Installation
To install, make sure you have Spring Boot CLI (2.0.0 or better):
$ spring version
Spring CLI v2.2.3.RELEASE
E.g. for SDKMan users
$ sdk install springboot 2.2.3.RELEASE
$ sdk use springboot 2.2.3.RELEASE
and install the Spring Cloud plugin
$ mvn install
$ spring install org.springframework.cloud:spring-cloud-cli:2.2.0.RELEASE
Prerequisites: to use the encryption and decryption features you need the full-strength JCE installed in your JVM (it’s not there by default). You can download the "Java Cryptography Extension (JCE) Unlimited Strength Jurisdiction Policy Files" from Oracle, and follow instructions for installation (essentially replace the 2 policy files in the JRE lib/security directory with the ones that you downloaded). |
