此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Authorization Server 1.4.3spring-doc.cadn.net.cn
作方法:使用 Redis 实现核心服务
本指南介绍如何使用 Redis 实现 Spring Authorization Server 的核心服务。 本指南的目的是为自行实施这些服务提供一个起点,以便您可以进行修改以满足您的需要。spring-doc.cadn.net.cn
本指南中提供的代码示例位于 redis 子目录下的 documentation samples 目录中。
定义实体模型
下面定义了RegisteredClient,OAuth2AuthorizationOAuth2AuthorizationConsentdomain 类。spring-doc.cadn.net.cn
注册客户实体
下面的清单显示了OAuth2RegisteredClient实体,用于保存从RegisteredClientdomain 类。spring-doc.cadn.net.cn
OAuth2RegisteredClient 实体
import java.time.Duration;
import java.time.Instant;
import java.util.Set;
import org.springframework.data.annotation.Id;
import org.springframework.data.redis.core.RedisHash;
import org.springframework.data.redis.core.index.Indexed;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.jose.jws.JwsAlgorithm;
import org.springframework.security.oauth2.jose.jws.SignatureAlgorithm;
import org.springframework.security.oauth2.server.authorization.settings.OAuth2TokenFormat;
@RedisHash("oauth2_registered_client")
public class OAuth2RegisteredClient {
	@Id
	private final String id;
	@Indexed
	private final String clientId;
	private final Instant clientIdIssuedAt;
	private final String clientSecret;
	private final Instant clientSecretExpiresAt;
	private final String clientName;
	private final Set<ClientAuthenticationMethod> clientAuthenticationMethods;
	private final Set<AuthorizationGrantType> authorizationGrantTypes;
	private final Set<String> redirectUris;
	private final Set<String> postLogoutRedirectUris;
	private final Set<String> scopes;
	private final ClientSettings clientSettings;
	private final TokenSettings tokenSettings;
	public OAuth2RegisteredClient(String id, String clientId, Instant clientIdIssuedAt, String clientSecret,
			Instant clientSecretExpiresAt, String clientName,
			Set<ClientAuthenticationMethod> clientAuthenticationMethods,
			Set<AuthorizationGrantType> authorizationGrantTypes, Set<String> redirectUris,
			Set<String> postLogoutRedirectUris, Set<String> scopes, ClientSettings clientSettings,
			TokenSettings tokenSettings) {
		this.id = id;
		this.clientId = clientId;
		this.clientIdIssuedAt = clientIdIssuedAt;
		this.clientSecret = clientSecret;
		this.clientSecretExpiresAt = clientSecretExpiresAt;
		this.clientName = clientName;
		this.clientAuthenticationMethods = clientAuthenticationMethods;
		this.authorizationGrantTypes = authorizationGrantTypes;
		this.redirectUris = redirectUris;
		this.postLogoutRedirectUris = postLogoutRedirectUris;
		this.scopes = scopes;
		this.clientSettings = clientSettings;
		this.tokenSettings = tokenSettings;
	public String getId() {
		return this.id;
	public String getClientId() {
		return this.clientId;
	public Instant getClientIdIssuedAt() {
		return this.clientIdIssuedAt;
	public String getClientSecret() {
		return this.clientSecret;
	public Instant getClientSecretExpiresAt() {
		return this.clientSecretExpiresAt;
	public String getClientName() {
		return this.clientName;
	public Set<ClientAuthenticationMethod> getClientAuthenticationMethods() {
		return this.clientAuthenticationMethods;
	public Set<AuthorizationGrantType> getAuthorizationGrantTypes() {
		return this.authorizationGrantTypes;
	public Set<String> getRedirectUris() {
		return this.redirectUris;
	public Set<String> getPostLogoutRedirectUris() {
		return this.postLogoutRedirectUris;
	public Set<String> getScopes() {
		return this.scopes;
