Getting Started
Creating a new project is as simple as typing spring boot new my-app
The output is
Cloning project from https://github.com/rd-1-2022/rest-service
Created project in directory 'my-app'
If the CLI seems to be stuck at the cloning step, you might be hitting GitHub rate limiting. Use the spring github auth login command to authenticate.
You can now cd
into the my-app
directory and build and run the application, which is, by default, a simple web application with a single endpoint:
cd my-app
./mvnw spring-boot:run
Then, in another terminal windows, you can interact with the endpoint by using curl:
curl http://localhost:8080/greeting
The curl command returns the default 'Hello World' greeting:
{"id":1,"content":"Hello, World!"}
The README.adoc file in the new project contains more information on how the web applications works.
Next steps
The Creating New Projects section shows you how to create applications other than the default application.
The Adding To Existing Projects section shows you how to add additional applications into your current working project.
