For the latest stable version, please use Spring Boot 3.4.0!spring-doc.cn
Web Services
Spring Boot provides Web Services auto-configuration so that all you must do is define your @Endpoint beans.spring-doc.cn
The Spring Web Services features can be easily accessed with the spring-boot-starter-webservices module.spring-doc.cn
SimpleWsdl11Definition and SimpleXsdSchema beans can be automatically created for your WSDLs and XSDs respectively. To do so, configure their location, as shown in the following example:spring-doc.cn
spring.webservices.wsdl-locations=classpath:/wsdl
spring:
  webservices:
    wsdl-locations: "classpath:/wsdl"
Calling Web Services with WebServiceTemplate
If you need to call remote Web services from your application, you can use the WebServiceTemplate class. Since WebServiceTemplate instances often need to be customized before being used, Spring Boot does not provide any single auto-configured WebServiceTemplate bean. It does, however, auto-configure a WebServiceTemplateBuilder, which can be used to create WebServiceTemplate instances when needed.spring-doc.cn
The following code shows a typical example:spring-doc.cn
import org.springframework.boot.webservices.client.WebServiceTemplateBuilder;
import org.springframework.stereotype.Service;
import org.springframework.ws.client.core.WebServiceTemplate;
import org.springframework.ws.soap.client.core.SoapActionCallback;
@Service
public class MyService {
	private final WebServiceTemplate webServiceTemplate;
	public MyService(WebServiceTemplateBuilder webServiceTemplateBuilder) {
		this.webServiceTemplate = webServiceTemplateBuilder.build();
	public SomeResponse someWsCall(SomeRequest detailsReq) {
		return (SomeResponse) this.webServiceTemplate.marshalSendAndReceive(detailsReq,
				new SoapActionCallback("https://ws.example.com/action"));
@Service
class MyService(webServiceTemplateBuilder: WebServiceTemplateBuilder) {
	private val webServiceTemplate: WebServiceTemplate
	init {
	fun someWsCall(detailsReq: SomeRequest?): SomeResponse {
		return webServiceTemplate.marshalSendAndReceive(
			detailsReq,
		) as SomeResponse
By default, WebServiceTemplateBuilder detects a suitable HTTP-based WebServiceMessageSender using the available HTTP client libraries on the classpath. You can also customize read and connection timeouts as follows:spring-doc.cn
import java.time.Duration;
import org.springframework.boot.webservices.client.HttpWebServiceMessageSenderBuilder;
import org.springframework.ws.transport.WebServiceMessageSender;
public class MyWebServiceTemplateConfiguration {
	public WebServiceTemplate webServiceTemplate(WebServiceTemplateBuilder builder) {
		WebServiceMessageSender sender = new HttpWebServiceMessageSenderBuilder()
				.setConnectTimeout(Duration.ofSeconds(5))
				.setReadTimeout(Duration.ofSeconds(2))
		return builder.messageSenders(sender).build();
	fun webServiceTemplate(builder: WebServiceTemplateBuilder): WebServiceTemplate {
		val sender = HttpWebServiceMessageSenderBuilder()
			.build()
