Spring Cloud Commons: Common Abstractions
Patterns such as service discovery, load balancing, and circuit breakers lend themselves to a common abstraction layer that can be consumed by all Spring Cloud clients, independent of the implementation (for example, discovery with Eureka or Consul).spring-doc.cn
The @EnableDiscoveryClient Annotation
Spring Cloud Commons provides the @EnableDiscoveryClient annotation. This looks for implementations of the DiscoveryClient and ReactiveDiscoveryClient interfaces with META-INF/spring.factories. Implementations of the discovery client add a configuration class to spring.factories under the org.springframework.cloud.client.discovery.EnableDiscoveryClient key. Examples of DiscoveryClient implementations include Spring Cloud Netflix Eureka, Spring Cloud Consul Discovery, and Spring Cloud Zookeeper Discovery.spring-doc.cn
Spring Cloud will provide both the blocking and reactive service discovery clients by default. You can disable the blocking and/or reactive clients easily by setting spring.cloud.discovery.blocking.enabled=false or spring.cloud.discovery.reactive.enabled=false. To completely disable service discovery you just need to set spring.cloud.discovery.enabled=false.spring-doc.cn
By default, implementations of DiscoveryClient auto-register the local Spring Boot server with the remote discovery server. This behavior can be disabled by setting autoRegister=false in @EnableDiscoveryClient.spring-doc.cn
@EnableDiscoveryClient is no longer required. You can put a DiscoveryClient implementation on the classpath to cause the Spring Boot application to register with the service discovery server.
Health Indicators
Commons auto-configures the following Spring Boot health indicators.spring-doc.cn
DiscoveryClientHealthIndicator
This health indicator is based on the currently registered DiscoveryClient implementation.spring-doc.cn
  • To disable entirely, set spring.cloud.discovery.client.health-indicator.enabled=false.spring-doc.cn
  • To disable the description field, set spring.cloud.discovery.client.health-indicator.include-description=false. Otherwise, it can bubble up as the description of the rolled up HealthIndicator.spring-doc.cn
  • To disable service retrieval, set spring.cloud.discovery.client.health-indicator.use-services-query=false. By default, the indicator invokes the client’s getServices method. In deployments with many registered services it may too costly to retrieve all services during every check. This will skip the service retrieval and instead use the client’s probe method.spring-doc.cn
DiscoveryCompositeHealthContributor
This composite health indicator is based on all registered DiscoveryHealthIndicator beans. To disable, set spring.cloud.discovery.client.composite-indicator.enabled=false.spring-doc.cn
Ordering DiscoveryClient instances
DiscoveryClient interface extends Ordered. This is useful when using multiple discovery clients, as it allows you to define the order of the returned discovery clients, similar to how you can order the beans loaded by a Spring application. By default, the order of any DiscoveryClient is set to 0. If you want to set a different order for your custom DiscoveryClient implementations, you just need to override the getOrder() method so that it returns the value that is suitable for your setup. Apart from this, you can use properties to set the order of the DiscoveryClient implementations provided by Spring Cloud, among others ConsulDiscoveryClient, EurekaDiscoveryClient and ZookeeperDiscoveryClient. In order to do it, you just need to set the spring.cloud.{clientIdentifier}.discovery.order (or eureka.client.order for Eureka) property to the desired value.spring-doc.cn
SimpleDiscoveryClient
If there is no Service-Registry-backed DiscoveryClient in the classpath, SimpleDiscoveryClient instance, that uses properties to get information on service and instances, will be used.spring-doc.cn
The information about the available instances should be passed to via properties in the following format: spring.cloud.discovery.client.simple.instances.service1[0].uri=http://s11:8080, where spring.cloud.discovery.client.simple.instances is the common prefix, then service1 stands for the ID of the service in question, while [0] indicates the index number of the instance (as visible in the example, indexes start with 0), and then the value of uri is the actual URI under which the instance is available.spring-doc.cn
ServiceRegistry
Commons now provides a ServiceRegistry interface that provides methods such as register(Registration) and deregister(Registration), which let you provide custom registered services. Registration is a marker interface.spring-doc.cn
