This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-bus 4.2.0! |
Bus Endpoints
Spring Cloud Bus provides three endpoints, /actuator/busrefresh
, /actutator/busshutdown
and /actuator/busenv
that correspond to individual actuator endpoints in Spring Cloud Commons,
/actuator/refresh
, /actuator/shutdown
, and /actuator/env
respectively.
Bus Refresh Endpoint
The /actuator/busrefresh
endpoint clears the RefreshScope
cache and rebinds
@ConfigurationProperties
. See the Refresh Scope documentation for
more information.
To expose the /actuator/busrefresh
endpoint, you need to add following configuration to your
application:
management.endpoints.web.exposure.include=busrefresh
Bus Env Endpoint
The /actuator/busenv
endpoint updates each instances environment with the specified
key/value pair across multiple instances.
To expose the /actuator/busenv
application:
management.endpoints.web.exposure.include=busenv
endpoint accepts POST
requests with the following shape:
"name": "key1",
"value": "value1"
Bus Shutdown Endpoint
The /actuator/busshutdown
shuts down the application gracefully.
To expose the /actuator/busshutdown
application:
management.endpoints.web.exposure.include=busshutdown
You can make a request to the busshutdown
endpoint by issuing a POST
request.
If you would like to target a specific application you can issue a POST
request to /busshutdown
and optionally
specify the bus id:
$ curl -X POST http://localhost:8080/actuator/busshutdown
You can also target a specific application instance by specifying the bus id:
$ curl -X POST http://localhost:8080/actuator/busshutdown/busid:123
