named mysql
cf set-env SPRING_DATASOURCE_URL '${vcap.services.mysql.credentials.jdbcUrl}'
cf set-env SPRING_DATASOURCE_USERNAME '${vcap.services.mysql.credentials.username}'
cf set-env SPRING_DATASOURCE_PASSWORD '${vcap.services.mysql.credentials.password}'
cf set-env SPRING_DATASOURCE_DRIVER_CLASS_NAME 'org.mariadb.jdbc.Driver'
For non-Java or non-Boot applications, your Docker app must parse the VCAP_SERVICES
variable in order to bind to any available services.
Passing application properties
When using non-Boot applications, chances are that you want to pass the application properties by using traditional
environment variables, as opposed to using the special
11.7. Application-level Service Bindings
When deploying streams in Cloud Foundry, you can take advantage of application-specific service bindings, so not all services are globally configured for all the apps orchestrated by Spring Cloud Data Flow.
For instance, if you want to provide a mysql
service binding only for the jdbc
application in the following stream
definition, you can pass the service binding as a deployment property:
dataflow:>stream create --name httptojdbc --definition "http | jdbc"
dataflow:>stream deploy --name httptojdbc --properties "deployer.jdbc.cloudfoundry.services=mysqlService"
where mysqlService
is the name of the service specifically bound only to the jdbc
application and the http
application does not get the binding by this method.
If you have more than one service to bind, they can be passed as comma-separated items
(for example: deployer.jdbc.cloudfoundry.services=mysqlService,someService
11.8. Configuring Service binding parameters
The CloudFoundry API supports providing configuration parameters when binding a service instance. Some service brokers require or recommend binding configuration. For example, binding the Google Cloud Platform service using the CF CLI looks something like:
cf bind-service my-app my-google-bigquery-example -c '{"role":"bigquery.user"}'
Likewise the NFS Volume Service supports binding configuration such as:
cf bind-service my-app nfs_service_instance -c '{"uid":"1000","gid":"1000","mount":"/var/volume1","readonly":true}'
Starting with version 2.0, Data Flow for Cloud Foundry allows you to provide binding configuration parameters may be provided in the app level or server level cloudfoundry.services
deployment property. For example, to bind to the nfs service, as above :
dataflow:> stream deploy --name mystream --properties "deployer.<app>.cloudfoundry.services='nfs_service_instance uid:1000,gid:1000,mount:/var/volume1,readonly:true'"
The format is intended to be compatible with the Data Flow DSL parser.
Generally, the cloudfoundry.services
deployment property accepts a comma delimited value.
Since a comma is also used to separate configuration parameters, and to avoid white space issues, any item including configuration parameters must be enclosed in singe quotes. Valid values incude things like:
rabbitmq,'nfs_service_instance uid:1000,gid:1000,mount:/var/volume1,readonly:true',mysql,'my-google-bigquery-example role:bigquery.user'
Spaces are permitted within single quotes and = may be used instead of : to delimit key-value pairs.
11.9. User-provided Services
In addition to marketplace services, Cloud Foundry supports User-provided Services (UPS). Throughout this reference manual, regular services have been mentioned, but there is nothing precluding the use of User-provided Services as well, whether for use as the messaging middleware (for example, if you want to use an external Apache Kafka installation) or for use by some of the stream applications (for example, an Oracle Database).
Now we review an example of extracting and supplying the connection credentials from a UPS.
The following example shows a sample UPS setup for Apache Kafka:
cf create-user-provided-service kafkacups -p '{”brokers":"HOST:PORT","zkNodes":"HOST:PORT"}'
The UPS credentials are wrapped within VCAP_SERVICES
, and they can be supplied directly in the stream definition, as
the following example shows.
stream create fooz --definition "time | log"
stream deploy fooz --properties "app.time.spring.cloud.stream.kafka.binder.brokers=${vcap.services.kafkacups.credentials.brokers},app.time.spring.cloud.stream.kafka.binder.zkNodes=${vcap.services.kafkacups.credentials.zkNodes},app.log.spring.cloud.stream.kafka.binder.brokers=${vcap.services.kafkacups.credentials.brokers},app.log.spring.cloud.stream.kafka.binder.zkNodes=${vcap.services.kafkacups.credentials.zkNodes}"
11.10. Database Connection Pool
As of Data Flow 2.0, the Spring Cloud Connector library is no longer used to create the DataSource. The library java-cfenv is now used which allows you to set Spring Boot properties to configure the connection pool.
11.11. Maximum Disk Quota
By default, every application in Cloud Foundry starts with 1G disk quota and this can be adjusted to a default maximum of 2G. The default maximum can also be overridden up to 10G by using Pivotal Cloud Foundry’s (PCF) Ops Manager GUI.
This configuration is relevant for Spring Cloud Data Flow because every task deployment is composed of applications (typically Spring Boot uber-jar’s), and those applications are resolved from a remote maven repository. After resolution, the application artifacts are downloaded to the local Maven Repository for caching and reuse. With this happening in the background, the default disk quota (1G) can fill up rapidly, especially when we experiment with streams that are made up of unique applications. In order to overcome this disk limitation and depending on your scaling requirements, you may want to change the default maximum from 2G to 10G. Let’s review the steps to change the default maximum disk quota allocation.
11.11.1. PCF’s Operations Manager
From PCF’s Ops Manager, select the “Pivotal Elastic Runtime” tile and navigate to the “Application Developer Controls” tab. Change the “Maximum Disk Quota per App (MB)” setting from 2048 (2G) to 10240 (10G). Save the disk quota update and click “Apply Changes” to complete the configuration override.
11.12. Scale Application
Once the disk quota change has been successfully applied and assuming you have a running application,
you can scale the application with a new disk_limit
through the CF CLI, as the following example shows:
→ cf scale dataflow-server -k 10GB
Scaling app dataflow-server in org ORG / space SPACE as user...
OK
state since cpu memory disk details
#0 running 2016-10-31 03:07:23 PM 1.8% 497.9M of 1.1G 193.9M of 10G
You can then list the applications and see the new maximum disk space, as the following example shows:
→ cf apps
Getting apps in org ORG / space SPACE as user...
