This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Authorization Server 1.5.0! |
Protocol Endpoints
OAuth2 Authorization Endpoint
OAuth2AuthorizationEndpointConfigurer
provides the ability to customize the OAuth2 Authorization endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 authorization requests.
provides the following configuration options:
public SecurityFilterChain authorizationServerSecurityFilterChain(HttpSecurity http) throws Exception {
OAuth2AuthorizationServerConfigurer authorizationServerConfigurer =
OAuth2AuthorizationServerConfigurer.authorizationServer();
http
.securityMatcher(authorizationServerConfigurer.getEndpointsMatcher())
.with(authorizationServerConfigurer, (authorizationServer) ->
authorizationServer
.authorizationEndpoint(authorizationEndpoint ->
.authorizationRequestConverter(authorizationRequestConverter) (1)
.authorizationRequestConverters(authorizationRequestConvertersConsumer) (2)
.authenticationProvider(authenticationProvider) (3)
.authenticationProviders(authenticationProvidersConsumer) (4)
.authorizationResponseHandler(authorizationResponseHandler) (5)
.errorResponseHandler(errorResponseHandler) (6)
.consentPage("/oauth2/v1/authorize") (7)
return http.build();
1 | authorizationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 authorization request (or consent) from HttpServletRequest to an instance of OAuth2AuthorizationCodeRequestAuthenticationToken or OAuth2AuthorizationConsentAuthenticationToken . |
2 | authorizationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2AuthorizationCodeRequestAuthenticationToken or OAuth2AuthorizationConsentAuthenticationToken . |
4 | authenticationProviders() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationProvider 's allowing the ability to add, remove, or customize a specific AuthenticationProvider . |
5 | authorizationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2AuthorizationCodeRequestAuthenticationToken and returning the OAuth2AuthorizationResponse. |
6 | errorResponseHandler() : The AuthenticationFailureHandler (post-processor) used for handling an OAuth2AuthorizationCodeRequestAuthenticationException and returning the OAuth2Error response. |
7 | consentPage() : The URI of the custom consent page to redirect resource owners to if consent is required during the authorization request flow. |
configures the OAuth2AuthorizationEndpointFilter
and registers it with the OAuth2 authorization server SecurityFilterChain
is the Filter
that processes OAuth2 authorization requests (and consents).
is configured with the following defaults:
— ADelegatingAuthenticationConverter
composed ofOAuth2AuthorizationCodeRequestAuthenticationConverter
andOAuth2AuthorizationConsentAuthenticationConverter
AuthenticationManager
— AnAuthenticationManager
composed ofOAuth2AuthorizationCodeRequestAuthenticationProvider
andOAuth2AuthorizationConsentAuthenticationProvider
— An internal implementation that handles an “authenticated”OAuth2AuthorizationCodeRequestAuthenticationToken
and returns theOAuth2AuthorizationResponse
— An internal implementation that uses theOAuth2Error
associated with theOAuth2AuthorizationCodeRequestAuthenticationException
and returns theOAuth2Error
response.
Customizing Authorization Request Validation
OAuth2AuthorizationCodeRequestAuthenticationValidator
is the default validator used for validating specific OAuth2 authorization request parameters used in the Authorization Code Grant.
The default implementation validates the redirect_uri
and scope
parameters.
If validation fails, an OAuth2AuthorizationCodeRequestAuthenticationException
is thrown.
provides the ability to override the default authorization request validation by supplying a custom authentication validator of type Consumer<OAuth2AuthorizationCodeRequestAuthenticationContext>
to setAuthenticationValidator()
OAuth2AuthorizationCodeRequestAuthenticationContext holds the OAuth2AuthorizationCodeRequestAuthenticationToken , which contains the OAuth2 authorization request parameters.
If validation fails, the authentication validator MUST throw OAuth2AuthorizationCodeRequestAuthenticationException .
A common use case during the development life cycle phase is to allow for localhost
in the redirect_uri
parameter.