	public ClientSettings getClientSettings() {
		return this.clientSettings;
	public TokenSettings getTokenSettings() {
		return this.tokenSettings;
	public static class ClientSettings {
		private final boolean requireProofKey;
		private final boolean requireAuthorizationConsent;
		private final String jwkSetUrl;
		private final JwsAlgorithm tokenEndpointAuthenticationSigningAlgorithm;
		private final String x509CertificateSubjectDN;
		public ClientSettings(boolean requireProofKey, boolean requireAuthorizationConsent, String jwkSetUrl,
				JwsAlgorithm tokenEndpointAuthenticationSigningAlgorithm, String x509CertificateSubjectDN) {
			this.requireProofKey = requireProofKey;
			this.requireAuthorizationConsent = requireAuthorizationConsent;
			this.jwkSetUrl = jwkSetUrl;
			this.tokenEndpointAuthenticationSigningAlgorithm = tokenEndpointAuthenticationSigningAlgorithm;
			this.x509CertificateSubjectDN = x509CertificateSubjectDN;
		public boolean isRequireProofKey() {
			return this.requireProofKey;
		public boolean isRequireAuthorizationConsent() {
			return this.requireAuthorizationConsent;
		public String getJwkSetUrl() {
			return this.jwkSetUrl;
		public JwsAlgorithm getTokenEndpointAuthenticationSigningAlgorithm() {
			return this.tokenEndpointAuthenticationSigningAlgorithm;
		public String getX509CertificateSubjectDN() {
			return this.x509CertificateSubjectDN;
	public static class TokenSettings {
		private final Duration authorizationCodeTimeToLive;
		private final Duration accessTokenTimeToLive;
		private final OAuth2TokenFormat accessTokenFormat;
		private final Duration deviceCodeTimeToLive;
		private final boolean reuseRefreshTokens;
		private final Duration refreshTokenTimeToLive;
		private final SignatureAlgorithm idTokenSignatureAlgorithm;
		private final boolean x509CertificateBoundAccessTokens;
		public TokenSettings(Duration authorizationCodeTimeToLive, Duration accessTokenTimeToLive,
				OAuth2TokenFormat accessTokenFormat, Duration deviceCodeTimeToLive, boolean reuseRefreshTokens,
				Duration refreshTokenTimeToLive, SignatureAlgorithm idTokenSignatureAlgorithm,
				boolean x509CertificateBoundAccessTokens) {
			this.authorizationCodeTimeToLive = authorizationCodeTimeToLive;
			this.accessTokenTimeToLive = accessTokenTimeToLive;
			this.accessTokenFormat = accessTokenFormat;
			this.deviceCodeTimeToLive = deviceCodeTimeToLive;
			this.reuseRefreshTokens = reuseRefreshTokens;
			this.refreshTokenTimeToLive = refreshTokenTimeToLive;
			this.idTokenSignatureAlgorithm = idTokenSignatureAlgorithm;
			this.x509CertificateBoundAccessTokens = x509CertificateBoundAccessTokens;
		public Duration getAuthorizationCodeTimeToLive() {
			return this.authorizationCodeTimeToLive;
		public Duration getAccessTokenTimeToLive() {
			return this.accessTokenTimeToLive;
		public OAuth2TokenFormat getAccessTokenFormat() {
			return this.accessTokenFormat;
		public Duration getDeviceCodeTimeToLive() {
			return this.deviceCodeTimeToLive;
		public boolean isReuseRefreshTokens() {
			return this.reuseRefreshTokens;
		public Duration getRefreshTokenTimeToLive() {
			return this.refreshTokenTimeToLive;
		public SignatureAlgorithm getIdTokenSignatureAlgorithm() {
			return this.idTokenSignatureAlgorithm;
		public boolean isX509CertificateBoundAccessTokens() {
			return this.x509CertificateBoundAccessTokens;
Click on the "Expand folded text" icon in the code sample above to display the full example.