OK
name requested state instances memory disk urls
dataflow-server started 1/1 1.1G 10G dataflow-server.apps.io
11.13. Managing Disk Use
Even when configuring the Data Flow server to use 10G of space, there is the possibility of exhausting
the available space on the local disk. To prevent this, jar
artifacts downloaded from external sources, i.e., apps registered as http
or maven
resources, are automatically deleted whenever the application is deployed, whether or not the deployment request succeeds.
This behavior is optimal for production environments in which container runtime stability is more critical than I/O latency incurred during deployment.
In development environments deployment happens more frequently. Additionally, the jar
artifact (or a lighter metadata
jar) contains metadata describing application configuration properties
which is used by various operations related to application configuration, more frequently performed during pre-production activities (see Application Metadata for details).
To provide a more responsive interactive developer experience at the expense of more disk usage in pre-production environments, you can set the CloudFoundry deployer property autoDeleteMavenArtifacts
to false
If you deploy the Data Flow server by using the default port
health check type, you must explicitly monitor the disk space on the server in order to avoid running out space.
If you deploy the server by using the http
health check type (see the next example), the Data Flow server is restarted if there is low disk space.
This is due to Spring Boot’s Disk Space Health Indicator.
You can configure the settings of the Disk Space Health Indicator by using the properties that have the management.health.diskspace
prefix.
For version 1.7, we are investigating the use of Volume Services for the Data Flow server to store .jar
artifacts before pushing them to Cloud Foundry.
The following example shows how to deploy the http
health check type to an endpoint called /management/health
health-check-type: http
health-check-http-endpoint: /management/health
11.14. Application Resolution Alternatives
Though we recommend using a Maven Artifactory for application Register a Stream Application, there might be situations where one of the following alternative approaches would make sense.
We have custom-built and maintain a SCDF APP Tool that can run as a regular Spring Boot application in Cloud Foundry, but it will in turn host and serve the application JARs for SCDF at runtime.
With the help of Spring Boot, we can serve static content in Cloud Foundry. A simple Spring Boot application can bundle all the required stream and task applications. By having it run on Cloud Foundry, the static application can then serve the über-jar’s. From the shell, you can, for example, register the application with the name
http-source.jar
by using--uri=http://<Route-To-StaticApp>/http-source.jar
The über-jar’s can be hosted on any external server that’s reachable over HTTP. They can be resolved from raw GitHub URIs as well. From the shell, you can, for example, register the app with the name
http-source.jar
by using--uri=http://<Raw_GitHub_URI>/http-source.jar
Static Buildpack support in Cloud Foundry is another option. A similar HTTP resolution works on this model, too.
Volume Services is another great option. The required über-jars can be hosted in an external file system. With the help of volume-services, you can, for example, register the application with the name
http-source.jar
by using--uri=file://<Path-To-FileSystem>/http-source.jar
11.15. Security
By default, the Data Flow server is unsecured and runs on an unencrypted HTTP connection. You can secure your REST endpoints
(as well as the Data Flow Dashboard) by enabling HTTPS and requiring clients to authenticate.
For more details about securing the
REST endpoints and configuring to authenticate against an OAUTH backend (UAA and SSO running on Cloud Foundry),
see the security section from the core [configuration-local-security]. You can configure the security details in dataflow-server.yml
or pass them as environment variables through cf set-env
commands.
11.15.1. Authentication
Spring Cloud Data Flow can either integrate with Pivotal Single Sign-On Service (for example, on PWS) or Cloud Foundry User Account and Authentication (UAA) Server.
When deploying Spring Cloud Data Flow to Cloud Foundry, you can bind the application to the Pivotal Single Sign-On Service. By doing so, Spring Cloud Data Flow takes advantage of the Java CFEnv, which provides Cloud Foundry-specific auto-configuration support for OAuth 2.0.
To do so, bind the Pivotal Single Sign-On Service to your Data Flow Server application and provide the following properties:
SPRING_CLOUD_DATAFLOW_SECURITY_CFUSEUAA: false (1)
SECURITY_OAUTH2_CLIENT_CLIENTID: "${security.oauth2.client.clientId}"
SECURITY_OAUTH2_CLIENT_CLIENTSECRET: "${security.oauth2.client.clientSecret}"
SECURITY_OAUTH2_CLIENT_ACCESSTOKENURI: "${security.oauth2.client.accessTokenUri}"
SECURITY_OAUTH2_CLIENT_USERAUTHORIZATIONURI: "${security.oauth2.client.userAuthorizationUri}"
SECURITY_OAUTH2_RESOURCE_USERINFOURI: "${security.oauth2.resource.userInfoUri}"
1 | It is important that the property spring.cloud.dataflow.security.cf-use-uaa is set to false |
Authorization is similarly supported for non-Cloud Foundry security scenarios. See the security section from the core Data Flow [configuration-local-security].
As the provisioning of roles can vary widely across environments, we by default assign all Spring Cloud Data Flow roles to users.
You can customize this behavior by providing your own AuthoritiesExtractor
The following example shows one possible approach to set the custom AuthoritiesExtractor
on the UserInfoTokenServices
public class MyUserInfoTokenServicesPostProcessor
implements BeanPostProcessor {
public Object postProcessBeforeInitialization(Object bean, String beanName) {
if (bean instanceof UserInfoTokenServices) {
final UserInfoTokenServices userInfoTokenServices == (UserInfoTokenServices) bean;
userInfoTokenServices.setAuthoritiesExtractor(ctx.getBean(AuthoritiesExtractor.class));
return bean;
public Object postProcessAfterInitialization(Object bean, String beanName) {
return bean;
Then you can declare it in your configuration class as follows:
public BeanPostProcessor myUserInfoTokenServicesPostProcessor() {
BeanPostProcessor postProcessor == new MyUserInfoTokenServicesPostProcessor();
return postProcessor;
Cloud Foundry UAA
The availability of Cloud Foundry User Account and Authentication (UAA) depends on the Cloud Foundry environment.
In order to provide UAA integration, you have to provide the necessary
OAuth2 configuration properties (for example, by setting the SPRING_APPLICATION_JSON
property).
The following JSON example shows how to create a security configuration:
"security.oauth2.client.client-id": "scdf",
"security.oauth2.client.client-secret": "scdf-secret",
"security.oauth2.client.access-token-uri": "https://login.cf.myhost.com/oauth/token",
"security.oauth2.client.user-authorization-uri": "https://login.cf.myhost.com/oauth/authorize",
"security.oauth2.resource.user-info-uri": "https://login.cf.myhost.com/userinfo"
By default, the spring.cloud.dataflow.security.cf-use-uaa
property is set to true
. This property activates a special
called CloudFoundryDataflowAuthoritiesExtractor
If you do not use CloudFoundry UAA, you should set spring.cloud.dataflow.security.cf-use-uaa
to false
Under the covers, this AuthoritiesExtractor
calls out to the
Cloud Foundry
Apps API and ensure that users are in fact Space Developers.