The following example shows how to configure OAuth2AuthorizationCodeRequestAuthenticationProvider
with a custom authentication validator that allows for localhost
in the redirect_uri
parameter:
http
authorizationServer
.authenticationProviders(configureAuthenticationValidator())
private Consumer<List<AuthenticationProvider>> configureAuthenticationValidator() {
return (authenticationProviders) ->
authenticationProviders.forEach((authenticationProvider) -> {
if (authenticationProvider instanceof OAuth2AuthorizationCodeRequestAuthenticationProvider) {
Consumer<OAuth2AuthorizationCodeRequestAuthenticationContext> authenticationValidator =
// Override default redirect_uri validator
new CustomRedirectUriValidator()
// Reuse default scope validator
.andThen(OAuth2AuthorizationCodeRequestAuthenticationValidator.DEFAULT_SCOPE_VALIDATOR);
((OAuth2AuthorizationCodeRequestAuthenticationProvider) authenticationProvider)
.setAuthenticationValidator(authenticationValidator);
static class CustomRedirectUriValidator implements Consumer<OAuth2AuthorizationCodeRequestAuthenticationContext> {
public void accept(OAuth2AuthorizationCodeRequestAuthenticationContext authenticationContext) {
OAuth2AuthorizationCodeRequestAuthenticationToken authorizationCodeRequestAuthentication =
authenticationContext.getAuthentication();
RegisteredClient registeredClient = authenticationContext.getRegisteredClient();
String requestedRedirectUri = authorizationCodeRequestAuthentication.getRedirectUri();
// Use exact string matching when comparing client redirect URIs against pre-registered URIs
if (!registeredClient.getRedirectUris().contains(requestedRedirectUri)) {
OAuth2Error error = new OAuth2Error(OAuth2ErrorCodes.INVALID_REQUEST);
throw new OAuth2AuthorizationCodeRequestAuthenticationException(error, null);
OAuth2 Pushed Authorization Request Endpoint
OAuth2PushedAuthorizationRequestEndpointConfigurer
provides the ability to customize the OAuth2 Pushed Authorization Request endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 Pushed Authorization requests.
http
authorizationServer
.pushedAuthorizationRequestEndpoint(pushedAuthorizationRequestEndpoint ->
.pushedAuthorizationRequestConverter(pushedAuthorizationRequestConverter) (1)
.pushedAuthorizationRequestConverters(pushedAuthorizationRequestConvertersConsumer) (2)
.pushedAuthorizationResponseHandler(pushedAuthorizationResponseHandler) (5)
1 | pushedAuthorizationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 pushed authorization request from HttpServletRequest to an instance of OAuth2PushedAuthorizationRequestAuthenticationToken . |
2 | pushedAuthorizationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2PushedAuthorizationRequestAuthenticationToken . |
5 | pushedAuthorizationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2PushedAuthorizationRequestAuthenticationToken and returning the OAuth2 pushed authorization response. |
6 | errorResponseHandler() : The AuthenticationFailureHandler (post-processor) used for handling an OAuth2AuthenticationException and returning the OAuth2Error response. |
configures the OAuth2PushedAuthorizationRequestEndpointFilter
is the Filter
that processes OAuth2 pushed authorization requests.
composed ofOAuth2PushedAuthorizationRequestAuthenticationProvider
— An internal implementation that handles an “authenticated”OAuth2PushedAuthorizationRequestAuthenticationToken
and returns the OAuth2 pushed authorization response. -
— AnOAuth2ErrorAuthenticationFailureHandler
Customizing Pushed Authorization Request Validation
is the default validator used for validating specific OAuth2 pushed authorization request parameters used in the Authorization Code Grant.
and scope
parameters.
is thrown.
provides the ability to override the default pushed authorization request validation by supplying a custom authentication validator of type Consumer<OAuth2AuthorizationCodeRequestAuthenticationContext>
OAuth2AuthorizationCodeRequestAuthenticationContext holds the OAuth2AuthorizationCodeRequestAuthenticationToken , which contains the OAuth2 pushed authorization request parameters.
in the redirect_uri
parameter.