Authorization Grant Base Entity
The entity model for the OAuth2Authorization domain class is designed with a class hierarchy based on authorization grant type.spring-doc.cadn.net.cn
The following listing shows the OAuth2AuthorizationGrantAuthorization base entity, which defines common attributes for each authorization grant type.spring-doc.cadn.net.cn
OAuth2AuthorizationGrantAuthorization Base Entity
import java.util.Map;
import org.springframework.security.oauth2.core.OAuth2AccessToken;
@RedisHash("oauth2_authorization")
public abstract class OAuth2AuthorizationGrantAuthorization {
	@Id
	private final String registeredClientId;
	private final String principalName;
	private final Set<String> authorizedScopes;
	private final AccessToken accessToken;
	private final RefreshToken refreshToken;
	protected OAuth2AuthorizationGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken, RefreshToken refreshToken) {
		this.id = id;
		this.registeredClientId = registeredClientId;
		this.principalName = principalName;
		this.authorizedScopes = authorizedScopes;
		this.accessToken = accessToken;
		this.refreshToken = refreshToken;
		return this.id;
	public String getRegisteredClientId() {
		return this.registeredClientId;
	public String getPrincipalName() {
		return this.principalName;
	public Set<String> getAuthorizedScopes() {
		return this.authorizedScopes;
	public AccessToken getAccessToken() {
		return this.accessToken;
	public RefreshToken getRefreshToken() {
		return this.refreshToken;
	protected abstract static class AbstractToken {
		@Indexed
		private final String tokenValue;
		private final Instant issuedAt;
		private final Instant expiresAt;
		private final boolean invalidated;
		protected AbstractToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
			this.tokenValue = tokenValue;
			this.issuedAt = issuedAt;
			this.expiresAt = expiresAt;
			this.invalidated = invalidated;
		public String getTokenValue() {
			return this.tokenValue;
		public Instant getIssuedAt() {
			return this.issuedAt;
		public Instant getExpiresAt() {
			return this.expiresAt;
		public boolean isInvalidated() {
			return this.invalidated;
	public static class ClaimsHolder {
		private final Map<String, Object> claims;
		public ClaimsHolder(Map<String, Object> claims) {
			this.claims = claims;
		public Map<String, Object> getClaims() {
			return this.claims;
	public static class AccessToken extends AbstractToken {
		private final OAuth2AccessToken.TokenType tokenType;
		private final OAuth2TokenFormat tokenFormat;
		private final ClaimsHolder claims;
		public AccessToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated,
				OAuth2AccessToken.TokenType tokenType, Set<String> scopes, OAuth2TokenFormat tokenFormat,
				ClaimsHolder claims) {
			super(tokenValue, issuedAt, expiresAt, invalidated);
			this.tokenType = tokenType;
			this.tokenFormat = tokenFormat;
		public OAuth2AccessToken.TokenType getTokenType() {
			return this.tokenType;
			return this.scopes;
		public OAuth2TokenFormat getTokenFormat() {
			return this.tokenFormat;
		public ClaimsHolder getClaims() {
			return this.claims;
	public static class RefreshToken extends AbstractToken {
		public RefreshToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
Authorization Code Grant Entity (OAuth 2.0)
The following listing shows the OAuth2AuthorizationCodeGrantAuthorization entity, which extends OAuth2AuthorizationGrantAuthorization, and defines additional attributes for the OAuth 2.0 authorization_code grant type.spring-doc.cadn.net.cn
OAuth2AuthorizationCodeGrantAuthorization Entity
import java.security.Principal;
import org.springframework.security.oauth2.core.endpoint.OAuth2AuthorizationRequest;
public class OAuth2AuthorizationCodeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	private final Principal principal;
	private final OAuth2AuthorizationRequest authorizationRequest;
	private final AuthorizationCode authorizationCode;
	@Indexed
	private final String state; // Used to correlate the request during the authorization
								// consent flow
	public OAuth2AuthorizationCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken, RefreshToken refreshToken, Principal principal,
			OAuth2AuthorizationRequest authorizationRequest, AuthorizationCode authorizationCode, String state) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, refreshToken);
		this.principal = principal;
		this.authorizationRequest = authorizationRequest;
		this.authorizationCode = authorizationCode;
		this.state = state;
	public Principal getPrincipal() {
		return this.principal;
	public OAuth2AuthorizationRequest getAuthorizationRequest() {
		return this.authorizationRequest;