If the authenticated user is verified as a Space Developer, all roles are assigned.
11.16. Configuration Reference
You must provide several pieces of configuration. These are Spring Boot @ConfigurationProperties
, so you can set
them as environment variables or by any other means that Spring Boot supports. The following listing is in environment
variable format, as that is an easy way to get started configuring Boot applications in Cloud Foundry.
Note that in the future, you will be able to deploy tasks to multiple platforms, but for 2.0.0.M1 you can deploy only to a single platform and the name must be default
# Default values appear after the equal signs.
# Example values, typical for Pivotal Web Services, are included as comments.
# URL of the CF API (used when using cf login -a for example) - for example, https://api.run.pivotal.io
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_URL=
# The name of the organization that owns the space above - for example, youruser-org
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_ORG=
# The name of the space into which modules will be deployed - for example, development
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SPACE=
# The root domain to use when mapping routes - for example, cfapps.io
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_DOMAIN=
# The user name and password of the user to use to create applications
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_USERNAME=
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_PASSWORD
# The identity provider to be used when accessing the Cloud Foundry API (optional).
# The passed string has to be a URL-Encoded JSON Object, containing the field origin with value as origin_key of an identity provider - for example, {"origin":"uaa"}
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_LOGIN_HINT=
# Whether to allow self-signed certificates during SSL validation (you should NOT do so in production)
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SKIP_SSL_VALIDATION
# A comma-separated set of service instance names to bind to every deployed task application.
# Among other things, this should include an RDBMS service that is used
# for Spring Cloud Task execution reporting, such as my_postgres
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES
spring.cloud.deployer.cloudfoundry.task.services=
# Timeout, in seconds, to use when doing blocking API calls to Cloud Foundry
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_API_TIMEOUT=
# Timeout, in milliseconds, to use when querying the Cloud Foundry API to compute app status
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_STATUS_TIMEOUT
Note that you can set spring.cloud.deployer.cloudfoundry.services
spring.cloud.deployer.cloudfoundry.buildpacks
, or the Spring Cloud Deployer-standard
spring.cloud.deployer.memory
and spring.cloud.deployer.disk
as part of an individual deployment request by using the deployer.<app-name>
shortcut, as the following example shows:
stream create --name ticktock --definition "time | log"
stream deploy --name ticktock --properties "deployer.time.memory=2g"
The commands in the preceding example deploy the time source with 2048MB of memory, while the log sink uses the default 1024MB.
When you deploy a stream, you can also pass JAVA_OPTS
as a deployment property, as the following example shows:
stream deploy --name ticktock --properties "deployer.time.cloudfoundry.javaOpts=-Duser.timezone=America/New_York"
11.17. Debugging
If you want to get better insights into what is happening when your streams and tasks are being deployed, you may want to turn on the following features:
Reactor “stacktraces”, showing which operators were involved before an error occurred. This feature is helpful, as the deployer relies on project reactor and regular stacktraces may not always allow understanding the flow before an error happened. Note that this comes with a performance penalty, so it is disabled by default.
spring.cloud.dataflow.server.cloudfoundry.debugReactor == true
Deployer and Cloud Foundry client library request and response logs. This feature allows seeing a detailed conversation between the Data Flow server and the Cloud Foundry Cloud Controller.
logging.level.cloudfoundry-client == DEBUG
11.18. Spring Cloud Config Server
You can use Spring Cloud Config Server to centralize configuration properties for Spring Boot applications. Likewise, both Spring Cloud Data Flow and the applications orchestrated by Spring Cloud Data Flow can be integrated with a configuration server to use the same capabilities.
11.18.1. Stream, Task, and Spring Cloud Config Server
Similar to Spring Cloud Data Flow server, you can configure both the stream and task applications to resolve the centralized properties from the configuration server.
Setting the spring.cloud.config.uri
property for the deployed applications is a common way to bind to the configuration server.
See the Spring Cloud Config Client reference guide for more information.
Since this property is likely to be used across all applications deployed by the Data Flow server, the Data Flow server’s spring.cloud.dataflow.applicationProperties.stream
property for stream applications and spring.cloud.dataflow.applicationProperties.task
property for task applications can be used to pass the uri
of the Config Server to each deployed stream or task application. See the section on Common Application Properties for more information.
Note that, if you use applications from the App Starters project, these applications already embed the spring-cloud-services-starter-config-client
dependency.
If you build your application from scratch and want to add the client side support for config server, you can add a dependency reference to the config server client library. The following snippet shows a Maven example:
<dependency>
<groupId>io.pivotal.spring.cloud</groupId>
<artifactId>spring-cloud-services-starter-config-client</artifactId>
<version>CONFIG_CLIENT_VERSION</version>
</dependency>
where CONFIG_CLIENT_VERSION
can be the latest release of the Spring Cloud Config Server
client for Pivotal Cloud Foundry.
You may see a WARN logging message if the application that uses this library cannot connect to the configuration
server when the application starts and whenever the /health endpoint is accessed.
If you know that you are not using config server functionality, you can disable the client library by setting the
SPRING_CLOUD_CONFIG_ENABLED environment variable to false .
