此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.0! |
映射 (mappings
这mappings
endpoint 提供有关应用程序的请求映射的信息。
检索映射
要检索映射,请创建一个GET
request 添加到/actuator/mappings
,如以下基于 curl 的示例所示:
$ curl 'http://localhost:42221/actuator/mappings' -i -X GET \
-H 'accept-encoding: gzip' \
-H 'user-agent: ReactorNetty/1.2.0' \
-H 'accept: */*'
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Transfer-Encoding: chunked
Date: Fri, 29 Nov 2024 09:49:47 GMT
Content-Length: 5342
"contexts" : {
"application" : {
"mappings" : {
"dispatcherServlets" : {
"dispatcherServlet" : [ {
"handler" : "Actuator web endpoint 'mappings'",
"predicate" : "{GET [/actuator/mappings], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping.OperationHandler",
"name" : "handle",
"descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljava/util/Map;)Ljava/lang/Object;"
"requestMappingConditions" : {
"consumes" : [ ],
"headers" : [ ],
"methods" : [ "GET" ],
"params" : [ ],
"patterns" : [ "/actuator/mappings" ],
"produces" : [ {
"mediaType" : "application/vnd.spring-boot.actuator.v3+json",
"negated" : false
"mediaType" : "application/vnd.spring-boot.actuator.v2+json",
"negated" : false
"mediaType" : "application/json",
"negated" : false
"handler" : "Actuator root web endpoint",
"predicate" : "{GET [/actuator], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.WebMvcEndpointHandlerMapping.WebMvcLinksHandler",
"name" : "links",
"descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljakarta/servlet/http/HttpServletResponse;)Ljava/util/Map;"
"consumes" : [ ],
"headers" : [ ],
"params" : [ ],
"patterns" : [ "/actuator" ],
"produces" : [ {
"negated" : false
"negated" : false
"negated" : false
"handler" : "org.springframework.boot.actuate.autoconfigure.endpoint.web.documentation.MappingsEndpointServletDocumentationTests$ExampleController#example()",
"predicate" : "{POST [/], params [a!=alpha], headers [X-Custom=Foo], consumes [application/json || !application/xml], produces [text/plain]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.autoconfigure.endpoint.web.documentation.MappingsEndpointServletDocumentationTests.ExampleController",
"name" : "example",
"descriptor" : "()Ljava/lang/String;"
"consumes" : [ {
"negated" : false
"mediaType" : "application/xml",
"negated" : true
"headers" : [ {
"name" : "X-Custom",
"value" : "Foo",
"negated" : false
"methods" : [ "POST" ],
"params" : [ {
"name" : "a",
"value" : "alpha",
"negated" : true
"patterns" : [ "/" ],
"produces" : [ {
"mediaType" : "text/plain",
"negated" : false
"handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/webjars/]]",
"predicate" : "/webjars/**"
"handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/], classpath [resources/], classpath [static/], classpath [public/], ServletContext [/]]",
"predicate" : "/**"
"servletFilters" : [ {
"urlPatternMappings" : [ "/*" ],
"servletNameMappings" : [ ],
"name" : "requestContextFilter",
"className" : "org.springframework.boot.web.servlet.filter.OrderedRequestContextFilter"
"name" : "formContentFilter",
"className" : "org.springframework.boot.web.servlet.filter.OrderedFormContentFilter"
"servlets" : [ {
"mappings" : [ "/" ],
"name" : "dispatcherServlet",
"className" : "org.springframework.web.servlet.DispatcherServlet"
响应结构
响应包含应用程序映射的详细信息。 在响应中找到的项目取决于 Web 应用程序的类型(反应式或基于 Servlet)。 下表描述了响应的常见元素的结构:
路径 | 类型 | 描述 |
以 id 为键的应用程序上下文。 |
上下文中的映射,按 mapping type 键控。 |
Dispatcher Servlet 映射(如果有)。 |
Servlet 过滤器映射(如果有)。 |
Servlet 映射(如果有)。 |
Dispatcher 处理程序映射(如果有)。 |
父应用程序上下文的 ID(如果有)。 |
可以在contexts.*.mappings
在以下各节中进行了介绍。
Dispatcher Servlet 响应结构
使用 Spring MVC 时,响应包含任何DispatcherServlet
请求映射contexts.*.mappings.dispatcherServlets
下表描述了响应的这一部分的结构:
路径 | 类型 | 描述 |
Dispatcher Servlet 映射(如果有),按 Dispatcher Servlet Bean 名称进行键控。 |
有关映射的其他特定于实现的详细信息。自选。 |
映射的处理程序。 |
映射的谓词。 |
将处理对此映射的请求的方法(如果有)的详细信息。 |
方法类的完全限定名称。 |
方法的名称。 |
Java 语言规范中指定的方法的描述符。 |
请求映射条件的详细信息。 |
consumes 条件的详细信息 |
使用的媒体类型。 |
媒体类型是否为否定。 |
headers 条件的详细信息。 |
标头的名称。 |
标头的必需值(如果有)。 |
该值是否为反值。 |
已处理的 HTTP 方法。 |
params 条件的详细信息。 |
参数的名称。 |
参数的必需值(如果有)。 |
该值是否为反值。 |
标识映射处理的路径的模式。 |
produce 条件的详细信息。 |
生成的媒体类型。 |
媒体类型是否为否定。 |
Servlet 响应结构
使用 Servlet 堆栈时,响应包含任何Servlet
映射contexts.*.mappings.servlets
下表描述了响应的这一部分的结构:
路径 | 类型 | 描述 |
Servlet 的映射。 |
Servlet 的名称。 |
Servlet 的类名 |
Servlet 过滤器响应结构
使用 Servlet 堆栈时,响应包含任何Filter
映射contexts.*.mappings.servletFilters
下表描述了响应的这一部分的结构:
路径 | 类型 | 描述 |
过滤器映射到的 Servlet 的名称。 |
过滤器映射到的 URL 模式。 |
筛选器的名称。 |
过滤器的类名 |
Dispatcher 处理程序响应结构
使用 Spring WebFlux 时,响应包含任何DispatcherHandler
请求映射contexts.*.mappings.dispatcherHandlers
下表描述了响应的这一部分的结构:
路径 | 类型 | 描述 |
调度程序处理程序映射(如果有),以调度程序处理程序 Bean 名称为键。 |
映射的处理程序。 |
映射的谓词。 |
请求映射条件的详细信息。 |
consumes 条件的详细信息 |
使用的媒体类型。 |
媒体类型是否为否定。 |
headers 条件的详细信息。 |
标头的名称。 |
标头的必需值(如果有)。 |
该值是否为反值。 |
已处理的 HTTP 方法。 |
params 条件的详细信息。 |
参数的名称。 |
参数的必需值(如果有)。 |
该值是否为反值。 |
标识映射处理的路径的模式。 |
produce 条件的详细信息。 |
生成的媒体类型。 |
媒体类型是否为否定。 |
方法类的完全限定名称。 |
方法的名称。 |
将处理对此映射的请求的函数(如果有)的详细信息。 |
函数类的完全限定名称。 |