The following example shows how to configure OAuth2PushedAuthorizationRequestAuthenticationProvider
in the redirect_uri
parameter:
http
authorizationServer
if (authenticationProvider instanceof OAuth2PushedAuthorizationRequestAuthenticationProvider) {
((OAuth2PushedAuthorizationRequestAuthenticationProvider) authenticationProvider)
OAuth2 Device Authorization Endpoint
OAuth2DeviceAuthorizationEndpointConfigurer
provides the ability to customize the OAuth2 Device Authorization endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 device authorization requests.
http
authorizationServer
.deviceAuthorizationEndpoint(deviceAuthorizationEndpoint ->
.deviceAuthorizationRequestConverter(deviceAuthorizationRequestConverter) (1)
.deviceAuthorizationRequestConverters(deviceAuthorizationRequestConvertersConsumer) (2)
.deviceAuthorizationResponseHandler(deviceAuthorizationResponseHandler) (5)
.verificationUri("/oauth2/v1/device_verification") (7)
1 | deviceAuthorizationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 device authorization request from HttpServletRequest to an instance of OAuth2DeviceAuthorizationRequestAuthenticationToken . |
2 | deviceAuthorizationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2DeviceAuthorizationRequestAuthenticationToken . |
5 | deviceAuthorizationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2DeviceAuthorizationRequestAuthenticationToken and returning the OAuth2DeviceAuthorizationResponse. |
7 | verificationUri() : The URI of the custom end-user verification page to direct resource owners to on a secondary device. |
configures the OAuth2DeviceAuthorizationEndpointFilter
is the Filter
that processes OAuth2 device authorization requests.
— AnOAuth2DeviceAuthorizationRequestAuthenticationConverter
composed ofOAuth2DeviceAuthorizationRequestAuthenticationProvider
— An internal implementation that handles an “authenticated”OAuth2DeviceAuthorizationRequestAuthenticationToken
and returns theOAuth2DeviceAuthorizationResponse
OAuth2 Device Verification Endpoint
OAuth2DeviceVerificationEndpointConfigurer
provides the ability to customize the OAuth2 Device Verification endpoint (or "User Interaction").
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 device verification requests.
http
authorizationServer
.deviceVerificationEndpoint(deviceVerificationEndpoint ->
.deviceVerificationRequestConverter(deviceVerificationRequestConverter) (1)
.deviceVerificationRequestConverters(deviceVerificationRequestConvertersConsumer) (2)
.deviceVerificationResponseHandler(deviceVerificationResponseHandler) (5)
.consentPage("/oauth2/v1/consent") (7)
1 | deviceVerificationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 device verification request (or consent) from HttpServletRequest to an instance of OAuth2DeviceVerificationAuthenticationToken or OAuth2DeviceAuthorizationConsentAuthenticationToken . |
2 | deviceVerificationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2DeviceVerificationAuthenticationToken or OAuth2DeviceAuthorizationConsentAuthenticationToken . |
5 | deviceVerificationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2DeviceVerificationAuthenticationToken and directing the resource owner to return to their device. |
6 | errorResponseHandler() : The AuthenticationFailureHandler (post-processor) used for handling an OAuth2AuthenticationException and returning the error response. |
7 | consentPage() : The URI of the custom consent page to redirect resource owners to if consent is required during the device verification request flow. |
configures the OAuth2DeviceVerificationEndpointFilter
is the Filter
that processes OAuth2 device verification requests (and consents).
composed ofOAuth2DeviceVerificationAuthenticationConverter
andOAuth2DeviceAuthorizationConsentAuthenticationConverter
composed ofOAuth2DeviceVerificationAuthenticationProvider
andOAuth2DeviceAuthorizationConsentAuthenticationProvider
— ASimpleUrlAuthenticationSuccessHandler
that handles an “authenticated”OAuth2DeviceVerificationAuthenticationToken
and redirects the user to a success page (/?success
associated with theOAuth2AuthenticationException
response.
OAuth2 Token Endpoint
OAuth2TokenEndpointConfigurer
provides the ability to customize the OAuth2 Token endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 access token requests.
http
authorizationServer
.tokenEndpoint(tokenEndpoint ->
tokenEndpoint
.accessTokenRequestConverter(accessTokenRequestConverter) (1)
.accessTokenRequestConverters(accessTokenRequestConvertersConsumer) (2)
.accessTokenResponseHandler(accessTokenResponseHandler) (5)
1 | accessTokenRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 access token request from HttpServletRequest to an instance of OAuth2AuthorizationGrantAuthenticationToken . |
2 | accessTokenRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2AuthorizationGrantAuthenticationToken . |
5 | accessTokenResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an OAuth2AccessTokenAuthenticationToken and returning the OAuth2AccessTokenResponse . |
configures the OAuth2TokenEndpointFilter
is the Filter
that processes OAuth2 access token requests.