	public AuthorizationCode getAuthorizationCode() {
		return this.authorizationCode;
	public String getState() {
		return this.state;
	public static class AuthorizationCode extends AbstractToken {
		public AuthorizationCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
Authorization Code Grant Entity (OpenID Connect 1.0)
The following listing shows the OidcAuthorizationCodeGrantAuthorization entity, which extends OAuth2AuthorizationCodeGrantAuthorization, and defines additional attributes for the OpenID Connect 1.0 authorization_code grant type.spring-doc.cadn.net.cn
OidcAuthorizationCodeGrantAuthorization Entity
public class OidcAuthorizationCodeGrantAuthorization extends OAuth2AuthorizationCodeGrantAuthorization {
	private final IdToken idToken;
	public OidcAuthorizationCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			OAuth2AuthorizationRequest authorizationRequest, AuthorizationCode authorizationCode, String state,
			IdToken idToken) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, refreshToken, principal,
				authorizationRequest, authorizationCode, state);
		this.idToken = idToken;
	public IdToken getIdToken() {
		return this.idToken;
	public static class IdToken extends AbstractToken {
		public IdToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated,
			return this.claims;
Client Credentials Grant Entity
The following listing shows the OAuth2ClientCredentialsGrantAuthorization entity, which extends OAuth2AuthorizationGrantAuthorization, for the client_credentials grant type.spring-doc.cadn.net.cn
OAuth2ClientCredentialsGrantAuthorization Entity
public class OAuth2ClientCredentialsGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	public OAuth2ClientCredentialsGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, null);
Device Code Grant Entity
The following listing shows the OAuth2DeviceCodeGrantAuthorization entity, which extends OAuth2AuthorizationGrantAuthorization, and defines additional attributes for the urn:ietf:params:oauth:grant-type:device_code grant type.spring-doc.cadn.net.cn
OAuth2DeviceCodeGrantAuthorization Entity
public class OAuth2DeviceCodeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	private final DeviceCode deviceCode;
	private final UserCode userCode;
	private final Set<String> requestedScopes;
	@Indexed
	private final String deviceState; // Used to correlate the request during the
										// authorization consent flow
	public OAuth2DeviceCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			DeviceCode deviceCode, UserCode userCode, Set<String> requestedScopes, String deviceState) {
		this.deviceCode = deviceCode;
		this.userCode = userCode;
		this.requestedScopes = requestedScopes;
		this.deviceState = deviceState;
	public DeviceCode getDeviceCode() {
		return this.deviceCode;
	public UserCode getUserCode() {
		return this.userCode;
	public Set<String> getRequestedScopes() {
		return this.requestedScopes;
	public String getDeviceState() {
		return this.deviceState;
	public static class DeviceCode extends AbstractToken {
		public DeviceCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
	public static class UserCode extends AbstractToken {
		public UserCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
Token Exchange Grant Entity
The following listing shows the OAuth2TokenExchangeGrantAuthorization entity, which extends OAuth2AuthorizationGrantAuthorization, for the urn:ietf:params:oauth:grant-type:token-exchange grant type.spring-doc.cadn.net.cn
OAuth2TokenExchangeGrantAuthorization Entity
public class OAuth2TokenExchangeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	public OAuth2TokenExchangeGrantAuthorization(String id, String registeredClientId, String principalName,
The following listing shows the OAuth2UserConsent entity, which is used to persist information mapped from the OAuth2AuthorizationConsent domain class.spring-doc.cadn.net.cn
OAuth2UserConsent Entity
import org.springframework.security.core.GrantedAuthority;
@RedisHash("oauth2_authorization_consent")
public class OAuth2UserConsent {
	@Id
	@Indexed
	@Indexed
	private final Set<GrantedAuthority> authorities;
	public OAuth2UserConsent(String id, String registeredClientId, String principalName,
			Set<GrantedAuthority> authorities) {
		this.id = id;
		this.authorities = authorities;
		return this.id;
	public Set<GrantedAuthority> getAuthorities() {
		return this.authorities;
Create Spring Data repositories
By closely examining the interfaces of each core service and reviewing the Jdbc implementations, we can derive a minimal set of queries needed for supporting a Redis version of each interface.spring-doc.cadn.net.cn
Registered Client Repository