The following example shows the ServiceRegistry in use:spring-doc.cn
@EnableDiscoveryClient(autoRegister=false)
public class MyConfiguration {
    private ServiceRegistry registry;
    public MyConfiguration(ServiceRegistry registry) {
        this.registry = registry;
    // called through some external process, such as an event or a custom actuator endpoint
    public void register() {
        Registration registration = constructRegistration();
        this.registry.register(registration);
Each ServiceRegistry implementation has its own Registry implementation.spring-doc.cn
  • ZookeeperRegistration used with ZookeeperServiceRegistryspring-doc.cn
  • EurekaRegistration used with EurekaServiceRegistryspring-doc.cn
  • ConsulRegistration used with ConsulServiceRegistryspring-doc.cn
If you are using the ServiceRegistry interface, you are going to need to pass the correct Registry implementation for the ServiceRegistry implementation you are using.spring-doc.cn
ServiceRegistry Auto-Registration
By default, the ServiceRegistry implementation auto-registers the running service. To disable that behavior, you can set: * @EnableDiscoveryClient(autoRegister=false) to permanently disable auto-registration. * spring.cloud.service-registry.auto-registration.enabled=false to disable the behavior through configuration.spring-doc.cn
ServiceRegistry Auto-Registration Events
There are two events that will be fired when a service auto-registers. The first event, called InstancePreRegisteredEvent, is fired before the service is registered. The second event, called InstanceRegisteredEvent, is fired after the service is registered. You can register an ApplicationListener(s) to listen to and react to these events.spring-doc.cn
These events will not be fired if the spring.cloud.service-registry.auto-registration.enabled property is set to false.
Service Registry Actuator Endpoint
Spring Cloud Commons provides a /serviceregistry actuator endpoint. This endpoint relies on a Registration bean in the Spring Application Context. Calling /serviceregistry with GET returns the status of the Registration. Using POST to the same endpoint with a JSON body changes the status of the current Registration to the new value. The JSON body has to include the status field with the preferred value. Please see the documentation of the ServiceRegistry implementation you use for the allowed values when updating the status and the values returned for the status. For instance, Eureka’s supported statuses are UP, DOWN, OUT_OF_SERVICE, and UNKNOWN.spring-doc.cn
Spring RestTemplate as a LoadBalancer Client
You can configure a RestTemplate to use a Load-balancer client. To create a load-balanced RestTemplate, create a RestTemplate @Bean and use the @LoadBalanced qualifier, as the following example shows:spring-doc.cn
    @LoadBalanced
    RestTemplate restTemplate() {
        return new RestTemplate();
public class MyClass {
    @Autowired
    private RestTemplate restTemplate;
    public String doOtherStuff() {
        String result = restTemplate.getForObject("http://stores/stores", String.class);
        return result;
A RestTemplate bean is no longer created through auto-configuration. Individual applications must create it.
The URI needs to use a virtual host name (that is, a service name, not a host name). The BlockingLoadBalancerClient is used to create a full physical address.spring-doc.cn
To use a load-balanced RestTemplate, you need to have a Spring Cloud LoadBalancer implementation in your classpath. Add Spring Cloud LoadBalancer starter to your project in order to use it.
Multiple RestTemplate Objects
If you want a RestTemplate that is not load-balanced, create a RestTemplate bean and inject it. To access the load-balanced RestTemplate, use the @LoadBalanced qualifier when you create your @Bean, as the following example shows:spring-doc.cn
    @LoadBalanced
    RestTemplate loadBalanced() {
    @Primary
    @Autowired
    @Autowired
    @LoadBalanced
    private RestTemplate loadBalanced;
        return loadBalanced.getForObject("http://stores/stores", String.class);
    public String doStuff() {
        return restTemplate.getForObject("http://example.com", String.class);
Notice the use of the @Primary annotation on the plain RestTemplate declaration in the preceding example to disambiguate the unqualified @Autowired injection.
If you see errors such as java.lang.IllegalArgumentException: Can not set org.springframework.web.client.RestTemplate field com.my.app.Foo.restTemplate to com.sun.proxy.$Proxy89, try injecting RestOperations or setting spring.aop.proxyTargetClass=true.