The supported authorization grant types are authorization_code
, refresh_token
, client_credentials
, urn:ietf:params:oauth:grant-type:device_code
, and urn:ietf:params:oauth:grant-type:token-exchange
composed ofOAuth2AuthorizationCodeAuthenticationConverter
,OAuth2RefreshTokenAuthenticationConverter
,OAuth2ClientCredentialsAuthenticationConverter
,OAuth2DeviceCodeAuthenticationConverter
, andOAuth2TokenExchangeAuthenticationConverter
composed ofOAuth2AuthorizationCodeAuthenticationProvider
,OAuth2RefreshTokenAuthenticationProvider
,OAuth2ClientCredentialsAuthenticationProvider
,OAuth2DeviceCodeAuthenticationProvider
, andOAuth2TokenExchangeAuthenticationProvider
— AnOAuth2AccessTokenResponseAuthenticationSuccessHandler
Customizing Client Credentials Grant Request Validation
OAuth2ClientCredentialsAuthenticationValidator
is the default validator used for validating specific OAuth2 Client Credentials Grant request parameters.
The default implementation validates the scope
parameter.
If validation fails, an OAuth2AuthenticationException
is thrown.
provides the ability to override the default request validation by supplying a custom authentication validator of type Consumer<OAuth2ClientCredentialsAuthenticationContext>
OAuth2ClientCredentialsAuthenticationContext holds the OAuth2ClientCredentialsAuthenticationToken , which contains the OAuth2 Client Credentials Grant request parameters.
If validation fails, the authentication validator MUST throw OAuth2AuthenticationException .
The following example shows how to configure OAuth2ClientCredentialsAuthenticationProvider
with a custom authentication validator that overrides the default scope
validation:
http
authorizationServer
tokenEndpoint
if (authenticationProvider instanceof OAuth2ClientCredentialsAuthenticationProvider) {
Consumer<OAuth2ClientCredentialsAuthenticationContext> authenticationValidator =
new CustomScopeValidator();
// Override default scope validation
((OAuth2ClientCredentialsAuthenticationProvider) authenticationProvider)
static class CustomScopeValidator implements Consumer<OAuth2ClientCredentialsAuthenticationContext> {
public void accept(OAuth2ClientCredentialsAuthenticationContext authenticationContext) {
OAuth2ClientCredentialsAuthenticationToken clientCredentialsAuthentication =
Set<String> requestedScopes = clientCredentialsAuthentication.getScopes();
Set<String> allowedScopes = registeredClient.getScopes();
// TODO Implement scope validation
DPoP-bound Access Tokens
RFC 9449 OAuth 2.0 Demonstrating Proof of Possession (DPoP) is an application-level mechanism for sender-constraining an access token.
The primary goal of DPoP is to prevent unauthorized or illegitimate clients from using leaked or stolen access tokens, by binding an access token to a public key upon issuance by the authorization server and requiring that the client proves possession of the corresponding private key when using the access token at the resource server.
Access tokens that are sender-constrained via DPoP stand in contrast to the typical bearer token, which can be used by any client in possession of the access token.
DPoP introduces the concept of a DPoP Proof, which is a JWT created by the client and sent as a header in an HTTP request. A client uses a DPoP proof to prove the possession of a private key corresponding to a certain public key.
When the client initiates an access token request, it attaches a DPoP proof to the request in an HTTP header. The authorization server binds (sender-constrains) the access token to the public key associated in the DPoP proof.
When the client initiates a protected resource request, it again attaches a DPoP proof to the request in an HTTP header.
The resource server obtains information about the public key bound to the access token, either directly in the access token (JWT) or via the OAuth2 Token Introspection endpoint. The resource server then verifies that the public key bound to the access token matches the public key in the DPoP proof. It also verifies that the access token hash in the DPoP proof matches the access token in the request.
DPoP Access Token Request
To request an access token that is bound to a public key using DPoP, the client MUST provide a valid DPoP proof in the DPoP
header when making an access token request to the OAuth2 Token endpoint.
This is applicable for all access token requests regardless of authorization grant type (e.g. authorization_code
, refresh_token
, etc).
