4. Reference
This part of the reference documentation details the various components that comprise Spring AMQP. The main chapter covers the core classes to develop an AMQP application. This part also includes a chapter about the sample applications.
4.1. Using Spring AMQP
This chapter explores the interfaces and classes that are the essential components for developing applications with Spring AMQP.
4.1.1. AMQP Abstractions
Spring AMQP consists of two modules (each represented by a JAR in the distribution): spring-amqp
and spring-rabbit
The 'spring-amqp' module contains the org.springframework.amqp.core
package.
Within that package, you can find the classes that represent the core AMQP “model”.
Our intention is to provide generic abstractions that do not rely on any particular AMQP broker implementation or client library.
End user code can be more portable across vendor implementations as it can be developed against the abstraction layer only.
These abstractions are then implemented by broker-specific modules, such as 'spring-rabbit'.
There is currently only a RabbitMQ implementation.
However, the abstractions have been validated in .NET using Apache Qpid in addition to RabbitMQ.
Since AMQP operates at the protocol level, in principle, you can use the RabbitMQ client with any broker that supports the same protocol version, but we do not test any other brokers at present.
This overview assumes that you are already familiar with the basics of the AMQP specification. If not, have a look at the resources listed in Other Resources
Message
The 0-9-1 AMQP specification does not define a Message
class or interface.
Instead, when performing an operation such as basicPublish()
, the content is passed as a byte-array argument and additional properties are passed in as separate arguments.
Spring AMQP defines a Message
class as part of a more general AMQP domain model representation.
The purpose of the Message
class is to encapsulate the body and properties within a single instance so that the API can, in turn, be simpler.
The following example shows the Message
class definition:
public class Message {
private final MessageProperties messageProperties;
private final byte[] body;
public Message(byte[] body, MessageProperties messageProperties) {
this.body = body;
this.messageProperties = messageProperties;
public byte[] getBody() {
return this.body;
public MessageProperties getMessageProperties() {
return this.messageProperties;
The MessageProperties
interface defines several common properties, such as 'messageId', 'timestamp', 'contentType', and several more.
You can also extend those properties with user-defined 'headers' by calling the setHeader(String key, Object value)
method.
Starting with versions 1.5.7 , 1.6.11 , 1.7.4 , and 2.0.0 , if a message body is a serialized Serializable java object, it is no longer deserialized (by default) when performing toString() operations (such as in log messages).
This is to prevent unsafe deserialization.
By default, only java.util and java.lang classes are deserialized.
To revert to the previous behavior, you can add allowable class/package patterns by invoking Message.addAllowedListPatterns(…) .
A simple wildcard is supported, for example com.something. , *.MyClass .
Bodies that cannot be deserialized are represented by byte[<size>] in log messages.
Exchange
The Exchange
interface represents an AMQP Exchange, which is what a Message Producer sends to.
Each Exchange within a virtual host of a broker has a unique name as well as a few other properties.
The following example shows the Exchange
interface:
public interface Exchange {
String getName();
String getExchangeType();
boolean isDurable();
boolean isAutoDelete();
Map<String, Object> getArguments();
As you can see, an Exchange
also has a 'type' represented by constants defined in ExchangeTypes
The basic types are: direct
, topic
, fanout
, and headers
In the core package, you can find implementations of the Exchange
interface for each of those types.
The behavior varies across these Exchange
types in terms of how they handle bindings to queues.
For example, a Direct
exchange lets a queue be bound by a fixed routing key (often the queue’s name).
A Topic
exchange supports bindings with routing patterns that may include the '*' and '#' wildcards for 'exactly-one' and 'zero-or-more', respectively.
The Fanout
exchange publishes to all queues that are bound to it without taking any routing key into consideration.
For much more information about these and the other Exchange types, see Other Resources.
The AMQP specification also requires that any broker provide a “default” direct exchange that has no name.
All queues that are declared are bound to that default Exchange with their names as routing keys.
You can learn more about the default Exchange’s usage within Spring AMQP in AmqpTemplate .
Queue
The Queue
class represents the component from which a message consumer receives messages.
Like the various Exchange
classes, our implementation is intended to be an abstract representation of this core AMQP type.
The following listing shows the Queue
class:
public class Queue {
private final String name;
private volatile boolean durable;
private volatile boolean exclusive;
private volatile boolean autoDelete;
private volatile Map<String, Object> arguments;
* The queue is durable, non-exclusive and non auto-delete.
* @param name the name of the queue.
public Queue(String name) {
this(name, true, false, false);
// Getters and Setters omitted for brevity
Notice that the constructor takes the queue name. Depending on the implementation, the admin template may provide methods for generating a uniquely named queue. Such queues can be useful as a “reply-to” address or in other temporary situations. For that reason, the 'exclusive' and 'autoDelete' properties of an auto-generated queue would both be set to 'true'.
See the section on queues in Configuring the Broker for information about declaring queues by using namespace support, including queue arguments. |
Binding
Given that a producer sends to an exchange and a consumer receives from a queue, the bindings that connect queues to exchanges are critical for connecting those producers and consumers via messaging.
In Spring AMQP, we define a Binding
class to represent those connections.
This section reviews the basic options for binding queues to exchanges.
You can bind a queue to a DirectExchange
with a fixed routing key, as the following example shows:
new Binding(someQueue, someDirectExchange, "foo.bar");
You can bind a queue to a TopicExchange
with a routing pattern, as the following example shows:
new Binding(someQueue, someTopicExchange, "foo.*");
You can bind a queue to a FanoutExchange
with no routing key, as the following example shows:
new Binding(someQueue, someFanoutExchange);
We also provide a BindingBuilder
to facilitate a “fluent API” style, as the following example shows:
Binding b = BindingBuilder.bind(someQueue).to(someTopicExchange).with("foo.*");
For clarity, the preceding example shows the BindingBuilder class, but this style works well when using a static import for the 'bind()' method.
By itself, an instance of the Binding
class only holds the data about a connection.
In other words, it is not an “active” component.
However, as you will see later in Configuring the Broker, the AmqpAdmin
class can use Binding
instances to actually trigger the binding actions on the broker.
Also, as you can see in that same section, you can define the Binding
instances by using Spring’s @Bean
annotations within @Configuration
classes.
There is also a convenient base class that further simplifies that approach for generating AMQP-related bean definitions and recognizes the queues, exchanges, and bindings so that they are all declared on the AMQP broker upon application startup.
The AmqpTemplate
is also defined within the core package.
As one of the main components involved in actual AMQP messaging, it is discussed in detail in its own section (see AmqpTemplate
4.1.2. Connection and Resource Management
Whereas the AMQP model we described in the previous section is generic and applicable to all implementations, when we get into the management of resources, the details are specific to the broker implementation. Therefore, in this section, we focus on code that exists only within our “spring-rabbit” module since, at this point, RabbitMQ is the only supported implementation.
The central component for managing a connection to the RabbitMQ broker is the ConnectionFactory
interface.
The responsibility of a ConnectionFactory
implementation is to provide an instance of org.springframework.amqp.rabbit.connection.Connection
, which is a wrapper for com.rabbitmq.client.Connection
Choosing a Connection Factory
There are three connection factories to chose from
PooledChannelConnectionFactory
ThreadChannelConnectionFactory
CachingConnectionFactory
The first two were added in version 2.3.
For most use cases, the PooledChannelConnectionFactory
should be used.
The ThreadChannelConnectionFactory
can be used if you want to ensure strict message ordering without the need to use Scoped Operations.
The CachingConnectionFactory
should be used if you want to use correlated publisher confirmations or if you wish to open multiple connections, via its CacheMode
Simple publisher confirmations are supported by all three factories.
When configuring a RabbitTemplate
to use a separate connection, you can now, starting with version 2.3.2, configure the publishing connection factory to be a different type.
By default, the publishing factory is the same type and any properties set on the main factory are also propagated to the publishing factory.
This factory manages a single connection and two pools of channels, based on the Apache Pool2.
One pool is for transactional channels, the other is for non-transactional channels.
The pools are GenericObjectPool
s with default configuration; a callback is provided to configure the pools; refer to the Apache documentation for more information.
The Apache commons-pool2
jar must be on the class path to use this factory.
PooledChannelConnectionFactory pcf() throws Exception {
ConnectionFactory rabbitConnectionFactory = new ConnectionFactory();
rabbitConnectionFactory.setHost("localhost");
PooledChannelConnectionFactory pcf = new PooledChannelConnectionFactory(rabbitConnectionFactory);
pcf.setPoolConfigurer((pool, tx) -> {
if (tx) {
// configure the transactional pool
else {
// configure the non-transactional pool
return pcf;
This factory manages a single connection and two ThreadLocal
s, one for transactional channels, the other for non-transactional channels.
This factory ensures that all operations on the same thread use the same channel (as long as it remains open).
This facilitates strict message ordering without the need for Scoped Operations.
To avoid memory leaks, if your application uses many short-lived threads, you must call the factory’s closeThreadChannel()
to release the channel resource.
Starting with version 2.3.7, a thread can transfer its channel(s) to another thread.
See Strict Message Ordering in a Multi-Threaded Environment for more information.
The third implementation provided is the CachingConnectionFactory
, which, by default, establishes a single connection proxy that can be shared by the application.
Sharing of the connection is possible since the “unit of work” for messaging with AMQP is actually a “channel” (in some ways, this is similar to the relationship between a connection and a session in JMS).
The connection instance provides a createChannel
method.
implementation supports caching of those channels, and it maintains separate caches for channels based on whether they are transactional.
When creating an instance of CachingConnectionFactory
, you can provide the 'hostname' through the constructor.
You should also provide the 'username' and 'password' properties.
To configure the size of the channel cache (the default is 25), you can call the
setChannelCacheSize()
method.
Starting with version 1.3, you can configure the CachingConnectionFactory
to cache connections as well as only channels.
In this case, each call to createConnection()
creates a new connection (or retrieves an idle one from the cache).
Closing a connection returns it to the cache (if the cache size has not been reached).
Channels created on such connections are also cached.
The use of separate connections might be useful in some environments, such as consuming from an HA cluster, in
conjunction with a load balancer, to connect to different cluster members, and others.
To cache connections, set the cacheMode
to CacheMode.CONNECTION
This does not limit the number of connections. Rather, it specifies how many idle open connections are allowed. |
Starting with version 1.5.5, a new property called connectionLimit
is provided.
When this property is set, it limits the total number of connections allowed.
When set, if the limit is reached, the channelCheckoutTimeLimit
is used to wait for a connection to become idle.
If the time is exceeded, an AmqpTimeoutException
is thrown.
When the cache mode is Also, at the time of this writing, the |
It is important to understand that the cache size is (by default) not a limit but is merely the number of channels that can be cached. With a cache size of, say, 10, any number of channels can actually be in use. If more than 10 channels are being used and they are all returned to the cache, 10 go in the cache. The remainder are physically closed.
Starting with version 1.6, the default channel cache size has been increased from 1 to 25. In high volume, multi-threaded environments, a small cache means that channels are created and closed at a high rate. Increasing the default cache size can avoid this overhead. You should monitor the channels in use through the RabbitMQ Admin UI and consider increasing the cache size further if you see many channels being created and closed. The cache grows only on-demand (to suit the concurrency requirements of the application), so this change does not impact existing low-volume applications.
Starting with version 1.4.2, the CachingConnectionFactory
has a property called channelCheckoutTimeout
When this property is greater than zero, the channelCacheSize
becomes a limit on the number of channels that can be created on a connection.
If the limit is reached, calling threads block until a channel is available or this timeout is reached, in which case a AmqpTimeoutException
is thrown.
Channels used within the framework (for example,
RabbitTemplate ) are reliably returned to the cache.
If you create channels outside of the framework, (for example,
by accessing the connections directly and invoking createChannel() ), you must return them (by closing) reliably, perhaps in a finally block, to avoid running out of channels.
The following example shows how to create a new connection
CachingConnectionFactory connectionFactory = new CachingConnectionFactory("somehost");
connectionFactory.setUsername("guest");
connectionFactory.setPassword("guest");
Connection connection = connectionFactory.createConnection();
When using XML, the configuration might look like the following example:
<bean id="connectionFactory"
class="org.springframework.amqp.rabbit.connection.CachingConnectionFactory">
<constructor-arg value="somehost"/>
<property name="username" value="guest"/>
<property name="password" value="guest"/>
</bean>
There is also a SingleConnectionFactory implementation that is available only in the unit test code of the framework.
It is simpler than CachingConnectionFactory , since it does not cache channels, but it is not intended for practical usage outside of simple tests due to its lack of performance and resilience.
If you need to implement your own ConnectionFactory for some reason, the AbstractConnectionFactory base class may provide a nice starting point.
A ConnectionFactory
can be created quickly and conveniently by using the rabbit namespace, as follows:
<rabbit:connection-factory id="connectionFactory"/>
In most cases, this approach is preferable, since the framework can choose the best defaults for you.
The created instance is a CachingConnectionFactory
Keep in mind that the default cache size for channels is 25.
If you want more channels to be cached, set a larger value by setting the 'channelCacheSize' property.
In XML it would look like as follows:
<property name="channelCacheSize" value="50"/>
</bean>
Also, with the namespace, you can add the 'channel-cache-size' attribute, as follows:
id="connectionFactory" channel-cache-size="50"/>
The default cache mode is CHANNEL
, but you can configure it to cache connections instead.
In the following example, we use connection-cache-size
id="connectionFactory" cache-mode="CONNECTION" connection-cache-size="25"/>
You can provide host and port attributes by using the namespace, as follows:
id="connectionFactory" host="somehost" port="5672"/>
Alternatively, if running in a clustered environment, you can use the addresses attribute, as follows:
id="connectionFactory" addresses="host1:5672,host2:5672" address-shuffle-mode="RANDOM"/>
See Connecting to a Cluster for information about address-shuffle-mode
The following example with a custom thread factory that prefixes thread names with rabbitmq-
<rabbit:connection-factory id="multiHost" virtual-host="/bar" addresses="host1:1234,host2,host3:4567"
thread-factory="tf"
channel-cache-size="10" username="user" password="password" />
<bean id="tf" class="org.springframework.scheduling.concurrent.CustomizableThreadFactory">
<constructor-arg value="rabbitmq-" />
</bean>
AddressResolver
Starting with version 2.1.15, you can now use an AddressResover
to resolve the connection address(es).
This will override any settings of the addresses
and host/port
properties.
Naming Connections
Starting with version 1.7, a ConnectionNameStrategy
is provided for the injection into the AbstractionConnectionFactory
The generated name is used for the application-specific identification of the target RabbitMQ connection.
The connection name is displayed in the management UI if the RabbitMQ server supports it.
This value does not have to be unique and cannot be used as a connection identifier — for example, in HTTP API requests.
This value is supposed to be human-readable and is a part of ClientProperties
under the connection_name
key.
You can use a simple Lambda, as follows:
connectionFactory.setConnectionNameStrategy(connectionFactory -> "MY_CONNECTION");
The ConnectionFactory
argument can be used to distinguish target connection names by some logic.
By default, the beanName
of the AbstractConnectionFactory
, a hex string representing the object, and an internal counter are used to generate the connection_name
The <rabbit:connection-factory>
namespace component is also supplied with the connection-name-strategy
attribute.
An implementation of SimplePropertyValueConnectionNameStrategy
sets the connection name to an application property.
You can declare it as a @Bean
and inject it into the connection factory, as the following example shows:
public SimplePropertyValueConnectionNameStrategy cns() {
return new SimplePropertyValueConnectionNameStrategy("spring.application.name");
public ConnectionFactory rabbitConnectionFactory(ConnectionNameStrategy cns) {
CachingConnectionFactory connectionFactory = new CachingConnectionFactory();
connectionFactory.setConnectionNameStrategy(cns);
return connectionFactory;
The property must exist in the application context’s Environment
When using Spring Boot and its autoconfigured connection factory, you need only declare the ConnectionNameStrategy @Bean .
Boot auto-detects the bean and wires it into the factory.
Blocked Connections and Resource Constraints
The connection might be blocked for interaction from the broker that corresponds to the Memory Alarm.
Starting with version 2.0, the org.springframework.amqp.rabbit.connection.Connection
can be supplied with com.rabbitmq.client.BlockedListener
instances to be notified for connection blocked and unblocked events.
In addition, the AbstractConnectionFactory
emits a ConnectionBlockedEvent
and ConnectionUnblockedEvent
, respectively, through its internal BlockedListener
implementation.
These let you provide application logic to react appropriately to problems on the broker and (for example) take some corrective actions.
When the application is configured with a single CachingConnectionFactory , as it is by default with Spring Boot auto-configuration, the application stops working when the connection is blocked by the Broker.
And when it is blocked by the Broker, any of its clients stop to work.
If we have producers and consumers in the same application, we may end up with a deadlock when producers are blocking the connection (because there are no resources on the Broker any more) and consumers cannot free them (because the connection is blocked).
To mitigate the problem, we suggest having one more separate CachingConnectionFactory instance with the same options — one for producers and one for consumers.
A separate CachingConnectionFactory is not possible for transactional producers that execute on a consumer thread, since they should reuse the Channel associated with the consumer transactions.
Starting with version 2.0.2, the RabbitTemplate
has a configuration option to automatically use a second connection factory, unless transactions are being used.
See Using a Separate Connection for more information.
The ConnectionNameStrategy
for the publisher connection is the same as the primary strategy with .publisher
appended to the result of calling the method.
Starting with version 1.7.7, an AmqpResourceNotAvailableException
is provided, which is thrown when SimpleConnection.createChannel()
cannot create a Channel
(for example, because the channelMax
limit is reached and there are no available channels in the cache).
You can use this exception in the RetryPolicy
to recover the operation after some back-off.
Configuring the Underlying Client Connection Factory
uses an instance of the Rabbit client ConnectionFactory
A number of configuration properties are passed through (host
, port
, userName
, password
, requestedHeartBeat
, and connectionTimeout
for example) when setting the equivalent property on the CachingConnectionFactory
To set other properties (clientProperties
, for example), you can define an instance of the Rabbit factory and provide a reference to it by using the appropriate constructor of the CachingConnectionFactory
When using the namespace (as described earlier), you need to provide a reference to the configured factory in the connection-factory
attribute.
For convenience, a factory bean is provided to assist in configuring the connection factory in a Spring application context, as discussed in the next section.
id="connectionFactory" connection-factory="rabbitConnectionFactory"/>
The 4.0.x client enables automatic recovery by default.
While compatible with this feature, Spring AMQP has its own recovery mechanisms and the client recovery feature generally is not needed.
We recommend disabling amqp-client automatic recovery, to avoid getting AutoRecoverConnectionNotCurrentlyOpenException instances when the broker is available but the connection has not yet recovered.
You may notice this exception, for example, when a RetryTemplate is configured in a RabbitTemplate , even when failing over to another broker in a cluster.
Since the auto-recovering connection recovers on a timer, the connection may be recovered more quickly by using Spring AMQP’s recovery mechanisms.
Starting with version 1.7.1, Spring AMQP disables amqp-client automatic recovery unless you explicitly create your own RabbitMQ connection factory and provide it to the CachingConnectionFactory .
RabbitMQ ConnectionFactory instances created by the RabbitConnectionFactoryBean also have the option disabled by default.
and Configuring SSL
Starting with version 1.4, a convenient RabbitConnectionFactoryBean
is provided to enable convenient configuration of SSL properties on the underlying client connection factory by using dependency injection.
Other setters delegate to the underlying factory.
Previously, you had to configure the SSL options programmatically.
The following example shows how to configure a RabbitConnectionFactoryBean
<rabbit:connection-factory id="rabbitConnectionFactory"
connection-factory="clientConnectionFactory"
host="${host}"
port="${port}"
virtual-host="${vhost}"
username="${username}" password="${password}" />
<bean id="clientConnectionFactory"
class="org.springframework.amqp.rabbit.connection.RabbitConnectionFactoryBean">
<property name="useSSL" value="true" />
<property name="sslPropertiesLocation" value="file:/secrets/rabbitSSL.properties"/>
</bean>
See the RabbitMQ Documentation for information about configuring SSL.
Omit the keyStore
and trustStore
configuration to connect over SSL without certificate validation.
The next example shows how you can provide key and trust store configuration.
The sslPropertiesLocation
property is a Spring Resource
pointing to a properties file containing the following keys:
keyStore=file:/secret/keycert.p12
trustStore=file:/secret/trustStore
keyStore.passPhrase=secret
trustStore.passPhrase=secret
The keyStore
and truststore
are Spring Resources
pointing to the stores.
Typically this properties file is secured by the operating system with the application having read access.
Starting with Spring AMQP version 1.5,you can set these properties directly on the factory bean.
If both discrete properties and sslPropertiesLocation
is provided, properties in the latter override the
discrete values.
Starting with version 2.0, the server certificate is validated by default because it is more secure.
If you wish to skip this validation for some reason, set the factory bean’s skipServerCertificateValidation property to true .
Starting with version 2.1, the RabbitConnectionFactoryBean now calls enableHostnameVerification() by default.
To revert to the previous behavior, set the enableHostnameVerification property to false .
Starting with version 2.2.5, the factory bean will always use TLS v1.2 by default; previously, it used v1.1 in some cases and v1.2 in others (depending on other properties).
If you need to use v1.1 for some reason, set the sslAlgorithm property: setSslAlgorithm("TLSv1.1") .
To connect to a cluster, configure the addresses
public CachingConnectionFactory ccf() {
CachingConnectionFactory ccf = new CachingConnectionFactory();
ccf.setAddresses("host1:5672,host2:5672,host3:5672");
return ccf;
The underlying connection factory will attempt to connect to each host, in order, whenever a new connection is established.
Starting with version 2.1.8, the connection order can be made random by setting the addressShuffleMode
property to RANDOM
; the shuffle will be applied before creating any new connection.
Starting with version 2.6, the INORDER
shuffle mode was added, which means the first address is moved to the end after a connection is created.
You may wish to use this mode with the RabbitMQ Sharding Plugin with CacheMode.CONNECTION
and suitable concurrency if you wish to consume from all shards on all nodes.
ccf.setAddressShuffleMode(AddressShuffleMode.RANDOM);
return ccf;
Routing Connection Factory
Starting with version 1.3, the AbstractRoutingConnectionFactory
has been introduced.
This factory provides a mechanism to configure mappings for several ConnectionFactories
and determine a target ConnectionFactory
by some lookupKey
at runtime.
Typically, the implementation checks a thread-bound context.
For convenience, Spring AMQP provides the SimpleRoutingConnectionFactory
, which gets the current thread-bound lookupKey
from the SimpleResourceHolder
The following examples shows how to configure a SimpleRoutingConnectionFactory
in both XML and Java:
class="org.springframework.amqp.rabbit.connection.SimpleRoutingConnectionFactory">
<property name="targetConnectionFactories">
<map>
<entry key="#{connectionFactory1.virtualHost}" ref="connectionFactory1"/>
<entry key="#{connectionFactory2.virtualHost}" ref="connectionFactory2"/>
</map>
</property>
</bean>
<rabbit:template id="template" connection-factory="connectionFactory" />
public class MyService {
@Autowired
private RabbitTemplate rabbitTemplate;
public void service(String vHost, String payload) {
SimpleResourceHolder.bind(rabbitTemplate.getConnectionFactory(), vHost);
rabbitTemplate.convertAndSend(payload);
SimpleResourceHolder.unbind(rabbitTemplate.getConnectionFactory());
It is important to unbind the resource after use.
For more information, see the JavaDoc for AbstractRoutingConnectionFactory
Starting with version 1.4, RabbitTemplate
supports the SpEL sendConnectionFactorySelectorExpression
and receiveConnectionFactorySelectorExpression
properties, which are evaluated on each AMQP protocol interaction operation (send
, sendAndReceive
, receive
, or receiveAndReply
), resolving to a lookupKey
value for the provided AbstractRoutingConnectionFactory
You can use bean references, such as @vHostResolver.getVHost(#root)
in the expression.
For send
operations, the message to be sent is the root evaluation object.
For receive
operations, the queueName
The routing algorithm is as follows: If the selector expression is null
or is evaluated to null
or the provided ConnectionFactory
is not an instance of AbstractRoutingConnectionFactory
, everything works as before, relying on the provided ConnectionFactory
implementation.
The same occurs if the evaluation result is not null
, but there is no target ConnectionFactory
for that lookupKey
and the AbstractRoutingConnectionFactory
is configured with lenientFallback = true
In the case of an AbstractRoutingConnectionFactory
, it does fallback to its routing
implementation based on determineCurrentLookupKey()
However, if lenientFallback = false
, an IllegalStateException
is thrown.
The namespace support also provides the send-connection-factory-selector-expression
and receive-connection-factory-selector-expression
attributes on the <rabbit:template>
component.
Also, starting with version 1.4, you can configure a routing connection factory in a listener container.
In that case, the list of queue names is used as the lookup key.
For example, if you configure the container with setQueueNames("thing1", "thing2")
, the lookup key is [thing1,thing]"
(note that there is no space in the key).
Starting with version 1.6.9, you can add a qualifier to the lookup key by using setLookupKeyQualifier
on the listener container.