11.18.2. Sample Manifest Template
The following SCDF and Skipper manifest.yml
templates includes the required environment variables for the Skipper and Spring Cloud Data Flow server and deployed applications and tasks to successfully run on Cloud Foundry and automatically resolve centralized properties from my-config-server
at runtime:
applications:
- name: data-flow-server
host: data-flow-server
memory: 2G
disk_quota: 2G
instances: 1
path: {PATH TO SERVER UBER-JAR}
env:
SPRING_APPLICATION_NAME: data-flow-server
MAVEN_REMOTE_REPOSITORIES_REPO1_URL: https://repo.spring.io/libs-snapshot
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_URL: https://api.sys.huron.cf-app.com
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_ORG: sabby20
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SPACE: sabby20
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_DOMAIN: apps.huron.cf-app.com
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_USERNAME: admin
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_PASSWORD: ***
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SKIP_SSL_VALIDATION: true
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES: mysql
SPRING_CLOUD_SKIPPER_CLIENT_SERVER_URI: https://<skipper-host-name>/api
services:
- mysql
- my-config-server
applications:
- name: skipper-server
host: skipper-server
memory: 1G
disk_quota: 1G
instances: 1
timeout: 180
buildpack: java_buildpack
path: <PATH TO THE DOWNLOADED SKIPPER SERVER UBER-JAR>
env:
SPRING_APPLICATION_NAME: skipper-server
SPRING_CLOUD_SKIPPER_SERVER_ENABLE_LOCAL_PLATFORM: false
SPRING_CLOUD_SKIPPER_SERVER_STRATEGIES_HEALTHCHECK_TIMEOUTINMILLIS: 300000
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_URL: https://api.local.pcfdev.io
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_ORG: pcfdev-org
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SPACE: pcfdev-space
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_DOMAIN: cfapps.io
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_USERNAME: admin
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_PASSWORD: admin
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SKIP_SSL_VALIDATION: false
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_DELETE_ROUTES: false
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES: rabbit, my-config-server
services:
- mysql
my-config-server
where my-config-server
is the name of the Spring Cloud Config Service instance running on Cloud Foundry.
By binding the service to Spring Cloud Data Flow server, Spring Cloud Task and via Skipper to all the Spring Cloud Stream applications respectively, we can now resolve centralized properties backed by this service.
11.18.3. Self-signed SSL Certificate and Spring Cloud Config Server
Often, in a development environment, we may not have a valid certificate to enable SSL communication between clients and the backend services. However, the configuration server for Pivotal Cloud Foundry uses HTTPS for all client-to-service communication, so we need to add a self-signed SSL certificate in environments with no valid certificates.
By using the same manifest.yml
templates listed in the previous section for the server, we can provide the self-signed SSL certificate by setting TRUST_CERTS: <API_ENDPOINT>
However, the deployed applications also require TRUST_CERTS
as a flat environment variable (as opposed to being wrapped inside SPRING_APPLICATION_JSON
), so we must instruct the server with yet another set of tokens (SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_USE_SPRING_APPLICATION_JSON: false
) for tasks.
With this setup, the applications receive their application properties as regular environment variables.
The following listing shows the updated manifest.yml
with the required changes. Both the Data Flow server and deployed applications
get their configuration from the my-config-server
Cloud Config server (deployed as a Cloud Foundry service).
applications:
- name: test-server
host: test-server
memory: 1G
disk_quota: 1G
instances: 1
path: spring-cloud-dataflow-server-VERSION.jar
env:
SPRING_APPLICATION_NAME: test-server
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES: mysql, config-server
TRUST_CERTS: <API_ENDPOINT> #this is for the server
SPRING_CLOUD_DATAFLOW_APPLICATION_PROPERTIES_TASK_TRUST_CERTS: <API_ENDPOINT> #this propagates to all tasks
services:
- mysql
- my-config-server #this is for the server
Also add the my-config-server
service to the Skipper’s manifest environment
applications:
memory: 1G
disk_quota: 1G
instances: 1
timeout: 180
env:
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_URL: <URL>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_ORG: <ORG>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_SPACE: <SPACE>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_DOMAIN: <DOMAIN>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_USERNAME: <USER>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_CONNECTION_PASSWORD: <PASSWORD>
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES: rabbit, my-config-server #this is so all stream applications bind to my-config-server
services:
- mysql
my-config-server
11.19. Configure Scheduling
This section discusses how to configure Spring Cloud Data Flow to connect to the PCF-Scheduler as its agent to execute tasks.
Before following these instructions, be sure to have an instance of the PCF-Scheduler service running in your Cloud Foundry space.
To create a PCF-Scheduler in your space (assuming it is in your Market Place) execute the following from the CF CLI: |
For scheduling, you must add (or update) the following environment variables in your environment:
Enable scheduling for Spring Cloud Data Flow by setting
spring.cloud.dataflow.features.schedules-enabled
totrue
Bind the task deployer to your instance of PCF-Scheduler by adding the PCF-Scheduler service name to the
environment variable. -
Establish the URL to the PCF-Scheduler by setting the
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_SCHEDULER_SCHEDULER_URL
After creating the preceding configurations, you must create any task definitions that need to be scheduled. |
The following sample manifest shows both environment properties configured (assuming you have a PCF-Scheduler service available with the name myscheduler
applications:
memory: 2G
disk_quota: 2G
instances: 1
env:
SPRING_CLOUD_SKIPPER_SERVER_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_DEPLOYMENT_SERVICES: rabbit, myscheduler
SPRING_CLOUD_DATAFLOW_FEATURES_SCHEDULES_ENABLED: true
SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]_SCHEDULER_SCHEDULER_URL: https://scheduler.local.pcfdev.io
services:
- mysql
Where the SPRING_CLOUD_DATAFLOW_TASK_PLATFORM_CLOUDFOUNDRY_ACCOUNTS[default]SCHEDULER_SCHEDULER_URL
has the following format: scheduler.<Domain-Name>
(for
example, scheduler.local.pcfdev.io
). Check the actual address from your _PCF environment.
Detailed examples for launching and scheduling tasks across multiple platforms, are available in this section Multiple Platform Support for Tasks on dataflow.spring.io. |
12. Configuration - Kubernetes
This section describes how to configure Spring Cloud Data Flow features, such as deployer properties, tasks, and which relational database to use.
12.1. Feature Toggles
Data Flow server offers specific set of features that can be enabled or disabled when launching. These features include all the lifecycle operations, REST endpoints (server and client implementations including Shell and the UI) for:
Streams
Tasks
Schedules
You can enable or disable these features by setting the following boolean environment variables when launching the Data Flow server:
SPRING_CLOUD_DATAFLOW_FEATURES_STREAMS_ENABLED
SPRING_CLOUD_DATAFLOW_FEATURES_TASKS_ENABLED
By default, all the features are enabled.
The /features
REST endpoint provides information on the features that have been enabled and disabled.
12.2. Deployer Properties
You can use the following configuration properties the Kubernetes deployer to customize how Streams and Tasks are deployed.
