For the latest stable version, please use Spring Cloud Commons 4.2.0!spring-doc.cn
Spring Cloud Circuit Breaker
Spring Cloud Circuit breaker provides an abstraction across different circuit breaker implementations. It provides a consistent API to use in your applications, letting you, the developer, choose the circuit breaker implementation that best fits your needs for your application.spring-doc.cn
Supported Implementations
Spring Cloud supports the following circuit-breaker implementations:spring-doc.cn
Core Concepts
To create a circuit breaker in your code, you can use the CircuitBreakerFactory API. When you include a Spring Cloud Circuit Breaker starter on your classpath, a bean that implements this API is automatically created for you. The following example shows a simple example of how to use this API:spring-doc.cn
@Service
public static class DemoControllerService {
	private RestTemplate rest;
	private CircuitBreakerFactory cbFactory;
	public DemoControllerService(RestTemplate rest, CircuitBreakerFactory cbFactory) {
		this.rest = rest;
		this.cbFactory = cbFactory;
	public String slow() {
		return cbFactory.create("slow").run(() -> rest.getForObject("/slow", String.class), throwable -> "fallback");
The CircuitBreakerFactory.create API creates an instance of a class called CircuitBreaker. The run method takes a Supplier and a Function. The Supplier is the code that you are going to wrap in a circuit breaker. The Function is the fallback that is run if the circuit breaker is tripped. The function is passed the Throwable that caused the fallback to be triggered. You can optionally exclude the fallback if you do not want to provide one.spring-doc.cn
Circuit Breakers In Reactive Code
If Project Reactor is on the class path, you can also use ReactiveCircuitBreakerFactory for your reactive code. The following example shows how to do so:spring-doc.cn
@Service
	private ReactiveCircuitBreakerFactory cbFactory;
	private WebClient webClient;
	public DemoControllerService(WebClient webClient, ReactiveCircuitBreakerFactory cbFactory) {
		this.webClient = webClient;
	public Mono<String> slow() {
		return webClient.get().uri("/slow").retrieve().bodyToMono(String.class).transform(
		it -> cbFactory.create("slow").run(it, throwable -> return Mono.just("fallback")));
The ReactiveCircuitBreakerFactory.create API creates an instance of a class called ReactiveCircuitBreaker. The run method takes a Mono or a Flux and wraps it in a circuit breaker. You can optionally profile a fallback Function, which will be called if the circuit breaker is tripped and is passed the Throwable that caused the failure.spring-doc.cn
Configuration
You can configure your circuit breakers by creating beans of type Customizer. The Customizer interface has a single method (called customize) that takes the Object to customize.spring-doc.cn
For detailed information on how to customize a given implementation see the following documentation:spring-doc.cn
Some CircuitBreaker implementations such as Resilience4JCircuitBreaker call customize method every time CircuitBreaker#run is called. It can be inefficient. In that case, you can use CircuitBreaker#once method. It is useful where calling customize many times doesn’t make sense, for example, in case of consuming Resilience4j’s events.spring-doc.cn
The following example shows the way for each io.github.resilience4j.circuitbreaker.CircuitBreaker to consume events.spring-doc.cn
Customizer.once(circuitBreaker -> {
  circuitBreaker.getEventPublisher()
    .onStateTransition(event -> log.info("{}: {}", event.getCircuitBreakerName(), event.getStateTransition()));
}, CircuitBreaker::getName)