Doing so enables, for example, listening to queues with the same name but in a different virtual host (where you would have a connection factory for each).
For example, with lookup key qualifier thing1
and a container listening to queue thing2
, the lookup key you could register the target connection factory with could be thing1[thing2]
The target (and default, if provided) connection factories must have the same settings for publisher confirms and returns. See Publisher Confirms and Returns. |
Starting with version 2.4.4, this validation can be disabled.
If you have a case that the values between confirms and returns need to be unequal, you can use AbstractRoutingConnectionFactory#setConsistentConfirmsReturns
to turn of the validation.
Note that the first connection factory added to AbstractRoutingConnectionFactory
will determine the general values of confirms
and returns
It may be useful if you have a case that certain messages you would to check confirms/returns and others you don’t. For example:
public RabbitTemplate rabbitTemplate() {
final com.rabbitmq.client.ConnectionFactory cf = new com.rabbitmq.client.ConnectionFactory();
cf.setHost("localhost");
cf.setPort(5672);
CachingConnectionFactory cachingConnectionFactory = new CachingConnectionFactory(cf);
cachingConnectionFactory.setPublisherConfirmType(CachingConnectionFactory.ConfirmType.CORRELATED);
PooledChannelConnectionFactory pooledChannelConnectionFactory = new PooledChannelConnectionFactory(cf);
final Map<Object, ConnectionFactory> connectionFactoryMap = new HashMap<>(2);
connectionFactoryMap.put("true", cachingConnectionFactory);
connectionFactoryMap.put("false", pooledChannelConnectionFactory);
final AbstractRoutingConnectionFactory routingConnectionFactory = new SimpleRoutingConnectionFactory();
routingConnectionFactory.setConsistentConfirmsReturns(false);
routingConnectionFactory.setDefaultTargetConnectionFactory(pooledChannelConnectionFactory);
routingConnectionFactory.setTargetConnectionFactories(connectionFactoryMap);
final RabbitTemplate rabbitTemplate = new RabbitTemplate(routingConnectionFactory);
final Expression sendExpression = new SpelExpressionParser().parseExpression(
"messageProperties.headers['x-use-publisher-confirms'] ?: false");
rabbitTemplate.setSendConnectionFactorySelectorExpression(sendExpression);
This way messages with the header x-use-publisher-confirms: true
will be sent through the caching connection and you can ensure the message delivery.
See Publisher Confirms and Returns for more information about ensuring message delivery.
Queue Affinity and the LocalizedQueueConnectionFactory
When using HA queues in a cluster, for the best performance, you may want to connect to the physical broker
where the lead queue resides.
can be configured with multiple broker addresses.
This is to fail over and the client attempts to connect in order.
The LocalizedQueueConnectionFactory
uses the REST API provided by the management plugin to determine which node is the lead for the queue.
It then creates (or retrieves from a cache) a CachingConnectionFactory
that connects to just that node.
If the connection fails, the new lead node is determined and the consumer connects to it.
is configured with a default connection factory, in case the physical location of the queue cannot be determined, in which case it connects as normal to the cluster.
is a RoutingConnectionFactory
and the SimpleMessageListenerContainer
uses the queue names as the lookup key as discussed in Routing Connection Factory above.
For this reason (the use of the queue name for the lookup), the LocalizedQueueConnectionFactory can only be used if the container is configured to listen to a single queue.
The RabbitMQ management plugin must be enabled on each node. |
This connection factory is intended for long-lived connections, such as those used by the SimpleMessageListenerContainer .
It is not intended for short connection use, such as with a RabbitTemplate because of the overhead of invoking the REST API before making the connection.
Also, for publish operations, the queue is unknown, and the message is published to all cluster members anyway, so the logic of looking up the node has little value.
The following example configuration shows how to configure the factories:
@Autowired
private ConfigurationProperties props;
public CachingConnectionFactory defaultConnectionFactory() {
CachingConnectionFactory cf = new CachingConnectionFactory();
cf.setAddresses(this.props.getAddresses());
cf.setUsername(this.props.getUsername());
cf.setPassword(this.props.getPassword());
cf.setVirtualHost(this.props.getVirtualHost());
return cf;
public LocalizedQueueConnectionFactory queueAffinityCF(
@Qualifier("defaultConnectionFactory") ConnectionFactory defaultCF) {
return new LocalizedQueueConnectionFactory(defaultCF,
StringUtils.commaDelimitedListToStringArray(this.props.getAddresses()),
StringUtils.commaDelimitedListToStringArray(this.props.getAdminUris()),
StringUtils.commaDelimitedListToStringArray(this.props.getNodes()),
this.props.getVirtualHost(), this.props.getUsername(), this.props.getPassword(),
false, null);
Notice that the first three parameters are arrays of addresses
, adminUris
, and nodes
These are positional in that, when a container attempts to connect to a queue, it uses the admin API to determine which node is the lead for the queue and connects to the address in the same array position as that node.
Starting with version 2.4.8, the RabbitMQ http-client is no longer used to access the Rest API.
Instead, by default, the WebClient from Spring Webflux is used if spring-webflux is on the class path; otherwise a RestTemplate is used.
To add WebFlux
to the class path:
<dependency>
<groupId>org.springframework.amqp</groupId>
<artifactId>spring-rabbit</artifactId>
</dependency>
compile 'org.springframework.amqp:spring-rabbit'
You can also use other REST technology by implementing LocalizedQueueConnectionFactory.NodeLocator
and overriding its createClient, ``restCall
, and optionally, close
methods.
lqcf.setNodeLocator(new NodeLocator<MyClient>() {
public MyClient createClient(String userName, String password) {
public HashMap<String, Object> restCall(MyClient client, URI uri) {
The framework provides the WebFluxNodeLocator
and RestTemplateNodeLocator
, with the default as discussed above.
Confirmed (with correlation) and returned messages are supported by setting the CachingConnectionFactory
property publisherConfirmType
to ConfirmType.CORRELATED
and the publisherReturns
property to 'true'.
When these options are set, Channel
instances created by the factory are wrapped in an PublisherCallbackChannel
, which is used to facilitate the callbacks.
When such a channel is obtained, the client can register a PublisherCallbackChannel.Listener
with the Channel
The PublisherCallbackChannel
implementation contains logic to route a confirm or return to the appropriate listener.
These features are explained further in the following sections.
See also simplePublisherConfirms
in Scoped Operations.
For some more background information, see the blog post by the RabbitMQ team titled Introducing Publisher Confirms. |
Connection and Channel Listeners
The connection factory supports registering ConnectionListener
and ChannelListener
implementations.
This allows you to receive notifications for connection and channel related events.
(A ConnectionListener
is used by the RabbitAdmin
to perform declarations when the connection is established - see Automatic Declaration of Exchanges, Queues, and Bindings for more information).
The following listing shows the ConnectionListener
interface definition:
@FunctionalInterface
public interface ConnectionListener {
void onCreate(Connection connection);
default void onClose(Connection connection) {
default void onShutDown(ShutdownSignalException signal) {
object can be supplied with com.rabbitmq.client.BlockedListener
The following example shows the ChannelListener interface definition:
public interface ChannelListener {
void onCreate(Channel channel, boolean transactional);
See Publishing is Asynchronous — How to Detect Successes and Failures for one scenario where you might want to register a ChannelListener
Logging Channel Close Events
Version 1.5 introduced a mechanism to enable users to control logging levels.
uses a default strategy to log channel closures as follows:
Normal channel closes (200 OK) are not logged.
If a channel is closed due to a failed passive queue declaration, it is logged at debug level.
If a channel is closed because the
basic.consume
is refused due to an exclusive consumer condition, it is logged at INFO level. -
All others are logged at ERROR level.
To modify this behavior, you can inject a custom ConditionalExceptionLogger
into the
in its closeExceptionLogger
property.
See also Consumer Events.
Runtime Cache Properties
Staring with version 1.6, the CachingConnectionFactory
now provides cache statistics through the getCacheProperties()
method.
These statistics can be used to tune the cache to optimize it in production.
For example, the high water marks can be used to determine whether the cache size should be increased.
If it equals the cache size, you might want to consider increasing further.
The following table describes the CacheMode.CHANNEL
properties:
Property | Meaning |
connectionName |
The name of the connection generated by the |
channelCacheSize |
The currently configured maximum channels that are allowed to be idle. |
localPort |
The local port for the connection (if available). This can be used to correlate with connections and channels on the RabbitMQ Admin UI. |
idleChannelsTx |
The number of transactional channels that are currently idle (cached). |
idleChannelsNotTx |
The number of non-transactional channels that are currently idle (cached). |
idleChannelsTxHighWater |
The maximum number of transactional channels that have been concurrently idle (cached). |
idleChannelsNotTxHighWater |
The maximum number of non-transactional channels have been concurrently idle (cached). |
The following table describes the CacheMode.CONNECTION
properties:
connectionName:<localPort> |
openConnections |
The number of connection objects representing connections to brokers. |
channelCacheSize |
connectionCacheSize |
The currently configured maximum connections that are allowed to be idle. |
idleConnections |
The number of connections that are currently idle. |
idleConnectionsHighWater |
The maximum number of connections that have been concurrently idle. |
idleChannelsTx:<localPort> |
The number of transactional channels that are currently idle (cached) for this connection.
You can use the |
idleChannelsNotTx:<localPort> |
The number of non-transactional channels that are currently idle (cached) for this connection.
The |
idleChannelsTxHighWater:<localPort> |
The maximum number of transactional channels that have been concurrently idle (cached). The localPort part of the property name can be used to correlate with connections and channels on the RabbitMQ Admin UI. |
idleChannelsNotTxHighWater:<localPort> |
You can use the |
The cacheMode
property (CHANNEL
or CONNECTION
) is also included.
RabbitMQ Automatic Connection/Topology recovery
Since the first version of Spring AMQP, the framework has provided its own connection and channel recovery in the event of a broker failure.
Also, as discussed in Configuring the Broker, the RabbitAdmin
re-declares any infrastructure beans (queues and others) when the connection is re-established.
It therefore does not rely on the auto-recovery that is now provided by the amqp-client
library.
The amqp-client
, has auto recovery enabled by default.
There are some incompatibilities between the two recovery mechanisms so, by default, Spring sets the automaticRecoveryEnabled
property on the underlying RabbitMQ connectionFactory
to false
Even if the property is true
, Spring effectively disables it, by immediately closing any recovered connections.
By default, only elements (queues, exchanges, bindings) that are defined as beans will be re-declared after a connection failure. See Recovering Auto-Delete Declarations for how to change that behavior. |
4.1.3. Adding Custom Client Connection Properties
now lets you access the underlying connection factory to allow, for example,
setting custom client properties.
The following example shows how to do so:
connectionFactory.getRabbitConnectionFactory().getClientProperties().put("thing1", "thing2");
These properties appear in the RabbitMQ Admin UI when viewing the connection.
4.1.4. AmqpTemplate
As with many other high-level abstractions provided by the Spring Framework and related projects, Spring AMQP provides a “template” that plays a central role.
The interface that defines the main operations is called AmqpTemplate
Those operations cover the general behavior for sending and receiving messages.
In other words, they are not unique to any implementation — hence the “AMQP” in the name.
On the other hand, there are implementations of that interface that are tied to implementations of the AMQP protocol.
Unlike JMS, which is an interface-level API itself, AMQP is a wire-level protocol.
The implementations of that protocol provide their own client libraries, so each implementation of the template interface depends on a particular client library.
Currently, there is only a single implementation: RabbitTemplate
In the examples that follow, we often use an AmqpTemplate
However, when you look at the configuration examples or any code excerpts where the template is instantiated or setters are invoked, you can see the implementation type (for example, RabbitTemplate
As mentioned earlier, the AmqpTemplate
interface defines all of the basic operations for sending and receiving messages.
We will explore message sending and reception, respectively, in Sending Messages and Receiving Messages.
See also Async Rabbit Template.
Adding Retry Capabilities
Starting with version 1.3, you can now configure the RabbitTemplate
to use a RetryTemplate
to help with handling problems with broker connectivity.
See the spring-retry project for complete information.
The following is only one example that uses an exponential back off policy and the default SimpleRetryPolicy
, which makes three tries before throwing the exception to the caller.
The following example uses the XML namespace:
<rabbit:template id="template" connection-factory="connectionFactory" retry-template="retryTemplate"/>
<bean id="retryTemplate" class="org.springframework.retry.support.RetryTemplate">
<property name="backOffPolicy">
<bean class="org.springframework.retry.backoff.ExponentialBackOffPolicy">
<property name="initialInterval" value="500" />
<property name="multiplier" value="10.0" />
<property name="maxInterval" value="10000" />
</bean>
</property>
</bean>
The following example uses the @Configuration
annotation in Java:
RabbitTemplate template = new RabbitTemplate(connectionFactory());
RetryTemplate retryTemplate = new RetryTemplate();
ExponentialBackOffPolicy backOffPolicy = new ExponentialBackOffPolicy();
backOffPolicy.setInitialInterval(500);
backOffPolicy.setMultiplier(10.0);
backOffPolicy.setMaxInterval(10000);
retryTemplate.setBackOffPolicy(backOffPolicy);
template.setRetryTemplate(retryTemplate);
return template;
Starting with version 1.4, in addition to the retryTemplate
property, the recoveryCallback
option is supported on the RabbitTemplate
It is used as a second argument for the RetryTemplate.execute(RetryCallback<T, E> retryCallback, RecoveryCallback<T> recoveryCallback)
The RecoveryCallback is somewhat limited, in that the retry context contains only the lastThrowable field.
For more sophisticated use cases, you should use an external RetryTemplate so that you can convey additional information to the RecoveryCallback through the context’s attributes.
retryTemplate.execute(
new RetryCallback<Object, Exception>() {
public Object doWithRetry(RetryContext context) throws Exception {
context.setAttribute("message", message);
return rabbitTemplate.convertAndSend(exchange, routingKey, message);
}, new RecoveryCallback<Object>() {
public Object recover(RetryContext context) throws Exception {
Object message = context.getAttribute("message");
Throwable t = context.getLastThrowable();
// Do something with message
return null;
In this case, you would not inject a RetryTemplate
into the RabbitTemplate
Publishing messages is an asynchronous mechanism and, by default, messages that cannot be routed are dropped by RabbitMQ. For successful publishing, you can receive an asynchronous confirm, as described in Correlated Publisher Confirms and Returns. Consider two failure scenarios:
Publish to an exchange but there is no matching destination queue.
Publish to a non-existent exchange.
The first case is covered by publisher returns, as described in Correlated Publisher Confirms and Returns.
For the second case, the message is dropped and no return is generated.
The underlying channel is closed with an exception.
By default, this exception is logged, but you can register a ChannelListener
with the CachingConnectionFactory
to obtain notifications of such events.
The following example shows how to add a ConnectionListener
this.connectionFactory.addConnectionListener(new ConnectionListener() {
public void onCreate(Connection connection) {
public void onShutDown(ShutdownSignalException signal) {
You can examine the signal’s reason
property to determine the problem that occurred.
To detect the exception on the sending thread, you can setChannelTransacted(true)
and the exception is detected on the txCommit()
However, transactions significantly impede performance, so consider this carefully before enabling transactions for just this one use case.
The RabbitTemplate
implementation of AmqpTemplate
supports publisher confirms and returns.
For returned messages, the template’s mandatory
property must be set to true
or the mandatory-expression
must evaluate to true
for a particular message.
This feature requires a CachingConnectionFactory
that has its publisherReturns
property set to true
(see Publisher Confirms and Returns).
Returns are sent to the client by it registering a RabbitTemplate.ReturnsCallback
by calling setReturnsCallback(ReturnsCallback callback)
The callback must implement the following method:
void returnedMessage(ReturnedMessage returned);
The ReturnedMessage
has the following properties:
message
- the returned message itself -
replyCode
- a code indicating the reason for the return -
replyText
- a textual reason for the return - e.g.NO_ROUTE
exchange
- the exchange to which the message was sent -
routingKey
- the routing key that was used
Only one ReturnsCallback
is supported by each RabbitTemplate
See also Reply Timeout.
For publisher confirms (also known as publisher acknowledgements), the template requires a CachingConnectionFactory
that has its publisherConfirm
property set to ConfirmType.CORRELATED
Confirms are sent to the client by it registering a RabbitTemplate.ConfirmCallback
by calling setConfirmCallback(ConfirmCallback callback)
The callback must implement this method:
void confirm(CorrelationData correlationData, boolean ack, String cause);
The CorrelationData
is an object supplied by the client when sending the original message.
The ack
is true for an ack
and false for a nack
For nack
instances, the cause may contain a reason for the nack
, if it is available when the nack
is generated.
An example is when sending a message to a non-existent exchange.
In that case, the broker closes the channel.
The reason for the closure is included in the cause
The cause
was added in version 1.4.
Only one ConfirmCallback
is supported by a RabbitTemplate
When a rabbit template send operation completes, the channel is closed.
This precludes the reception of confirms or returns when the connection factory cache is full (when there is space in the cache, the channel is not physically closed and the returns and confirms proceed normally).
When the cache is full, the framework defers the close for up to five seconds, in order to allow time for the confirms and returns to be received.
When using confirms, the channel is closed when the last confirm is received.
When using only returns, the channel remains open for the full five seconds.
We generally recommend setting the connection factory’s channelCacheSize to a large enough value so that the channel on which a message is published is returned to the cache instead of being closed.
You can monitor channel usage by using the RabbitMQ management plugin.
If you see channels being opened and closed rapidly, you should consider increasing the cache size to reduce overhead on the server.
Before version 2.1, channels enabled for publisher confirms were returned to the cache before the confirms were received.
Some other process could check out the channel and perform some operation that causes the channel to close — such as publishing a message to a non-existent exchange.
This could cause the confirm to be lost.
Version 2.1 and later no longer return the channel to the cache while confirms are outstanding.
The RabbitTemplate performs a logical close() on the channel after each operation.
In general, this means that only one confirm is outstanding on a channel at a time.
Starting with version 2.2, the callbacks are invoked on one of the connection factory’s executor threads.
This is to avoid a potential deadlock if you perform Rabbit operations from within the callback.
With previous versions, the callbacks were invoked directly on the amqp-client connection I/O thread; this would deadlock if you perform some RPC operation (such as opening a new channel) since the I/O thread blocks waiting for the result, but the result needs to be processed by the I/O thread itself.
With those versions, it was necessary to hand off work (such as sending a messasge) to another thread within the callback.
This is no longer necessary since the framework now hands off the callback invocation to the executor.
The guarantee of receiving a returned message before the ack is still maintained as long as the return callback executes in 60 seconds or less. The confirm is scheduled to be delivered after the return callback exits or after 60 seconds, whichever comes first. |
Starting with version 2.1, the CorrelationData
object has a ListenableFuture
that you can use to get the result, instead of using a ConfirmCallback
on the template.
The following example shows how to configure a CorrelationData
instance:
CorrelationData cd1 = new CorrelationData();
this.templateWithConfirmsEnabled.convertAndSend("exchange", queue.getName(), "foo", cd1);
assertTrue(cd1.getFuture().get(10, TimeUnit.SECONDS).isAck());
Since it is a ListenableFuture<Confirm>
, you can either get()
the result when ready or add listeners for an asynchronous callback.
The Confirm
object is a simple bean with 2 properties: ack
and reason
(for nack
instances).
The reason is not populated for broker-generated nack
instances.
It is populated for nack
instances generated by the framework (for example, closing the connection while ack
instances are outstanding).
In addition, when both confirms and returns are enabled, the CorrelationData
is populated with the returned message, as long as the CorrelationData
has a unique id
; this is always the case, by default, starting with version 2.3.
It is guaranteed that the returned message is set before the future is set with the ack
See also Scoped Operations for a simpler mechanism for waiting for publisher confirms.
Scoped Operations
Normally, when using the template, a Channel
is checked out of the cache (or created), used for the operation, and returned to the cache for reuse.
In a multi-threaded environment, there is no guarantee that the next operation uses the same channel.
There may be times, however, where you want to have more control over the use of a channel and ensure that a number of operations are all performed on the same channel.
Starting with version 2.0, a new method called invoke
is provided, with an OperationsCallback
Any operations performed within the scope of the callback and on the provided RabbitOperations
argument use the same dedicated Channel
, which will be closed at the end (not returned to a cache).
If the channel is a PublisherCallbackChannel
, it is returned to the cache after all confirms have been received (see Correlated Publisher Confirms and Returns).
public interface OperationsCallback<T> {
T doInRabbit(RabbitOperations operations);
One example of why you might need this is if you wish to use the waitForConfirms()
method on the underlying Channel
This method was not previously exposed by the Spring API because the channel is, generally, cached and shared, as discussed earlier.
The RabbitTemplate
now provides waitForConfirms(long timeout)
and waitForConfirmsOrDie(long timeout)
, which delegate to the dedicated channel used within the scope of the OperationsCallback
The methods cannot be used outside of that scope, for obvious reasons.
Note that a higher-level abstraction that lets you correlate confirms to requests is provided elsewhere (see Correlated Publisher Confirms and Returns). If you want only to wait until the broker has confirmed delivery, you can use the technique shown in the following example:
Collection<?> messages = getMessagesToSend();
Boolean result = this.template.invoke(t -> {
messages.forEach(m -> t.convertAndSend(ROUTE, m));
t.waitForConfirmsOrDie(10_000);
return true;
If you wish RabbitAdmin
operations to be invoked on the same channel within the scope of the OperationsCallback
, the admin must have been constructed by using the same RabbitTemplate
that was used for the invoke
operation.
The preceding discussion is moot if the template operations are already performed within the scope of an existing transaction — for example, when running on a transacted listener container thread and performing operations on a transacted template.
In that case, the operations are performed on that channel and committed when the thread returns to the container.
It is not necessary to use invoke in that scenario.
When using confirms in this way, much of the infrastructure set up for correlating confirms to requests is not really needed (unless returns are also enabled).
Starting with version 2.2, the connection factory supports a new property called publisherConfirmType
When this is set to ConfirmType.SIMPLE
, the infrastructure is avoided and the confirm processing can be more efficient.
Furthermore, the RabbitTemplate
sets the publisherSequenceNumber
property in the sent message MessageProperties
If you wish to check (or log or otherwise use) specific confirms, you can do so with an overloaded invoke
method, as the following example shows:
public <T> T invoke(OperationsCallback<T> action, com.rabbitmq.client.ConfirmCallback acks,
com.rabbitmq.client.ConfirmCallback nacks);
These ConfirmCallback objects (for ack and nack instances) are the Rabbit client callbacks, not the template callback.
The following example logs ack
and nack
instances:
return true;
}, (tag, multiple) -> {
log.info("Ack: " + tag + ":" + multiple);
log.info("Nack: " + tag + ":" + multiple);
Scoped operations are bound to a thread. See Strict Message Ordering in a Multi-Threaded Environment for a discussion about strict ordering in a multi-threaded environment. |
The discussion in Scoped Operations applies only when the operations are performed on the same thread.
Consider the following situation:
thread-1
sends a message to a queue and hands off work tothread-2
thread-2
sends a message to the same queue
Because of the async nature of RabbitMQ and the use of cached channels; it is not certain that the same channel will be used and therefore the order in which the messages arrive in the queue is not guaranteed.
(In most cases they will arrive in order, but the probability of out-of-order delivery is not zero).
To solve this use case, you can use a bounded channel cache with size 1
(together with a channelCheckoutTimeout
) to ensure the messages are always published on the same channel, and order will be guaranteed.
To do this, if you have other uses for the connection factory, such as consumers, you should either use a dedicated connection factory for the template, or configure the template to use the publisher connection factory embedded in the main connection factory (see Using a Separate Connection).
This is best illustrated with a simple Spring Boot Application:
@SpringBootApplication
public class Application {
private static final Logger log = LoggerFactory.getLogger(Application.class);
SpringApplication.run(Application.class, args);
TaskExecutor exec() {
ThreadPoolTaskExecutor exec = new ThreadPoolTaskExecutor();
exec.setCorePoolSize(10);
return exec;
CachingConnectionFactory ccf = new CachingConnectionFactory("localhost");
CachingConnectionFactory publisherCF = (CachingConnectionFactory) ccf.getPublisherConnectionFactory();
publisherCF.setChannelCacheSize(1);
publisherCF.setChannelCheckoutTimeout(1000L);
return ccf;
@RabbitListener(queues = "queue")
void listen(String in) {
log.info(in);
Queue queue() {
return new Queue("queue");
public ApplicationRunner runner(Service service, TaskExecutor exec) {
return args -> {
exec.execute(() -> service.mainService("test"));
@Component
class Service {
private static final Logger LOG = LoggerFactory.getLogger(Service.class);
private final RabbitTemplate template;
private final TaskExecutor exec;
Service(RabbitTemplate template, TaskExecutor exec) {
template.setUsePublisherConnection(true);
this.template = template;
this.exec = exec;
void mainService(String toSend) {
LOG.info("Publishing from main service");
this.template.convertAndSend("queue", toSend);
this.exec.execute(() -> secondaryService(toSend.toUpperCase()));
void secondaryService(String toSend) {
LOG.info("Publishing from secondary service");
Even though the publishing is performed on two different threads, they will both use the same channel because the cache is capped at a single channel.