Using @LoadBalanced RestTemplateBuilder to create a LoadBalancer Client
You can also configure a RestTemplate to use a Load-Balancer client by annotating a RestTemplateBuilder bean with @LoadBalanced:spring-doc.cn
import org.springframework.boot.web.client.RestTemplateBuilder;@Configuration
	@LoadBalanced
	RestTemplateBuilder loadBalancedRestTemplateBuilder() {
		return new RestTemplateBuilder();
    private final RestTemplate restTemplate;
	MyClass(@LoadBalanced RestTemplateBuilder restTemplateBuilder) {
		this.restTemplate = restTemplateBuilder.build();
    public String getStores() {
        return restTemplate.getForObject("http://stores/stores", String.class);
In order to leverage additional capabilities that Spring Boot provides for RestTemplateBuilder (for example, observability support) you may want to use the autoconfigured RestTemplateBuilderConfigurer while creating the @LoadBalanced RestTemplateBuilder beans:spring-doc.cn
	@LoadBalanced
	RestTemplateBuilder loadBalancedRestTemplateBuilder(RestTemplateBuilderConfigurer configurer) {
		return configurer.configure(new RestTemplateBuilder());
To use it, add Spring Cloud LoadBalancer starter to your project.
Multiple RestTemplateBuilder beans
If you want a RestTemplateBuilder that is not load-balanced, create a RestTemplateBuilder bean and inject it. To access the load-balanced RestTemplateBuilder, use the @LoadBalanced qualifier when you create your @Bean, as the following example shows:spring-doc.cn
    @LoadBalanced
    @Primary
    RestTemplateBuilder restTemplateBuilder() {
    @Autowired
    private RestTemplateBuilder restTemplateBuilder;
    @Autowired
    @LoadBalanced
    private RestTemplateBuilder loadBalanced;
		return restTemplateBuilder.build().getForObject("http://example.com", String.class);
Notice the use of the @Primary annotation on the plain RestTemplateBuilder declaration in the preceding example to disambiguate the unqualified @Autowired injection.
Spring RestClient as a LoadBalancer Client
You can configure a RestClient to use a Load-balancer client. To create a load-balanced RestClient, create a RestClient.Builder @Bean and use the @LoadBalanced qualifier, as the following example shows:spring-doc.cn
    @LoadBalanced
    RestClient.Builder restClientBuilder() {
        return RestClient.builder();
    @Autowired
    private RestClient.Builder restClientBuilder;
        return restClientBuilder.build().get().uri(URI.create("http://stores/stores")).retrieve().body(String.class);
In order to leverage additional capabilities that Spring Boot provides for RestClient.Builder (for example, observability support) you may want to use the autoconfigured RestClientBuilderConfigurer while creating the @LoadBalanced RestClient.Builder beans:spring-doc.cn
    @LoadBalanced
    RestClient.Builder restClientBuilder(RestClientBuilderConfigurer configurer) {
		return configurer.configure(RestClient.builder());
Multiple RestClient.Builder Objects
If you want a RestClient.Builder that is not load-balanced, create a RestClient.Builder bean and inject it. To access the load-balanced RestClient.Builder, use the @LoadBalanced qualifier when you create your @Bean, as the following example shows:spring-doc.cn
    @LoadBalanced
    RestClient.Builder loadBalanced() {
    @Primary
    @Autowired
    @Autowired
    @LoadBalanced
    private RestClient.Builder loadBalanced;
        return loadBalanced.build().get().uri("http://stores/stores")
        return restClientBuilder.build().get().uri("http://example.com")
Notice the use of the @Primary annotation on the plain RestClient.Builder declaration in the preceding example to disambiguate the unqualified @Autowired injection.