The following HTTP request shows an authorization_code
access token request with a DPoP proof in the DPoP
header:
POST /oauth2/token HTTP/1.1
Host: server.example.com
Content-Type: application/x-www-form-urlencoded
DPoP: 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.eyJodG0iOiJQT1NUIiwiaHR1IjoiaHR0cHM6Ly9zZXJ2ZXIuZXhhbXBsZS5jb20vb2F1dGgyL3Rva2VuIiwiaWF0IjoxNzQ2ODA2MzA1LCJqdGkiOiI0YjIzNDBkMi1hOTFmLTQwYTUtYmFhOS1kZDRlNWRlYWM4NjcifQ.wq8gJ_G6vpiEinfaY3WhereqCCLoeJOG8tnWBBAzRWx9F1KU5yAAWq-ZVCk_k07-h6DIqz2wgv6y9dVbNpRYwNwDUeik9qLRsC60M8YW7EFVyI3n_NpujLwzZeub_nDYMVnyn4ii0NaZrYHtoGXOlswQfS_-ET-jpC0XWm5nBZsCdUEXjOYtwaACC6Js-pyNwKmSLp5SKIk11jZUR5xIIopaQy521y9qJHhGRwzj8DQGsP7wMZ98UFL0E--1c-hh4rTy8PMeWCqRHdwjj_ry_eTe0DJFcxxYQdeL7-0_0CIO4Ayx5WHEpcUOIzBRoN32RsNpDZc-5slDNj9ku004DA
grant_type=authorization_code\
&client_id=s6BhdRkqt\
&code=SplxlOBeZQQYbYS6WxSbIA\
&redirect_uri=https%3A%2F%2Fclient%2Eexample%2Ecom%2Fcb\
&code_verifier=bEaL42izcC-o-xBk0K2vuJ6U-y1p9r_wW2dFWIWgjz-
The following shows a representation of the DPoP Proof JWT header and claims:
"typ": "dpop+jwt",
"alg": "RS256",
"jwk": {
"kty": "RSA",
"e": "AQAB",
"n": "3FlqJr5TRskIQIgdE3Dd7D9lboWdcTUT8a-fJR7MAvQm7XXNoYkm3v7MQL1NYtDvL2l8CAnc0WdSTINU6IRvc5Kqo2Q4csNX9SHOmEfzoROjQqahEcve1jBXluoCXdYuYpx4_1tfRgG6ii4Uhxh6iI8qNMJQX-fLfqhbfYfxBQVRPywBkAbIP4x1EAsbC6FSNmkhCxiMNqEgxaIpY8C2kJdJ_ZIV-WW4noDdzpKqHcwmB8FsrumlVY_DNVvUSDIipiq9PbP4H99TXN1o746oRaNa07rq1hoCgMSSy-85SagCoxlmyE-D-of9SsMY8Ol9t0rdzpobBuhyJ_o5dfvjKw"
"htm": "POST",
"htu": "https://server.example.com/oauth2/token",
"iat": 1746806305,
"jti": "4b2340d2-a91f-40a5-baa9-dd4e5deac867"
The following code shows an example of how to generate the DPoP Proof JWT:
RSAKey rsaKey = ...
JWKSource<SecurityContext> jwkSource = (jwkSelector, securityContext) -> jwkSelector
.select(new JWKSet(rsaKey));
NimbusJwtEncoder jwtEncoder = new NimbusJwtEncoder(jwkSource);
JwsHeader jwsHeader = JwsHeader.with(SignatureAlgorithm.RS256)
.type("dpop+jwt")
.jwk(rsaKey.toPublicJWK().toJSONObject())
JwtClaimsSet claims = JwtClaimsSet.builder()
.issuedAt(Instant.now())
.claim("htm", "POST")
.claim("htu", "https://server.example.com/oauth2/token")
.id(UUID.randomUUID().toString())
Jwt dPoPProof = jwtEncoder.encode(JwtEncoderParameters.from(jwsHeader, claims));
After the authorization server successfully validates the DPoP proof, the public key from the DPoP proof will be bound (sender-constrained) to the issued access token.
The following access token response shows the token_type
parameter as DPoP
to signal to the client that the access token was bound to its DPoP proof public key:
HTTP/1.1 200 OK
Content-Type: application/json
Cache-Control: no-store
"access_token": "Kz~8mXK1EalYznwH-LC-1fBAo.4Ljp~zsPE_NeO.gxU",
"token_type": "DPoP",
"expires_in": 2677
Public Key Confirmation
Resource servers MUST be able to identify whether an access token is DPoP-bound and verify the binding to the public key of the DPoP proof. The binding is accomplished by associating the public key with the access token in a way that can be accessed by the resource server, such as embedding the public key hash in the access token directly (JWT) or through token introspection.
