2. Getting Started
To get started, create a Spring Boot application and include the Spring Cloud App Broker dependency in the application’s build file.
2.1. Maven Dependencies
If you use Maven, include the following in your application’s pom.xml
file:
<dependencies>
<dependency>
<artifactId>spring-cloud-starter-app-broker-cloudfoundry</artifactId>
<version>1.6.2</version>
</dependency>
</dependencies>
2.2. Gradle Dependencies
If you use Gradle, include the following in your application’s build.gradle
file:
dependencies {
api 'org.springframework.cloud:spring-cloud-starter-app-broker-cloudfoundry:1.6.2'
2.3. Configuring the Service Broker
The service broker is configured with Spring Boot externalized configuration, supplied by a YAML or Java Properties file (for example, you can provide configuration in the application.yml
file). Because Spring Cloud App Broker builds on Spring Cloud Open Service Broker, you must provide Spring Cloud Open Service Broker configuration to use Spring Cloud App Broker.
To do so, include Spring Cloud Open Servce Broker configuration using properties under spring.cloud.openservicebroker
as follows:
spring:
cloud:
openservicebroker:
catalog:
services:
- name: example
description: A useful service
bindable: true
tags:
- example
plans:
- name: standard
description: A standard plan
free: true
Then include Spring Cloud App Broker configuration using properties under spring.cloud.appbroker
, as follows:
spring:
cloud:
appbroker:
services:
- service-name: example
plan-name: standard
apps:
- name: example-service-app1
path: classpath:app1.jar
- name: example-service-app2
path: classpath:app2.jar
deployer:
cloudfoundry:
api-host: api.sys.example.local
api-port: 443
username: admin
password: adminpass
default-org: test
default-space: development