Spring WebClient as a LoadBalancer Client
You can configure WebClient to automatically use a load-balancer client. To create a load-balanced WebClient, create a WebClient.Builder @Bean and use the @LoadBalanced qualifier, as follows:spring-doc.cn
	@LoadBalanced
	public WebClient.Builder loadBalancedWebClientBuilder() {
		return WebClient.builder();
    @Autowired
    private WebClient.Builder webClientBuilder;
    public Mono<String> doOtherStuff() {
        return webClientBuilder.build().get().uri("http://stores/stores")
        				.retrieve().bodyToMono(String.class);
The URI needs to use a virtual host name (that is, a service name, not a host name). The Spring Cloud LoadBalancer is used to create a full physical address.spring-doc.cn
In order to leverage additional capabilities that Spring Boot provides for WebClient.Builder (for example, observability support) you may want to use the autoconfigured WebClientCustomizer beans while creating the @LoadBalanced WebClient.Builder beans:spring-doc.cn
	@LoadBalanced
	public WebClient.Builder loadBalancedWebClientBuilder(ObjectProvider<WebClientCustomizer> customizerProvider) {
		WebClient.Builder builder = WebClient.builder();
		customizerProvider.orderedStream().forEach((customizer) -> customizer.customize(builder));
		return builder;
If you want to use a @LoadBalanced WebClient.Builder, you need to have a Spring Cloud LoadBalancer implementation in the classpath. We recommend that you add the Spring Cloud LoadBalancer starter to your project. Then, ReactiveLoadBalancer is used underneath.
Multiple WebClient.Builder Objects
If you want a WebClient.Buider that is not load-balanced, create a WebClient bean and inject it. To access the load-balanced WebClient.Builder, use the @LoadBalanced qualifier when you create your @Bean, as the following example shows:spring-doc.cn
    @LoadBalanced
    WebClient.Builder loadBalanced() {
    @Primary
    WebClient.Builder webClientBuilder() {
    @Autowired
    @Autowired
    @LoadBalanced
    private WebClient.Builder loadBalanced;
    public Mono<String> doStuff() {
        return webClientBuilder.build().get().uri("http://example.com")
Retrying Failed Requests
A load-balanced RestTemplate can be configured to retry failed requests. By default, this logic is disabled. For the non-reactive version (with RestTemplate), you can enable it by adding Spring Retry to your application’s classpath. For the reactive version (with WebTestClient), you need to set spring.cloud.loadbalancer.retry.enabled=true.spring-doc.cn
If you would like to disable the retry logic with Spring Retry or Reactive Retry on the classpath, you can set spring.cloud.loadbalancer.retry.enabled=false.spring-doc.cn
For the non-reactive implementation, if you would like to implement a BackOffPolicy in your retries, you need to create a bean of type LoadBalancedRetryFactory and override the createBackOffPolicy() method.spring-doc.cn
For the reactive implementation, you just need to enable it by setting spring.cloud.loadbalancer.retry.backoff.enabled to false.spring-doc.cn
You can set:spring-doc.cn
  • spring.cloud.loadbalancer.retry.maxRetriesOnSameServiceInstance - indicates how many times a request should be retried on the same ServiceInstance (counted separately for every selected instance)spring-doc.cn
  • spring.cloud.loadbalancer.retry.maxRetriesOnNextServiceInstance - indicates how many times a request should be retried a newly selected ServiceInstancespring-doc.cn
  • spring.cloud.loadbalancer.retry.retryableStatusCodes - the status codes on which to always retry a failed request.spring-doc.cn
For the reactive implementation, you can additionally set: - spring.cloud.loadbalancer.retry.backoff.minBackoff - Sets the minimum backoff duration (by default, 5 milliseconds) - spring.cloud.loadbalancer.retry.backoff.maxBackoff - Sets the maximum backoff duration (by default, max long value of milliseconds) - spring.cloud.loadbalancer.retry.backoff.jitter - Sets the jitter used for calculating the actual backoff duration for each call (by default, 0.5).spring-doc.cn
For the reactive implementation, you can also implement your own LoadBalancerRetryPolicy to have more detailed control over the load-balanced call retries.spring-doc.cn
For both implementations, you can also set the exceptions that trigger the replies by adding a list of values under the spring.cloud.loadbalancer.[serviceId].retry.retryable-exceptions property. If you do, we make sure to add RetryableStatusCodeExceptions to the list of exceptions provided by you, so that we also retry on retryable status codes. If you do not specify any exceptions via properties, the exceptions we use by default are IOException, TimeoutException and RetryableStatusCodeException. You can also enable retrying on all exceptions by setting spring.cloud.loadbalancer.[serviceId].retry.retry-on-all-exceptions to true.spring-doc.cn
If you use the blocking implementation with Spring Retries, if you want to keep the behaviour from previous releases, set spring.cloud.loadbalancer.[serviceId].retry.retry-on-all-exceptions to true as that used to be the default mode for the blocking implementation.
