This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-bus 4.2.0!spring-doc.cn
Addressing Instances
Addressing an Instance
Each instance of the application has a service ID, whose value can be set with spring.cloud.bus.id and whose value is expected to be a colon-separated list of identifiers, in order from least specific to most specific. The default value is constructed from the environment as a combination of the spring.application.name and server.port (or spring.application.index, if set). The default value of the ID is constructed in the form of app:index:id, where:spring-doc.cn
  • app is the vcap.application.name, if it exists, or spring.application.namespring-doc.cn
  • index is the vcap.application.instance_index, if it exists, spring.application.index, local.server.port, server.port, or 0 (in that order).spring-doc.cn
  • id is the vcap.application.instance_id, if it exists, or a random value.spring-doc.cn
The HTTP endpoints accept a “destination” path parameter, such as /busrefresh/customers:9000, where destination is a service ID. If the ID is owned by an instance on the bus, it processes the message, and all other instances ignore it.spring-doc.cn
Addressing All Instances of a Service
The “destination” parameter is used in a Spring PathMatcher (with the path separator as a colon — :) to determine if an instance processes the message. Using the example from earlier, /busenv/customers:** targets all instances of the “customers” service regardless of the rest of the service ID.spring-doc.cn
Service ID Must Be Unique
The bus tries twice to eliminate processing an event — once from the original ApplicationEvent and once from the queue. To do so, it checks the sending service ID against the current service ID. If multiple instances of a service have the same ID, events are not processed. When running on a local machine, each service is on a different port, and that port is part of the ID. Cloud Foundry supplies an index to differentiate. To ensure that the ID is unique outside Cloud Foundry, set spring.application.index to something unique for each instance of a service.spring-doc.cn
