For the latest stable version, please use spring-cloud-bus 4.2.0!spring-doc.cn
Bus Endpoints
Spring Cloud Bus provides two endpoints, /actuator/busrefresh and /actuator/busenv that correspond to individual actuator endpoints in Spring Cloud Commons, /actuator/refresh and /actuator/env respectively.spring-doc.cn
Bus Refresh Endpoint
The /actuator/busrefresh endpoint clears the RefreshScope cache and rebinds @ConfigurationProperties. See the Refresh Scope documentation for more information.spring-doc.cn
To expose the /actuator/busrefresh endpoint, you need to add following configuration to your application:spring-doc.cn
management.endpoints.web.exposure.include=busrefresh
Bus Env Endpoint
The /actuator/busenv endpoint updates each instances environment with the specified key/value pair across multiple instances.spring-doc.cn
To expose the /actuator/busenv endpoint, you need to add following configuration to your application:spring-doc.cn
management.endpoints.web.exposure.include=busenv
The /actuator/busenv endpoint accepts POST requests with the following shape:spring-doc.cn
	"name": "key1",
	"value": "value1"
