9. Hystrix metrics aggregation with Turbine and Consul
Turbine (provided by the Spring Cloud Netflix project), aggregates multiple instances Hystrix metrics streams, so the dashboard can display an aggregate view. Turbine uses the DiscoveryClient interface to lookup relevant instances. To use Turbine with Spring Cloud Consul, configure the Turbine application in a manner similar to the following examples:
pom.xml
<dependency>
    <artifactId>spring-cloud-netflix-turbine</artifactId>
</dependency>
<dependency>
    <artifactId>spring-cloud-starter-consul-discovery</artifactId>
</dependency>
Notice that the Turbine dependency is not a starter. The turbine starter includes support for Netflix Eureka.
application.yml
spring.application.name: turbine
applications: consulhystrixclient
turbine:
  aggregator:
    clusterConfig: ${applications}
  appConfig: ${applications}
The clusterConfig and appConfig sections must match, so it’s useful to put the comma-separated list of service ID’s into a separate configuration property.
Turbine.java
@EnableTurbine
@SpringBootApplication
public class Turbine {
        SpringApplication.run(DemoturbinecommonsApplication.class, args);
APP信息