The following listing shows the OAuth2RegisteredClientRepository, which is able to find a OAuth2RegisteredClient by the id and clientId fields.spring-doc.cadn.net.cn
import sample.redis.entity.OAuth2RegisteredClient;
import org.springframework.data.repository.CrudRepository;
import org.springframework.stereotype.Repository;
@Repository
public interface OAuth2RegisteredClientRepository extends CrudRepository<OAuth2RegisteredClient, String> {
	OAuth2RegisteredClient findByClientId(String clientId);
Authorization Grant Repository
The following listing shows the OAuth2AuthorizationGrantAuthorizationRepository, which is able to find an OAuth2AuthorizationGrantAuthorization by the id field as well as by state, authorizationCode, accessToken, refreshToken, idToken, deviceState, userCode and deviceCode values.spring-doc.cadn.net.cn
import sample.redis.entity.OAuth2AuthorizationCodeGrantAuthorization;
import sample.redis.entity.OAuth2AuthorizationGrantAuthorization;
import sample.redis.entity.OAuth2DeviceCodeGrantAuthorization;
import sample.redis.entity.OidcAuthorizationCodeGrantAuthorization;
@Repository
public interface OAuth2AuthorizationGrantAuthorizationRepository
		extends CrudRepository<OAuth2AuthorizationGrantAuthorization, String> {
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByState(String state);
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByAuthorizationCode_TokenValue(String authorizationCode);
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByStateOrAuthorizationCode_TokenValue(String state, String authorizationCode);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByAccessToken_TokenValue(String accessToken);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByRefreshToken_TokenValue(String refreshToken);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByAccessToken_TokenValueOrRefreshToken_TokenValue(String accessToken, String refreshToken);
	<T extends OidcAuthorizationCodeGrantAuthorization> T findByIdToken_TokenValue(String idToken);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceState(String deviceState);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceCode_TokenValue(String deviceCode);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByUserCode_TokenValue(String userCode);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceStateOrDeviceCode_TokenValueOrUserCode_TokenValue(String deviceState, String deviceCode, String userCode);
The following listing shows the OAuth2UserConsentRepository, which is able to find and delete an OAuth2UserConsent by the registeredClientId and principalName fields that form the composite primary key.spring-doc.cadn.net.cn
import sample.redis.entity.OAuth2UserConsent;
@Repository
public interface OAuth2UserConsentRepository extends CrudRepository<OAuth2UserConsent, String> {
	OAuth2UserConsent findByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
	void deleteByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
Implement core services
With the above entities and repositories, we can begin implementing the core services.spring-doc.cadn.net.cn
The core services make use of the ModelMapper utility class for converting to and from the domain object (e.g. RegisteredClient) to the entity model representation (e.g. OAuth2RegisteredClient).
The following listing shows the RedisRegisteredClientRepository, which uses an OAuth2RegisteredClientRepository for persisting an OAuth2RegisteredClient and maps to and from the RegisteredClient domain object, using the ModelMapper utility class.spring-doc.cadn.net.cn
import sample.redis.repository.OAuth2RegisteredClientRepository;
import org.springframework.lang.Nullable;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
import org.springframework.util.Assert;
public class RedisRegisteredClientRepository implements RegisteredClientRepository {
	private final OAuth2RegisteredClientRepository registeredClientRepository;
	public RedisRegisteredClientRepository(OAuth2RegisteredClientRepository registeredClientRepository) {
		Assert.notNull(registeredClientRepository, "registeredClientRepository cannot be null");
		this.registeredClientRepository = registeredClientRepository;
	public void save(RegisteredClient registeredClient) {
		Assert.notNull(registeredClient, "registeredClient cannot be null");
		OAuth2RegisteredClient oauth2RegisteredClient = ModelMapper.convertOAuth2RegisteredClient(registeredClient);
		this.registeredClientRepository.save(oauth2RegisteredClient);
	@Nullable
	public RegisteredClient findById(String id) {
		Assert.hasText(id, "id cannot be empty");
		return this.registeredClientRepository.findById(id).map(ModelMapper::convertRegisteredClient).orElse(null);
	@Nullable