When an access token is represented as a JWT, the public key hash is contained in the jkt
claim under the confirmation method (cnf
) claim.
The following example shows the claims of a JWT access token containing a cnf
claim with a jkt
claim, which is the JWK SHA-256 Thumbprint of the DPoP proof public key:
"sub":"[email protected]",
"iss":"https://server.example.com",
"nbf":1562262611,
"exp":1562266216,
"cnf":
"jkt":"CQMknzRoZ5YUi7vS58jck1q8TmZT8wiIiXrCN1Ny4VU"
OAuth2 Token Introspection Endpoint
OAuth2TokenIntrospectionEndpointConfigurer
provides the ability to customize the OAuth2 Token Introspection endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 introspection requests.
http
authorizationServer
.tokenIntrospectionEndpoint(tokenIntrospectionEndpoint ->
.introspectionRequestConverter(introspectionRequestConverter) (1)
.introspectionRequestConverters(introspectionRequestConvertersConsumer) (2)
.introspectionResponseHandler(introspectionResponseHandler) (5)
1 | introspectionRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 introspection request from HttpServletRequest to an instance of OAuth2TokenIntrospectionAuthenticationToken . |
2 | introspectionRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2TokenIntrospectionAuthenticationToken . |
5 | introspectionResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2TokenIntrospectionAuthenticationToken and returning the OAuth2TokenIntrospection response. |
configures the OAuth2TokenIntrospectionEndpointFilter
is the Filter
that processes OAuth2 introspection requests.
— AnOAuth2TokenIntrospectionAuthenticationConverter
composed ofOAuth2TokenIntrospectionAuthenticationProvider
— An internal implementation that handles an “authenticated”OAuth2TokenIntrospectionAuthenticationToken
and returns theOAuth2TokenIntrospection
response. -
OAuth2 Token Revocation Endpoint
OAuth2TokenRevocationEndpointConfigurer
provides the ability to customize the OAuth2 Token Revocation endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for OAuth2 revocation requests.
http
authorizationServer
.tokenRevocationEndpoint(tokenRevocationEndpoint ->
.revocationRequestConverter(revocationRequestConverter) (1)
.revocationRequestConverters(revocationRequestConvertersConsumer) (2)
.revocationResponseHandler(revocationResponseHandler) (5)
1 | revocationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an OAuth2 revocation request from HttpServletRequest to an instance of OAuth2TokenRevocationAuthenticationToken . |
2 | revocationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OAuth2TokenRevocationAuthenticationToken . |
5 | revocationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OAuth2TokenRevocationAuthenticationToken and returning the OAuth2 revocation response. |
configures the OAuth2TokenRevocationEndpointFilter
is the Filter
that processes OAuth2 revocation requests.
— AnOAuth2TokenRevocationAuthenticationConverter
composed ofOAuth2TokenRevocationAuthenticationProvider
— An internal implementation that handles an “authenticated”OAuth2TokenRevocationAuthenticationToken
and returns the OAuth2 revocation response. -
OAuth2 Authorization Server Metadata Endpoint
OAuth2AuthorizationServerMetadataEndpointConfigurer
provides the ability to customize the OAuth2 Authorization Server Metadata endpoint.
It defines an extension point that lets you customize the OAuth2 Authorization Server Metadata response.
provides the following configuration option:
http
authorizationServer
.authorizationServerMetadataEndpoint(authorizationServerMetadataEndpoint ->
.authorizationServerMetadataCustomizer(authorizationServerMetadataCustomizer) (1)
1 | authorizationServerMetadataCustomizer() : The Consumer providing access to the OAuth2AuthorizationServerMetadata.Builder allowing the ability to customize the claims of the Authorization Server’s configuration. |
configures the OAuth2AuthorizationServerMetadataEndpointFilter
is the Filter
that returns the OAuth2AuthorizationServerMetadata response.
JWK Set Endpoint
provides support for the JWK Set endpoint.
configures the NimbusJwkSetEndpointFilter
is the Filter
that returns the JWK Set.
The JWK Set endpoint is configured only if a JWKSource<SecurityContext> @Bean is registered.
