Appendix A: Micrometer Observation Documentation
A.1. Observability - Metrics
Below you can find a list of all metrics declared by this project.
A.1.1. Listener Observation
Observation for Rabbit listeners.
Metric name spring.rabbit.listener
(defined by convention class RabbitListenerObservation$DefaultRabbitListenerObservationConvention
). Type timer
Metric name spring.rabbit.listener.active
). Type long task timer
KeyValues that are added after starting the Observation might be missing from the *.active metrics. |
Micrometer internally uses nanoseconds for the baseunit. However, each backend determines the actual baseunit. (i.e. Prometheus uses seconds)
Name of the enclosing class RabbitListenerObservation
All tags must be prefixed with spring.rabbit.listener prefix!
Name |
Description |
Listener id. |
A.1.2. Stream Listener Observation
Observation for Rabbit stream listeners.
Metric name spring.rabbit.stream.listener
(defined by convention class RabbitStreamListenerObservation$DefaultRabbitStreamListenerObservationConvention
). Type timer
Metric name spring.rabbit.stream.listener.active
Name of the enclosing class RabbitStreamListenerObservation
All tags must be prefixed with spring.rabbit.stream.listener prefix!
Name |
Description |
Listener id. |
A.1.3. Stream Template Observation
Observation for `RabbitStreamTemplate`s.
Metric name spring.rabbit.stream.template
(defined by convention class RabbitStreamTemplateObservation$DefaultRabbitStreamTemplateObservationConvention
). Type timer
Metric name spring.rabbit.stream.template.active
Name of the enclosing class RabbitStreamTemplateObservation
All tags must be prefixed with spring.rabbit.stream.template prefix!
Name |
Description |
Bean name of the template. |
A.1.4. Template Observation
Observation for RabbitTemplates.
Metric name spring.rabbit.template
(defined by convention class RabbitTemplateObservation$DefaultRabbitTemplateObservationConvention
). Type timer
Metric name spring.rabbit.template.active
Name of the enclosing class RabbitTemplateObservation
All tags must be prefixed with spring.rabbit.template prefix!
Name |
Description |
A.2. Observability - Spans
Below you can find a list of all spans declared by this project.
A.2.1. Listener Observation Span
Span name spring.rabbit.listener
Name |
Description |
Listener id. |
A.2.2. Stream Listener Observation Span
Span name spring.rabbit.stream.listener
Name |
Description |
Listener id. |
A.2.3. Stream Template Observation Span
Span name spring.rabbit.stream.template
Name |
Description |
A.2.4. Template Observation Span
Span name spring.rabbit.template
Name |
Description |
A.3. Observability - Conventions
Below you can find a list of all GlobalObservationConvention
and ObservationConvention
ObservationConvention Class Name |
Applicable ObservationContext Class Name |