	public RegisteredClient findByClientId(String clientId) {
		Assert.hasText(clientId, "clientId cannot be empty");
		OAuth2RegisteredClient oauth2RegisteredClient = this.registeredClientRepository.findByClientId(clientId);
		return oauth2RegisteredClient != null ? ModelMapper.convertRegisteredClient(oauth2RegisteredClient) : null;
Authorization Service
The following listing shows the RedisOAuth2AuthorizationService, which uses an OAuth2AuthorizationGrantAuthorizationRepository for persisting an OAuth2AuthorizationGrantAuthorization and maps to and from the OAuth2Authorization domain object, using the ModelMapper utility class.spring-doc.cadn.net.cn
import sample.redis.repository.OAuth2AuthorizationGrantAuthorizationRepository;
import org.springframework.security.oauth2.core.endpoint.OAuth2ParameterNames;
import org.springframework.security.oauth2.core.oidc.endpoint.OidcParameterNames;
import org.springframework.security.oauth2.server.authorization.OAuth2Authorization;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
public class RedisOAuth2AuthorizationService implements OAuth2AuthorizationService {
	private final RegisteredClientRepository registeredClientRepository;
	private final OAuth2AuthorizationGrantAuthorizationRepository authorizationGrantAuthorizationRepository;
	public RedisOAuth2AuthorizationService(RegisteredClientRepository registeredClientRepository,
			OAuth2AuthorizationGrantAuthorizationRepository authorizationGrantAuthorizationRepository) {
		Assert.notNull(authorizationGrantAuthorizationRepository,
				"authorizationGrantAuthorizationRepository cannot be null");
		this.authorizationGrantAuthorizationRepository = authorizationGrantAuthorizationRepository;
	public void save(OAuth2Authorization authorization) {
		Assert.notNull(authorization, "authorization cannot be null");
		OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization = ModelMapper
			.convertOAuth2AuthorizationGrantAuthorization(authorization);
		this.authorizationGrantAuthorizationRepository.save(authorizationGrantAuthorization);
	public void remove(OAuth2Authorization authorization) {
		this.authorizationGrantAuthorizationRepository.deleteById(authorization.getId());
	@Nullable
	public OAuth2Authorization findById(String id) {
		return this.authorizationGrantAuthorizationRepository.findById(id)
			.map(this::toOAuth2Authorization)
			.orElse(null);
	@Nullable
	public OAuth2Authorization findByToken(String token, OAuth2TokenType tokenType) {
		Assert.hasText(token, "token cannot be empty");
		OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization = null;
		if (tokenType == null) {
			authorizationGrantAuthorization = this.authorizationGrantAuthorizationRepository
				.findByStateOrAuthorizationCode_TokenValue(token, token);
			if (authorizationGrantAuthorization == null) {
						.findByAccessToken_TokenValueOrRefreshToken_TokenValue(token, token);
						.findByIdToken_TokenValue(token);
						.findByDeviceStateOrDeviceCode_TokenValueOrUserCode_TokenValue(token, token, token);
		else if (OAuth2ParameterNames.STATE.equals(tokenType.getValue())) {
			authorizationGrantAuthorization = this.authorizationGrantAuthorizationRepository.findByState(token);
					.findByDeviceState(token);
		else if (OAuth2ParameterNames.CODE.equals(tokenType.getValue())) {
				.findByAuthorizationCode_TokenValue(token);
		else if (OAuth2TokenType.ACCESS_TOKEN.equals(tokenType)) {
				.findByAccessToken_TokenValue(token);
		else if (OidcParameterNames.ID_TOKEN.equals(tokenType.getValue())) {
		else if (OAuth2TokenType.REFRESH_TOKEN.equals(tokenType)) {
				.findByRefreshToken_TokenValue(token);
		else if (OAuth2ParameterNames.USER_CODE.equals(tokenType.getValue())) {
				.findByUserCode_TokenValue(token);
		else if (OAuth2ParameterNames.DEVICE_CODE.equals(tokenType.getValue())) {
				.findByDeviceCode_TokenValue(token);
		return authorizationGrantAuthorization != null ? toOAuth2Authorization(authorizationGrantAuthorization) : null;
	private OAuth2Authorization toOAuth2Authorization(
			OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization) {
		RegisteredClient registeredClient = this.registeredClientRepository
			.findById(authorizationGrantAuthorization.getRegisteredClientId());
		OAuth2Authorization.Builder builder = OAuth2Authorization.withRegisteredClient(registeredClient);
		ModelMapper.mapOAuth2AuthorizationGrantAuthorization(authorizationGrantAuthorization, builder);
		return builder.build();
The following listing shows the RedisOAuth2AuthorizationConsentService, which uses an OAuth2UserConsentRepository for persisting an OAuth2UserConsent and maps to and from the OAuth2AuthorizationConsent domain object, using the ModelMapper utility class.spring-doc.cadn.net.cn