Individual Loadbalancer clients may be configured individually with the same properties as above except the prefix is spring.cloud.loadbalancer.clients.<clientId>.* where clientId is the name of the loadbalancer.
For load-balanced retries, by default, we wrap the ServiceInstanceListSupplier bean with RetryAwareServiceInstanceListSupplier to select a different instance from the one previously chosen, if available. You can disable this behavior by setting the value of spring.cloud.loadbalancer.retry.avoidPreviousInstance to false.
    LoadBalancedRetryFactory retryFactory() {
        return new LoadBalancedRetryFactory() {
            public BackOffPolicy createBackOffPolicy(String service) {
        		return new ExponentialBackOffPolicy();
If you want to add one or more RetryListener implementations to your retry functionality, you need to create a bean of type LoadBalancedRetryListenerFactory and return the RetryListener array you would like to use for a given service, as the following example shows:spring-doc.cn
    LoadBalancedRetryListenerFactory retryListenerFactory() {
        return new LoadBalancedRetryListenerFactory() {
            public RetryListener[] createRetryListeners(String service) {
                return new RetryListener[]{new RetryListener() {
                    public <T, E extends Throwable> boolean open(RetryContext context, RetryCallback<T, E> callback) {
                        //TODO Do you business...
                        return true;
                     public <T, E extends Throwable> void close(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
                    public <T, E extends Throwable> void onError(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
Spring WebFlux WebClient as a Load Balancer Client
The Spring WebFlux can work with both reactive and non-reactive WebClient configurations, as the topics describe:spring-doc.cn
Spring WebFlux WebClient with ReactorLoadBalancerExchangeFilterFunction
You can configure WebClient to use the ReactiveLoadBalancer. If you add Spring Cloud LoadBalancer starter to your project and if spring-webflux is on the classpath, ReactorLoadBalancerExchangeFilterFunction is auto-configured. The following example shows how to configure a WebClient to use reactive load-balancer:spring-doc.cn
    @Autowired
    private ReactorLoadBalancerExchangeFilterFunction lbFunction;
        return WebClient.builder().baseUrl("http://stores")
            .filter(lbFunction)
            .build()
            .get()
            .uri("/stores")
            .retrieve()
The URI needs to use a virtual host name (that is, a service name, not a host name). The ReactorLoadBalancer is used to create a full physical address.spring-doc.cn
Spring WebFlux WebClient with a Non-reactive Load Balancer Client
If spring-webflux is on the classpath, LoadBalancerExchangeFilterFunction is auto-configured. Note, however, that this uses a non-reactive client under the hood. The following example shows how to configure a WebClient to use load-balancer:spring-doc.cn
    @Autowired
    private LoadBalancerExchangeFilterFunction lbFunction;
            .filter(lbFunction)
            .build()
            .get()
            .uri("/stores")
            .retrieve()
The URI needs to use a virtual host name (that is, a service name, not a host name). The LoadBalancerClient is used to create a full physical address.spring-doc.cn
WARN: This approach is now deprecated. We suggest that you use WebFlux with reactive Load-Balancer instead.spring-doc.cn
Ignore Network Interfaces
Sometimes, it is useful to ignore certain named network interfaces so that they can be excluded from Service Discovery registration (for example, when running in a Docker container). A list of regular expressions can be set to cause the desired network interfaces to be ignored. The following configuration ignores the docker0 interface and all interfaces that start with veth:spring-doc.cn
application.yml
spring:
  cloud:
    inetutils:
      ignoredInterfaces:
        - docker0
        - veth.*
You can also force the use of only specified network addresses by using a list of regular expressions, as the following example shows:spring-doc.cn
bootstrap.yml
spring:
  cloud:
    inetutils:
      preferredNetworks:
        - 192.168
        - 10.0
You can also force the use of only site-local addresses, as the following example shows:spring-doc.cn