Starting with version 2.3.7, the ThreadChannelConnectionFactory
supports transferring a thread’s channel(s) to another thread, using the prepareContextSwitch
and switchContext
methods.
The first method returns a context which is passed to the second thread which calls the second method.
A thread can have either a non-transactional channel or a transactional channel (or one of each) bound to it; you cannot transfer them individually, unless you use two connection factories.
An example follows:
return exec;
ThreadChannelConnectionFactory tccf() {
return new ThreadChannelConnectionFactory(rabbitConnectionFactory);
log.info(in);
Queue queue() {
return args -> {
@Component
class Service {
private final ThreadChannelConnectionFactory connFactory;
Service(RabbitTemplate template, TaskExecutor exec,
ThreadChannelConnectionFactory tccf) {
this.exec = exec;
this.connFactory = tccf;
Object context = this.connFactory.prepareSwitchContext();
this.exec.execute(() -> secondaryService(toSend.toUpperCase(), context));
void secondaryService(String toSend, Object threadContext) {
this.connFactory.switchContext(threadContext);
this.connFactory.closeThreadChannel();
Once the prepareSwitchContext is called, if the current thread performs any more operations, they will be performed on a new channel.
It is important to close the thread-bound channel when it is no longer needed.
Messaging Integration
Starting with version 1.4, RabbitMessagingTemplate
(built on top of RabbitTemplate
) provides an integration with the Spring Framework messaging abstraction — that is,
org.springframework.messaging.Message
This lets you send and receive messages by using the spring-messaging
Message<?>
abstraction.
This abstraction is used by other Spring projects, such as Spring Integration and Spring’s STOMP support.
There are two message converters involved: one to convert between a spring-messaging Message<?>
and Spring AMQP’s Message
abstraction and one to convert between Spring AMQP’s Message
abstraction and the format required by the underlying RabbitMQ client library.
By default, the message payload is converted by the provided RabbitTemplate
instance’s message converter.
Alternatively, you can inject a custom MessagingMessageConverter
with some other payload converter, as the following example shows:
MessagingMessageConverter amqpMessageConverter = new MessagingMessageConverter();
amqpMessageConverter.setPayloadConverter(myPayloadConverter);
rabbitMessagingTemplate.setAmqpMessageConverter(amqpMessageConverter);
Validated User Id
Starting with version 1.6, the template now supports a user-id-expression
(userIdExpression
when using Java configuration).
If a message is sent, the user id property is set (if not already set) after evaluating this expression.
The root object for the evaluation is the message to be sent.
The following examples show how to use the user-id-expression
attribute:
<rabbit:template ... user-id-expression="'guest'" />
<rabbit:template ... user-id-expression="@myConnectionFactory.username" />
The first example is a literal expression.
The second obtains the username
property from a connection factory bean in the application context.
Starting with version 2.0.2, you can set the usePublisherConnection
property to true
to use a different connection to that used by listener containers, when possible.
This is to avoid consumers being blocked when a producer is blocked for any reason.
The connection factories maintain a second internal connection factory for this purpose; by default it is the same type as the main factory, but can be set explicity if you wish to use a different factory type for publishing.
If the rabbit template is running in a transaction started by the listener container, the container’s channel is used, regardless of this setting.
In general, you should not use a RabbitAdmin with a template that has this set to true .
Use the RabbitAdmin constructor that takes a connection factory.
If you use the other constructor that takes a template, ensure the template’s property is false .
This is because, often, an admin is used to declare queues for listener containers.
Using a template that has the property set to true would mean that exclusive queues (such as AnonymousQueue ) would be declared on a different connection to that used by listener containers.
In that case, the queues cannot be used by the containers.
4.1.5. Sending Messages
When sending a message, you can use any of the following methods:
void send(Message message) throws AmqpException;
void send(String routingKey, Message message) throws AmqpException;
void send(String exchange, String routingKey, Message message) throws AmqpException;
We can begin our discussion with the last method in the preceding listing, since it is actually the most explicit.
It lets an AMQP exchange name (along with a routing key)be provided at runtime.
The last parameter is the callback that is responsible for actual creating the message instance.
An example of using this method to send a message might look like this:
The following example shows how to use the send
method to send a message:
amqpTemplate.send("marketData.topic", "quotes.nasdaq.THING1",
new Message("12.34".getBytes(), someProperties));
You can set the exchange
property on the template itself if you plan to use that template instance to send to the same exchange most or all of the time.
In such cases, you can use the second method in the preceding listing.
The following example is functionally equivalent to the previous example:
amqpTemplate.setExchange("marketData.topic");
amqpTemplate.send("quotes.nasdaq.FOO", new Message("12.34".getBytes(), someProperties));
If both the exchange
and routingKey
properties are set on the template, you can use the method that accepts only the Message
amqpTemplate.setRoutingKey("quotes.nasdaq.FOO");
amqpTemplate.send(new Message("12.34".getBytes(), someProperties));
A better way of thinking about the exchange and routing key properties is that the explicit method parameters always override the template’s default values.
In fact, even if you do not explicitly set those properties on the template, there are always default values in place.
In both cases, the default is an empty String
, but that is actually a sensible default.
As far as the routing key is concerned, it is not always necessary in the first place (for example, for
a Fanout
exchange).
Furthermore, a queue may be bound to an exchange with an empty String
Those are both legitimate scenarios for reliance on the default empty String
value for the routing key property of the template.
As far as the exchange name is concerned, the empty String
is commonly used because the AMQP specification defines the “default exchange” as having no name.
Since all queues are automatically bound to that default exchange (which is a direct exchange), using their name as the binding value, the second method in the preceding listing can be used for simple point-to-point messaging to any queue through the default exchange.
You can provide the queue name as the routingKey
, either by providing the method parameter at runtime.
RabbitTemplate template = new RabbitTemplate(); // using default no-name Exchange
template.send("queue.helloWorld", new Message("Hello World".getBytes(), someProperties));
Alternately, you can create a template that can be used for publishing primarily or exclusively to a single Queue. The following example shows how to do so:
template.setRoutingKey("queue.helloWorld"); // but we'll always send to this Queue
template.send(new Message("Hello World".getBytes(), someProperties));
Message Builder API
Starting with version 1.3, a message builder API is provided by the MessageBuilder
and MessagePropertiesBuilder
These methods provide a convenient “fluent” means of creating a message or message properties.
The following examples show the fluent API in action:
Message message = MessageBuilder.withBody("foo".getBytes())
.setContentType(MessageProperties.CONTENT_TYPE_TEXT_PLAIN)
.setMessageId("123")
.setHeader("bar", "baz")
MessageProperties props = MessagePropertiesBuilder.newInstance()
.andProperties(props)
Each of the properties defined on the MessageProperties
can be set.
Other methods include setHeader(String key, String value)
, removeHeader(String key)
, removeHeaders()
, and copyProperties(MessageProperties properties)
Each property setting method has a set*IfAbsent()
variant.
In the cases where a default initial value exists, the method is named set*IfAbsentOrDefault()
Five static methods are provided to create an initial message builder:
public static MessageBuilder withBody(byte[] body) (1)
public static MessageBuilder withClonedBody(byte[] body) (2)
public static MessageBuilder withBody(byte[] body, int from, int to) (3)
public static MessageBuilder fromMessage(Message message) (4)
public static MessageBuilder fromClonedMessage(Message message) (5)
1 | The message created by the builder has a body that is a direct reference to the argument. |
2 | The message created by the builder has a body that is a new array containing a copy of bytes in the argument. |
3 | The message created by the builder has a body that is a new array containing the range of bytes from the argument.
See Arrays.copyOfRange() for more details. |
4 | The message created by the builder has a body that is a direct reference to the body of the argument.
The argument’s properties are copied to a new MessageProperties object. |
5 | The message created by the builder has a body that is a new array containing a copy of the argument’s body.
Three static methods are provided to create a MessagePropertiesBuilder
instance:
public static MessagePropertiesBuilder newInstance() (1)
public static MessagePropertiesBuilder fromProperties(MessageProperties properties) (2)
public static MessagePropertiesBuilder fromClonedProperties(MessageProperties properties) (3)
1 | A new message properties object is initialized with default values. |
2 | The builder is initialized with, and build() will return, the provided properties object., |
3 | The argument’s properties are copied to a new MessageProperties object. |
With the RabbitTemplate
, each of the send()
methods has an overloaded version that takes an additional CorrelationData
object.
When publisher confirms are enabled, this object is returned in the callback described in AmqpTemplate
This lets the sender correlate a confirm (ack
or nack
) with the sent message.
Starting with version 1.6.7, the CorrelationAwareMessagePostProcessor
interface was introduced, allowing the correlation data to be modified after the message has been converted.
The following example shows how to use it:
Message postProcessMessage(Message message, Correlation correlation);
In version 2.0, this interface is deprecated.
The method has been moved to MessagePostProcessor
with a default implementation that delegates to postProcessMessage(Message message)
Also starting with version 1.6.7, a new callback interface called CorrelationDataPostProcessor
is provided.
This is invoked after all MessagePostProcessor
instances (provided in the send()
method as well as those provided in setBeforePublishPostProcessors()
Implementations can update or replace the correlation data supplied in the send()
method (if any).
The Message
and original CorrelationData
(if any) are provided as arguments.
The following example shows how to use the postProcess
method:
CorrelationData postProcess(Message message, CorrelationData correlationData);
Publisher Returns
When the template’s mandatory
property is true
, returned messages are provided by the callback described in AmqpTemplate
Starting with version 1.4, the RabbitTemplate
supports the SpEL mandatoryExpression
property, which is evaluated against each request message as the root evaluation object, resolving to a boolean
value.
Bean references, such as @myBean.isMandatory(#root)
, can be used in the expression.
Publisher returns can also be used internally by the RabbitTemplate
in send and receive operations.
See Reply Timeout for more information.
Batching
Version 1.4.2 introduced the BatchingRabbitTemplate
This is a subclass of RabbitTemplate
with an overridden send
method that batches messages according to the BatchingStrategy
Only when a batch is complete is the message sent to RabbitMQ.
The following listing shows the BatchingStrategy
public interface BatchingStrategy {
MessageBatch addToBatch(String exchange, String routingKey, Message message);
Date nextRelease();
Collection<MessageBatch> releaseBatches();
Batched data is held in memory. Unsent messages can be lost in the event of a system failure. |
A SimpleBatchingStrategy
is provided.
It supports sending messages to a single exchange or routing key.
It has the following properties:
batchSize
: The number of messages in a batch before it is sent. -
bufferLimit
: The maximum size of the batched message. This preempts thebatchSize
, if exceeded, and causes a partial batch to be sent. -
timeout
: A time after which a partial batch is sent when there is no new activity adding messages to the batch.
The SimpleBatchingStrategy
formats the batch by preceding each embedded message with a four-byte binary length.
This is communicated to the receiving system by setting the springBatchFormat
message property to lengthHeader4
Batched messages are automatically de-batched by listener containers by default (by using the springBatchFormat message header).
Rejecting any message from a batch causes the entire batch to be rejected.
However, see @RabbitListener with Batching for more information.
4.1.6. Receiving Messages
Message reception is always a little more complicated than sending.
There are two ways to receive a Message
The simpler option is to poll for one Message
at a time with a polling method call.
The more complicated yet more common approach is to register a listener that receives Messages
on-demand, asynchronously.
We consider an example of each approach in the next two sub-sections.
Polling Consumer
The AmqpTemplate
itself can be used for polled Message
reception.
By default, if no message is available, null
is returned immediately.
There is no blocking.
Starting with version 1.5, you can set a receiveTimeout
, in milliseconds, and the receive methods block for up to that long, waiting for a message.
A value less than zero means block indefinitely (or at least until the connection to the broker is lost).
Version 1.6 introduced variants of the receive
methods that allows the timeout be passed in on each call.
Since the receive operation creates a new QueueingConsumer for each message, this technique is not really appropriate for high-volume environments.
Consider using an asynchronous consumer or a receiveTimeout of zero for those use cases.
Starting with version 2.4.8, when using a non-zero timeout, you can specify arguments passed into the basicConsume
method used to associate the consumer with the channel.
For example: template.addConsumerArg("x-priority", 10)
There are four simple receive
methods available.
As with the Exchange
on the sending side, there is a method that requires that a default queue property has been set
directly on the template itself, and there is a method that accepts a queue parameter at runtime.
Version 1.6 introduced variants to accept timeoutMillis
to override receiveTimeout
on a per-request basis.
The following listing shows the definitions of the four methods:
Message receive() throws AmqpException;
Message receive(String queueName) throws AmqpException;
Message receive(long timeoutMillis) throws AmqpException;
Message receive(String queueName, long timeoutMillis) throws AmqpException;
As in the case of sending messages, the AmqpTemplate
has some convenience methods for receiving POJOs instead of Message
instances, and implementations provide a way to customize the MessageConverter
used to create the Object
returned:
The following listing shows those methods:
Object receiveAndConvert() throws AmqpException;
Object receiveAndConvert(String queueName) throws AmqpException;
Object receiveAndConvert(long timeoutMillis) throws AmqpException;
Object receiveAndConvert(String queueName, long timeoutMillis) throws AmqpException;
Starting with version 2.0, there are variants of these methods that take an additional ParameterizedTypeReference
argument to convert complex types.
The template must be configured with a SmartMessageConverter
See Converting From a Message
With RabbitTemplate
Similar to sendAndReceive
methods, beginning with version 1.3, the AmqpTemplate
has several convenience receiveAndReply
methods for synchronously receiving, processing and replying to messages.
The following listing shows those method definitions:
<R, S> boolean receiveAndReply(ReceiveAndReplyCallback<R, S> callback)
<R, S> boolean receiveAndReply(String queueName, ReceiveAndReplyCallback<R, S> callback)
<R, S> boolean receiveAndReply(ReceiveAndReplyCallback<R, S> callback,
String replyExchange, String replyRoutingKey) throws AmqpException;
<R, S> boolean receiveAndReply(String queueName, ReceiveAndReplyCallback<R, S> callback,
ReplyToAddressCallback<S> replyToAddressCallback) throws AmqpException;
The AmqpTemplate
implementation takes care of the receive
and reply
phases.
In most cases, you should provide only an implementation of ReceiveAndReplyCallback
to perform some business logic for the received message and build a reply object or message, if needed.
Note, a ReceiveAndReplyCallback
may return null
In this case, no reply is sent and receiveAndReply
works like the receive
method.
This lets the same queue be used for a mixture of messages, some of which may not need a reply.
Automatic message (request and reply) conversion is applied only if the provided callback is not an instance of ReceiveAndReplyMessageCallback
, which provides a raw message exchange contract.
The ReplyToAddressCallback
is useful for cases requiring custom logic to determine the replyTo
address at runtime against the received message and reply from the ReceiveAndReplyCallback
By default, replyTo
information in the request message is used to route the reply.
The following listing shows an example of POJO-based receive and reply:
boolean received =
this.template.receiveAndReply(ROUTE, new ReceiveAndReplyCallback<Order, Invoice>() {
public Invoice handle(Order order) {
return processOrder(order);
if (received) {
log.info("We received an order!");
Asynchronous Consumer
Spring AMQP also supports annotated listener endpoints through the use of the @RabbitListener annotation and provides an open infrastructure to register endpoints programmatically.
This is by far the most convenient way to setup an asynchronous consumer.
See Annotation-driven Listener Endpoints for more details.
The prefetch default value used to be 1, which could lead to under-utilization of efficient consumers. Starting with version 2.0, the default prefetch value is now 250, which should keep consumers busy in most common scenarios and thus improve throughput. There are, nevertheless, scenarios where the prefetch value should be low:
Also, with low-volume messaging and multiple consumers (including concurrency within a single listener container instance), you may wish to reduce the prefetch to get a more even distribution of messages across consumers. For more background about prefetch, see this post about consumer utilization in RabbitMQ and this post about queuing theory. |
Message Listener
For asynchronous Message
reception, a dedicated component (not the AmqpTemplate
) is involved.
That component is a container for a Message
-consuming callback.
We consider the container and its properties later in this section.
First, though, we should look at the callback, since that is where your application code is integrated with the messaging system.
There are a few options for the callback, starting with an implementation of the MessageListener
interface, which the following listing shows:
public interface MessageListener {
void onMessage(Message message);
If your callback logic depends on the AMQP Channel instance for any reason, you may instead use the ChannelAwareMessageListener
It looks similar but has an extra parameter.
The following listing shows the ChannelAwareMessageListener
public interface ChannelAwareMessageListener {
void onMessage(Message message, Channel channel) throws Exception;
In version 2.1, this interface moved from package o.s.amqp.rabbit.core to o.s.amqp.rabbit.listener.api .
MessageListenerAdapter
If you prefer to maintain a stricter separation between your application logic and the messaging API, you can rely upon an adapter implementation that is provided by the framework. This is often referred to as “Message-driven POJO” support.
Version 1.5 introduced a more flexible mechanism for POJO messaging, the @RabbitListener annotation.
See Annotation-driven Listener Endpoints for more information.
When using the adapter, you need to provide only a reference to the instance that the adapter itself should invoke. The following example shows how to do so:
MessageListenerAdapter listener = new MessageListenerAdapter(somePojo);
listener.setDefaultListenerMethod("myMethod");
You can subclass the adapter and provide an implementation of getListenerMethodName()
to dynamically select different methods based on the message.
This method has two parameters, originalMessage
and extractedMessage
, the latter being the result of any conversion.
By default, a SimpleMessageConverter
is configured.
See SimpleMessageConverter
for more information and information about other converters available.
Starting with version 1.4.2, the original message has consumerQueue
and consumerTag
properties, which can be used to determine the queue from which a message was received.
Starting with version 1.5, you can configure a map of consumer queue or tag to method name, to dynamically select the method to call.
If no entry is in the map, we fall back to the default listener method.
The default listener method (if not set) is handleMessage
Starting with version 2.0, a convenient FunctionalInterface
has been provided.
The following listing shows the definition of FunctionalInterface
public interface ReplyingMessageListener<T, R> {
R handleMessage(T t);
This interface facilitates convenient configuration of the adapter by using Java 8 lambdas, as the following example shows:
new MessageListenerAdapter((ReplyingMessageListener<String, String>) data -> {
return result;
Starting with version 2.2, the buildListenerArguments(Object)
has been deprecated and new buildListenerArguments(Object, Channel, Message)
one has been introduced instead.
The new method helps listener to get Channel
and Message
arguments to do more, such as calling channel.basicReject(long, boolean)
in manual acknowledge mode.
The following listing shows the most basic example:
public class ExtendedListenerAdapter extends MessageListenerAdapter {
protected Object[] buildListenerArguments(Object extractedMessage, Channel channel, Message message) {
return new Object[]{extractedMessage, channel, message};
Now you could configure ExtendedListenerAdapter
as same as MessageListenerAdapter
if you need to receive “channel” and “message”.
Parameters of listener should be set as buildListenerArguments(Object, Channel, Message)
returned, as the following example of listener shows:
public void handleMessage(Object object, Channel channel, Message message) throws IOException {
Container
Now that you have seen the various options for the Message
-listening callback, we can turn our attention to the container.
Basically, the container handles the “active” responsibilities so that the listener callback can remain passive.
The container is an example of a “lifecycle” component.
It provides methods for starting and stopping.
When configuring the container, you essentially bridge the gap between an AMQP Queue and the MessageListener
instance.
You must provide a reference to the ConnectionFactory
and the queue names or Queue instances from which that listener should consume messages.
Prior to version 2.0, there was one listener container, the SimpleMessageListenerContainer
There is now a second container, the DirectMessageListenerContainer
The differences between the containers and criteria you might apply when choosing which to use are described in Choosing a Container.
The following listing shows the most basic example, which works by using the, SimpleMessageListenerContainer
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer();
container.setConnectionFactory(rabbitConnectionFactory);
container.setQueueNames("some.queue");
container.setMessageListener(new MessageListenerAdapter(somePojo));
As an “active” component, it is most common to create the listener container with a bean definition so that it can run in the background. The following example shows one way to do so with XML:
<rabbit:listener-container connection-factory="rabbitConnectionFactory">
<rabbit:listener queues="some.queue" ref="somePojo" method="handle"/>
</rabbit:listener-container>
The following listing shows another way to do so with XML:
<rabbit:listener-container connection-factory="rabbitConnectionFactory" type="direct">
Both of the preceding examples create a DirectMessageListenerContainer
(notice the type
attribute — it defaults to simple
Alternately, you may prefer to use Java configuration, which looks similar to the preceding code snippet:
public class ExampleAmqpConfiguration {
public SimpleMessageListenerContainer messageListenerContainer() {
container.setConnectionFactory(rabbitConnectionFactory());
container.setQueueName("some.queue");
container.setMessageListener(exampleListener());
return container;
public CachingConnectionFactory rabbitConnectionFactory() {
CachingConnectionFactory connectionFactory =
connectionFactory.setUsername("guest");
connectionFactory.setPassword("guest");
return connectionFactory;
public MessageListener exampleListener() {
return new MessageListener() {
public void onMessage(Message message) {
System.out.println("received: " + message);
Consumer Priority
Starting with RabbitMQ Version 3.2, the broker now supports consumer priority (see Using Consumer Priorities with RabbitMQ).
This is enabled by setting the x-priority
argument on the consumer.
The SimpleMessageListenerContainer
now supports setting consumer arguments, as the following example shows:
container.setConsumerArguments(Collections.
<String, Object> singletonMap("x-priority", Integer.valueOf(10)));
For convenience, the namespace provides the priority
attribute on the listener
element, as the following example shows:
<rabbit:listener queues="some.queue" ref="somePojo" method="handle" priority="10" />
Starting with version 1.3, you can modify the queues on which the container listens at runtime. See Listener Container Queues.
auto-delete
Queues
When a container is configured to listen to auto-delete
queues, the queue has an x-expires
option, or the Time-To-Live policy is configured on the Broker, the queue is removed by the broker when the container is stopped (that is, when the last consumer is cancelled).
Before version 1.3, the container could not be restarted because the queue was missing.
The RabbitAdmin
only automatically redeclares queues and so on when the connection is closed or when it opens, which does not happen when the container is stopped and started.
Starting with version 1.3, the container uses a RabbitAdmin
to redeclare any missing queues during startup.
You can also use conditional declaration (see Conditional Declaration) together with an auto-startup="false"
admin to defer queue declaration until the container is started.
<rabbit:queue id="otherAnon" declared-by="containerAdmin" />
<rabbit:direct-exchange name="otherExchange" auto-delete="true" declared-by="containerAdmin">
<rabbit:bindings>
<rabbit:binding queue="otherAnon" key="otherAnon" />
</rabbit:bindings>
</rabbit:direct-exchange>
<rabbit:listener-container id="container2" auto-startup="false">
<rabbit:listener id="listener2" ref="foo" queues="otherAnon" admin="containerAdmin" />
<rabbit:admin id="containerAdmin" connection-factory="rabbitConnectionFactory"
auto-startup="false" />
In this case, the queue and exchange are declared by containerAdmin
, which has auto-startup="false"
so that the elements are not declared during context initialization.
Also, the container is not started for the same reason.
When the container is later started, it uses its reference to containerAdmin
to declare the elements.
Batched Messages
Batched messages (created by a producer) are automatically de-batched by listener containers (using the springBatchFormat
message header).
See Batching for more information about batching.
Starting with version 2.2, the SimpleMessageListenerContainer
can be use to create batches on the consumer side (where the producer sent discrete messages).
Set the container property consumerBatchEnabled
to enable this feature.
deBatchingEnabled
must also be true so that the container is responsible for processing batches of both types.
Implement BatchMessageListener
or ChannelAwareBatchMessageListener
when consumerBatchEnabled
is true.
Starting with version 2.2.7 both the SimpleMessageListenerContainer
and DirectMessageListenerContainer
can debatch producer created batches as List<Message>
See @RabbitListener with Batching for information about using this feature with @RabbitListener
Consumer Events
The containers publish application events whenever a listener
(consumer) experiences a failure of some kind.
The event ListenerContainerConsumerFailedEvent
container
: The listener container where the consumer experienced the problem. -
reason
: A textual reason for the failure. -
fatal
: A boolean indicating whether the failure was fatal. With non-fatal exceptions, the container tries to restart the consumer, according to therecoveryInterval
orrecoveryBackoff
(for theSimpleMessageListenerContainer
) or themonitorInterval
(for theDirectMessageListenerContainer
throwable
: TheThrowable
that was caught.
These events can be consumed by implementing ApplicationListener<ListenerContainerConsumerFailedEvent>
System-wide events (such as connection failures) are published by all consumers when concurrentConsumers is greater than 1.
If a consumer fails because one if its queues is being used exclusively, by default, as well as publishing the event, a WARN
log is issued.
To change this logging behavior, provide a custom ConditionalExceptionLogger
in the SimpleMessageListenerContainer
instance’s exclusiveConsumerExceptionLogger
property.
See also Logging Channel Close Events.
Fatal errors are always logged at the ERROR
level.
This it not modifiable.