When deploying with the Data Flow shell, you can use the syntax deployer.<appName>.kubernetes.<deployerPropertyName>
These properties are also used when configuring the Kubernetes task platforms in the Data Flow server and Kubernetes platforms in Skipper for deploying Streams.
namespace |
Namespace to use |
environment variable |
deployment.nodeSelector |
The node selectors to apply to the deployment in |
<none> |
imagePullSecret |
Secrets for a access a private registry to pull images. |
<none> |
imagePullPolicy |
The Image Pull Policy to apply when pulling images. Valid options are |
IfNotPresent |
livenessProbeDelay |
Delay in seconds when the Kubernetes liveness check of the app container should start checking its health status. |
10 |
livenessProbePeriod |
Period in seconds for performing the Kubernetes liveness check of the app container. |
60 |
livenessProbeTimeout |
Timeout in seconds for the Kubernetes liveness check of the app container. If the health check takes longer than this value to return it is assumed as 'unavailable'. |
2 |
livenessProbePath |
Path that app container has to respond to for liveness check. |
<none> |
livenessProbePort |
Port that app container has to respond on for liveness check. |
<none> |
readinessProbeDelay |
Delay in seconds when the readiness check of the app container should start checking if the module is fully up and running. |
10 |
readinessProbePeriod |
Period in seconds to perform the readiness check of the app container. |
10 |
readinessProbeTimeout |
Timeout in seconds that the app container has to respond to its health status during the readiness check. |
2 |
readinessProbePath |
Path that app container has to respond to for readiness check. |
<none> |
readinessProbePort |
Port that app container has to respond on for readiness check. |
<none> |
probeCredentialsSecret |
The secret name containing the credentials to use when accessing secured probe endpoints. |
<none> |
limits.memory |
The memory limit, maximum needed value to allocate a pod, Default unit is mebibytes, 'M' and 'G" suffixes supported |
<none> |
limits.cpu |
The CPU limit, maximum needed value to allocate a pod |
<none> |
requests.memory |
The memory request, guaranteed needed value to allocate a pod. |
<none> |
requests.cpu |
The CPU request, guaranteed needed value to allocate a pod. |
<none> |
statefulSet.volumeClaimTemplate.storageClassName |
Name of the storage class for a stateful set |
<none> |
statefulSet.volumeClaimTemplate.storage |
The storage amount. Default unit is mebibytes, 'M' and 'G" suffixes supported |
<none> |
environmentVariables |
List of environment variables to set for any deployed app container |
<none> |
entryPointStyle |
Entry point style used for the Docker image. Used to determine how to pass in properties. Can be |
createLoadBalancer |
Create a "LoadBalancer" for the service created for each app. This facilitates assignment of external IP to app. |
false |
serviceAnnotations |
Service annotations to set for the service created for each application. String of the format |
<none> |
podAnnotations |
Pod annotations to set for the pod created for each deployment. String of the format |
<none> |
jobAnnotations |
Job annotations to set for the pod or job created for a job. String of the format |
<none> |
minutesToWaitForLoadBalancer |
Time to wait for load balancer to be available before attempting delete of service (in minutes). |
5 |
maxTerminatedErrorRestarts |
Maximum allowed restarts for app that fails due to an error or excessive resource use. |
2 |
maxCrashLoopBackOffRestarts |
Maximum allowed restarts for app that is in a CrashLoopBackOff. Values are |
volumeMounts |
volume mounts expressed in YAML format. e.g. |
<none> |
volumes |
The volumes that a Kubernetes instance supports specifed in YAML format. e.g. |
<none> |
hostNetwork |
The hostNetwork setting for the deployments, see kubernetes.io/docs/api-reference/v1/definitions/#_v1_podspec |
false |
createDeployment |
Create a "Deployment" with a "Replica Set" instead of a "Replication Controller". |
true |
createJob |
Create a "Job" instead of just a "Pod" when launching tasks. |
false |
containerCommand |
Overrides the default entry point command with the provided command and arguments. |
<none> |
containerPorts |
Adds additional ports to expose on the container. |
<none> |
createNodePort |
The explicit port to use when |
<none> |
deploymentServiceAccountName |
Service account name used in app deployments. Note: The service account name used for app deployments is derived from the Data Flow servers deployment. |
<none> |
deploymentLabels |
Additional labels to add to the deployment in |
<none> |
bootMajorVersion |
The Spring Boot major version to use. Currently only used to configure Spring Boot version specific probe paths automatically. Valid options are |
2 |
tolerations.key |
The key to use for the toleration. |
<none> |
tolerations.effect |
The toleration effect. See kubernetes.io/docs/concepts/configuration/taint-and-toleration for valid options. |
<none> |
tolerations.operator |
The toleration operator. See kubernetes.io/docs/concepts/configuration/taint-and-toleration/ for valid options. |
<none> |
tolerations.tolerationSeconds |
The number of seconds defining how long the pod will stay bound to the node after a taint is added. |
<none> |
tolerations.value |
The toleration value to apply, used in conjunction with |
<none> |
secretRefs |
The name of the secret(s) to load the entire data contents into individual environment variables. Multiple secrets may be comma separated. |
<none> |
secretKeyRefs.envVarName |
The environment variable name to hold the secret data |
<none> |
secretKeyRefs.secretName |
The secret name to access |
<none> |
secretKeyRefs.dataKey |
The key name to obtain secret data from |
<none> |
configMapRefs |
The name of the ConfigMap(s) to load the entire data contents into individual environment variables. Multiple ConfigMaps be comma separated. |
<none> |
configMapKeyRefs.envVarName |
The environment variable name to hold the ConfigMap data |
<none> |
configMapKeyRefs.configMapName |
The ConfigMap name to access |
<none> |
configMapKeyRefs.dataKey |
The key name to obtain ConfigMap data from |
<none> |
maximumConcurrentTasks |
The maximum concurrent tasks allowed for this platform instance. |
20 |
podSecurityContext.runAsUser |
The numeric user ID to run pod container processes under |
<none> |
podSecurityContext.fsGroup |
The numeric group ID to run pod container processes under |
<none> |
affinity.nodeAffinity |
The node affinity expressed in YAML format. e.g. |
<none> |
affinity.podAffinity |
The pod affinity expressed in YAML format. e.g. |
<none> |
affinity.podAntiAffinity |
The pod anti-affinity expressed in YAML format. e.g. |
<none> |
statefulSetInitContainerImageName |
A custom image name to use for the StatefulSet Init Container |
<none> |
initContainer |
An Init Container expressed in YAML format to be applied to a pod. e.g. |
<none> |
additionalContainers |
Additional containers expressed in YAML format to be applied to a pod. e.g. |
<none> |
12.3. Tasks
When Data Flow is running on Kubernetes, a Task platfom must be defined.
