7. Deployment Platforms
You can configure details of deployment platforms in App Broker configuration properties. These properties are under spring.cloud.appbroker.deployer. Currently, Spring Cloud App Broker supports only Cloud Foundry as a deployment platform.spring-doc.cn
To configure a Cloud Foundry deployment platform, use properties under spring.cloud.appbroker.deployer.cloudfoundry, as follows:spring-doc.cn
spring:
  cloud:
    appbroker:
      deployer:
        cloudfoundry:
          api-host: api.sys.example.local
          api-port: 443
          username: admin
          password: adminpass
          client-id: EXAMPLE_ID
          client-secret: EXAMPLE_SECRET
          default-org: test
          default-space: development
          staging-timeout: 15
          deployment-timeout: 10
The two properties, username and password, and the two properties, client-id and client-secret, are mutually exclusive. The client-id and client-secret properties are for use with OAuth 2.0.