Several other events are published at various stages of the container lifecycle:
AsyncConsumerStartedEvent
: When the consumer is started. -
AsyncConsumerRestartedEvent
: When the consumer is restarted after a failure -SimpleMessageListenerContainer
only. -
AsyncConsumerTerminatedEvent
: When a consumer is stopped normally. -
AsyncConsumerStoppedEvent
: When the consumer is stopped -SimpleMessageListenerContainer
only. -
ConsumeOkEvent
: When aconsumeOk
is received from the broker, contains the queue name andconsumerTag
ListenerContainerIdleEvent
: See Detecting Idle Asynchronous Consumers. -
MissingQueueEvent
: When a missing queue is detected.
Consumer Tags
You can provide a strategy to generate consumer tags.
By default, the consumer tag is generated by the broker.
The following listing shows the ConsumerTagStrategy
public interface ConsumerTagStrategy {
String createConsumerTag(String queue);
The queue is made available so that it can (optionally) be used in the tag.
The easiest way to receive a message asynchronously is to use the annotated listener endpoint infrastructure.
In a nutshell, it lets you expose a method of a managed bean as a Rabbit listener endpoint.
The following example shows how to use the @RabbitListener
annotation:
@Component
public class MyService {
@RabbitListener(queues = "myQueue")
public void processOrder(String data) {
The idea of the preceding example is that, whenever a message is available on the queue named myQueue
, the processOrder
method is invoked accordingly (in this case, with the payload of the message).
The annotated endpoint infrastructure creates a message listener container behind the scenes for each annotated method, by using a RabbitListenerContainerFactory
In the preceding example, myQueue
must already exist and be bound to some exchange.
The queue can be declared and bound automatically, as long as a RabbitAdmin
exists in the application context.
Property placeholders (${some.property} ) or SpEL expressions (#{someExpression} ) can be specified for the annotation properties (queues etc).
See Listening to Multiple Queues for an example of why you might use SpEL instead of a property placeholder.
The following listing shows three examples of how to declare a Rabbit listener:
@Component
@RabbitListener(bindings = @QueueBinding(
value = @Queue(value = "myQueue", durable = "true"),
exchange = @Exchange(value = "auto.exch", ignoreDeclarationExceptions = "true"),
key = "orderRoutingKey")
public void processOrder(Order order) {
value = @Queue,
exchange = @Exchange(value = "auto.exch"),
key = "invoiceRoutingKey")
public void processInvoice(Invoice invoice) {
@RabbitListener(queuesToDeclare = @Queue(name = "${my.queue}", durable = "true"))
public String handleWithSimpleDeclare(String data) {
In the first example, a queue myQueue
is declared automatically (durable) together with the exchange, if needed,
and bound to the exchange with the routing key.
In the second example, an anonymous (exclusive, auto-delete) queue is declared and bound; the queue name is created by the framework using the Base64UrlNamingStrategy
You cannot declare broker-named queues using this technique; they need to be declared as bean definitions; see Containers and Broker-Named queues.
Multiple QueueBinding
entries can be provided, letting the listener listen to multiple queues.
In the third example, a queue with the name retrieved from property my.queue
is declared, if necessary, with the default binding to the default exchange using the queue name as the routing key.
Since version 2.0, the @Exchange
annotation supports any exchange types, including custom.
For more information, see AMQP Concepts.
You can use normal @Bean
definitions when you need more advanced configuration.
Notice ignoreDeclarationExceptions
on the exchange in the first example.
This allows, for example, binding to an existing exchange that might have different settings (such as internal
By default, the properties of an existing exchange must match.
Starting with version 2.0, you can now bind a queue to an exchange with multiple routing keys, as the following example shows:
key = { "red", "yellow" }
You can also specify arguments within @QueueBinding
annotations for queues, exchanges,
and bindings, as the following example shows:
value = @Queue(value = "auto.headers", autoDelete = "true",
arguments = @Argument(name = "x-message-ttl", value = "10000",
type = "java.lang.Integer")),
exchange = @Exchange(value = "auto.headers", type = ExchangeTypes.HEADERS, autoDelete = "true"),
arguments = {
@Argument(name = "x-match", value = "all"),
@Argument(name = "thing1", value = "somevalue"),
@Argument(name = "thing2")
public String handleWithHeadersExchange(String foo) {
Notice that the x-message-ttl
argument is set to 10 seconds for the queue.
Since the argument type is not String
, we have to specify its type — in this case, Integer
As with all such declarations, if the queue already exists, the arguments must match those on the queue.
For the header exchange, we set the binding arguments to match messages that have the thing1
header set to somevalue
, and
the thing2
header must be present with any value.
The x-match
argument means both conditions must be satisfied.
The argument name, value, and type can be property placeholders (${…}
) or SpEL expressions (#{…}
The name
must resolve to a String
The expression for type
must resolve to a Class
or the fully-qualified name of a class.
The value
must resolve to something that can be converted by the DefaultConversionService
to the type (such as the x-message-ttl
in the preceding example).
If a name resolves to null
or an empty String
, that @Argument
is ignored.
Meta-annotations
Sometimes you may want to use the same configuration for multiple listeners. To reduce the boilerplate configuration, you can use meta-annotations to create your own listener annotation. The following example shows how to do so:
@Target({ElementType.TYPE, ElementType.METHOD, ElementType.ANNOTATION_TYPE})
value = @Queue,
exchange = @Exchange(value = "metaFanout", type = ExchangeTypes.FANOUT)))
public @interface MyAnonFanoutListener {
public class MetaListener {
@MyAnonFanoutListener
public void handle1(String foo) {
public void handle2(String foo) {
In the preceding example, each listener created by the @MyAnonFanoutListener
annotation binds an anonymous, auto-delete
queue to the fanout exchange, metaFanout
Starting with version 2.2.3, @AliasFor
is supported to allow overriding properties on the meta-annotated annotation.
Also, user annotations can now be @Repeatable
, allowing multiple containers to be created for a method.
@Component
static class MetaAnnotationTestBean {
@MyListener("queue1")
@MyListener("queue2")
public void handleIt(String body) {
@RabbitListener
@Target(ElementType.METHOD)
@Repeatable(MyListeners.class)
static @interface MyListener {
@AliasFor(annotation = RabbitListener.class, attribute = "queues")
String[] value() default {};
static @interface MyListeners {
MyListener[] value();
Enable Listener Endpoint Annotations
To enable support for @RabbitListener
annotations, you can add @EnableRabbit
to one of your @Configuration
classes.
@EnableRabbit
public class AppConfig {
public SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory() {
SimpleRabbitListenerContainerFactory factory = new SimpleRabbitListenerContainerFactory();
factory.setConnectionFactory(connectionFactory());
factory.setConcurrentConsumers(3);
factory.setMaxConcurrentConsumers(10);
factory.setContainerCustomizer(container -> /* customize the container */);
return factory;
Since version 2.0, a DirectMessageListenerContainerFactory
is also available.
It creates DirectMessageListenerContainer
instances.
For information to help you choose between SimpleRabbitListenerContainerFactory and DirectRabbitListenerContainerFactory , see Choosing a Container.
Starting wih version 2.2.2, you can provide a ContainerCustomizer
implementation (as shown above).
This can be used to further configure the container after it has been created and configured; you can use this, for example, to set properties that are not exposed by the container factory.
Version 2.4.8 provides the CompositeContainerCustomizer
for situations where you wish to apply multiple customizers.
By default, the infrastructure looks for a bean named rabbitListenerContainerFactory
as the source for the factory to use to create message listener containers.
In this case, and ignoring the RabbitMQ infrastructure setup, the processOrder
method can be invoked with a core poll size of three threads and a maximum pool size of ten threads.
You can customize the listener container factory to use for each annotation, or you can configure an explicit default by implementing the RabbitListenerConfigurer
interface.
The default is required only if at least one endpoint is registered without a specific container factory.
See the Javadoc for full details and examples.
The container factories provide methods for adding MessagePostProcessor
instances that are applied after receiving messages (before invoking the listener) and before sending replies.
See Reply Management for information about replies.
Starting with version 2.0.6, you can add a RetryTemplate
and RecoveryCallback
to the listener container factory.
It is used when sending replies.
is invoked when retries are exhausted.
You can use a SendRetryContextAccessor
to get information from the context.
factory.setRetryTemplate(retryTemplate);
factory.setReplyRecoveryCallback(ctx -> {
Message failed = SendRetryContextAccessor.getMessage(ctx);
Address replyTo = SendRetryContextAccessor.getAddress(ctx);
Throwable t = ctx.getLastThrowable();
return null;
If you prefer XML configuration, you can use the <rabbit:annotation-driven>
element.
Any beans annotated with @RabbitListener
are detected.
For SimpleRabbitListenerContainer
instances, you can use XML similar to the following:
<rabbit:annotation-driven/>
<bean id="rabbitListenerContainerFactory"
class="org.springframework.amqp.rabbit.config.SimpleRabbitListenerContainerFactory">
<property name="connectionFactory" ref="connectionFactory"/>
<property name="concurrentConsumers" value="3"/>
<property name="maxConcurrentConsumers" value="10"/>
</bean>
For DirectMessageListenerContainer
class="org.springframework.amqp.rabbit.config.DirectRabbitListenerContainerFactory">
<property name="consumersPerQueue" value="3"/>
</bean>
Starting with version 2.0, the @RabbitListener
annotation has a concurrency
property.
It supports SpEL expressions (#{…}
) and property placeholders (${…}
Its meaning and allowed values depend on the container type, as follows:
For the
, the value must be a single integer value, which sets theconsumersPerQueue
property on the container. -
For the
, the value can be a single integer value, which sets theconcurrentConsumers
property on the container, or it can have the form,m-n
, wherem
is theconcurrentConsumers
property andn
is themaxConcurrentConsumers
property.
In either case, this setting overrides the settings on the factory. Previously you had to define different container factories if you had listeners that required different concurrency.
The annotation also allows overriding the factory autoStartup
and taskExecutor
properties via the autoStartup
and executor
(since 2.2) annotation properties.
Using a different executor for each might help with identifying threads associated with each listener in logs and thread dumps.
Version 2.2 also added the ackMode
property, which allows you to override the container factory’s acknowledgeMode
property.
@RabbitListener(id = "manual.acks.1", queues = "manual.acks.1", ackMode = "MANUAL")
public void manual1(String in, Channel channel,
@Header(AmqpHeaders.DELIVERY_TAG) long tag) throws IOException {
channel.basicAck(tag, false);
Message Conversion for Annotated Methods
There are two conversion steps in the pipeline before invoking the listener.
The first step uses a MessageConverter
to convert the incoming Spring AMQP Message
to a Spring-messaging Message
When the target method is invoked, the message payload is converted, if necessary, to the method parameter type.
The default MessageConverter
for the first step is a Spring AMQP SimpleMessageConverter
that handles conversion to
String
and java.io.Serializable
objects.
All others remain as a byte[]
In the following discussion, we call this the “message converter”.
The default converter for the second step is a GenericMessageConverter
, which delegates to a conversion service
(an instance of DefaultFormattingConversionService
In the following discussion, we call this the “method argument converter”.
To change the message converter, you can add it as a property to the container factory bean. The following example shows how to do so:
factory.setMessageConverter(new Jackson2JsonMessageConverter());
return factory;
This configures a Jackson2 converter that expects header information to be present to guide the conversion.
You can also use a ContentTypeDelegatingMessageConverter
, which can handle conversion of different content types.
Starting with version 2.3, you can override the factory converter by specifying a bean name in the messageConverter
property.
public Jackson2JsonMessageConverter jsonConverter() {
return new Jackson2JsonMessageConverter();
@RabbitListener(..., messageConverter = "jsonConverter")
public void listen(String in) {
This avoids having to declare a different container factory just to change the converter.
In most cases, it is not necessary to customize the method argument converter unless, for example, you want to use
a custom ConversionService
In versions prior to 1.6, the type information to convert the JSON had to be provided in message headers, or a
custom ClassMapper
was required.
Starting with version 1.6, if there are no type information headers, the type can be inferred from the target
method arguments.
This type inference works only for @RabbitListener at the method level.
See Jackson2JsonMessageConverter for more information.
If you wish to customize the method argument converter, you can do so as follows:
@EnableRabbit
public class AppConfig implements RabbitListenerConfigurer {
public DefaultMessageHandlerMethodFactory myHandlerMethodFactory() {
DefaultMessageHandlerMethodFactory factory = new DefaultMessageHandlerMethodFactory();
factory.setMessageConverter(new GenericMessageConverter(myConversionService()));
return factory;
public DefaultConversionService myConversionService() {
DefaultConversionService conv = new DefaultConversionService();
conv.addConverter(mySpecialConverter());
return conv;
public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
registrar.setMessageHandlerMethodFactory(myHandlerMethodFactory());
For multi-method listeners (see Multi-method Listeners), the method selection is based on the payload of the message after the message conversion. The method argument converter is called only after the method has been selected. |
Adding a Custom HandlerMethodArgumentResolver
to @RabbitListener
Starting with version 2.3.7 you are able to add your own HandlerMethodArgumentResolver
and resolve custom method parameters.
All you need is to implement RabbitListenerConfigurer
and use method setCustomMethodArgumentResolvers()
from class RabbitListenerEndpointRegistrar
class CustomRabbitConfig implements RabbitListenerConfigurer {
registrar.setCustomMethodArgumentResolvers(
new HandlerMethodArgumentResolver() {
public boolean supportsParameter(MethodParameter parameter) {
return CustomMethodArgument.class.isAssignableFrom(parameter.getParameterType());
public Object resolveArgument(MethodParameter parameter, org.springframework.messaging.Message<?> message) {
return new CustomMethodArgument(
(String) message.getPayload(),
message.getHeaders().get("customHeader", String.class)
Programmatic Endpoint Registration
provides a model of a Rabbit endpoint and is responsible for configuring the container for that model.
The infrastructure lets you configure endpoints programmatically in addition to the ones that are detected by the RabbitListener
annotation.
@EnableRabbit
SimpleRabbitListenerEndpoint endpoint = new SimpleRabbitListenerEndpoint();
endpoint.setQueueNames("anotherQueue");
endpoint.setMessageListener(message -> {
// processing
registrar.registerEndpoint(endpoint);
In the preceding example, we used SimpleRabbitListenerEndpoint
, which provides the actual MessageListener
to invoke, but you could just as well build your own endpoint variant to describe a custom invocation mechanism.
It should be noted that you could just as well skip the use of @RabbitListener
altogether and register your endpoints programmatically through RabbitListenerConfigurer
Annotated Endpoint Method Signature
So far, we have been injecting a simple String
in our endpoint, but it can actually have a very flexible method signature.
The following example rewrites it to inject the Order
with a custom header:
@Component
public void processOrder(Order order, @Header("order_type") String orderType) {
The following list shows the arguments that are available to be matched with parameters in listener endpoints:
The raw
org.springframework.amqp.core.Message
The
MessageProperties
from the rawMessage
The
com.rabbitmq.client.Channel
on which the message was received. -
The
converted from the incoming AMQP message. -
@Header
-annotated method arguments to extract a specific header value, including standard AMQP headers. -
@Headers
-annotated argument that must also be assignable tojava.util.Map
for getting access to all headers. -
The converted payload
A non-annotated element that is not one of the supported types (that is,
Message
, MessageProperties
, Message<?>
and Channel
) is matched with the payload.
You can make that explicit by annotating the parameter with @Payload
You can also turn on validation by adding an extra @Valid
The ability to inject Spring’s message abstraction is particularly useful to benefit from all the information stored in the transport-specific message without relying on the transport-specific API. The following example shows how to do so:
public void processOrder(Message<Order> order) { ...
Handling of method arguments is provided by DefaultMessageHandlerMethodFactory
, which you can further customize to support additional method arguments.
The conversion and validation support can be customized there as well.
For instance, if we want to make sure our Order
is valid before processing it, we can annotate the payload with @Valid
and configure the necessary validator, as follows:
@EnableRabbit
factory.setValidator(myValidator());
return factory;
@RabbitListener @Payload Validation
Starting with version 2.3.7, it is now easier to add a Validator
to validate @RabbitListener
and @RabbitHandler
@Payload
arguments.
Now, you can simply add the validator to the registrar itself.
@EnableRabbit
public class Config implements RabbitListenerConfigurer {
registrar.setValidator(new MyValidator());
When using Spring Boot with the validation starter, a LocalValidatorFactoryBean is auto-configured:
@EnableRabbit
@Autowired
private LocalValidatorFactoryBean validator;
registrar.setValidator(this.validator);
To validate:
public static class ValidatedClass {
@Max(10)
private int bar;
public int getBar() {
return this.bar;
public void setBar(int bar) {
this.bar = bar;
and
@RabbitListener(id="validated", queues = "queue1", errorHandler = "validationErrorHandler",
containerFactory = "jsonListenerContainerFactory")
public void validatedListener(@Payload @Valid ValidatedClass val) {
public RabbitListenerErrorHandler validationErrorHandler() {
return (m, e) -> {
When you use the queues
attribute, you can specify that the associated container can listen to multiple queues.
You can use a @Header
annotation to make the queue name from which a message was received available to the POJO
method.
@Component
@RabbitListener(queues = { "queue1", "queue2" } )
public void processOrder(String data, @Header(AmqpHeaders.CONSUMER_QUEUE) String queue) {
Starting with version 1.5, you can externalize the queue names by using property placeholders and SpEL. The following example shows how to do so:
@Component
@RabbitListener(queues = "#{'${property.with.comma.delimited.queue.names}'.split(',')}" )
Prior to version 1.5, only a single queue could be specified this way. Each queue needed a separate property.
Reply Management
The existing support in MessageListenerAdapter
already lets your method have a non-void return type.
When that is the case, the result of the invocation is encapsulated in a message sent to the address specified in the ReplyToAddress
header of the original message, or to the default address configured on the listener.
You can set that default address by using the @SendTo
annotation of the messaging abstraction.
Assuming our processOrder
method should now return an OrderStatus
, we can write it as follows to automatically send a reply:
@RabbitListener(destination = "myQueue")
@SendTo("status")
public OrderStatus processOrder(Order order) {
// order processing
return status;
If you need to set additional headers in a transport-independent manner, you could return a Message
instead, something like the following:
@SendTo("status")
public Message<OrderStatus> processOrder(Order order) {
// order processing
return MessageBuilder
.withPayload(status)
.setHeader("code", 1234)
Alternatively, you can use a MessagePostProcessor
in the beforeSendReplyMessagePostProcessors
container factory property to add more headers.
Starting with version 2.2.3, the called bean/method is made avaiable in the reply message, which can be used in a message post processor to communicate the information back to the caller:
factory.setBeforeSendReplyPostProcessors(msg -> {
msg.getMessageProperties().setHeader("calledBean",
msg.getMessageProperties().getTargetBean().getClass().getSimpleName());
msg.getMessageProperties().setHeader("calledMethod",
msg.getMessageProperties().getTargetMethod().getName());
return m;
Starting with version 2.2.5, you can configure a ReplyPostProcessor
to modify the reply message before it is sent; it is called after the correlationId
header has been set up to match the request.
@RabbitListener(queues = "test.header", group = "testGroup", replyPostProcessor = "echoCustomHeader")
public String capitalizeWithHeader(String in) {
return in.toUpperCase();
public ReplyPostProcessor echoCustomHeader() {
return (req, resp) -> {
resp.getMessageProperties().setHeader("myHeader", req.getMessageProperties().getHeader("myHeader"));
return resp;
The @SendTo
value is assumed as a reply exchange
and routingKey
pair that follows the exchange/routingKey
pattern,
where one of those parts can be omitted.
The valid values are as follows:
thing1/thing2
: ThereplyTo
exchange and theroutingKey
.thing1/
: ThereplyTo
exchange and the default (empty)routingKey
.thing2
or/thing2
: ThereplyTo
routingKey
and the default (empty) exchange./
or empty: ThereplyTo
default exchange and the defaultroutingKey
Also, you can use @SendTo
without a value
attribute.
This case is equal to an empty sendTo
pattern.
@SendTo
is used only if the inbound message does not have a replyToAddress
property.
Starting with version 1.5, the @SendTo
value can be a bean initialization SpEL Expression, as shown in the following example:
@RabbitListener(queues = "test.sendTo.spel")
@SendTo("#{spelReplyTo}")
public String capitalizeWithSendToSpel(String foo) {
return foo.toUpperCase();
public String spelReplyTo() {
return "test.sendTo.reply.spel";
The expression must evaluate to a String
, which can be a simple queue name (sent to the default exchange) or with
the form exchange/routingKey
as discussed prior to the preceding example.
The #{…} expression is evaluated once, during initialization.
For dynamic reply routing, the message sender should include a reply_to
message property or use the alternate
runtime SpEL expression (described after the next example).
Starting with version 1.6, the @SendTo
can be a SpEL expression that is evaluated at runtime against the request
and reply, as the following example shows:
@SendTo("!{'some.reply.queue.with.' + result.queueName}")
public Bar capitalizeWithSendToSpel(Foo foo) {
return processTheFooAndReturnABar(foo);
The runtime nature of the SpEL expression is indicated with !{…}
delimiters.
The evaluation context #root
object for the expression has three properties:
request
: Theo.s.amqp.core.Message
request object. -
source
: Theo.s.messaging.Message<?>
after conversion. -
result
: The method result.
The context has a map property accessor, a standard type converter, and a bean resolver, which lets other beans in the
context be referenced (for example, @someBeanName.determineReplyQ(request, result)
In summary, #{…}
is evaluated once during initialization, with the #root
object being the application context.
Beans are referenced by their names.
is evaluated at runtime for each message, with the root object having the properties listed earlier.
Beans are referenced with their names, prefixed by @
Starting with version 2.1, simple property placeholders are also supported (for example, ${some.reply.to}
With earlier versions, the following can be used as a work around, as the following example shows:
@RabbitListener(queues = "foo")
@SendTo("#{environment['my.send.to']}")
public String listen(Message in) {
return ...
Reply ContentType
If you are using a sophisticated message converter, such as the ContentTypeDelegatingMessageConverter
, you can control the content type of the reply by setting the replyContentType
property on the listener.
This allows the converter to select the appropriate delegate converter for the reply.
@RabbitListener(queues = "q1", messageConverter = "delegating",
replyContentType = "application/json")
public Thing2 listen(Thing1 in) {
By default, for backwards compatibility, any content type property set by the converter will be overwritten by this value after conversion.
Converters such as the SimpleMessageConverter
use the reply type rather than the content type to determine the conversion needed and sets the content type in the reply message appropriately.
This may not be the desired action and can be overridden by setting the converterWinsContentType
property to false
For example, if you return a String
containing JSON, the SimpleMessageConverter
will set the content type in the reply to text/plain
The following configuration will ensure the content type is set properly, even if the SimpleMessageConverter
is used.
@RabbitListener(queues = "q1", replyContentType = "application/json",
converterWinsContentType = "false")
public String listen(Thing in) {
return someJsonString;
These properties (replyContentType
and converterWinsContentType
) do not apply when the return type is a Spring AMQP Message
or a Spring Messaging Message<?>
In the first case, there is no conversion involved; simply set the contentType
message property.
In the second case, the behavior is controlled using message headers:
@RabbitListener(queues = "q1", messageConverter = "delegating")
@SendTo("q2")
public Message<String> listen(String in) {
return MessageBuilder.withPayload(in.toUpperCase())
.setHeader(MessageHeaders.CONTENT_TYPE, "application/xml")
This content type will be passed in the MessageProperties
to the converter.
If you wish to override that behavior, also set the AmqpHeaders.CONTENT_TYPE_CONVERTER_WINS
to true
and any value set by the converter will be retained.
Starting with version 1.5.0, you can specify the @RabbitListener
annotation at the class level.
Together with the new @RabbitHandler
annotation, this lets a single listener invoke different methods, based on
the payload type of the incoming message.
This is best described using an example:
@RabbitListener(id="multi", queues = "someQueue")
@SendTo("my.reply.queue")
public class MultiListenerBean {
@RabbitHandler
public String thing2(Thing2 thing2) {
@RabbitHandler
public String cat(Cat cat) {
@RabbitHandler
public String hat(@Header("amqp_receivedRoutingKey") String rk, @Payload Hat hat) {
@RabbitHandler(isDefault = true)
public String defaultMethod(Object object) {
In this case, the individual @RabbitHandler
methods are invoked if the converted payload is a Thing2
, a Cat
, or a Hat
You should understand that the system must be able to identify a unique method based on the payload type.
The type is checked for assignability to a single parameter that has no annotations or that is annotated with the @Payload
annotation.
Notice that the same method signatures apply, as discussed in the method-level @RabbitListener
(described earlier).
Starting with version 2.0.3, a @RabbitHandler
method can be designated as the default method, which is invoked if there is no match on other methods.
At most, one method can be so designated.
@RabbitHandler is intended only for processing message payloads after conversion, if you wish to receive the unconverted raw Message object, you must use @RabbitListener on the method, not the class.
@Repeatable
@RabbitListener
Starting with version 1.6, the @RabbitListener
annotation is marked with @Repeatable
This means that the annotation can appear on the same annotated element (method or class) multiple times.