To configure new platform accounts that target Kubernetes, provide an entry under the spring.cloud.dataflow.task.platform.kubernetes
In the following example, two Kubernetes platform accounts named dev
and qa
are created.
and disk
spring:
cloud:
dataflow:
task:
platform:
kubernetes:
accounts:
dev:
namespace: devNamespace
imagePullPolicy: Always
entryPointStyle: exec
limits:
cpu: 4
qa:
namespace: qaNamespace
imagePullPolicy: IfNotPresent
entryPointStyle: boot
limits:
memory: 2048m
, the value default
will be used.
You can configure the Data Flow server that is on Kubernetes to deploy tasks to Cloud Foundry and Kubernetes. See the section on Cloud Foundry Task Platform Configuration for more information.
12.4. General Configuration
The Spring Cloud Data Flow server for Kubernetes uses the spring-cloud-kubernetes
module to process secrets that are mounted under /etc/secrets
. ConfigMaps must be mounted as application.yaml
in the /config
directory that is processed by Spring Boot. To avoid access to the Kubernetes API server the SPRING_CLOUD_KUBERNETES_CONFIG_ENABLE_API
and SPRING_CLOUD_KUBERNETES_SECRETS_ENABLE_API
are set to false
12.4.1. Using ConfigMap and Secrets
You can pass configuration properties to the Data Flow Server by using Kubernetes ConfigMap and secrets.
The following example shows one possible configuration, which enables MySQL and sets a memory limit:
apiVersion: v1
kind: ConfigMap
metadata:
labels:
app: scdf-server
data:
application.yaml: |-
spring:
cloud:
dataflow:
task:
platform:
kubernetes:
accounts:
default:
limits:
memory: 1024Mi
datasource:
url: jdbc:mysql://${MYSQL_SERVICE_HOST}:${MYSQL_SERVICE_PORT}/mysql
username: root
password: ${mysql-root-password}
driverClassName: org.mariadb.jdbc.Driver
testOnBorrow: true
validationQuery: "SELECT 1"
The preceding example assumes that MySQL is deployed with mysql
as the service name. Kubernetes publishes the host and port values of these services as environment variables that we can use when configuring the apps we deploy.
We prefer to provide the MySQL connection password in a Secrets file, as the following example shows:
apiVersion: v1
kind: Secret
metadata:
labels:
app: mysql
data:
mysql-root-password: eW91cnBhc3N3b3Jk
The password is a base64-encoded value.
12.5. Database Configuration
Spring Cloud Data Flow provides schemas for H2, HSQLDB, MySQL, Oracle, PostgreSQL, DB2, and SQL Server. The appropriate schema is automatically created when the server starts, provided the right database driver and appropriate credentials are in the classpath.
The JDBC drivers for MySQL (via MariaDB driver), HSQLDB, PostgreSQL, and embedded H2 are available out of the box. If you use any other database, you need to put the corresponding JDBC driver jar on the classpath of the server.
For instance, if you use MySQL in addition to a password in the secrets file, you could provide the following properties in the ConfigMap:
data:
spring:
datasource:
username: root
url: jdbc:mysql://${MYSQL_SERVICE_HOST}:${MYSQL_SERVICE_PORT}/test
For PostgreSQL, you could use the following configuration:
data:
spring:
datasource:
url: jdbc:postgresql://${PGSQL_SERVICE_HOST}:${PGSQL_SERVICE_PORT}/database
username: root
password: ${postgres-password}
driverClassName: org.postgresql.Driver
For HSQLDB, you could use the following configuration:
data:
spring:
datasource:
url: jdbc:hsqldb:hsql://${HSQLDB_SERVICE_HOST}:${HSQLDB_SERVICE_PORT}/database
username: sa
driverClassName: org.hsqldb.jdbc.JDBCDriver
The following YAML snippet from a Deployment is an example of mounting a ConfigMap as application.yaml
under /config
where Spring Boot will process it plus a Secret mounted under /etc/secrets
where it will get picked up by the spring-cloud-kubernetes library due to the environment variable SPRING_CLOUD_KUBERNETES_SECRETS_PATHS
being set to /etc/secrets
containers:
- name: scdf-server
image: springcloud/spring-cloud-dataflow-server:2.5.0.BUILD-SNAPSHOT
volumeMounts:
- name: config
mountPath: /config
readOnly: true
- name: database
mountPath: /etc/secrets/database
readOnly: true
ports:
volumes:
- name: config
configMap:
items:
- key: application.yaml
path: application.yaml
- name: database
secret:
secretName: mysql
You can find migration scripts for specific database types in the spring-cloud-task repo.
12.6. Monitoring and Management
We recommend using the kubectl
command for troubleshooting streams and tasks.
You can list all artifacts and resources used by using the following command:
kubectl get all,cm,secrets,pvc
You can list all resources used by a specific application or service by using a label to select resources. The following command lists all resources used by the mysql
service:
kubectl get all -l app=mysql
You can get the logs for a specific pod by issuing the following command:
kubectl logs pod <pod-name>
If the pod is continuously getting restarted, you can add -p
as an option to see the previous log, as follows:
kubectl logs -p <pod-name>
You can also tail or follow a log by adding an -f
option, as follows:
kubectl logs -f <pod-name>
A useful command to help in troubleshooting issues, such as a container that has a fatal error when starting up, is to use the describe
command, as the following example shows:
kubectl describe pod ticktock-log-0-qnk72
12.6.1. Inspecting Server Logs
You can access the server logs by using the following command:
kubectl get pod -l app=scdf=server
kubectl logs <scdf-server-pod-name>
12.6.2. Streams
Stream applications are deployed with the stream name followed by the name of the application. For processors and sinks, an instance index is also appended.
To see all the pods that are deployed by the Spring Cloud Data Flow server, you can specify the role=spring-app
label, as follows:
kubectl get pod -l role=spring-app
To see details for a specific application deployment you can use the following command:
kubectl describe pod <app-pod-name>
To view the application logs, you can use the following command:
kubectl logs <app-pod-name>
If you would like to tail a log you can use the following command:
kubectl logs -f <app-pod-name>
12.6.3. Tasks
Tasks are launched as bare pods without a replication controller. The pods remain after the tasks complete, which gives you an opportunity to review the logs.
