This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
AOT and Native Image Support
Since 4.0.0, Spring Cloud Config Server supports Spring AOT transformations. As of 4.1.0 it also supports GraalVM native images, as long as GraalVM 21 or higher is used, however it requires the user to add some workarounds for known GraalVM issues, as described below.spring-doc.cn
IMPORTANT
Due to [a bug](github.com/oracle/graal/issues/5134) in Graal’s FileSystemProvider a configuration workaround needs to be added to allow the Config Server to run as a native image. You will need to add the following options to your GraalVM build plugin setup (please refer to GraalVM Maven or Gradle plugin documentation for more details):spring-doc.cn
-H:-AddAllFileSystemProviders
--strict-image-heap
--initialize-at-build-time=org.bouncycastle
--initialize-at-build-time=net.i2p.crypto.eddsa.EdDSASecurityProvider
--initialize-at-run-time=org.bouncycastle.jcajce.provider.drbg.DRBG$Default
--initialize-at-run-time=org.bouncycastle.jcajce.provider.drbg.DRBG$NonceAndIV
NOTE
Adding the additional build time initializations can affect performance, but it still may offer gains as compared to a regular JVM run. Make sure to measure and compare for your application.spring-doc.cn
TIP
If you are connecting with your config data backend over SSH, keep in mind that GraalVM requires security provider registration using java.securityspring-doc.cn
Refresh scope is not supported with native images. If you are going to run your config client application as a native image, make sure to set spring.cloud.refresh.enabled property to false.
