This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Authorization Server 1.5.0!spring-doc.cn
How-to: Add authorities as custom claims in JWT access tokens
This guide demonstrates how to add resource owner authorities to a JWT access token. The term "authorities" may represent varying forms such as roles, permissions, or groups of the resource owner.spring-doc.cn
To make resource owner’s authorities available to the resource server, we add custom claims to the access token. When the client uses the access token to access a protected resource, the resource server will be able to obtain the information about the resource owner’s level of access, among other potential uses and benefits.spring-doc.cn
Add custom claims to JWT access tokens
You may add your own custom claims to an access token using an OAuth2TokenCustomizer<JWTEncodingContext> @Bean. Please note that this @Bean may only be defined once, and so care must be taken to ensure that you are customizing the appropriate token type — an access token in this case. If you are interested in customizing the ID Token, see the User Info Mapper guide for more information.spring-doc.cn
The following is an example of adding custom claims to an access token — in other words, every access token that is issued by the authorization server will have the custom claims populated.spring-doc.cn
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
import org.springframework.security.oauth2.server.authorization.token.JwtEncodingContext;
import org.springframework.security.oauth2.server.authorization.token.OAuth2TokenCustomizer;
public class CustomClaimsConfiguration {
	public OAuth2TokenCustomizer<JwtEncodingContext> jwtTokenCustomizer() {
		return (context) -> {
			if (OAuth2TokenType.ACCESS_TOKEN.equals(context.getTokenType())) {
				context.getClaims().claims((claims) -> {
					claims.put("claim-1", "value-1");
					claims.put("claim-2", "value-2");
Add authorities as custom claims to JWT access tokens
To add authorities of the resource owner to a JWT access token, we can refer to the custom claim mapping method above and populate a custom claim with the authorities of the Principal.spring-doc.cn
We define a sample user with a set of authorities for demonstration purposes, and populate a custom claim in the access token with those authorities.spring-doc.cn
import org.springframework.security.core.authority.AuthorityUtils;
import org.springframework.security.core.userdetails.User;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.security.provisioning.InMemoryUserDetailsManager;
import java.util.Collections;
import java.util.Set;
import java.util.stream.Collectors;
public class CustomClaimsWithAuthoritiesConfiguration {
	public UserDetailsService users() {
		UserDetails user = User.withDefaultPasswordEncoder()
				.username("user1") (1)
				.password("password")
				.roles("user", "admin") (2)
		return new InMemoryUserDetailsManager(user);
	public OAuth2TokenCustomizer<JwtEncodingContext> jwtTokenCustomizer() { (3)
			if (OAuth2TokenType.ACCESS_TOKEN.equals(context.getTokenType())) { (4)
				context.getClaims().claims((claims) -> { (5)
					Set<String> roles = AuthorityUtils.authorityListToSet(context.getPrincipal().getAuthorities())
							.stream()
							.map(c -> c.replaceFirst("^ROLE_", ""))
							.collect(Collectors.collectingAndThen(Collectors.toSet(), Collections::unmodifiableSet)); (6)
					claims.put("roles", roles); (7)
1 Define a sample user user1 with an in-memory UserDetailsService.
2 Assign the roles for user1.
3 Define an OAuth2TokenCustomizer<JwtEncodingContext> @Bean that allows for customizing the JWT claims.
4 Check whether the JWT is an access token.
5 Access the default claims via the JwtEncodingContext.
6 Extract the roles from the Principal object. The role information is stored as a string prefixed with ROLE_, so we strip the prefix here.
7 Set the custom claim roles to the set of roles collected from the previous step.
As a result of this customization, authorities information about the user will be included as a custom claim in the access token.spring-doc.cn