OpenID Connect 1.0 Provider Configuration Endpoint
OidcProviderConfigurationEndpointConfigurer
provides the ability to customize the OpenID Connect 1.0 Provider Configuration endpoint.
It defines an extension point that lets you customize the OpenID Provider Configuration response.
http
authorizationServer
.oidc(oidc ->
oidc
.providerConfigurationEndpoint(providerConfigurationEndpoint ->
.providerConfigurationCustomizer(providerConfigurationCustomizer) (1)
1 | providerConfigurationCustomizer() : The Consumer providing access to the OidcProviderConfiguration.Builder allowing the ability to customize the claims of the OpenID Provider’s configuration. |
configures the OidcProviderConfigurationEndpointFilter
is the Filter
that returns the OidcProviderConfiguration response.
OpenID Connect 1.0 Logout Endpoint
OidcLogoutEndpointConfigurer
provides the ability to customize the OpenID Connect 1.0 Logout endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for RP-Initiated Logout requests.
http
authorizationServer
.oidc(oidc ->
oidc
.logoutEndpoint(logoutEndpoint ->
logoutEndpoint
.logoutRequestConverter(logoutRequestConverter) (1)
.logoutRequestConverters(logoutRequestConvertersConsumer) (2)
.logoutResponseHandler(logoutResponseHandler) (5)
1 | logoutRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract a Logout request from HttpServletRequest to an instance of OidcLogoutAuthenticationToken . |
2 | logoutRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OidcLogoutAuthenticationToken . |
5 | logoutResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OidcLogoutAuthenticationToken and performing the logout. |
configures the OidcLogoutEndpointFilter
is the Filter
that processes RP-Initiated Logout requests and performs the logout of the End-User.
— AnOidcLogoutAuthenticationConverter
composed ofOidcLogoutAuthenticationProvider
— AnOidcLogoutAuthenticationSuccessHandler
response.
OidcLogoutAuthenticationProvider uses a SessionRegistry to look up the SessionInformation instance associated to the End-User requesting to be logged out.
OidcClientInitiatedLogoutSuccessHandler is the corresponding configuration in Spring Security’s OAuth2 Client support for configuring OpenID Connect 1.0 RP-Initiated Logout.
Customizing Logout Request Validation
OidcLogoutAuthenticationValidator
is the default validator used for validating specific OpenID Connect RP-Initiated Logout Request parameters.
The default implementation validates the post_logout_redirect_uri
parameter.
is thrown.
provides the ability to override the default logout request validation by supplying a custom authentication validator of type Consumer<OidcLogoutAuthenticationContext>
OidcLogoutAuthenticationContext holds the OidcLogoutAuthenticationToken , which contains the logout request parameters.
The following example shows how to configure OidcLogoutAuthenticationProvider
with a custom authentication validator:
http
authorizationServer
.oidc(oidc ->
oidc
logoutEndpoint
if (authenticationProvider instanceof OidcLogoutAuthenticationProvider oidcLogoutAuthenticationProvider) {
Consumer<OidcLogoutAuthenticationContext> authenticationValidator = new CustomPostLogoutRedirectUriValidator();
oidcLogoutAuthenticationProvider.setAuthenticationValidator(authenticationValidator);
static class CustomPostLogoutRedirectUriValidator implements Consumer<OidcLogoutAuthenticationContext> {
public void accept(OidcLogoutAuthenticationContext authenticationContext) {
OidcLogoutAuthenticationToken oidcLogoutAuthentication =
// TODO
OpenID Connect 1.0 UserInfo Endpoint
OidcUserInfoEndpointConfigurer
provides the ability to customize the OpenID Connect 1.0 UserInfo endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for UserInfo requests.
http
authorizationServer
.oidc(oidc ->
oidc
.userInfoEndpoint(userInfoEndpoint ->
userInfoEndpoint
.userInfoRequestConverter(userInfoRequestConverter) (1)
.userInfoRequestConverters(userInfoRequestConvertersConsumer) (2)
.userInfoResponseHandler(userInfoResponseHandler) (5)
.userInfoMapper(userInfoMapper) (7)
1 | userInfoRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract an UserInfo request from HttpServletRequest to an instance of OidcUserInfoAuthenticationToken . |
2 | userInfoRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OidcUserInfoAuthenticationToken . |
5 | userInfoResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OidcUserInfoAuthenticationToken and returning the UserInfo response. |
6 | errorResponseHandler() : The AuthenticationFailureHandler (post-processor) used for handling an OAuth2AuthenticationException and returning the UserInfo Error response. |
7 | userInfoMapper() : The Function used to extract claims from OidcUserInfoAuthenticationContext to an instance of OidcUserInfo . |
configures the OidcUserInfoEndpointFilter
is the Filter
that processes UserInfo requests and returns the OidcUserInfo response.