application.yml
spring:
  cloud:
    inetutils:
      useOnlySiteLocalInterfaces: true
See Inet4Address.html.isSiteLocalAddress() for more details about what constitutes a site-local address.spring-doc.cn
HTTP Client Factories
Spring Cloud Commons provides beans for creating both Apache HTTP clients (ApacheHttpClientFactory) and OK HTTP clients (OkHttpClientFactory). The OkHttpClientFactory bean is created only if the OK HTTP jar is on the classpath. In addition, Spring Cloud Commons provides beans for creating the connection managers used by both clients: ApacheHttpClientConnectionManagerFactory for the Apache HTTP client and OkHttpClientConnectionPoolFactory for the OK HTTP client. If you would like to customize how the HTTP clients are created in downstream projects, you can provide your own implementation of these beans. In addition, if you provide a bean of type HttpClientBuilder or OkHttpClient.Builder, the default factories use these builders as the basis for the builders returned to downstream projects. You can also disable the creation of these beans by setting spring.cloud.httpclientfactories.apache.enabled or spring.cloud.httpclientfactories.ok.enabled to false.spring-doc.cn
Enabled Features
Spring Cloud Commons provides a /features actuator endpoint. This endpoint returns features available on the classpath and whether they are enabled. The information returned includes the feature type, name, version, and vendor.spring-doc.cn
Feature types
There are two types of 'features': abstract and named.spring-doc.cn
Abstract features are features where an interface or abstract class is defined and that an implementation the creates, such as DiscoveryClient, LoadBalancerClient, or LockService. The abstract class or interface is used to find a bean of that type in the context. The version displayed is bean.getClass().getPackage().getImplementationVersion().spring-doc.cn
Named features are features that do not have a particular class they implement. These features include “Circuit Breaker”, “API Gateway”, “Spring Cloud Bus”, and others. These features require a name and a bean type.spring-doc.cn
Declaring features
Any module can declare any number of HasFeature beans, as the following examples show:spring-doc.cn
public HasFeatures commonsFeatures() {
  return HasFeatures.abstractFeatures(DiscoveryClient.class, LoadBalancerClient.class);
public HasFeatures consulFeatures() {
  return HasFeatures.namedFeatures(
    new NamedFeature("Spring Cloud Bus", ConsulBusAutoConfiguration.class),
    new NamedFeature("Circuit Breaker", HystrixCommandAspect.class));
HasFeatures localFeatures() {
  return HasFeatures.builder()
      .abstractFeature(Something.class)
      .namedFeature(new NamedFeature("Some Other Feature", Someother.class))
      .abstractFeature(Somethingelse.class)
Each of these beans should go in an appropriately guarded @Configuration.spring-doc.cn
Spring Cloud Compatibility Verification
Due to the fact that some users have problem with setting up Spring Cloud application, we’ve decided to add a compatibility verification mechanism. It will break if your current setup is not compatible with Spring Cloud requirements, together with a report, showing what exactly went wrong.spring-doc.cn
At the moment we verify which version of Spring Boot is added to your classpath.spring-doc.cn
Example of a reportspring-doc.cn
APPLICATION FAILED TO START
Description:
Your project setup is incompatible with our requirements due to following reasons:
- Spring Boot [2.1.0.RELEASE] is not compatible with this Spring Cloud release train
Action:
Consider applying the following actions:
- Change Spring Boot version to one of the following versions [1.2.x, 1.3.x] .
You can find the latest Spring Boot versions here [https://spring.io/projects/spring-boot#learn].
If you want to learn more about the Spring Cloud Release train compatibility, you can visit this page [https://spring.io/projects/spring-cloud#overview] and check the [Release Trains] section.
In order to disable this feature, set spring.cloud.compatibility-verifier.enabled to false. If you want to override the compatible Spring Boot versions, just set the spring.cloud.compatibility-verifier.compatible-boot-versions property with a comma separated list of compatible Spring Boot versions.spring-doc.cn