In this case, a separate listener container is created for each annotation, each of which invokes the same listener
Repeatable annotations can be used with Java 8 or above.
Proxy @RabbitListener
and Generics
If your service is intended to be proxied (for example, in the case of @Transactional
), you should keep in mind some considerations when
the interface has generic parameters.
Consider the following example:
interface TxService<P> {
String handle(P payload, String header);
static class TxServiceImpl implements TxService<Foo> {
@RabbitListener(...)
public String handle(Thing thing, String rk) {
With a generic interface and a particular implementation, you are forced to switch to the CGLIB target class proxy because the actual implementation of the interface
handle
method is a bridge method.
In the case of transaction management, the use of CGLIB is configured by using
an annotation option: @EnableTransactionManagement(proxyTargetClass = true)
And in this case, all annotations have to be declared on the target method in the implementation, as the following example shows:
@Transactional
public String handle(@Payload Foo foo, @Header("amqp_receivedRoutingKey") String rk) {
Handling Exceptions
By default, if an annotated listener method throws an exception, it is thrown to the container and the message are requeued and redelivered, discarded, or routed to a dead letter exchange, depending on the container and broker configuration. Nothing is returned to the sender.
annotation has two new attributes: errorHandler
and returnExceptions
These are not configured by default.
You can use the errorHandler
to provide the bean name of a RabbitListenerErrorHandler
implementation.
This functional interface has one method, as follows:
@FunctionalInterface
public interface RabbitListenerErrorHandler {
Object handleError(Message amqpMessage, org.springframework.messaging.Message<?> message,
ListenerExecutionFailedException exception) throws Exception;
As you can see, you have access to the raw message received from the container, the spring-messaging Message<?>
object produced by the message converter, and the exception that was thrown by the listener (wrapped in a ListenerExecutionFailedException
The error handler can either return some result (which is sent as the reply) or throw the original or a new exception (which is thrown to the container or returned to the sender, depending on the returnExceptions
setting).
The returnExceptions
attribute, when true
, causes exceptions to be returned to the sender.
The exception is wrapped in a RemoteInvocationResult
object.
On the sender side, there is an available RemoteInvocationAwareMessageConverterAdapter
, which, if configured into the RabbitTemplate
, re-throws the server-side exception, wrapped in an AmqpRemoteException
The stack trace of the server exception is synthesized by merging the server and client stack traces.
This mechanism generally works only with the default SimpleMessageConverter , which uses Java serialization.
Exceptions are generally not “Jackson-friendly” and cannot be serialized to JSON.
If you use JSON, consider using an errorHandler to return some other Jackson-friendly Error object when an exception is thrown.
In version 2.1, this interface moved from package o.s.amqp.rabbit.listener to o.s.amqp.rabbit.listener.api .
Starting with version 2.1.7, the Channel
is available in a messaging message header; this allows you to ack or nack the failed messasge when using AcknowledgeMode.MANUAL
public Object handleError(Message amqpMessage, org.springframework.messaging.Message<?> message,
ListenerExecutionFailedException exception) {
message.getHeaders().get(AmqpHeaders.CHANNEL, Channel.class)
.basicReject(message.getHeaders().get(AmqpHeaders.DELIVERY_TAG, Long.class),
true);
Starting with version 2.2.18, if a message conversion exception is thrown, the error handler will be called, with null
in the message
argument.
This allows the application to send some result to the caller, indicating that a badly-formed message was received.
Previously, such errors were thrown and handled by the container.
Container Management
Containers created for annotations are not registered with the application context.
You can obtain a collection of all containers by invoking getListenerContainers()
on the
RabbitListenerEndpointRegistry
bean.
You can then iterate over this collection, for example, to stop or start all containers or invoke the Lifecycle
methods
on the registry itself, which will invoke the operations on each container.
You can also get a reference to an individual container by using its id
, using getListenerContainer(String id)
— for
example, registry.getListenerContainer("multi")
for the container created by the snippet above.
Starting with version 1.5.2, you can obtain the id
values of the registered containers with getListenerContainerIds()
Starting with version 1.5, you can now assign a group
to the container on the RabbitListener
endpoint.
This provides a mechanism to get a reference to a subset of containers.
Adding a group
attribute causes a bean of type Collection<MessageListenerContainer>
to be registered with the context with the group name.
By default, stopping a container will cancel the consumer and process all prefetched messages before stopping. Starting with versions 2.4.14, 3.0.6, you can set the [forceStop] container property to true to stop immediately after the current message is processed, causing any prefetched messages to be requeued. This is useful, for example, if exclusive or single-active consumers are being used.
When receiving a a batch of messages, the de-batching is normally performed by the container and the listener is invoked with one message at at time.
Starting with version 2.2, you can configure the listener container factory and listener to receive the entire batch in one call, simply set the factory’s batchListener
property, and make the method payload parameter a List
factory.setBatchListener(true);
return factory;
@RabbitListener(queues = "batch.1")
public void listen1(List<Thing> in) {
// or
@RabbitListener(queues = "batch.2")
public void listen2(List<Message<Thing>> in) {
Setting the batchListener
property to true automatically turns off the deBatchingEnabled
container property in containers that the factory creates (unless consumerBatchEnabled
is true
- see below). Effectively, the debatching is moved from the container to the listener adapter and the adapter creates the list that is passed to the listener.
A batch-enabled factory cannot be used with a multi-method listener.
Also starting with version 2.2. when receiving batched messages one-at-a-time, the last message contains a boolean header set to true
This header can be obtained by adding the @Header(AmqpHeaders.LAST_IN_BATCH)
boolean last` parameter to your listener method.
The header is mapped from MessageProperties.isLastInBatch()
In addition, AmqpHeaders.BATCH_SIZE
is populated with the size of the batch in every message fragment.
In addition, a new property consumerBatchEnabled
has been added to the SimpleMessageListenerContainer
When this is true, the container will create a batch of messages, up to batchSize
; a partial batch is delivered if receiveTimeout
elapses with no new messages arriving.
If a producer-created batch is received, it is debatched and added to the consumer-side batch; therefore the actual number of messages delivered may exceed batchSize
, which represents the number of messages received from the broker.
deBatchingEnabled
must be true when consumerBatchEnabled
is true; the container factory will enforce this requirement.
public SimpleRabbitListenerContainerFactory consumerBatchContainerFactory() {
factory.setConnectionFactory(rabbitConnectionFactory());
factory.setConsumerTagStrategy(consumerTagStrategy());
factory.setBatchListener(true); // configures a BatchMessageListenerAdapter
factory.setBatchSize(2);
factory.setConsumerBatchEnabled(true);
return factory;
When using consumerBatchEnabled
@RabbitListener(queues = "batch.1", containerFactory = "consumerBatchContainerFactory")
public void consumerBatch1(List<Message> amqpMessages) {
this.amqpMessagesReceived = amqpMessages;
this.batch1Latch.countDown();
@RabbitListener(queues = "batch.2", containerFactory = "consumerBatchContainerFactory")
public void consumerBatch2(List<org.springframework.messaging.Message<Invoice>> messages) {
this.messagingMessagesReceived = messages;
this.batch2Latch.countDown();
@RabbitListener(queues = "batch.3", containerFactory = "consumerBatchContainerFactory")
public void consumerBatch3(List<Invoice> strings) {
this.batch3Strings = strings;
this.batch3Latch.countDown();
the first is called with the raw, unconverted
s received. -
the second is called with the
s with converted payloads and mapped headers/properties. -
the third is called with the converted payloads, with no access to headers/properties.
You can also add a Channel
parameter, often used when using MANUAL
ack mode.
This is not very useful with the third example because you don’t have access to the delivery_tag
property.
Using Container Factories
Listener container factories were introduced to support the @RabbitListener
and registering containers with the RabbitListenerEndpointRegistry
, as discussed in Programmatic Endpoint Registration.
Starting with version 2.1, they can be used to create any listener container — even a container without a listener (such as for use in Spring Integration). Of course, a listener must be added before the container is started.
There are two ways to create such containers:
Use a SimpleRabbitListenerEndpoint
Add the listener after creation
The following example shows how to use a SimpleRabbitListenerEndpoint
to create a listener container:
public SimpleMessageListenerContainer factoryCreatedContainerSimpleListener(
SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory) {
endpoint.setQueueNames("queue.1");
return rabbitListenerContainerFactory.createListenerContainer(endpoint);
The following example shows how to add the listener after creation:
public SimpleMessageListenerContainer factoryCreatedContainerNoListener(
SimpleMessageListenerContainer container = rabbitListenerContainerFactory.createListenerContainer();
container.setMessageListener(message -> {
container.setQueueNames("test.no.listener.yet");
return container;
In either case, the listener can also be a ChannelAwareMessageListener
, since it is now a sub-interface of MessageListener
These techniques are useful if you wish to create several containers with similar properties or use a pre-configured container factory such as the one provided by Spring Boot auto configuration or both.
Containers created this way are normal @Bean instances and are not registered in the RabbitListenerEndpointRegistry .
Asynchronous @RabbitListener
Return Types
Starting with version 2.1, @RabbitListener
(and @RabbitHandler
) methods can be specified with asynchronous return types ListenableFuture<?>
and Mono<?>
, letting the reply be sent asynchronously.
CompletableFuture<?>
was added in 2.4.7 and ListenableFuture<?>
will be removed in 3.0.
The listener container factory must be configured with AcknowledgeMode.MANUAL so that the consumer thread will not ack the message; instead, the asynchronous completion will ack or nack the message when the async operation completes.
When the async result is completed with an error, whether the message is requeued or not depends on the exception type thrown, the container configuration, and the container error handler.
By default, the message will be requeued, unless the container’s defaultRequeueRejected property is set to false (it is true by default).
If the async result is completed with an AmqpRejectAndDontRequeueException , the message will not be requeued.
If the container’s defaultRequeueRejected property is false , you can override that by setting the future’s exception to a ImmediateRequeueException and the message will be requeued.
If some exception occurs within the listener method that prevents creation of the async result object, you MUST catch that exception and return an appropriate return object that will cause the message to be acknowledged or requeued.
Starting with versions 2.2.21, 2.3.13, 2.4.1, the AcknowledgeMode
will be automatically set the MANUAL
when async return types are detected.
In addition, incoming messages with fatal exceptions will be negatively acknowledged individually, previously any prior unacknowledged message were also negatively acknowledged.
Starting with version 2.4.16, the @RabbitListener
(and @RabbitHandler
) methods can be marked with Kotlin suspend
and the whole handling process and reply producing (optional) happens on respective Kotlin coroutine.
The above mentioned rules about AcknowledgeMode.MANUAL
still apply.
The org.jetbrains.kotlinx:kotlinx-coroutines-reactor
dependency must be present in classpath to allow suspend
function invocations.
Threading and Asynchronous Consumers
A number of different threads are involved with asynchronous consumers.
Threads from the TaskExecutor
configured in the SimpleMessageListenerContainer
are used to invoke the MessageListener
when a new message is delivered by RabbitMQ Client
If not configured, a SimpleAsyncTaskExecutor
is used.
If you use a pooled executor, you need to ensure the pool size is sufficient to handle the configured concurrency.
With the DirectMessageListenerContainer
, the MessageListener
is invoked directly on a RabbitMQ Client
thread.
In this case, the taskExecutor
is used for the task that monitors the consumers.
When using the default SimpleAsyncTaskExecutor , for the threads the listener is invoked on, the listener container beanName is used in the threadNamePrefix .
This is useful for log analysis.
We generally recommend always including the thread name in the logging appender configuration.
When a TaskExecutor is specifically provided through the taskExecutor property on the container, it is used as is, without modification.
It is recommended that you use a similar technique to name the threads created by a custom TaskExecutor bean definition, to aid with thread identification in log messages.
The Executor
configured in the CachingConnectionFactory
is passed into the RabbitMQ Client
when creating the connection, and its threads are used to deliver new messages to the listener container.
If this is not configured, the client uses an internal thread pool executor with (at the time of writing) a pool size of Runtime.getRuntime().availableProcessors() * 2
for each connection.
If you have a large number of factories or are using CacheMode.CONNECTION
, you may wish to consider using a shared ThreadPoolTaskExecutor
with enough threads to satisfy your workload.
With the DirectMessageListenerContainer , you need to ensure that the connection factory is configured with a task executor that has sufficient threads to support your desired concurrency across all listener containers that use that factory.
The default pool size (at the time of writing) is Runtime.getRuntime().availableProcessors() * 2 .
The RabbitMQ client
uses a ThreadFactory
to create threads for low-level I/O (socket) operations.
To modify this factory, you need to configure the underlying RabbitMQ ConnectionFactory
, as discussed in Configuring the Underlying Client Connection Factory.
Version 2.0 introduced the DirectMessageListenerContainer
(DMLC).
Previously, only the SimpleMessageListenerContainer
(SMLC) was available.
The SMLC uses an internal queue and a dedicated thread for each consumer.
If a container is configured to listen to multiple queues, the same consumer thread is used to process all the queues.
Concurrency is controlled by concurrentConsumers
and other properties.
As messages arrive from the RabbitMQ client, the client thread hands them off to the consumer thread through the queue.
This architecture was required because, in early versions of the RabbitMQ client, multiple concurrent deliveries were not possible.
Newer versions of the client have a revised threading model and can now support concurrency.
This has allowed the introduction of the DMLC where the listener is now invoked directly on the RabbitMQ Client thread.
Its architecture is, therefore, actually “simpler” than the SMLC.
However, there are some limitations with this approach, and certain features of the SMLC are not available with the DMLC.
Also, concurrency is controlled by consumersPerQueue
(and the client library’s thread pool).
The concurrentConsumers
and associated properties are not available with this container.
The following features are available with the SMLC but not the DMLC:
batchSize
: With the SMLC, you can set this to control how many messages are delivered in a transaction or to reduce the number of acks, but it may cause the number of duplicate deliveries to increase after a failure. (The DMLC does havemessagesPerAck
, which you can use to reduce the acks, the same as withbatchSize
and the SMLC, but it cannot be used with transactions — each message is delivered and ack’d in a separate transaction). -
: enables batching of discrete messages in the consumer; see Message Listener Container Configuration for more information. -
and consumer scaling intervals or triggers — there is no auto-scaling in the DMLC. It does, however, let you programmatically change theconsumersPerQueue
property and the consumers are adjusted accordingly.
However, the DMLC has the following benefits over the SMLC:
Adding and removing queues at runtime is more efficient. With the SMLC, the entire consumer thread is restarted (all consumers canceled and re-created). With the DMLC, unaffected consumers are not canceled.
The context switch between the RabbitMQ Client thread and the consumer thread is avoided.
Threads are shared across consumers rather than having a dedicated thread for each consumer in the SMLC. However, see the IMPORTANT note about the connection factory configuration in Threading and Asynchronous Consumers.
See Message Listener Container Configuration for information about which configuration properties apply to each container.
While efficient, one problem with asynchronous consumers is detecting when they are idle — users might want to take some action if no messages arrive for some period of time.
Starting with version 1.6, it is now possible to configure the listener container to publish a
when some time passes with no message delivery.
While the container is idle, an event is published every idleEventInterval
milliseconds.
To configure this feature, set idleEventInterval
on the container.
The following example shows how to do so in XML and in Java (for both a SimpleMessageListenerContainer
and a SimpleRabbitListenerContainerFactory
<rabbit:listener-container connection-factory="connectionFactory"
idle-event-interval="60000"
<rabbit:listener id="container1" queue-names="foo" ref="myListener" method="handle" />
public SimpleMessageListenerContainer(ConnectionFactory connectionFactory) {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer(connectionFactory);
container.setIdleEventInterval(60000L);
return container;
factory.setIdleEventInterval(60000L);
return factory;
In each of these cases, an event is published once per minute while the container is idle.
Event Consumption
You can capture idle events by implementing ApplicationListener
— either a general listener, or one narrowed to only
receive this specific event.
You can also use @EventListener
, introduced in Spring Framework 4.2.
The following example combines the @RabbitListener
and @EventListener
into a single class.
You need to understand that the application listener gets events for all containers, so you may need to
check the listener ID if you want to take specific action based on which container is idle.
You can also use the @EventListener
condition
for this purpose.
The events have four properties:
source
: The listener container instance -
id
: The listener ID (or container bean name) -
idleTime
: The time the container had been idle when the event was published -
queueNames
: The names of the queue(s) that the container listens to
The following example shows how to create listeners by using both the @RabbitListener
and the @EventListener
annotations:
public class Listener {
@RabbitListener(id="someId", queues="#{queue.name}")
public String listen(String foo) {
@EventListener(condition = "event.listenerId == 'someId'")
public void onApplicationEvent(ListenerContainerIdleEvent event) {
Event listeners see events for all containers. Consequently, in the preceding example, we narrow the events received based on the listener ID. |
If you wish to use the idle event to stop the lister container, you should not call container.stop() on the thread that calls the listener.
Doing so always causes delays and unnecessary log messages.
Instead, you should hand off the event to a different thread that can then stop the container.
Monitoring Listener Performance
Starting with version 2.2, the listener containers will automatically create and update Micrometer Timer
s for the listener, if Micrometer
is detected on the class path, and a single MeterRegistry
is present in the application context (or exactly one is annotated @Primary
, such as when using Spring Boot).
The timers can be disabled by setting the container property micrometerEnabled
to false
Two timers are maintained - one for successful calls to the listener and one for failures.
With a simple MessageListener
, there is a pair of timers for each configured queue.
The timers are named spring.rabbitmq.listener
and have the following tags:
listenerId
: (listener id or container bean name) -
queue
: (the queue name for a simple listener or list of configured queue names whenconsumerBatchEnabled
istrue
- because a batch may contain messages from multiple queues) -
result
:success
orfailure
exception
:none
orListenerExecutionFailedException
You can add additional tags using the micrometerTags
container property.
4.1.7. Containers and Broker-Named queues
While it is preferable to use AnonymousQueue
instances as auto-delete queues, starting with version 2.1, you can use broker named queues with listener containers.
public Queue queue() {
return new Queue("", false, true, true);
public SimpleMessageListenerContainer container() {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer(cf());
container.setQueues(queue());
container.setMessageListener(m -> {
container.setMissingQueuesFatal(false);
return container;
Notice the empty String
for the name.
When the RabbitAdmin
declares queues, it updates the Queue.actualName
property with the name returned by the broker.
You must use setQueues()
when you configure the container for this to work, so that the container can access the declared name at runtime.
Just setting the names is insufficient.
You cannot add broker-named queues to the containers while they are running. |
When a connection is reset and a new one is established, the new queue gets a new name.
Since there is a race condition between the container restarting and the queue being re-declared, it is important to set the container’s missingQueuesFatal property to false , since the container is likely to initially try to reconnect to the old queue.
4.1.8. Message Converters
The AmqpTemplate
also defines several methods for sending and receiving messages that delegate to a MessageConverter
The MessageConverter
provides a single method for each direction: one for converting to a Message
and another for converting from a Message
Notice that, when converting to a Message
, you can also provide properties in addition to the object.
The object
parameter typically corresponds to the Message body.
The following listing shows the MessageConverter
interface definition:
public interface MessageConverter {
Message toMessage(Object object, MessageProperties messageProperties)
throws MessageConversionException;
Object fromMessage(Message message) throws MessageConversionException;
The relevant Message
-sending methods on the AmqpTemplate
are simpler than the methods we discussed previously, because they do not require the Message
instance.
Instead, the MessageConverter
is responsible for “creating” each Message
by converting the provided object to the byte array for the Message
body and then adding any provided MessageProperties
The following listing shows the definitions of the various methods:
void convertAndSend(Object message) throws AmqpException;
void convertAndSend(String routingKey, Object message) throws AmqpException;
void convertAndSend(String exchange, String routingKey, Object message)
void convertAndSend(Object message, MessagePostProcessor messagePostProcessor)
void convertAndSend(String routingKey, Object message,
MessagePostProcessor messagePostProcessor) throws AmqpException;
void convertAndSend(String exchange, String routingKey, Object message,
On the receiving side, there are only two methods: one that accepts the queue name and one that relies on the template’s “queue” property having been set. The following listing shows the definitions of the two methods:
Object receiveAndConvert() throws AmqpException;
Object receiveAndConvert(String queueName) throws AmqpException;
The MessageListenerAdapter mentioned in Asynchronous Consumer also uses a MessageConverter .
The default implementation of the MessageConverter
strategy is called SimpleMessageConverter
This is the converter that is used by an instance of RabbitTemplate
if you do not explicitly configure an alternative.
It handles text-based content, serialized Java objects, and byte arrays.
Converting From a Message
If the content type of the input Message
begins with "text" (for example,
"text/plain"), it also checks for the content-encoding property to determine the charset to be used when converting the Message
body byte array to a Java String
If no content-encoding property had been set on the input Message
, it uses the UTF-8 charset by default.
If you need to override that default setting, you can configure an instance of SimpleMessageConverter
, set its defaultCharset
property, and inject that into a RabbitTemplate
instance.
If the content-type property value of the input Message
is set to "application/x-java-serialized-object", the SimpleMessageConverter
tries to deserialize (rehydrate) the byte array into a Java object.
While that might be useful for simple prototyping, we do not recommend relying on Java serialization, since it leads to tight coupling between the producer and the consumer.
Of course, it also rules out usage of non-Java systems on either side.
With AMQP being a wire-level protocol, it would be unfortunate to lose much of that advantage with such restrictions.
In the next two sections, we explore some alternatives for passing rich domain object content without relying on Java serialization.
For all other content-types, the SimpleMessageConverter
returns the Message
body content directly as a byte array.
See Java Deserialization for important information.
Converting To a Message
When converting to a Message
from an arbitrary Java Object, the SimpleMessageConverter
likewise deals with byte arrays, strings, and serializable instances.
It converts each of these to bytes (in the case of byte arrays, there is nothing to convert), and it sets the content-type property accordingly.
If the Object
to be converted does not match one of those types, the Message
body is null.
SerializerMessageConverter
This converter is similar to the SimpleMessageConverter
except that it can be configured with other Spring Framework
Serializer
and Deserializer
implementations for application/x-java-serialized-object
conversions.
This section covers using the Jackson2JsonMessageConverter
to convert to and from a Message
It has the following sections:
Converting to a Message
As mentioned in the previous section, relying on Java serialization is generally not recommended.
One rather common alternative that is more flexible and portable across different languages and platforms is JSON
(JavaScript Object Notation).
The converter can be configured on any RabbitTemplate
instance to override its usage of the SimpleMessageConverter
default.
The Jackson2JsonMessageConverter
uses the com.fasterxml.jackson
2.x library.
The following example configures a Jackson2JsonMessageConverter
<bean class="org.springframework.amqp.rabbit.core.RabbitTemplate">
<property name="connectionFactory" ref="rabbitConnectionFactory"/>
<property name="messageConverter">
<bean class="org.springframework.amqp.support.converter.Jackson2JsonMessageConverter">
<!-- if necessary, override the DefaultClassMapper -->
<property name="classMapper" ref="customClassMapper"/>
</bean>
</property>
</bean>
As shown above, Jackson2JsonMessageConverter
uses a DefaultClassMapper
by default.
Type information is added to (and retrieved from) MessageProperties
If an inbound message does not contain type information in MessageProperties
, but you know the expected type, you
can configure a static type by using the defaultType
property, as the following example shows:
<bean id="jsonConverterWithDefaultType"
class="o.s.amqp.support.converter.Jackson2JsonMessageConverter">
<property name="classMapper">
<bean class="org.springframework.amqp.support.converter.DefaultClassMapper">
<property name="defaultType" value="thing1.PurchaseOrder"/>
</bean>
</property>
</bean>
In addition, you can provide custom mappings from the value in the TypeId
header.
public Jackson2JsonMessageConverter jsonMessageConverter() {
Jackson2JsonMessageConverter jsonConverter = new Jackson2JsonMessageConverter();
jsonConverter.setClassMapper(classMapper());
return jsonConverter;
public DefaultClassMapper classMapper() {
DefaultClassMapper classMapper = new DefaultClassMapper();
Map<String, Class<?>> idClassMapping = new HashMap<>();
idClassMapping.put("thing1", Thing1.class);
idClassMapping.put("thing2", Thing2.class);
classMapper.setIdClassMapping(idClassMapping);
return classMapper;
Now, if the sending system sets the header to thing1
, the converter creates a Thing1
object, and so on.
See the Receiving JSON from Non-Spring Applications sample application for a complete discussion about converting messages from non-Spring applications.
Starting with version 2.4.3, the converter will not add a contentEncoding
message property if the supportedMediaType
has a charset
parameter; this is also used for the encoding.
A new method setSupportedMediaType
has been added:
String utf16 = "application/json; charset=utf-16";
converter.setSupportedContentType(MimeTypeUtils.parseMimeType(utf16));
Converting from a Message
Inbound messages are converted to objects according to the type information added to headers by the sending system.
Starting with version 2.4.3, if there is no contentEncoding
message property, the converter will attempt to detect a charset
parameter in the contentType
message property and use that.