— An internal implementation that obtains theAuthentication
from theSecurityContext
and creates anOidcUserInfoAuthenticationToken
with the principal. -
composed ofOidcUserInfoAuthenticationProvider
, which is associated with an internal implementation ofuserInfoMapper
that extracts standard claims from the ID Token based on the scopes requested during authorization. -
— An internal implementation that handles an “authenticated”OidcUserInfoAuthenticationToken
and returns theOidcUserInfo
response. -
response.
You can customize the ID Token by providing an OAuth2TokenCustomizer<JwtEncodingContext> @Bean .
The OpenID Connect 1.0 UserInfo endpoint is an OAuth2 protected resource, which REQUIRES an access token to be sent as a bearer token in the UserInfo request.
OAuth2 resource server support is autoconfigured, however, a JwtDecoder @Bean is REQUIRED for the OpenID Connect 1.0 UserInfo endpoint.
The guide How-to: Customize the OpenID Connect 1.0 UserInfo response contains examples of customizing the UserInfo endpoint. |
OpenID Connect 1.0 Client Registration Endpoint
OidcClientRegistrationEndpointConfigurer
provides the ability to customize the OpenID Connect 1.0 Client Registration endpoint.
It defines extension points that let you customize the pre-processing, main processing, and post-processing logic for Client Registration requests or Client Read requests.
http
authorizationServer
.oidc(oidc ->
oidc
.clientRegistrationEndpoint(clientRegistrationEndpoint ->
.clientRegistrationRequestConverter(clientRegistrationRequestConverter) (1)
.clientRegistrationRequestConverters(clientRegistrationRequestConvertersConsumers) (2)
.clientRegistrationResponseHandler(clientRegistrationResponseHandler) (5)
1 | clientRegistrationRequestConverter() : Adds an AuthenticationConverter (pre-processor) used when attempting to extract a Client Registration request or Client Read request from HttpServletRequest to an instance of OidcClientRegistrationAuthenticationToken . |
2 | clientRegistrationRequestConverters() : Sets the Consumer providing access to the List of default and (optionally) added AuthenticationConverter 's allowing the ability to add, remove, or customize a specific AuthenticationConverter . |
3 | authenticationProvider() : Adds an AuthenticationProvider (main processor) used for authenticating the OidcClientRegistrationAuthenticationToken . |
5 | clientRegistrationResponseHandler() : The AuthenticationSuccessHandler (post-processor) used for handling an “authenticated” OidcClientRegistrationAuthenticationToken and returning the Client Registration response or Client Read response. |
6 | errorResponseHandler() : The AuthenticationFailureHandler (post-processor) used for handling an OAuth2AuthenticationException and returning the Client Registration Error response or Client Read Error response. |
The OpenID Connect 1.0 Client Registration endpoint is disabled by default because many deployments do not require dynamic client registration. |
configures the OidcClientRegistrationEndpointFilter
is the Filter
that processes Client Registration requests and returns the OidcClientRegistration response.
OidcClientRegistrationEndpointFilter also processes Client Read requests and returns the OidcClientRegistration response.
— AnOidcClientRegistrationAuthenticationConverter
composed ofOidcClientRegistrationAuthenticationProvider
andOidcClientConfigurationAuthenticationProvider
— An internal implementation that handles an “authenticated”OidcClientRegistrationAuthenticationToken
and returns theOidcClientRegistration
response. -
response.
The OpenID Connect 1.0 Client Registration endpoint is an OAuth2 protected resource, which REQUIRES an access token to be sent as a bearer token in the Client Registration (or Client Read) request.
OAuth2 resource server support is autoconfigured, however, a JwtDecoder @Bean is REQUIRED for the OpenID Connect 1.0 Client Registration endpoint.
The access token in a Client Registration request REQUIRES the OAuth2 scope client.create .
The access token in a Client Read request REQUIRES the OAuth2 scope client.read .
