This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.0!spring-doc.cn
Next Steps
Hopefully, this section provided some of the Spring Cloud Contract basics and got you on your way to writing your own applications. If you are a task-oriented type of developer, you might want to jump over to spring.io and check out some getting started guides that solve specific “How do I do that with Spring?” problems. We also have Spring Cloud Contract-specific “how-to” reference documentation.spring-doc.cn
Otherwise, the next logical step is to read Using Spring Cloud Contract. If you are really impatient, you could also jump ahead and read about Spring Cloud Contract features.spring-doc.cn
In addition, you can check out the following videos:spring-doc.cn
  • "Consumer Driven Contracts and Your Microservice Architecture" by Olga Maciaszek-Sharma and Marcin Grzejszczakspring-doc.cn
  • "Contract Tests in the Enterprise" by Marcin Grzejszczakspring-doc.cn
  • "Why Contract Tests Matter?" by Marcin Grzejszczakspring-doc.cn
You can find the default project samples at samples.spring-doc.cn