If neither exist, if the supportedMediaType
has a charset
parameter, it will be used for decoding, with a final fallback to the defaultCharset
property.
has been added:
In versions prior to 1.6, if type information is not present, conversion would fail. Starting with version 1.6, if type information is missing, the converter converts the JSON by using Jackson defaults (usually a map).
Also, starting with version 1.6, when you use @RabbitListener
annotations (on methods), the inferred type information is added to the MessageProperties
This lets the converter convert to the argument type of the target method.
This only applies if there is one parameter with no annotations or a single parameter with the @Payload
annotation.
Parameters of type Message
are ignored during the analysis.
By default, the inferred type information will override the inbound TypeId and related headers created
This lets the receiving system automatically convert to a different domain object.
This applies only if the parameter type is concrete (not abstract or an interface) or it is from the java.util
package.
In all other cases, the TypeId and related headers is used.
There are cases where you might wish to override the default behavior and always use the TypeId information.
For example, suppose you have a @RabbitListener that takes a Thing1 argument but the message contains a Thing2 that
is a subclass of Thing1 (which is concrete).
The inferred type would be incorrect.
To handle this situation, set the TypePrecedence property on the Jackson2JsonMessageConverter to TYPE_ID instead
of the default INFERRED .
(The property is actually on the converter’s DefaultJackson2JavaTypeMapper , but a setter is provided on the converter
for convenience.)
If you inject a custom type mapper, you should set the property on the mapper instead.
When converting from the Message , an incoming MessageProperties.getContentType() must be JSON-compliant (contentType.contains("json") is used to check).
Starting with version 2.2, application/json is assumed if there is no contentType property, or it has the default value application/octet-stream .
To revert to the previous behavior (return an unconverted byte[] ), set the converter’s assumeSupportedContentType property to false .
If the content type is not supported, a WARN log message Could not convert incoming message with content-type […] , is emitted and message.getBody() is returned as is — as a byte[] .
So, to meet the Jackson2JsonMessageConverter requirements on the consumer side, the producer must add the contentType message property — for example, as application/json or text/x-json or by using the Jackson2JsonMessageConverter , which sets the header automatically.
The following listing shows a number of converter calls:
@RabbitListener
public void thing1(Thing1 thing1) {...}
@RabbitListener
public void thing1(@Payload Thing1 thing1, @Header("amqp_consumerQueue") String queue) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.amqp.core.Message message) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.messaging.Message<Foo> message) {...}
@RabbitListener
public void thing1(Thing1 thing1, String bar) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.messaging.Message<?> message) {...}
In the first four cases in the preceding listing, the converter tries to convert to the Thing1
type.
The fifth example is invalid because we cannot determine which argument should receive the message payload.
With the sixth example, the Jackson defaults apply due to the generic type being a WildcardType
You can, however, create a custom converter and use the targetMethod
message property to decide which type to convert
the JSON to.
This type inference can only be achieved when the @RabbitListener annotation is declared at the method level.
With class-level @RabbitListener , the converted type is used to select which @RabbitHandler method to invoke.
For this reason, the infrastructure provides the targetObject message property, which you can use in a custom
converter to determine the type.
Starting with version 1.6.11, Jackson2JsonMessageConverter and, therefore, DefaultJackson2JavaTypeMapper (DefaultClassMapper ) provide the trustedPackages option to overcome Serialization Gadgets vulnerability.
By default and for backward compatibility, the Jackson2JsonMessageConverter trusts all packages — that is, it uses * for the option.
Starting with version 2.4.7, the converter can be configured to return Optional.empty()
if Jackson returns null
after deserializing the message body.
This facilitates @RabbitListener
s to receive null payloads, in two ways:
@RabbitListener(queues = "op.1")
void listen(@Payload(required = false) Thing payload) {
handleOptional(payload); // payload might be null
@RabbitListener(queues = "op.2")
void listen(Optional<Thing> optional) {
handleOptional(optional.orElse(this.emptyThing));
To enable this feature, set setNullAsOptionalEmpty
to true
; when false
(default), the converter falls back to the raw message body (byte[]
Jackson2JsonMessageConverter converter() {
Jackson2JsonMessageConverter converter = new Jackson2JsonMessageConverter();
converter.setNullAsOptionalEmpty(true);
return converter;
Deserializing Abstract Classes
Prior to version 2.2.8, if the inferred type of a @RabbitListener
was an abstract class (including interfaces), the converter would fall back to looking for type information in the headers and, if present, used that information; if that was not present, it would try to create the abstract class.
This caused a problem when a custom ObjectMapper
that is configured with a custom deserializer to handle the abstract class is used, but the incoming message has invalid type headers.
Starting with version 2.2.8, the previous behavior is retained by default. If you have such a custom ObjectMapper
and you want to ignore type headers, and always use the inferred type for conversion, set the alwaysConvertToInferredType
to true
This is needed for backwards compatibility and to avoid the overhead of an attempted conversion when it would fail (with a standard ObjectMapper
Using Spring Data Projection Interfaces
Starting with version 2.2, you can convert JSON to a Spring Data Projection interface instead of a concrete type. This allows very selective, and low-coupled bindings to data, including the lookup of values from multiple places inside the JSON document. For example the following interface can be defined as message payload type:
interface SomeSample {
@JsonPath({ "$.username", "$.user.name" })
String getUsername();
@RabbitListener(queues = "projection")
public void projection(SomeSample in) {
String username = in.getUsername();
Accessor methods will be used to lookup the property name as field in the received JSON document by default.
The @JsonPath
expression allows customization of the value lookup, and even to define multiple JSON path expressions, to lookup values from multiple places until an expression returns an actual value.
To enable this feature, set the useProjectionForInterfaces
to true
on the message converter.
You must also add spring-data:spring-data-commons
and com.jayway.jsonpath:json-path
to the class path.
When used as the parameter to a @RabbitListener
method, the interface type is automatically passed to the converter as normal.
With RabbitTemplate
As mentioned earlier, type information is conveyed in message headers to assist the converter when converting from a message.
This works fine in most cases.
However, when using generic types, it can only convert simple objects and known “container” objects (lists, arrays, and maps).
Starting with version 2.0, the Jackson2JsonMessageConverter
implements SmartMessageConverter
, which lets it be used with the new RabbitTemplate
methods that take a ParameterizedTypeReference
argument.
This allows conversion of complex generic types, as shown in the following example:
Thing1<Thing2<Cat, Hat>> thing1 =
rabbitTemplate.receiveAndConvert(new ParameterizedTypeReference<Thing1<Thing2<Cat, Hat>>>() { });
Starting with version 2.1, the AbstractJsonMessageConverter class has been removed.
It is no longer the base class for Jackson2JsonMessageConverter .
It has been replaced by AbstractJackson2MessageConverter .
MarshallingMessageConverter
Yet another option is the MarshallingMessageConverter
It delegates to the Spring OXM library’s implementations of the Marshaller
and Unmarshaller
strategy interfaces.
You can read more about that library here.
In terms of configuration, it is most common to provide only the constructor argument, since most implementations of Marshaller
also implement Unmarshaller
The following example shows how to configure a MarshallingMessageConverter
<bean class="org.springframework.amqp.support.converter.MarshallingMessageConverter">
<constructor-arg ref="someImplemenationOfMarshallerAndUnmarshaller"/>
</bean>
</property>
</bean>
Jackson2XmlMessageConverter
This class was introduced in version 2.1 and can be used to convert messages from and to XML.
Both Jackson2XmlMessageConverter
and Jackson2JsonMessageConverter
have the same base class: AbstractJackson2MessageConverter
The AbstractJackson2MessageConverter class is introduced to replace a removed class: AbstractJsonMessageConverter .
The Jackson2XmlMessageConverter
2.x library.
You can use it the same way as Jackson2JsonMessageConverter
, except it supports XML instead of JSON.
<bean id="xmlConverterWithDefaultType"
class="org.springframework.amqp.support.converter.Jackson2XmlMessageConverter">
<property name="defaultType" value="foo.PurchaseOrder"/>
</bean>
</property>
</bean>
Starting with version 2.2, application/xml is assumed if there is no contentType property, or it has the default value application/octet-stream .
This class was introduced in version 1.4.2 and allows delegation to a specific MessageConverter
based on the content type property in the MessageProperties
By default, it delegates to a SimpleMessageConverter
property or there is a value that matches none of the configured converters.
The following example configures a ContentTypeDelegatingMessageConverter
<bean id="contentTypeConverter" class="ContentTypeDelegatingMessageConverter">
<property name="delegates">
<map>
<entry key="application/json" value-ref="jsonMessageConverter" />
<entry key="application/xml" value-ref="xmlMessageConverter" />
</map>
</property>
</bean>
This section covers how to deserialize Java objects.
There is a possible vulnerability when deserializing java objects from untrusted sources. If you accept messages from untrusted sources with a By default, the allowed list is empty, meaning no classes will be deserialized. You can set a list of patterns, such as The patterns are checked in order until a match is found.
If there is no match, a You can set the patterns using the |
Message Properties Converters
The MessagePropertiesConverter
strategy interface is used to convert between the Rabbit Client BasicProperties
and Spring AMQP MessageProperties
The default implementation (DefaultMessagePropertiesConverter
) is usually sufficient for most purposes, but you can implement your own if needed.
The default properties converter converts BasicProperties
elements of type LongString
to String
instances when the size is not greater than 1024
bytes.
Larger LongString
instances are not converted (see the next paragraph).
This limit can be overridden with a constructor argument.
Starting with version 1.6, headers longer than the long string limit (default: 1024) are now left as
LongString
instances by default by the DefaultMessagePropertiesConverter
You can access the contents through the getBytes[]
, toString()
, or getStream()
methods.
Previously, the DefaultMessagePropertiesConverter
“converted” such headers to a DataInputStream
(actually it just referenced the LongString
instance’s DataInputStream
On output, this header was not converted (except to a String — for example, java.io.DataInputStream@1d057a39
by calling toString()
on the stream).
Large incoming LongString
headers are now correctly “converted” on output, too (by default).
A new constructor is provided to let you configure the converter to work as before. The following listing shows the Javadoc comment and declaration of the method:
* Construct an instance where LongStrings will be returned
* unconverted or as a java.io.DataInputStream when longer than this limit.
* Use this constructor with 'true' to restore pre-1.6 behavior.
* @param longStringLimit the limit.
* @param convertLongLongStrings LongString when false,
* DataInputStream when true.
* @since 1.6
public DefaultMessagePropertiesConverter(int longStringLimit, boolean convertLongLongStrings) { ... }
Also starting with version 1.6, a new property called correlationIdString
has been added to MessageProperties
Previously, when converting to and from BasicProperties
used by the RabbitMQ client, an unnecessary byte[] <→ String
conversion was performed because MessageProperties.correlationId
is a byte[]
, but BasicProperties
uses a String
(Ultimately, the RabbitMQ client uses UTF-8 to convert the String
to bytes to put in the protocol message).
To provide maximum backwards compatibility, a new property called correlationIdPolicy
This takes a DefaultMessagePropertiesConverter.CorrelationIdPolicy
enum argument.
By default it is set to BYTES
, which replicates the previous behavior.
For inbound messages:
STRING
: Only thecorrelationIdString
property is mapped -
BYTES
BOTH
: Both properties are mapped
For outbound messages:
STRING
BYTES
BOTH
: Both properties are considered, with theString
property taking precedence
Also starting with version 1.6, the inbound deliveryMode
property is no longer mapped to MessageProperties.deliveryMode
It is mapped to MessageProperties.receivedDeliveryMode
instead.
Also, the inbound userId
property is no longer mapped to MessageProperties.userId
It is mapped to MessageProperties.receivedUserId
instead.
These changes are to avoid unexpected propagation of these properties if the same MessageProperties
object is used for an outbound message.
Starting with version 2.2, the DefaultMessagePropertiesConverter
converts any custom headers with values of type Class<?>
using getName()
instead of toString()
; this avoids consuming application having to parse the class name out of the toString()
representation.
For rolling upgrades, you may need to change your consumers to understand both formats until all producers are upgraded.
4.1.9. Modifying Messages - Compression and More
A number of extension points exist. They let you perform some processing on a message, either before it is sent to RabbitMQ or immediately after it is received.
As can be seen in Message Converters, one such extension point is in the AmqpTemplate
convertAndReceive
operations, where you can provide a MessagePostProcessor
For example, after your POJO has been converted, the MessagePostProcessor
lets you set custom headers or properties on the Message
Starting with version 1.4.2, additional extension points have been added to the RabbitTemplate
- setBeforePublishPostProcessors()
and setAfterReceivePostProcessors()
The first enables a post processor to run immediately before sending to RabbitMQ.
When using batching (see Batching), this is invoked after the batch is assembled and before the batch is sent.
The second is invoked immediately after a message is received.
These extension points are used for such features as compression and, for this purpose, several MessagePostProcessor
implementations are provided.
GZipPostProcessor
, ZipPostProcessor
and DeflaterPostProcessor
compress messages before sending, and GUnzipPostProcessor
, UnzipPostProcessor
and InflaterPostProcessor
decompress received messages.
Starting with version 2.1.5, the GZipPostProcessor can be configured with the copyProperties = true option to make a copy of the original message properties.
By default, these properties are reused for performance reasons, and modified with compression content encoding and the optional MessageProperties.SPRING_AUTO_DECOMPRESS header.
If you retain a reference to the original outbound message, its properties will change as well.
So, if your application retains a copy of an outbound message with these message post processors, consider turning the copyProperties option on.
Starting with version 2.2.12, you can configure the delimiter that the compressing post processors use between content encoding elements.
With versions 2.2.11 and before, this was hard-coded as : , it is now set to , ` by default.
The decompressors will work with both delimiters.
However, if you publish messages with 2.3 or later and consume with 2.2.11 or earlier, you MUST set the `encodingDelimiter property on the compressor(s) to : .
When your consumers are upgraded to 2.2.11 or later, you can revert to the default of `, `.
Similarly, the SimpleMessageListenerContainer
also has a setAfterReceivePostProcessors()
method, letting the decompression be performed after messages are received by the container.
Starting with version 2.1.4, addBeforePublishPostProcessors()
and addAfterReceivePostProcessors()
to allow appending new post processors to the list of before publish and after receive post processors respectively.
Also there are methods provided to remove the post processors.
Similarly, AbstractMessageListenerContainer
also has addAfterReceivePostProcessors()
and removeAfterReceivePostProcessor()
methods added.
See the Javadoc of RabbitTemplate
and AbstractMessageListenerContainer
for more detail.
4.1.10. Request/Reply Messaging
The AmqpTemplate
also provides a variety of sendAndReceive
methods that accept the same argument options that were described earlier for the one-way send operations (exchange
, routingKey
, and Message
Those methods are quite useful for request-reply scenarios, since they handle the configuration of the necessary reply-to
property before sending and can listen for the reply message on an exclusive queue that is created internally for that purpose.
Similar request-reply methods are also available where the MessageConverter
is applied to both the request and reply.
Those methods are named convertSendAndReceive
See the Javadoc of AmqpTemplate
for more detail.
Starting with version 1.5.0, each of the sendAndReceive
method variants has an overloaded version that takes CorrelationData
Together with a properly configured connection factory, this enables the receipt of publisher confirms for the send side of the operation.
See Correlated Publisher Confirms and Returns and the Javadoc for RabbitOperations
Starting with version 2.0, there are variants of these methods (convertSendAndReceiveAsType
) that take an additional ParameterizedTypeReference
argument to convert complex returned types.
The template must be configured with a SmartMessageConverter
See Converting From a Message
With RabbitTemplate
Starting with version 2.1, you can configure the RabbitTemplate
with the noLocalReplyConsumer
option to control a noLocal
flag for reply consumers.
This is false
by default.
Reply Timeout
By default, the send and receive methods timeout after five seconds and return null.
You can modify this behavior by setting the replyTimeout
property.
Starting with version 1.5, if you set the mandatory
property to true
(or the mandatory-expression
evaluates to true
for a particular message), if the message cannot be delivered to a queue, an AmqpMessageReturnedException
is thrown.
This exception has returnedMessage
, replyCode
, and replyText
properties, as well as the exchange
and routingKey
used for the send.
This feature uses publisher returns.
You can enable it by setting publisherReturns to true on the CachingConnectionFactory (see Publisher Confirms and Returns).
Also, you must not have registered your own ReturnCallback with the RabbitTemplate .
Starting with version 2.1.2, a replyTimedOut
method has been added, letting subclasses be informed of the timeout so that they can clean up any retained state.
Starting with versions 2.0.11 and 2.1.3, when you use the default DirectReplyToMessageListenerContainer
, you can add an error handler by setting the template’s replyErrorHandler
property.
This error handler is invoked for any failed deliveries, such as late replies and messages received without a correlation header.
The exception passed in is a ListenerExecutionFailedException
, which has a failedMessage
property.
RabbitMQ Direct reply-to
Starting with version 3.4.0, the RabbitMQ server supports direct reply-to.
This eliminates the main reason for a fixed reply queue (to avoid the need to create a temporary queue for each request).
Starting with Spring AMQP version 1.4.1 direct reply-to is used by default (if supported by the server) instead of creating temporary reply queues.
When no replyQueue is provided (or it is set with a name of amq.rabbitmq.reply-to ), the RabbitTemplate automatically detects whether direct reply-to is supported and either uses it or falls back to using a temporary reply queue.
When using direct reply-to, a reply-listener is not required and should not be configured.
Reply listeners are still supported with named queues (other than amq.rabbitmq.reply-to
), allowing control of reply concurrency and so on.
Starting with version 1.6, if you wish to use a temporary, exclusive, auto-delete queue for each
reply, set the useTemporaryReplyQueues
property to true
This property is ignored if you set a replyAddress
You can change the criteria that dictate whether to use direct reply-to by subclassing RabbitTemplate
and overriding useDirectReplyTo()
to check different criteria.
The method is called once only, when the first request is sent.
Prior to version 2.0, the RabbitTemplate
created a new consumer for each request and canceled the consumer when the reply was received (or timed out).
Now the template uses a DirectReplyToMessageListenerContainer
instead, letting the consumers be reused.
The template still takes care of correlating the replies, so there is no danger of a late reply going to a different sender.
If you want to revert to the previous behavior, set the useDirectReplyToContainer
(direct-reply-to-container
when using XML configuration) property to false.
The AsyncRabbitTemplate
has no such option.
It always used a DirectReplyToContainer
for replies when direct reply-to is used.
Starting with version 2.3.7, the template has a new property useChannelForCorrelation
When this is true
, the server does not have to copy the correlation id from the request message headers to the reply message.
Instead, the channel used to send the request is used to correlate the reply to the request.
Message Correlation With A Reply Queue
When using a fixed reply queue (other than amq.rabbitmq.reply-to
), you must provide correlation data so that replies can be correlated to requests.
See RabbitMQ Remote Procedure Call (RPC).
By default, the standard correlationId
property is used to hold the correlation data.
However, if you wish to use a custom property to hold correlation data, you can set the correlation-key
attribute on the <rabbit-template/>.
Explicitly setting the attribute to correlationId
is the same as omitting the attribute.
The client and server must use the same header for correlation data.
Spring AMQP version 1.1 used a custom property called spring_reply_correlation for this data.
If you wish to revert to this behavior with the current version (perhaps to maintain compatibility with another application using 1.1), you must set the attribute to spring_reply_correlation .
By default, the template generates its own correlation ID (ignoring any user-supplied value).
If you wish to use your own correlation ID, set the RabbitTemplate
instance’s userCorrelationId
property to true
The correlation ID must be unique to avoid the possibility of a wrong reply being returned for a request. |
Reply Listener Container
When using RabbitMQ versions prior to 3.4.0, a new temporary queue is used for each reply.
However, a single reply queue can be configured on the template, which can be more efficient and also lets you set arguments on that queue.
In this case, however, you must also provide a <reply-listener/> sub element.
This element provides a listener container for the reply queue, with the template being the listener.
All of the Message Listener Container Configuration attributes allowed on a <listener-container/> are allowed on the element, except for connection-factory
and message-converter
, which are inherited from the template’s configuration.
If you run multiple instances of your application or use multiple RabbitTemplate instances, you MUST use a unique reply queue for each.
RabbitMQ has no ability to select messages from a queue, so, if they all use the same queue, each instance would compete for replies and not necessarily receive their own.
The following example defines a rabbit template with a connection factory:
<rabbit:template id="amqpTemplate"
reply-queue="replies"
reply-address="replyEx/routeReply">
<rabbit:reply-listener/>
</rabbit:template>
While the container and template share a connection factory, they do not share a channel. Therefore, requests and replies are not performed within the same transaction (if transactional).
Prior to version 1.5.0, the reply-address attribute was not available.
Replies were always routed by using the default exchange and the reply-queue name as the routing key.
This is still the default, but you can now specify the new reply-address attribute.
The reply-address can contain an address with the form <exchange>/<routingKey> and the reply is routed to the specified exchange and routed to a queue bound with the routing key.
The reply-address has precedence over reply-queue .
When only reply-address is in use, the <reply-listener> must be configured as a separate <listener-container> component.
The reply-address and reply-queue (or queues attribute on the <listener-container> ) must refer to the same queue logically.
With this configuration, a SimpleListenerContainer
is used to receive the replies, with the RabbitTemplate
being the MessageListener
When defining a template with the <rabbit:template/>
namespace element, as shown in the preceding example, the parser defines the container and wires in the template as the listener.
When the template does not use a fixed replyQueue (or is using direct reply-to — see RabbitMQ Direct reply-to), a listener container is not needed.
Direct reply-to is the preferred mechanism when using RabbitMQ 3.4.0 or later.
If you define your RabbitTemplate
as a <bean/>
or use an @Configuration
class to define it as an @Bean
or when you create the template programmatically, you need to define and wire up the reply listener container yourself.
If you fail to do this, the template never receives the replies and eventually times out and returns null as the reply to a call to a sendAndReceive
method.
Starting with version 1.5, the RabbitTemplate
detects if it has been
configured as a MessageListener
to receive replies.
If not, attempts to send and receive messages with a reply address
fail with an IllegalStateException
(because the replies are never received).
Further, if a simple replyAddress
(queue name) is used, the reply listener container verifies that it is listening
to a queue with the same name.
This check cannot be performed if the reply address is an exchange and routing key and a debug log message is written.
When wiring the reply listener and template yourself, it is important to ensure that the template’s replyAddress and the container’s queues (or queueNames ) properties refer to the same queue.
The template inserts the reply address into the outbound message replyTo property.
The following listing shows examples of how to manually wire up the beans:
<bean id="amqpTemplate" class="org.springframework.amqp.rabbit.core.RabbitTemplate">
<constructor-arg ref="connectionFactory" />
<property name="exchange" value="foo.exchange" />
<property name="routingKey" value="foo" />
<property name="replyQueue" ref="replyQ" />
<property name="replyTimeout" value="600000" />
<property name="useDirectReplyToContainer" value="false" />
</bean>
<bean class="org.springframework.amqp.rabbit.listener.SimpleMessageListenerContainer">
<property name="queues" ref="replyQ" />
<property name="messageListener" ref="amqpTemplate" />
</bean>
<rabbit:queue id="replyQ" name="my.reply.queue" />
public RabbitTemplate amqpTemplate() {
RabbitTemplate rabbitTemplate = new RabbitTemplate(connectionFactory());
rabbitTemplate.setMessageConverter(msgConv());
rabbitTemplate.setReplyAddress(replyQueue().getName());
rabbitTemplate.setReplyTimeout(60000);
rabbitTemplate.setUseDirectReplyToContainer(false);
return rabbitTemplate;
public SimpleMessageListenerContainer replyListenerContainer() {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer();
container.setConnectionFactory(connectionFactory());
container.setQueues(replyQueue());
container.setMessageListener(amqpTemplate());
return container;
public Queue replyQueue() {
return new Queue("my.reply.queue");
A complete example of a RabbitTemplate
wired with a fixed reply queue, together with a “remote” listener container that handles the request and returns the reply is shown in this test case.
When the reply times out (replyTimeout ), the sendAndReceive() methods return null.
Prior to version 1.3.6, late replies for timed out messages were only logged.
Now, if a late reply is received, it is rejected (the template throws an AmqpRejectAndDontRequeueException
If the reply queue is configured to send rejected messages to a dead letter exchange, the reply can be retrieved for later analysis.
To do so, bind a queue to the configured dead letter exchange with a routing key equal to the reply queue’s name.
See the RabbitMQ Dead Letter Documentation for more information about configuring dead lettering.
You can also take a look at the FixedReplyQueueDeadLetterTests
test case for an example.
Async Rabbit Template
Version 1.6 introduced the AsyncRabbitTemplate
This has similar sendAndReceive
(and convertSendAndReceive
) methods to those on the AmqpTemplate
However, instead of blocking, they return a ListenableFuture
The sendAndReceive
methods return a RabbitMessageFuture
The convertSendAndReceive
methods return a RabbitConverterFuture
You can either synchronously retrieve the result later, by invoking get()
on the future, or you can register a callback that is called asynchronously with the result.
