Spring Cloud Config Client
A Spring Boot application can take immediate advantage of the Spring Config Server (or other external property sources provided by the application developer).
It also picks up some additional useful features related to Environment
change events.
Spring Boot Config Data Import
Spring Boot 2.4 introduced a new way to import configuration data via the spring.config.import
property. This is now the default way to bind to Config Server.
To optionally connect to config server set the following in application.properties:
spring.config.import=optional:configserver:
This will connect to the Config Server at the default location of "http://localhost:8888". Removing the optional:
prefix will cause the Config Client to fail if it is unable to connect to Config Server. To change the location of Config Server either set spring.cloud.config.uri
or add the url to the spring.config.import
statement such as, spring.config.import=optional:configserver:http://myhost:8888
. The location in the import property has precedence over the uri property.
A bootstrap file (properties or yaml) is not needed for the Spring Boot Config Data method of import via spring.config.import .
Config First Bootstrap
To use the legacy bootstrap way of connecting to Config Server, bootstrap must be enabled via a property or the spring-cloud-starter-bootstrap
starter. The property is spring.cloud.bootstrap.enabled=true
. It must be set as a System Property or environment variable.
Once bootstrap has been enabled any application with Spring Cloud Config Client on the classpath will connect to Config Server as follows:
When a config client starts, it binds to the Config Server (through the spring.cloud.config.uri
bootstrap configuration property) and initializes Spring Environment
with remote property sources.
The net result of this behavior is that all client applications that want to consume the Config Server need a bootstrap.yml
(or an environment variable) with the server address set in spring.cloud.config.uri
(it defaults to "http://localhost:8888").
Discovery First Lookup
Unless you are using config first bootstrap, you will need to have a spring.config.import property in your configuration properties with an optional: prefix.
For example, spring.config.import=optional:configserver: .
If you use a DiscoveryClient
implementation, such as Spring Cloud Netflix and Eureka Service Discovery or Spring Cloud Consul, you can have the Config Server register with the Discovery Service.
If you prefer to use DiscoveryClient
to locate the Config Server, you can do so by setting spring.cloud.config.discovery.enabled=true
(the default is false
For example, with Spring Cloud Netflix, you need to define the Eureka server address (for example, in eureka.client.serviceUrl.defaultZone
The price for using this option is an extra network round trip on startup, to locate the service registration.
The benefit is that, as long as the Discovery Service is a fixed point, the Config Server can change its coordinates.
The default service ID is configserver
, but you can change that on the client by setting spring.cloud.config.discovery.serviceId
(and on the server, in the usual way for a service, such as by setting spring.application.name
The discovery client implementations all support some kind of metadata map (for example, we have eureka.instance.metadataMap
for Eureka).
Some additional properties of the Config Server may need to be configured in its service registration metadata so that clients can connect correctly.
If the Config Server is secured with HTTP Basic, you can configure the credentials as user
and password
Also, if the Config Server has a context path, you can set configPath
For example, the following YAML file is for a Config Server that is a Eureka client:
eureka:
instance:
metadataMap:
user: osufhalskjrtl
password: lviuhlszvaorhvlo5847
configPath: /config
Discovery First Bootstrap Using Eureka And WebClient
If you use the Eureka DiscoveryClient
from Spring Cloud Netflix and also want to use WebClient
instead of Jersey or RestTemplate
you need to include WebClient
on your classpath as well as set eureka.client.webclient.enabled=true
Config Client Fail Fast
In some cases, you may want to fail startup of a service if it cannot connect to the Config Server.
If this is the desired behavior, set the bootstrap configuration property spring.cloud.config.fail-fast=true
to make the client halt with an Exception.
To get similar functionality using spring.config.import , simply omit the optional: prefix.
Config Client Retry
If you expect that the config server may occasionally be unavailable when your application starts, you can make it keep trying after a failure.
First, you need to set spring.cloud.config.fail-fast=true
Then you need to add spring-retry
and spring-boot-starter-aop
to your classpath.
The default behavior is to retry six times with an initial backoff interval of 1000ms and an exponential multiplier of 1.1 for subsequent backoffs.
You can configure these properties (and others) by setting the spring.cloud.config.retry.*
configuration properties.
To take full control of the retry behavior and are using legacy bootstrap, add a @Bean of type RetryOperationsInterceptor with an ID of configServerRetryInterceptor .
Spring Retry has a RetryInterceptorBuilder that supports creating one.
Config Client Retry with spring.config.import
Retry works with the Spring Boot spring.config.import
statement and the normal properties work. However, if the import statement is in a profile, such as application-prod.properties
, then you need a different way to configure retry. Configuration needs to be placed as url parameters on the import statement.
spring.config.import=configserver:http://configserver.example.com?fail-fast=true&max-attempts=10&max-interval=1500&multiplier=1.2&initial-interval=1100"
This sets spring.cloud.config.fail-fast=true
(notice the missing prefix above) and all the available spring.cloud.config.retry.*
Locating Remote Configuration Resources
The Config Service serves property sources from /{application}/{profile}/{label}
, where the default bindings in the client app are as follows:
"application" =
${spring.application.name}
"profile" =
${spring.profiles.active}
(actuallyEnvironment.getActiveProfiles()
"label" = "master"
When setting the property ${spring.application.name} do not prefix your app name with the reserved word application- to prevent issues resolving the correct property source.