import sample.redis.repository.OAuth2UserConsentRepository;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsent;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsentService;
public class RedisOAuth2AuthorizationConsentService implements OAuth2AuthorizationConsentService {
	private final OAuth2UserConsentRepository userConsentRepository;
	public RedisOAuth2AuthorizationConsentService(OAuth2UserConsentRepository userConsentRepository) {
		Assert.notNull(userConsentRepository, "userConsentRepository cannot be null");
		this.userConsentRepository = userConsentRepository;
	public void save(OAuth2AuthorizationConsent authorizationConsent) {
		Assert.notNull(authorizationConsent, "authorizationConsent cannot be null");
		OAuth2UserConsent oauth2UserConsent = ModelMapper.convertOAuth2UserConsent(authorizationConsent);
		this.userConsentRepository.save(oauth2UserConsent);
	public void remove(OAuth2AuthorizationConsent authorizationConsent) {
		this.userConsentRepository.deleteByRegisteredClientIdAndPrincipalName(
				authorizationConsent.getRegisteredClientId(), authorizationConsent.getPrincipalName());
	@Nullable
	public OAuth2AuthorizationConsent findById(String registeredClientId, String principalName) {
		Assert.hasText(registeredClientId, "registeredClientId cannot be empty");
		Assert.hasText(principalName, "principalName cannot be empty");
		OAuth2UserConsent oauth2UserConsent = this.userConsentRepository
			.findByRegisteredClientIdAndPrincipalName(registeredClientId, principalName);
		return oauth2UserConsent != null ? ModelMapper.convertOAuth2AuthorizationConsent(oauth2UserConsent) : null;
Configure core services
The following example shows how to configure the core services:spring-doc.cadn.net.cn
RedisConfig
import java.util.Arrays;
import sample.redis.convert.BytesToClaimsHolderConverter;
import sample.redis.convert.BytesToOAuth2AuthorizationRequestConverter;
import sample.redis.convert.BytesToUsernamePasswordAuthenticationTokenConverter;
import sample.redis.convert.ClaimsHolderToBytesConverter;
import sample.redis.convert.OAuth2AuthorizationRequestToBytesConverter;
import sample.redis.convert.UsernamePasswordAuthenticationTokenToBytesConverter;
import sample.redis.service.RedisOAuth2AuthorizationConsentService;
import sample.redis.service.RedisOAuth2AuthorizationService;
import sample.redis.service.RedisRegisteredClientRepository;
import org.springframework.data.redis.connection.RedisConnectionFactory;
import org.springframework.data.redis.connection.jedis.JedisConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.core.convert.RedisCustomConversions;
import org.springframework.data.redis.repository.configuration.EnableRedisRepositories;
@EnableRedisRepositories("sample.redis.repository")	(1)
public class RedisConfig {
	public RedisConnectionFactory redisConnectionFactory() {
		return new JedisConnectionFactory();	(2)
	public RedisTemplate<?, ?> redisTemplate(RedisConnectionFactory redisConnectionFactory) {
		RedisTemplate<byte[], byte[]> redisTemplate = new RedisTemplate<>();
		redisTemplate.setConnectionFactory(redisConnectionFactory);
		return redisTemplate;
	public RedisCustomConversions redisCustomConversions() {	(3)
		return new RedisCustomConversions(Arrays.asList(new UsernamePasswordAuthenticationTokenToBytesConverter(),
				new BytesToUsernamePasswordAuthenticationTokenConverter(),
				new OAuth2AuthorizationRequestToBytesConverter(), new BytesToOAuth2AuthorizationRequestConverter(),
				new ClaimsHolderToBytesConverter(), new BytesToClaimsHolderConverter()));
	public RedisRegisteredClientRepository registeredClientRepository(
		return new RedisRegisteredClientRepository(registeredClientRepository);	(4)
	public RedisOAuth2AuthorizationService authorizationService(RegisteredClientRepository registeredClientRepository,
		return new RedisOAuth2AuthorizationService(registeredClientRepository,
				authorizationGrantAuthorizationRepository);	(5)
	public RedisOAuth2AuthorizationConsentService authorizationConsentService(
		return new RedisOAuth2AuthorizationConsentService(userConsentRepository);	(6)
1 Activate the Spring Data Redis repositories under the sample.redis.repository base package.
2 Use the Jedis Connector.
3 Register the custom Converter's that perform the Object-to-Hash conversion before persisting to Redis.
4 Register the RedisRegisteredClientRepository with the activated OAuth2RegisteredClientRepository.
5 Register the RedisOAuth2AuthorizationService with the activated OAuth2AuthorizationGrantAuthorizationRepository.
6 Register the RedisOAuth2AuthorizationConsentService with the activated OAuth2UserConsentRepository.
APP信息