The following listing shows both approaches:
@Autowired
private AsyncRabbitTemplate template;
public void doSomeWorkAndGetResultLater() {
ListenableFuture<String> future = this.template.convertSendAndReceive("foo");
// do some more work
String reply = null;
try {
reply = future.get();
catch (ExecutionException e) {
public void doSomeWorkAndGetResultAsync() {
RabbitConverterFuture<String> future = this.template.convertSendAndReceive("foo");
future.addCallback(new ListenableFutureCallback<String>() {
public void onSuccess(String result) {
public void onFailure(Throwable ex) {
If mandatory
is set and the message cannot be delivered, the future throws an ExecutionException
with a cause of AmqpMessageReturnedException
, which encapsulates the returned message and information about the return.
If enableConfirms
is set, the future has a property called confirm
, which is itself a ListenableFuture<Boolean>
with true
indicating a successful publish.
If the confirm future is false
, the RabbitFuture
has a further property called nackCause
, which contains the reason for the failure, if available.
The publisher confirm is discarded if it is received after the reply, since the reply implies a successful publish. |
You can set the receiveTimeout
property on the template to time out replies (it defaults to 30000
- 30 seconds).
If a timeout occurs, the future is completed with an AmqpReplyTimeoutException
The template implements SmartLifecycle
Stopping the template while there are pending replies causes the pending Future
instances to be canceled.
Starting with version 2.0, the asynchronous template now supports direct reply-to instead of a configured reply queue. To enable this feature, use one of the following constructors:
public AsyncRabbitTemplate(ConnectionFactory connectionFactory, String exchange, String routingKey)
public AsyncRabbitTemplate(RabbitTemplate template)
See RabbitMQ Direct reply-to to use direct reply-to with the synchronous RabbitTemplate
Version 2.0 introduced variants of these methods (convertSendAndReceiveAsType
You must configure the underlying RabbitTemplate
With RabbitTemplate
In version 3.0, AsyncRabbitTemplate method return types will be CompletableFuture instead of ListenableFuture .
Spring Remoting with AMQP
This feature is deprecated and will be removed in 3.0.
It has been superseded for a long time by Handling Exceptions with the returnExceptions being set to true, and configuring a RemoteInvocationAwareMessageConverterAdapter on the sending side.
See Handling Exceptions for more information.
The Spring Framework has a general remoting capability, allowing Remote Procedure Calls (RPC) that use various transports.
Spring-AMQP supports a similar mechanism with a AmqpProxyFactoryBean
on the client and a AmqpInvokerServiceExporter
on the server.
This provides RPC over AMQP.
On the client side, a RabbitTemplate
is used as described earlier.
On the server side, the invoker (configured as a MessageListener
) receives the message, invokes the configured service, and returns the reply by using the inbound message’s replyTo
information.
You can inject the client factory bean into any bean (by using its serviceInterface
The client can then invoke methods on the proxy, resulting in remote execution over AMQP.
With the default MessageConverter instances, the method parameters and returned value must be instances of Serializable .
On the server side, the AmqpInvokerServiceExporter
has both AmqpTemplate
and MessageConverter
properties.
Currently, the template’s MessageConverter
is not used.
If you need to supply a custom message converter, you should provide it by setting the messageConverter
property.
On the client side, you can add a custom message converter to the AmqpTemplate
, which is provided to the AmqpProxyFactoryBean
by using its amqpTemplate
property.
The following listing shows sample client and server configurations:
<bean id="client"
class="org.springframework.amqp.remoting.client.AmqpProxyFactoryBean">
<property name="amqpTemplate" ref="template" />
<property name="serviceInterface" value="foo.ServiceInterface" />
</bean>
<rabbit:connection-factory id="connectionFactory" />
<rabbit:template id="template" connection-factory="connectionFactory" reply-timeout="2000"
routing-key="remoting.binding" exchange="remoting.exchange" />
<rabbit:admin connection-factory="connectionFactory" />
<rabbit:queue name="remoting.queue" />
<rabbit:direct-exchange name="remoting.exchange">
<rabbit:bindings>
<rabbit:binding queue="remoting.queue" key="remoting.binding" />
</rabbit:bindings>
</rabbit:direct-exchange>
<bean id="listener"
class="org.springframework.amqp.remoting.service.AmqpInvokerServiceExporter">
<property name="service" ref="service" />
</bean>
<bean id="service" class="foo.ServiceImpl" />
<rabbit:template id="template" connection-factory="connectionFactory" />
<rabbit:listener-container connection-factory="connectionFactory">
<rabbit:listener ref="listener" queue-names="remoting.queue" />
</rabbit:listener-container>
The AmqpInvokerServiceExporter can process only properly formed messages, such as those sent from the AmqpProxyFactoryBean .
If it receives a message that it cannot interpret, a serialized RuntimeException is sent as a reply.
If the message has no replyToAddress property, the message is rejected and permanently lost if no dead letter exchange has been configured.
By default, if the request message cannot be delivered, the calling thread eventually times out and a RemoteProxyFailureException is thrown.
By default, the timeout is five seconds.
You can modify that duration by setting the replyTimeout property on the RabbitTemplate .
Starting with version 1.5, by setting the mandatory property to true and enabling returns on the connection factory (see Publisher Confirms and Returns), the calling thread throws an AmqpMessageReturnedException .
See Reply Timeout for more information.
4.1.11. Configuring the Broker
The AMQP specification describes how the protocol can be used to configure queues, exchanges, and bindings on the broker.
These operations (which are portable from the 0.8 specification and higher) are present in the AmqpAdmin
interface in the org.springframework.amqp.core
package.
The RabbitMQ implementation of that class is RabbitAdmin
located in the org.springframework.amqp.rabbit.core
package.
The AmqpAdmin
interface is based on using the Spring AMQP domain abstractions and is shown in the following listing:
public interface AmqpAdmin {
// Exchange Operations
void declareExchange(Exchange exchange);
void deleteExchange(String exchangeName);
// Queue Operations
Queue declareQueue();
String declareQueue(Queue queue);
void deleteQueue(String queueName);
void deleteQueue(String queueName, boolean unused, boolean empty);
void purgeQueue(String queueName, boolean noWait);
// Binding Operations
void declareBinding(Binding binding);
void removeBinding(Binding binding);
Properties getQueueProperties(String queueName);
See also Scoped Operations.
The getQueueProperties()
method returns some limited information about the queue (message count and consumer count).
The keys for the properties returned are available as constants in the RabbitTemplate
(QUEUE_NAME
QUEUE_MESSAGE_COUNT
, and QUEUE_CONSUMER_COUNT
The RabbitMQ REST API provides much more information in the QueueInfo
object.
The no-arg declareQueue()
method defines a queue on the broker with a name that is automatically generated.
The additional properties of this auto-generated queue are exclusive=true
, autoDelete=true
, and durable=false
The declareQueue(Queue queue)
method takes a Queue
object and returns the name of the declared queue.
If the name
property of the provided Queue
is an empty String
, the broker declares the queue with a generated name.
That name is returned to the caller.
That name is also added to the actualName
property of the Queue
You can use this functionality programmatically only by invoking the RabbitAdmin
directly.
When using auto-declaration by the admin when defining a queue declaratively in the application context, you can set the name property to ""
(the empty string).
The broker then creates the name.
Starting with version 2.1, listener containers can use queues of this type.
See Containers and Broker-Named queues for more information.
This is in contrast to an AnonymousQueue
where the framework generates a unique (UUID
) name and sets durable
to
false
and exclusive
, autoDelete
to true
A <rabbit:queue/>
with an empty (or missing) name
attribute always creates an AnonymousQueue
See AnonymousQueue
to understand why AnonymousQueue
is preferred over broker-generated queue names as well as
how to control the format of the name.
Starting with version 2.1, anonymous queues are declared with argument Queue.X_QUEUE_LEADER_LOCATOR
set to client-local
by default.
This ensures that the queue is declared on the node to which the application is connected.
Declarative queues must have fixed names because they might be referenced elsewhere in the context — such as in the
listener shown in the following example:
<rabbit:listener-container>
<rabbit:listener ref="listener" queue-names="#{someQueue.name}" />
The RabbitMQ implementation of this interface is RabbitAdmin
, which, when configured by using Spring XML, resembles the following example:
<rabbit:connection-factory id="connectionFactory"/>
<rabbit:admin id="amqpAdmin" connection-factory="connectionFactory"/>
When the CachingConnectionFactory
cache mode is CHANNEL
(the default), the RabbitAdmin
implementation does automatic lazy declaration of queues, exchanges, and bindings declared in the same ApplicationContext
These components are declared as soon as a Connection
is opened to the broker.
There are some namespace features that make this very convenient — for example,
in the Stocks sample application, we have the following:
<rabbit:queue id="tradeQueue"/>
<rabbit:queue id="marketDataQueue"/>
<fanout-exchange name="broadcast.responses"
xmlns="http://www.springframework.org/schema/rabbit">
<bindings>
<binding queue="tradeQueue"/>
</bindings>
</fanout-exchange>
<topic-exchange name="app.stock.marketdata"
<bindings>
<binding queue="marketDataQueue" pattern="${stocks.quote.pattern}"/>
</bindings>
</topic-exchange>
In the preceding example, we use anonymous queues (actually, internally, just queues with names generated by the framework, not by the broker) and refer to them by ID. We can also declare queues with explicit names, which also serve as identifiers for their bean definitions in the context. The following example configures a queue with an explicit name:
<rabbit:queue name="stocks.trade.queue"/>
You can provide both id and name attributes.
This lets you refer to the queue (for example, in a binding) by an ID that is independent of the queue name.
It also allows standard Spring features (such as property placeholders and SpEL expressions for the queue name).
These features are not available when you use the name as the bean identifier.
Queues can be configured with additional arguments — for example, x-message-ttl
When you use the namespace support, they are provided in the form of a Map
of argument-name/argument-value pairs, which are defined by using the <rabbit:queue-arguments>
element.
The following example shows how to do so:
<rabbit:queue name="withArguments">
<entry key="x-dead-letter-exchange" value="myDLX"/>
<entry key="x-dead-letter-routing-key" value="dlqRK"/>
</rabbit:queue-arguments>
</rabbit:queue>
By default, the arguments are assumed to be strings. For arguments of other types, you must provide the type. The following example shows how to specify the type:
<rabbit:queue-arguments value-type="java.lang.Long">
<entry key="x-message-ttl" value="100"/>
</rabbit:queue>
When providing arguments of mixed types, you must provide the type for each entry element. The following example shows how to do so:
<entry key="x-message-ttl">
<value type="java.lang.Long">100</value>
</entry>
</rabbit:queue>
With Spring Framework 3.2 and later, this can be declared a little more succinctly, as follows:
<entry key="x-message-ttl" value="100" value-type="java.lang.Long"/>
<entry key="x-ha-policy" value="all"/>
</rabbit:queue>
When you use Java configuration, the Queue.X_QUEUE_LEADER_LOCATOR
argument is supported as a first class property through the setLeaderLocator()
method on the Queue
class.
Starting with version 2.1, anonymous queues are declared with this property set to client-local
by default.
This ensures that the queue is declared on the node the application is connected to.
The RabbitMQ broker does not allow declaration of a queue with mismatched arguments.
For example, if a queue already exists with no time to live argument, and you attempt to declare it with (for example) key="x-message-ttl" value="100" , an exception is thrown.
By default, the RabbitAdmin
immediately stops processing all declarations when any exception occurs.
This could cause downstream issues, such as a listener container failing to initialize because another queue (defined after the one in error) is not declared.
This behavior can be modified by setting the ignore-declaration-exceptions
attribute to true
on the RabbitAdmin
instance.
This option instructs the RabbitAdmin
to log the exception and continue declaring other elements.
When configuring the RabbitAdmin
using Java, this property is called ignoreDeclarationExceptions
This is a global setting that applies to all elements.
Queues, exchanges, and bindings have a similar property that applies to just those elements.
Prior to version 1.6, this property took effect only if an IOException
occurred on the channel, such as when there is a mismatch between current and desired properties.
Now, this property takes effect on any exception, including TimeoutException
and others.
In addition, any declaration exceptions result in the publishing of a DeclarationExceptionEvent
, which is an ApplicationEvent
that can be consumed by any ApplicationListener
in the context.
The event contains a reference to the admin, the element that was being declared, and the Throwable
Headers Exchange
Starting with version 1.3, you can configure the HeadersExchange
to match on multiple headers.
You can also specify whether any or all headers must match.
<rabbit:headers-exchange name="headers-test">
<rabbit:bindings>
<rabbit:binding queue="bucket">
<rabbit:binding-arguments>
<entry key="foo" value="bar"/>
<entry key="baz" value="qux"/>
<entry key="x-match" value="all"/>
</rabbit:binding-arguments>
</rabbit:binding>
</rabbit:bindings>
</rabbit:headers-exchange>
Starting with version 1.6, you can configure Exchanges
with an internal
flag (defaults to false
) and such an
Exchange
is properly configured on the Broker through a RabbitAdmin
(if one is present in the application context).
If the internal
flag is true
for an exchange, RabbitMQ does not let clients use the exchange.
This is useful for a dead letter exchange or exchange-to-exchange binding, where you do not wish the exchange to be used
directly by publishers.
To see how to use Java to configure the AMQP infrastructure, look at the Stock sample application,
where there is the @Configuration
class AbstractStockRabbitConfiguration
, which ,in turn has
RabbitClientConfiguration
and RabbitServerConfiguration
subclasses.
The following listing shows the code for AbstractStockRabbitConfiguration
public abstract class AbstractStockAppRabbitConfiguration {
public CachingConnectionFactory connectionFactory() {
CachingConnectionFactory connectionFactory =
new CachingConnectionFactory("localhost");
connectionFactory.setUsername("guest");
connectionFactory.setPassword("guest");
return connectionFactory;
public RabbitTemplate rabbitTemplate() {
RabbitTemplate template = new RabbitTemplate(connectionFactory());
template.setMessageConverter(jsonMessageConverter());
configureRabbitTemplate(template);
return template;
return new Jackson2JsonMessageConverter();
public TopicExchange marketDataExchange() {
return new TopicExchange("app.stock.marketdata");
// additional code omitted for brevity
In the Stock application, the server is configured by using the following @Configuration
class:
public class RabbitServerConfiguration extends AbstractStockAppRabbitConfiguration {
public Queue stockRequestQueue() {
return new Queue("app.stock.request");
This is the end of the whole inheritance chain of @Configuration
classes.
The end result is that TopicExchange
and Queue
are declared to the broker upon application startup.
There is no binding of TopicExchange
to a queue in the server configuration, as that is done in the client application.
The stock request queue, however, is automatically bound to the AMQP default exchange.
This behavior is defined by the specification.
The client @Configuration
class is a little more interesting.
Its declaration follows:
public class RabbitClientConfiguration extends AbstractStockAppRabbitConfiguration {
@Value("${stocks.quote.pattern}")
private String marketDataRoutingKey;
public Queue marketDataQueue() {
return amqpAdmin().declareQueue();
* Binds to the market data exchange.
* Interested in any stock quotes
* that match its routing key.
public Binding marketDataBinding() {
return BindingBuilder.bind(
marketDataQueue()).to(marketDataExchange()).with(marketDataRoutingKey);
The client declares another queue through the declareQueue()
method on the AmqpAdmin
It binds that queue to the market data exchange with a routing pattern that is externalized in a properties file.
Builder API for Queues and Exchanges
Version 1.6 introduces a convenient fluent API for configuring Queue
and Exchange
objects when using Java configuration.
The following example shows how to use it:
return QueueBuilder.nonDurable("foo")
.autoDelete()
.exclusive()
.withArgument("foo", "bar")
public Exchange exchange() {
return ExchangeBuilder.directExchange("foo")
.autoDelete()
.internal()
See the Javadoc for org.springframework.amqp.core.QueueBuilder
and org.springframework.amqp.core.ExchangeBuilder
Starting with version 2.0, the ExchangeBuilder
now creates durable exchanges by default, to be consistent with the simple constructors on the individual AbstractExchange
classes.
To make a non-durable exchange with the builder, use .durable(false)
before invoking .build()
The durable()
method with no parameter is no longer provided.
Version 2.2 introduced fluent APIs to add "well known" exchange and queue arguments…
public Queue allArgs1() {
return QueueBuilder.nonDurable("all.args.1")
.ttl(1000)
.expires(200_000)
.maxLength(42)
.maxLengthBytes(10_000)
.overflow(Overflow.rejectPublish)
.deadLetterExchange("dlx")
.deadLetterRoutingKey("dlrk")
.maxPriority(4)
.lazy()
.leaderLocator(LeaderLocator.minLeaders)
.singleActiveConsumer()
public DirectExchange ex() {
return ExchangeBuilder.directExchange("ex.with.alternate")
.durable(true)
.alternate("alternate")
Declaring Collections of Exchanges, Queues, and Bindings
You can wrap collections of Declarable
objects (Queue
, Exchange
, and Binding
) in Declarables
objects.
The RabbitAdmin
detects such beans (as well as discrete Declarable
beans) in the application context, and declares the contained objects on the broker whenever a connection is established (initially and after a connection failure).
public static class Config {
public CachingConnectionFactory cf() {
return new CachingConnectionFactory("localhost");
public RabbitAdmin admin(ConnectionFactory cf) {
return new RabbitAdmin(cf);
public DirectExchange e1() {
return new DirectExchange("e1", false, true);
public Queue q1() {
return new Queue("q1", false, false, true);
public Binding b1() {
return BindingBuilder.bind(q1()).to(e1()).with("k1");
public Declarables es() {
return new Declarables(
new DirectExchange("e2", false, true),
new DirectExchange("e3", false, true));
public Declarables qs() {
new Queue("q2", false, false, true),
new Queue("q3", false, false, true));
@Scope(ConfigurableBeanFactory.SCOPE_PROTOTYPE)
public Declarables prototypes() {
return new Declarables(new Queue(this.prototypeQueueName, false, false, true));
public Declarables bs() {
new Binding("q2", DestinationType.QUEUE, "e2", "k2", null),
new Binding("q3", DestinationType.QUEUE, "e3", "k3", null));
public Declarables ds() {
new DirectExchange("e4", false, true),
new Queue("q4", false, false, true),
new Binding("q4", DestinationType.QUEUE, "e4", "k4", null));
In versions prior to 2.1, you could declare multiple Declarable instances by defining beans of type Collection<Declarable> .
This can cause undesirable side effects in some cases, because the admin has to iterate over all Collection<?> beans.
Version 2.2 added the getDeclarablesByType
method to Declarables
; this can be used as a convenience, for example, when declaring the listener container bean(s).
public SimpleMessageListenerContainer container(ConnectionFactory connectionFactory,
Declarables mixedDeclarables, MessageListener listener) {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer(connectionFactory);
container.setQueues(mixedDeclarables.getDeclarablesByType(Queue.class).toArray(new Queue[0]));
container.setMessageListener(listener);
return container;
Conditional Declaration
By default, all queues, exchanges, and bindings are declared by all RabbitAdmin
instances (assuming they have auto-startup="true"
) in the application context.
Starting with version 2.1.9, the RabbitAdmin
has a new property explicitDeclarationsOnly
(which is false
by default); when this is set to true
, the admin will only declare beans that are explicitly configured to be declared by that admin.
Starting with the 1.2 release, you can conditionally declare these elements. This is particularly useful when an application connects to multiple brokers and needs to specify with which brokers a particular element should be declared. |
The classes representing these elements implement Declarable
, which has two methods: shouldDeclare()
and getDeclaringAdmins()
The RabbitAdmin
uses these methods to determine whether a particular instance should actually process the declarations on its Connection
The properties are available as attributes in the namespace, as shown in the following examples:
<rabbit:admin id="admin1" connection-factory="CF1" />
<rabbit:admin id="admin2" connection-factory="CF2" />
<rabbit:admin id="admin3" connection-factory="CF3" explicit-declarations-only="true" />
<rabbit:queue id="declaredByAdmin1AndAdmin2Implicitly" />
<rabbit:queue id="declaredByAdmin1AndAdmin2" declared-by="admin1, admin2" />
<rabbit:queue id="declaredByAdmin1Only" declared-by="admin1" />
<rabbit:queue id="notDeclaredByAllExceptAdmin3" auto-declare="false" />
<rabbit:direct-exchange name="direct" declared-by="admin1, admin2">
<rabbit:bindings>
<rabbit:binding key="foo" queue="bar"/>
</rabbit:bindings>
By default, the auto-declare attribute is true and, if the declared-by is not supplied (or is empty), then all RabbitAdmin instances declare the object (as long as the admin’s auto-startup attribute is true , the default, and the admin’s explicit-declarations-only attribute is false).
Similarly, you can use Java-based @Configuration
to achieve the same effect.
In the following example, the components are declared by admin1
but not by`admin2`:
public RabbitAdmin admin1() {
return new RabbitAdmin(cf1());
public RabbitAdmin admin2() {
return new RabbitAdmin(cf2());
public Queue queue() {
Queue queue = new Queue("foo");
queue.setAdminsThatShouldDeclare(admin1());
return queue;
DirectExchange exchange = new DirectExchange("bar");
exchange.setAdminsThatShouldDeclare(admin1());
return exchange;
public Binding binding() {
Binding binding = new Binding("foo", DestinationType.QUEUE, exchange().getName(), "foo", null);
binding.setAdminsThatShouldDeclare(admin1());
return binding;
A Note On the id
and name
Attributes
The name
attribute on <rabbit:queue/>
and <rabbit:exchange/>
elements reflects the name of the entity in the broker.
For queues, if the name
is omitted, an anonymous queue is created (see AnonymousQueue
In versions prior to 2.0, the name
was also registered as a bean name alias (similar to name
on <bean/>
elements).
This caused two problems:
It prevented the declaration of a queue and exchange with the same name.
The alias was not resolved if it contained a SpEL expression (
Starting with version 2.0, if you declare one of these elements with both an id
and a name
attribute, the name is no longer declared as a bean name alias.
If you wish to declare a queue and exchange with the same name
, you must provide an id
There is no change if the element has only a name
attribute.
The bean can still be referenced by the name
— for example, in binding declarations.
However, you still cannot reference it if the name contains SpEL — you must provide an id
for reference purposes.
AnonymousQueue
In general, when you need a uniquely-named, exclusive, auto-delete queue, we recommend that you use the AnonymousQueue
instead of broker-defined queue names (using ""
as a Queue
name causes the broker to generate the queue
name).
This is because:
The queues are actually declared when the connection to the broker is established. This is long after the beans are created and wired together. Beans that use the queue need to know its name. In fact, the broker might not even be running when the application is started.
If the connection to the broker is lost for some reason, the admin re-declares the
AnonymousQueue
with the same name. If we used broker-declared queues, the queue name would change.
You can control the format of the queue name used by AnonymousQueue
instances.
By default, the queue name is prefixed by spring.gen-
followed by a base64 representation of the UUID
— for example: spring.gen-MRBv9sqISkuCiPfOYfpo4g
You can provide an AnonymousQueue.NamingStrategy
implementation in a constructor argument.
public Queue anon1() {
return new AnonymousQueue();
public Queue anon2() {
return new AnonymousQueue(new AnonymousQueue.Base64UrlNamingStrategy("something-"));
public Queue anon3() {
return new AnonymousQueue(AnonymousQueue.UUIDNamingStrategy.DEFAULT);
The first bean generates a queue name prefixed by spring.gen-
— for
The second bean generates a queue name prefixed by something-
The third bean generates a name by using only the UUID (no base64 conversion) — for example, f20c818a-006b-4416-bf91-643590fedb0e
The base64 encoding uses the “URL and Filename Safe Alphabet” from RFC 4648.
Trailing padding characters (=
) are removed.
You can provide your own naming strategy, whereby you can include other information (such as the application name or client host) in the queue name.
You can specify the naming strategy when you use XML configuration.
The naming-strategy
attribute is present on the <rabbit:queue>
element
for a bean reference that implements AnonymousQueue.NamingStrategy
The following examples show how to specify the naming strategy in various ways:
<rabbit:queue id="uuidAnon" />
<rabbit:queue id="springAnon" naming-strategy="uuidNamer" />
<rabbit:queue id="customAnon" naming-strategy="customNamer" />
<bean id="uuidNamer" class="org.springframework.amqp.core.AnonymousQueue.UUIDNamingStrategy" />
<bean id="customNamer" class="org.springframework.amqp.core.AnonymousQueue.Base64UrlNamingStrategy">
<constructor-arg value="custom.gen-" />
</bean>
The first example creates names such as spring.gen-MRBv9sqISkuCiPfOYfpo4g
The second example creates names with a String representation of a UUID.
The third example creates names such as custom.gen-MRBv9sqISkuCiPfOYfpo4g
You can also provide your own naming strategy bean.
set to client-local
by default.
You can revert to the previous behavior by calling queue.setLeaderLocator(null)
after constructing the instance.
Recovering Auto-Delete Declarations
Normally, the RabbitAdmin
(s) only recover queues/exchanges/bindings that are declared as beans in the application context; if any such declarations are auto-delete, they will be removed by the broker if the connection is lost.
When the connection is re-established, the admin will redeclare the entities.
Normally, entities created by calling admin.declareQueue(…)
, admin.declareExchange(…)
and admin.declareBinding(…)
will not be recovered.