To see all pods for a specific task, use the following command:
kubectl get pod -l task-name=<task-name>
To review the task logs, use the following command:
kubectl logs <task-pod-name>
You have two options to delete completed pods. You can delete them manually once they are no longer needed or you can use the Data Flow shell task execution cleanup
command to remove the completed pod for a task execution.
To delete the task pod manually, use the following command:
kubectl delete pod <task-pod-name>
To use the task execution cleanup
command, you must first determine the ID
for the task execution. To do so, use the task execution list
command, as the following example (with output) shows:
dataflow:>task execution list
║Task Name│ID│ Start Time │ End Time │Exit Code║
║task1 │1 │Fri May 05 18:12:05 EDT 2017│Fri May 05 18:12:05 EDT 2017│0 ║
Once you have the ID, you can issue the command to cleanup the execution artifacts (the completed pod), as the following example shows:
dataflow:>task execution cleanup --id 1
Request to clean up resources for task execution 1 has been submitted
Database Credentials for Tasks
By default Spring Cloud Data Flow passes database credentials as properties to the pod at task launch time.
If using the exec
or shell
entry point styles the DB credentials will be viewable if the user does a kubectl describe
on the task’s pod.
To configure Spring Cloud Data Flow to use Kubernetes Secrets: Set spring.cloud.dataflow.task.use.kubernetes.secrets.for.db.credentials
property to true
. If using the yaml files provided by Spring Cloud Data Flow update the `src/kubernetes/server/server-deployment.yaml to add the following environment variable:
- name: SPRING_CLOUD_DATAFLOW_TASK_USE_KUBERNETES_SECRETS_FOR_DB_CREDENTIALS
value: 'true'
If upgrading from a previous version of SCDF be sure to verify that spring.datasource.username
and spring.datasource.password
environment variables are present in the secretKeyRefs
in the server-config.yaml. If not, add it as shown in the example below:
task:
platform:
kubernetes:
accounts:
default:
secretKeyRefs:
- envVarName: "spring.datasource.password"
secretName: mysql
dataKey: mysql-root-password
- envVarName: "spring.datasource.username"
secretName: mysql
dataKey: mysql-root-username
Also verify that the associated secret(dataKey) is also available in secrets. SCDF provides an example of this for MySql here: src/kubernetes/mysql/mysql-svc.yaml
Passing of DB credentials via properties by default is to preserve to backwards compatibility. This will be feature will be removed in future release. |
12.7. Scheduling
This section covers customization of how scheduled tasks are configured. Scheduling of tasks is enabled by default in the Spring Cloud Data Flow Kubernetes Server. Properties are used to influence settings for scheduled tasks and can be configured on a global or per-schedule basis.
Unless noted, properties set on a per-schedule basis always take precedence over properties set as the server configuration. This arrangement allows for the ability to override global server level properties for a specific schedule. |
See KubernetesSchedulerProperties
for more on the supported options.
12.7.1. Entry Point Style
An Entry Point Style affects how application properties are passed to the task container to be deployed. Currently, three styles are supported:
exec
: (default) Passes all application properties as command line arguments. -
shell
: Passes all application properties as environment variables. -
boot
: Creates an environment variable calledSPRING_APPLICATION_JSON
that contains a JSON representation of all application properties.
You can configure the entry point style as follows:
deployer.kubernetes.entryPointStyle=<Entry Point Style>
Replace <Entry Point Style>
with your desired Entry Point Style.
You can also configure the Entry Point Style at the server level in the container env
section of a deployment YAML, as the following example shows:
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_ENTRY_POINT_STYLE
value: entryPointStyle
Replace entryPointStyle
with the desired Entry Point Style.
You should choose an Entry Point Style of either exec
or shell
, to correspond to how the ENTRYPOINT
syntax is defined in the container’s Dockerfile
. For more information and uses cases on exec
vs shell
, see the ENTRYPOINT section of the Docker documentation.
Using the boot
Entry Point Style corresponds to using the exec
style ENTRYPOINT
. Command line arguments from the deployment request are passed to the container, with the addition of application properties mapped into the SPRING_APPLICATION_JSON
environment variable rather than command line arguments.
12.7.2. Environment Variables
To influence the environment settings for a given application, you can take advantage of the spring.cloud.deployer.kubernetes.environmentVariables
property.
For example, a common requirement in production settings is to influence the JVM memory arguments.
You can achieve this by using the JAVA_TOOL_OPTIONS
environment variable, as the following example shows:
deployer.kubernetes.environmentVariables=JAVA_TOOL_OPTIONS=-Xmx1024m
When deploying stream applications or launching task applications where some of the properties may contain sensitive information, use the shell or boot as the entryPointStyle . This is because the exec (default) converts all properties to command line arguments and thus may not be secure in some environments.
Additionally you can configure environment variables at the server level in the container env
When specifying environment variables in the server configuration and on a per-schedule basis, environment variables will be merged. This allows for the ability to set common environment variables in the server configuration and more specific at the specific schedule level. |
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_ENVIRONMENT_VARIABLES
value: myVar=myVal
Replace myVar=myVal
with your desired environment variables.
12.7.3. Image Pull Policy
An image pull policy defines when a Docker image should be pulled to the local registry. Currently, three policies are supported:
IfNotPresent
: (default) Do not pull an image if it already exists. -
Always
: Always pull the image regardless of whether it already exists. -
Never
: Never pull an image. Use only an image that already exists.
The following example shows how you can individually configure containers:
deployer.kubernetes.imagePullPolicy=Always
Replace Always
with your desired image pull policy.
You can configure an image pull policy at the server level in the container env
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_IMAGE_PULL_POLICY
value: Always
Replace Always
12.7.4. Private Docker Registry
Docker images that are private and require authentication can be pulled by configuring a Secret. First, you must create a Secret in the cluster. Follow the Pull an Image from a Private Registry guide to create the Secret.
Once you have created the secret, use the imagePullSecret
property to set the secret to use, as the following example shows:
deployer.kubernetes.imagePullSecret=mysecret
Replace mysecret
with the name of the secret you created earlier.