You can override all of them by setting spring.cloud.config.*
(where *
is name
, profile
or label
The label
is useful for rolling back to previous versions of configuration.
With the default Config Server implementation, it can be a git label, branch name, or commit ID.
Label can also be provided as a comma-separated list.
In that case, the items in the list are tried one by one until one succeeds.
This behavior can be useful when working on a feature branch.
For instance, you might want to align the config label with your branch but make it optional (in that case, use spring.cloud.config.label=myfeature,develop
Specifying Multiple Urls for the Config Server
To ensure high availability when you have multiple instances of Config Server deployed and expect one or more instances to be unavailable from time to time, you can either specify multiple URLs (as a comma-separated list under the spring.cloud.config.uri
property) or have all your instances register in a Service Registry like Eureka ( if using Discovery-First Bootstrap mode ). Note that doing so ensures high availability only when the Config Server is not running (that is, when the application has exited) or when a connection timeout has occurred. For example, if the Config Server returns a 500 (Internal Server Error) response or the Config Client receives a 401 from the Config Server (due to bad credentials or other causes), the Config Client does not try to fetch properties from other URLs. An error of that kind indicates a user issue rather than an availability problem.
If you use HTTP basic security on your Config Server, it is currently possible to support per-Config Server auth credentials only if you embed the credentials in each URL you specify under the spring.cloud.config.uri
property. If you use any other kind of security mechanism, you cannot (currently) support per-Config Server authentication and authorization.
Configuring Timeouts
If you want to configure timeout thresholds:
Read timeouts can be configured by using the property
spring.cloud.config.request-read-timeout
Connection timeouts can be configured by using the property
spring.cloud.config.request-connect-timeout
Security
If you use HTTP Basic security on the server, clients need to know the password (and username if it is not the default). You can specify the username and password through the config server URI or via separate username and password properties, as shown in the following example:
spring:
cloud:
config:
uri: https://user:[email protected]
The following example shows an alternate way to pass the same information:
spring:
cloud:
config:
uri: https://myconfig.mycompany.com
username: user
password: secret
The spring.cloud.config.password
and spring.cloud.config.username
values override anything that is provided in the URI.
If you deploy your apps on Cloud Foundry, the best way to provide the password is through service credentials (such as in the URI, since it does not need to be in a config file).
The following example works locally and for a user-provided service on Cloud Foundry named configserver
spring:
cloud:
config:
uri: ${vcap.services.configserver.credentials.uri:http://user:password@localhost:8888}
If config server requires client side TLS certificate, you can configure client side TLS certificate and trust store via properties, as shown in following example:
spring:
cloud:
config:
uri: https://myconfig.myconfig.com
tls:
enabled: true
key-store: <path-of-key-store>
key-store-type: PKCS12
key-store-password: <key-store-password>
key-password: <key-password>
trust-store: <path-of-trust-store>
trust-store-type: PKCS12
trust-store-password: <trust-store-password>
The spring.cloud.config.tls.enabled
needs to be true to enable config client side TLS. When spring.cloud.config.tls.trust-store
is omitted, a JVM default trust store is used. The default value for spring.cloud.config.tls.key-store-type
and spring.cloud.config.tls.trust-store-type
is PKCS12. When password properties are omitted, empty password is assumed.
If you use another form of security, you might need to provide a RestTemplate
to the ConfigServicePropertySourceLocator
(for example, by grabbing it in the bootstrap context and injecting it).
Health Indicator
The Config Client supplies a Spring Boot Health Indicator that attempts to load configuration from the Config Server.
The health indicator can be disabled by setting health.config.enabled=false
The response is also cached for performance reasons.
The default cache time to live is 5 minutes.
To change that value, set the health.config.time-to-live
property (in milliseconds).
Providing A Custom RestTemplate
In some cases, you might need to customize the requests made to the config server from the client.
Typically, doing so involves passing special Authorization
headers to authenticate requests to the server.
To provide a custom RestTemplate
Create a new configuration bean with an implementation of
public class CustomConfigServiceBootstrapConfiguration {
public ConfigServicePropertySourceLocator configServicePropertySourceLocator() {
ConfigClientProperties clientProperties = configClientProperties();
ConfigServicePropertySourceLocator configServicePropertySourceLocator = new ConfigServicePropertySourceLocator(clientProperties);
configServicePropertySourceLocator.setRestTemplate(customRestTemplate(clientProperties));
return configServicePropertySourceLocator;
For a simplified approach to adding Authorization headers, the spring.cloud.config.headers.* property can be used instead.
In
resources/META-INF
, create a file calledspring.factories
and specify your custom configuration, as shown in the following example:
org.springframework.cloud.bootstrap.BootstrapConfiguration = com.my.config.client.CustomConfigServiceBootstrapConfiguration
Vault
When using Vault as a backend to your config server, the client needs to supply a token for the server to retrieve values from Vault.
This token can be provided within the client by setting spring.cloud.config.token
in bootstrap.yml
spring:
cloud:
config:
token: YourVaultToken
Nested Keys In Vault
Vault supports the ability to nest keys in a value stored in Vault, as shown in the following example:
echo -n '{"appA": {"secret": "appAsecret"}, "bar": "baz"}' | vault write secret/myapp -
This command writes a JSON object to your Vault.
To access these values in Spring, you would use the traditional dot(.
) annotation, as shown in the following example
@Value("${appA.secret}")
String name = "World";
The preceding code would sets the value of the name
variable to appAsecret
