Running Spring Cloud Services in Development
The Launcher CLI can be used to run common services like Eureka,
Config Server etc. from the command line. To list the available
services you can do spring cloud --list
, and to launch a default set
of services just spring cloud
. To choose the services to deploy,
just list them on the command line, e.g.
$ spring cloud eureka configserver h2 kafka stubrunner zipkin
Summary of supported deployables:
Service | Name | Address | Description |
eureka |
Eureka Server |
Eureka server for service registration and discovery. All the other services show up in its catalog by default. |
configserver |
Config Server |
Spring Cloud Config Server running in the "native" profile and serving configuration from the local directory ./launcher |
h2 |
H2 Database |
http://localhost:9095 (console), jdbc:h2:tcp://localhost:9096/{data} |
Relation database service. Use a file path for |
kafka |
Kafka Broker |
http://localhost:9091 (actuator endpoints), localhost:9092 |
dataflow |
Dataflow Server |
Spring Cloud Dataflow server with UI at /admin-ui. Connect the Dataflow shell to target at root path. |
zipkin |
Zipkin Server |
Zipkin Server with UI for visualizing traces. Stores span data in memory and accepts them via HTTP POST of JSON data. |
stubrunner |
Stub Runner Boot |
Downloads WireMock stubs, starts WireMock and feeds the started servers with stored stubs. Pass |
Each of these apps can be configured using a local YAML file with the same name (in the current
working directory or a subdirectory called "config" or in ~/.spring-cloud
). E.g. in configserver.yml
you might want to
do something like this to locate a local git repository for the backend:
spring:
profiles:
active: git
cloud:
config:
server:
git:
uri: file://${user.home}/dev/demo/config-repo
E.g. in Stub Runner app you could fetch stubs from your local .m2
in the following way.
stubrunner:
workOffline: true
ids:
- com.example:beer-api-producer:+:9876
Adding Additional Applications
Additional applications can be added to ./config/cloud.yml
(not
./config.yml
because that would replace the defaults), e.g. with
spring:
cloud:
launcher:
deployables:
source:
coordinates: maven://com.example:source:0.0.1-SNAPSHOT
port: 7000
sink:
coordinates: maven://com.example:sink:0.0.1-SNAPSHOT
port: 7001
when you list the apps:
$ spring cloud --list
source sink configserver dataflow eureka h2 kafka stubrunner zipkin
(notice the additional apps at the start of the list).