You can also configure the image pull secret at the server level in the container env
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_IMAGE_PULL_SECRET
value: mysecret
Replace mysecret
12.7.5. Namespace
By default the namespace used for scheduled tasks is default
. This value can be set at the server level configuration in the container env
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_NAMESPACE
value: mynamespace
12.7.6. Service Account
You can configure a custom service account for scheduled tasks through properties. An existing service account can be used or a new one created. One way to create a service account is by using kubectl
$ kubectl create serviceaccount myserviceaccountname
serviceaccount "myserviceaccountname" created
Then you can configure the service account to use on a per-schedule basis as follows:
deployer.kubernetes.taskServiceAccountName=myserviceaccountname
Replace myserviceaccountname
with your service account name.
You can also configure the service account name at the server level in the container env
env:
- name: SPRING_CLOUD_SCHEDULER_KUBERNETES_TASK_SERVICE_ACCOUNT_NAME
value: myserviceaccountname
with the service account name to be applied to all deployments.
For more information on scheduling tasks see Scheduling Tasks.
12.8. Debug Support
Debugging the Spring Cloud Data Flow Kubernetes Server and included components (such as the Spring Cloud Kubernetes Deployer) is supported through the Java Debug Wire Protocol (JDWP). This section outlines an approach to manually enable debugging and another approach that uses configuration files provided with Spring Cloud Data Flow Server Kubernetes to “patch” a running deployment.
JDWP itself does not use any authentication. This section assumes debugging is being done on a local development environment (such as Minikube), so guidance on securing the debug port is not provided. |
12.8.1. Enabling Debugging Manually
To manually enable JDWP, first edit src/kubernetes/server/server-deployment.yaml
and add an additional containerPort
entry under spec.template.spec.containers.ports
with a value of 5005
. Additionally, add the JAVA_TOOL_OPTIONS
environment variable under spec.template.spec.containers.env
spec:
template:
spec:
containers:
- name: scdf-server
ports:
- containerPort: 5005
env:
- name: JAVA_TOOL_OPTIONS
value: '-agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=5005'
The preceding example uses port 5005, but it can be any number that does not conflict with another port. The chosen port number must also be the same for the added containerPort value and the address parameter of the JAVA_TOOL_OPTIONS -agentlib flag, as shown in the preceding example.
You can now start the Spring Cloud Data Flow Kubernetes Server. Once the server is up, you can verify the configuration changes on the scdf-server
deployment, as the following example (with output) shows:
kubectl describe deployment/scdf-server
Pod Template:
Containers:
scdf-server:
Ports: 80/TCP, 5005/TCP
Environment:
JAVA_TOOL_OPTIONS: -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=5005
With the server started and JDWP enabled, you need to configure access to the port. In this example, we use the port-forward
subcommand of kubectl
. The following example (with output) shows how to expose a local port to your debug target by using port-forward
$ kubectl get pod -l app=scdf-server
NAME READY STATUS RESTARTS AGE
scdf-server-5b7cfd86f7-d8mj4 1/1 Running 0 10m
$ kubectl port-forward scdf-server-5b7cfd86f7-d8mj4 5005:5005
Forwarding from 127.0.0.1:5005 -> 5005
Forwarding from [::1]:5005 -> 5005
You can now attach a debugger by pointing it to 127.0.0.1
as the host and 5005
as the port. The port-forward
subcommand runs until stopped (by pressing CTRL+c
, for example).
You can remove debugging support by reverting the changes to src/kubernetes/server/server-deployment.yaml
. The reverted changes are picked up on the next deployment of the Spring Cloud Data Flow Kubernetes Server. Manually adding debug support to the configuration is useful when debugging should be enabled by default each time the server is deployed.
12.8.2. Enabling Debugging with Patching
Rather than manually changing the server-deployment.yaml
, Kubernetes objects can be “patched” in place. For convenience, patch files that provide the same configuration as the manual approach are included. To enable debugging by patching, use the following command:
kubectl patch deployment scdf-server -p "$(cat src/kubernetes/server/server-deployment-debug.yaml)"
Running the preceding command automatically adds the containerPort
attribute and the JAVA_TOOL_OPTIONS
environment variable. The following example (with output) shows how toverify changes to the scdf-server
deployment:
$ kubectl describe deployment/scdf-server
Pod Template:
Containers:
scdf-server:
Ports: 5005/TCP, 80/TCP
Environment:
To enable access to the debug port, rather than using the port-forward
, you can patch the scdf-server
Kubernetes service object. You must first ensure that the scdf-server
Kubernetes service object has the proper configuration. The following example (with output) shows how to do so:
kubectl describe service/scdf-server
Port: <unset> 80/TCP
TargetPort: 80/TCP
NodePort: <unset> 30784/TCP
If the output contains <unset>
, you must patch the service to add a name for this port. The following example shows how to do so:
$ kubectl patch service scdf-server -p "$(cat src/kubernetes/server/server-svc.yaml)"
A port name should only be missing if the target cluster had been created prior to debug functionality being added. Since multiple ports are being added to the scdf-server Kubernetes Service Object, each needs to have its own name.
Now you can add the debug port, as the following example shows:
kubectl patch service scdf-server -p "$(cat src/kubernetes/server/server-svc-debug.yaml)"
The following example (with output) shows how to verify the mapping:
$ kubectl describe service scdf-server
Port: scdf-server-jdwp 5005/TCP
TargetPort: 5005/TCP
NodePort: scdf-server-jdwp 31339/TCP
Port: scdf-server 80/TCP
TargetPort: 80/TCP
NodePort: scdf-server 30883/TCP
The output shows that container port 5005 has been mapped to the NodePort of 31339. The following example (with output) shows how to get the IP address of the Minikube node:
$ minikube ip
192.168.99.100
With this information, you can create a debug connection by using a host of 192.168.99.100 and a port of 31339.
The following example shows how to disable JDWP:
$ kubectl rollout undo deployment/scdf-server
$ kubectl patch service scdf-server --type json -p='[{"op": "remove", "path": "/spec/ports/0"}]'
The Kubernetes deployment object is rolled back to its state before being patched. The Kubernetes service object is then patched with a remove
operation to remove port 5005 from the containerPorts
list.
kubectl rollout undo forces the pod to restart. Patching the Kubernetes Service Object does not re-create the service, and the port mapping to the scdf-server deployment remains the same.
See Rolling Back a Deployment for more information on deployment rollbacks, including managing history and Updating API Objects in Place Using kubectl Patch.