Starting with version 2.4, the admin has a new property redeclareManualDeclarations
; when true
, the admin will recover these entities in addition to the beans in the application context.
Recovery of individual declarations will not be performed if deleteQueue(…)
, deleteExchange(…)
or removeBinding(…)
is called.
Associated bindings are removed from the recoverable entities when queues and exchanges are deleted.
Finally, calling resetAllManualDeclarations()
will prevent the recovery of any previously declared entities.
4.1.12. Broker Event Listener
When the Event Exchange Plugin is enabled, if you add a bean of type BrokerEventListener
to the application context, it publishes selected broker events as BrokerEvent
instances, which can be consumed with a normal Spring ApplicationListener
or @EventListener
method.
Events are published by the broker to a topic exchange amq.rabbitmq.event
with a different routing key for each event type.
The listener uses event keys, which are used to bind an AnonymousQueue
to the exchange so the listener receives only selected events.
Since it is a topic exchange, wildcards can be used (as well as explicitly requesting specific events), as the following example shows:
public BrokerEventListener eventListener() {
return new BrokerEventListener(connectionFactory(), "user.deleted", "channel.#", "queue.#");
You can further narrow the received events in individual event listeners, by using normal Spring techniques, as the following example shows:
@EventListener(condition = "event.eventType == 'queue.created'")
public void listener(BrokerEvent event) {
4.1.13. Delayed Message Exchange
Version 1.6 introduces support for the Delayed Message Exchange Plugin
The plugin is currently marked as experimental but has been available for over a year (at the time of writing). If changes to the plugin make it necessary, we plan to add support for such changes as soon as practical. For that reason, this support in Spring AMQP should be considered experimental, too. This functionality was tested with RabbitMQ 3.6.0 and version 0.0.1 of the plugin. |
To use a RabbitAdmin
to declare an exchange as delayed, you can set the delayed
property on the exchange bean to
true
The RabbitAdmin
uses the exchange type (Direct
, Fanout
, and so on) to set the x-delayed-type
argument and
declare the exchange with type x-delayed-message
The delayed
property (default: false
) is also available when configuring exchange beans using XML.
<rabbit:topic-exchange name="topic" delayed="true" />
To send a delayed message, you can set the x-delay
header through MessageProperties
, as the following examples show:
MessageProperties properties = new MessageProperties();
properties.setDelay(15000);
template.send(exchange, routingKey,
MessageBuilder.withBody("foo".getBytes()).andProperties(properties).build());
rabbitTemplate.convertAndSend(exchange, routingKey, "foo", new MessagePostProcessor() {
public Message postProcessMessage(Message message) throws AmqpException {
message.getMessageProperties().setDelay(15000);
return message;
To check if a message was delayed, use the getReceivedDelay()
method on the MessageProperties
It is a separate property to avoid unintended propagation to an output message generated from an input message.
4.1.14. RabbitMQ REST API
When the management plugin is enabled, the RabbitMQ server exposes a REST API to monitor and configure the broker.
A Java Binding for the API is now provided.
The com.rabbitmq.http.client.Client
is a standard, immediate, and, therefore, blocking API.
It is based on the Spring Web module and its RestTemplate
implementation.
On the other hand, the com.rabbitmq.http.client.ReactorNettyClient
is a reactive, non-blocking implementation based on the Reactor Netty project.
The hop dependency (com.rabbitmq:http-client
) is now also optional
See their Javadoc for more information.
4.1.15. Exception Handling
Many operations with the RabbitMQ Java client can throw checked exceptions.
For example, there are a lot of cases where IOException
instances may be thrown.
The RabbitTemplate
, SimpleMessageListenerContainer
, and other Spring AMQP components catch those exceptions and convert them into one of the exceptions within AmqpException
hierarchy.
Those are defined in the 'org.springframework.amqp' package, and AmqpException
is the base of the hierarchy.
When a listener throws an exception, it is wrapped in a ListenerExecutionFailedException
Normally the message is rejected and requeued by the broker.
Setting defaultRequeueRejected
to false
causes messages to be discarded (or routed to a dead letter exchange).
As discussed in Message Listeners and the Asynchronous Case, the listener can throw an AmqpRejectAndDontRequeueException
(or ImmediateRequeueAmqpException
) to conditionally control this behavior.
However, there is a class of errors where the listener cannot control the behavior.
When a message that cannot be converted is encountered (for example, an invalid content_encoding
header), some exceptions are thrown before the message reaches user code.
With defaultRequeueRejected
set to true
(default) (or throwing an ImmediateRequeueAmqpException
), such messages would be redelivered over and over.
Before version 1.3.2, users needed to write a custom ErrorHandler
, as discussed in Exception Handling, to avoid this situation.
Starting with version 1.3.2, the default ErrorHandler
is now a ConditionalRejectingErrorHandler
that rejects (and does not requeue) messages that fail with an irrecoverable error.
Specifically, it rejects messages that fail with the following errors:
o.s.amqp…MessageConversionException
: Can be thrown when converting the incoming message payload using aMessageConverter
o.s.messaging…MessageConversionException
: Can be thrown by the conversion service if additional conversion is required when mapping to a@RabbitListener
method. -
o.s.messaging…MethodArgumentNotValidException
: Can be thrown if validation (for example,@Valid
) is used in the listener and the validation fails. -
o.s.messaging…MethodArgumentTypeMismatchException
: Can be thrown if the inbound message was converted to a type that is not correct for the target method. For example, the parameter is declared asMessage<Foo>
butMessage<Bar>
is received. -
java.lang.NoSuchMethodException
: Added in version 1.6.3. -
java.lang.ClassCastException
You can configure an instance of this error handler with a FatalExceptionStrategy
so that users can provide their own rules for conditional message rejection — for example, a delegate implementation to the BinaryExceptionClassifier
from Spring Retry (Message Listeners and the Asynchronous Case).
In addition, the ListenerExecutionFailedException
now has a failedMessage
property that you can use in the decision.
If the FatalExceptionStrategy.isFatal()
method returns true
, the error handler throws an AmqpRejectAndDontRequeueException
The default FatalExceptionStrategy
logs a warning message when an exception is determined to be fatal.
Since version 1.6.3, a convenient way to add user exceptions to the fatal list is to subclass ConditionalRejectingErrorHandler.DefaultExceptionStrategy
and override the isUserCauseFatal(Throwable cause)
method to return true
for fatal exceptions.
A common pattern for handling DLQ messages is to set a time-to-live
on those messages as well as additional DLQ configuration such that these messages expire and are routed back to the main queue for retry.
The problem with this technique is that messages that cause fatal exceptions loop forever.
Starting with version 2.1, the ConditionalRejectingErrorHandler
detects an x-death
header on a message that causes a fatal exception to be thrown.
The message is logged and discarded.
You can revert to the previous behavior by setting the discardFatalsWithXDeath
property on the ConditionalRejectingErrorHandler
to false
Starting with version 2.1.9, messages with these fatal exceptions are rejected and NOT requeued by default, even if the container acknowledge mode is MANUAL.
These exceptions generally occur before the listener is invoked so the listener does not have a chance to ack or nack the message so it remained in the queue in an un-acked state.
To revert to the previous behavior, set the rejectManual property on the ConditionalRejectingErrorHandler to false .
4.1.16. Transactions
The Spring Rabbit framework has support for automatic transaction management in the synchronous and asynchronous use cases with a number of different semantics that can be selected declaratively, as is familiar to existing users of Spring transactions. This makes many if not most common messaging patterns easy to implement.
There are two ways to signal the desired transaction semantics to the framework.
In both the RabbitTemplate
and SimpleMessageListenerContainer
, there is a flag channelTransacted
which, if true
, tells the framework to use a transactional channel and to end all operations (send or receive) with a commit or rollback (depending on the outcome), with an exception signaling a rollback.
Another signal is to provide an external transaction with one of Spring’s PlatformTransactionManager
implementations as a context for the ongoing operation.
If there is already a transaction in progress when the framework is sending or receiving a message, and the channelTransacted
flag is true
, the commit or rollback of the messaging transaction is deferred until the end of the current transaction.
If the channelTransacted
flag is false
, no transaction semantics apply to the messaging operation (it is auto-acked).
The channelTransacted
flag is a configuration time setting.
It is declared and processed once when the AMQP components are created, usually at application startup.
The external transaction is more dynamic in principle because the system responds to the current thread state at runtime.
However, in practice, it is often also a configuration setting, when the transactions are layered onto an application declaratively.
For synchronous use cases with RabbitTemplate
, the external transaction is provided by the caller, either declaratively or imperatively according to taste (the usual Spring transaction model).
The following example shows a declarative approach (usually preferred because it is non-invasive), where the template has been configured with channelTransacted=true
@Transactional
public void doSomething() {
String incoming = rabbitTemplate.receiveAndConvert();
// do some more database processing...
String outgoing = processInDatabaseAndExtractReply(incoming);
rabbitTemplate.convertAndSend(outgoing);
In the preceding example, a String
payload is received, converted, and sent as a message body inside a method marked as @Transactional
If the database processing fails with an exception, the incoming message is returned to the broker, and the outgoing message is not sent.
This applies to any operations with the RabbitTemplate
inside a chain of transactional methods (unless, for instance, the Channel
is directly manipulated to commit the transaction early).
For asynchronous use cases with SimpleMessageListenerContainer
, if an external transaction is needed, it has to be requested by the container when it sets up the listener.
To signal that an external transaction is required, the user provides an implementation of PlatformTransactionManager
to the container when it is configured.
public class ExampleExternalTransactionAmqpConfiguration {
public SimpleMessageListenerContainer messageListenerContainer() {
container.setConnectionFactory(rabbitConnectionFactory());
container.setTransactionManager(transactionManager());
container.setChannelTransacted(true);
container.setQueueName("some.queue");
container.setMessageListener(exampleListener());
return container;
In the preceding example, the transaction manager is added as a dependency injected from another bean definition (not shown), and the channelTransacted
flag is also set to true
The effect is that if the listener fails with an exception, the transaction is rolled back, and the message is also returned to the broker.
Significantly, if the transaction fails to commit (for example, because of
a database constraint error or connectivity problem), the AMQP transaction is also rolled back, and the message is returned to the broker.
This is sometimes known as a “Best Efforts 1 Phase Commit”, and is a very powerful pattern for reliable messaging.
flag was set to false
(the default) in the preceding example, the external transaction would still be provided for the listener, but all messaging operations would be auto-acked, so the effect is to commit the messaging operations even on a rollback of the business operation.
Conditional Rollback
Prior to version 1.6.6, adding a rollback rule to a container’s transactionAttribute
when using an external transaction manager (such as JDBC) had no effect.
Exceptions always rolled back the transaction.
Also, when using a transaction advice in the container’s advice chain, conditional rollback was not very useful, because all listener exceptions are wrapped in a ListenerExecutionFailedException
The first problem has been corrected, and the rules are now applied properly.
Further, the ListenerFailedRuleBasedTransactionAttribute
is now provided.
It is a subclass of RuleBasedTransactionAttribute
, with the only difference being that it is aware of the ListenerExecutionFailedException
and uses the cause of such exceptions for the rule.
This transaction attribute can be used directly in the container or through a transaction advice.
The following example uses this rule:
public AbstractMessageListenerContainer container() {
container.setTransactionManager(transactionManager);
RuleBasedTransactionAttribute transactionAttribute =
new ListenerFailedRuleBasedTransactionAttribute();
transactionAttribute.setRollbackRules(Collections.singletonList(
new NoRollbackRuleAttribute(DontRollBackException.class)));
container.setTransactionAttribute(transactionAttribute);
A note on Rollback of Received Messages
AMQP transactions apply only to messages and acks sent to the broker.
Consequently, when there is a rollback of a Spring transaction and a message has been received, Spring AMQP has to not only rollback the transaction but also manually reject the message (sort of a nack, but that is not what the specification calls it).
The action taken on message rejection is independent of transactions and depends on the defaultRequeueRejected
property (default: true
For more information about rejecting failed messages, see Message Listeners and the Asynchronous Case.
For more information about RabbitMQ transactions and their limitations, see RabbitMQ Broker Semantics.
Prior to RabbitMQ 2.7.0, such messages (and any that are unacked when a channel is closed or aborts) went to the back of the queue on a Rabbit broker. Since 2.7.0, rejected messages go to the front of the queue, in a similar manner to JMS rolled back messages. |
Previously, message requeue on transaction rollback was inconsistent between local transactions and when a TransactionManager was provided.
In the former case, the normal requeue logic (AmqpRejectAndDontRequeueException or defaultRequeueRejected=false ) applied (see Message Listeners and the Asynchronous Case).
With a transaction manager, the message was unconditionally requeued on rollback.
Starting with version 2.0, the behavior is consistent and the normal requeue logic is applied in both cases.
To revert to the previous behavior, you can set the container’s alwaysRequeueWithTxManagerRollback property to true .
See Message Listener Container Configuration.
Using RabbitTransactionManager
The RabbitTransactionManager is an alternative to executing Rabbit operations within, and synchronized with, external transactions.
This transaction manager is an implementation of the PlatformTransactionManager
interface and should be used with a single Rabbit ConnectionFactory
This strategy is not able to provide XA transactions — for example, in order to share transactions between messaging and database access. |
Application code is required to retrieve the transactional Rabbit resources through ConnectionFactoryUtils.getTransactionalResourceHolder(ConnectionFactory, boolean)
instead of a standard Connection.createChannel()
call with subsequent channel creation.
When using Spring AMQP’s RabbitTemplate, it will autodetect a thread-bound Channel and automatically participate in its transaction.
With Java Configuration, you can setup a new RabbitTransactionManager by using the following bean:
public RabbitTransactionManager rabbitTransactionManager() {
return new RabbitTransactionManager(connectionFactory);
If you prefer XML configuration, you can declare the following bean in your XML Application Context file:
<bean id="rabbitTxManager"
class="org.springframework.amqp.rabbit.transaction.RabbitTransactionManager">
<property name="connectionFactory" ref="connectionFactory"/>
</bean>
Transaction Synchronization
Synchronizing a RabbitMQ transaction with some other (e.g. DBMS) transaction provides "Best Effort One Phase Commit" semantics.
It is possible that the RabbitMQ transaction fails to commit during the after completion phase of transaction synchronization.
This is logged by the spring-tx
infrastructure as an error, but no exception is thrown to the calling code.
Starting with version 2.3.10, you can call ConnectionUtils.checkAfterCompletion()
after the transaction has committed on the same thread that processed the transaction.
It will simply return if no exception occurred; otherwise it will throw an AfterCompletionFailedException
which will have a property representing the synchronization status of the completion.
Enable this feature by calling ConnectionFactoryUtils.enableAfterCompletionFailureCapture(true)
; this is a global flag and applies to all threads.
4.1.17. Message Listener Container Configuration
There are quite a few options for configuring a SimpleMessageListenerContainer
(SMLC) and a DirectMessageListenerContainer
(DMLC) related to transactions and quality of service, and some of them interact with each other.
Properties that apply to the SMLC, DMLC, or StreamListenerContainer
(StLC) (see Using the RabbitMQ Stream Plugin are indicated by the check mark in the appropriate column.
See Choosing a Container for information to help you decide which container is appropriate for your application.
The following table shows the container property names and their equivalent attribute names (in parentheses) when using the namespace to configure a <rabbit:listener-container/>
The type
attribute on that element can be simple
(default) or direct
to specify an SMLC
or DMLC
respectively.
Some properties are not exposed by the namespace.
These are indicated by N/A
for the attribute.
Property (Attribute) | Description | SMLC | DMLC | StLC | ||||||
When |
An array of AOP Advice to apply to the listener execution.
This can be used to apply additional cross-cutting concerns, such as automatic retry in the event of broker death.
Note that simple re-connection after an AMQP error is handled by the |
An array of |
Set to |
When set to
Flag to indicate that the container should start when the |
When used with |
The strategy used when debatchng messages.
Default |
Boolean flag to signal that all messages should be acknowledged in a transaction (either manually or automatically). |
The number of concurrent consumers to initially start for each listener. See Listener Concurrency. |
A reference to the |
The minimum number of consecutive messages received by a consumer, without a receive timeout occurring, when considering starting a new consumer. Also impacted by 'batchSize'. See Listener Concurrency. Default: 10. |
The minimum number of receive timeouts a consumer must experience before considering stopping a consumer. Also impacted by 'batchSize'. See Listener Concurrency. Default: 10. |
If the |
A |
The time in milliseconds to wait for a consumer thread to start.
If this time elapses, an error log is written.
An example of when this might happen is if a configured See Threading and Asynchronous Consumers. Default: 60000 (one minute). |
Set an implementation of ConsumerTagStrategy, enabling the creation of a (unique) tag for each consumer. |
The number of consumers to create for each configured queue. See Listener Concurrency. |
When using the RabbitMQ Sharding Plugin with |
When true, the listener container will debatch batched messages and invoke the listener with each message from the batch.
Starting with version 2.2.7, producer created batches will be debatched as a |
The number of retry attempts when passive queue declaration fails. Passive queue declaration occurs when the consumer starts or, when consuming from multiple queues, when not all queues were available during initialization. When none of the configured queues can be passively declared (for any reason) after the retries are exhausted, the container behavior is controlled by the 'missingQueuesFatal` property, described earlier. Default: Three retries (for a total of four attempts). |
Determines whether messages that are rejected because the listener threw an exception should be requeued or not.
Default: |
A reference to an |
Determines whether the single consumer in this container has exclusive access to the queues.
The concurrency of the container must be 1 when this is |
An exception logger used when an exclusive consumer cannot gain access to a queue.
By default, this is logged at the |
The interval between passive queue declaration retry attempts. Passive queue declaration occurs when the consumer starts or, when consuming from multiple queues, when not all queues were available during initialization. Default: 5000 (five seconds). |
If the consumers do not respond to a shutdown within |
Set to true to stop (when the container is stopped) after the current record is processed; causing all prefetched messages to be requeued.
By default, the container will cancel the consumer and process all prefetched messages before stopping.
Since versions 2.4.14, 3.0.6
Defaults to |
When true, the |
(group) |
This is available only when using the namespace.
When specified, a bean of type |
An |
The maximum number of concurrent consumers to start, if needed, on demand. Must be greater than or equal to 'concurrentConsumers'. See Listener Concurrency. |
The number of messages to receive between acks.
Use this to reduce the number of acks sent to the broker (at the cost of increasing the possibility of redelivered messages).
Generally, you should set this property only on high-volume listener containers.
If this is set and a message is rejected (exception thrown), pending acks are acknowledged and the failed message is rejected.
Not allowed with transacted channels.
If the |
When the container starts, if this property is If the problem is detected during recovery (for example, after a lost connection), the container is stopped. There must be a single
When set to This was not configurable in previous versions. When set to You can also use a properties bean to set the property globally for all containers, as follows:
This global property is not applied to any containers that have an explicit The default retry properties (three retries at five-second intervals) can be overridden by setting the properties below.
With the DMLC, a task is scheduled to run at this interval to monitor the state of the consumers and recover any that have failed. |
Set to |
When |
When set to Since version 2.0. DirectMessageListenerContainer When set to SimpleMessageListenerContainer When set to You can also use a properties bean to set the property globally for all containers, as follows:
This global property will not be applied to any containers that have an explicit The default retry properties (3 retries at 5 second intervals) can be overridden using the properties after this one. |
The number of unacknowledged messages that can be outstanding at each consumer.
The higher this value is, the faster the messages can be delivered, but the higher the risk of non-sequential processing.
Ignored if the
Also see |
When a listener container listens to at least one auto-delete queue and it is found to be missing during startup, the container uses a |
The maximum time to wait for each message.
If |
Specifies the |
Determines the time in milliseconds between attempts to start a consumer if it fails to start for non-fatal reasons.
Default: 5000.
Mutually exclusive with |
If a subset of the configured queues are available during consumer initialization, the consumer starts consuming from those queues. The consumer tries to passively declare the missing queues by using this interval. When this interval elapses, the 'declarationRetries' and 'failedDeclarationRetryInterval' is used again. If there are still missing queues, the consumer again waits for this interval before trying again. This process continues indefinitely until all queues are available. Default: 60000 (one minute). |
When a container shuts down (for example,
if its enclosing |
The time in milliseconds that must elapse before each new consumer is started on demand. See Listener Concurrency. Default: 10000 (10 seconds). |
When using a stateful retry advice, if a message with a missing |
The time in milliseconds that must elapse before a consumer is stopped since the last consumer was stopped when an idle consumer is detected. See Listener Concurrency. Default: 60000 (one minute). |
A |
A reference to a Spring |
With the DMLC, the scheduler used to run the monitor task at the 'monitorInterval'. |
External transaction manager for the operation of the listener.
Also complementary to |
4.1.18. Listener Concurrency
By default, the listener container starts a single consumer that receives messages from the queues.
When examining the table in the previous section, you can see a number of properties and attributes that control concurrency.
The simplest is concurrentConsumers
, which creates that (fixed) number of consumers that concurrently process messages.
Prior to version 1.3.0, this was the only setting available and the container had to be stopped and started again to change the setting.
Since version 1.3.0, you can now dynamically adjust the concurrentConsumers
property.
If it is changed while the container is running, consumers are added or removed as necessary to adjust to the new setting.
In addition, a new property called maxConcurrentConsumers
has been added and the container dynamically adjusts the concurrency based on workload.
This works in conjunction with four additional properties: consecutiveActiveTrigger
, startConsumerMinInterval
, consecutiveIdleTrigger
, and stopConsumerMinInterval
With the default settings, the algorithm to increase consumers works as follows:
If the maxConcurrentConsumers
has not been reached and an existing consumer is active for ten consecutive cycles AND at least 10 seconds has elapsed since the last consumer was started, a new consumer is started.
A consumer is considered active if it received at least one message in batchSize
* receiveTimeout
milliseconds.
With the default settings, the algorithm to decrease consumers works as follows:
If there are more than concurrentConsumers
running and a consumer detects ten consecutive timeouts (idle) AND the last consumer was stopped at least 60 seconds ago, a consumer is stopped.
The timeout depends on the receiveTimeout
and the batchSize
properties.
A consumer is considered idle if it receives no messages in batchSize
* receiveTimeout
milliseconds.
So, with the default timeout (one second) and a batchSize
of four, stopping a consumer is considered after 40 seconds of idle time (four timeouts correspond to one idle detection).
Practically, consumers can be stopped only if the whole container is idle for some time. This is because the broker shares its work across all the active consumers. |
Each consumer uses a single channel, regardless of the number of configured queues.
Starting with version 2.0, the concurrentConsumers
and maxConcurrentConsumers
properties can be set with the concurrency
property — for example, 2-4
Using DirectMessageListenerContainer
With this container, concurrency is based on the configured queues and consumersPerQueue
Each consumer for each queue uses a separate channel, and the concurrency is controlled by the rabbit client library.
By default, at the time of writing, it uses a pool of DEFAULT_NUM_THREADS = Runtime.getRuntime().availableProcessors() * 2
threads.
You can configure a taskExecutor
to provide the required maximum concurrency.
4.1.19. Exclusive Consumer
Starting with version 1.3, you can configure the listener container with a single exclusive consumer.
This prevents other containers from consuming from the queues until the current consumer is cancelled.
The concurrency of such a container must be 1
When using exclusive consumers, other containers try to consume from the queues according to the recoveryInterval
property and log a WARN
message if the attempt fails.
4.1.20. Listener Container Queues
Version 1.3 introduced a number of improvements for handling multiple queues in a listener container.
Container can be initially configured to listen on zero queues.
Queues can be added and removed at runtime.
The SimpleMessageListenerContainer
recycles (cancels and re-creates) all consumers when any pre-fetched messages have been processed.
The DirectMessageListenerContainer
creates/cancels individual consumer(s) for each queue without affecting consumers on other queues.
See the Javadoc for the addQueues
, addQueueNames
, removeQueues
and removeQueueNames
methods.
If not all queues are available, the container tries to passively declare (and consume from) the missing queues every 60 seconds.
Also, if a consumer receives a cancel from the broker (for example, if a queue is deleted) the consumer tries to recover, and the recovered consumer continues to process messages from any other configured queues. Previously, a cancel on one queue cancelled the entire consumer and, eventually, the container would stop due to the missing queue.
If you wish to permanently remove a queue, you should update the container before or after deleting to queue, to avoid future attempts trying to consume from it.
4.1.21. Resilience: Recovering from Errors and Broker Failures
Some of the key (and most popular) high-level features that Spring AMQP provides are to do with recovery and automatic re-connection in the event of a protocol error or broker failure. We have seen all the relevant components already in this guide, but it should help to bring them all together here and call out the features and recovery scenarios individually.
The primary reconnection features are enabled by the CachingConnectionFactory
itself.
It is also often beneficial to use the RabbitAdmin
auto-declaration features.
In addition, if you care about guaranteed delivery, you probably also need to use the channelTransacted
flag in RabbitTemplate
and the AcknowledgeMode.AUTO
(or manual if you do the acks yourself) in the SimpleMessageListenerContainer
Automatic Declaration of Exchanges, Queues, and Bindings
The RabbitAdmin
component can declare exchanges, queues, and bindings on startup.
It does this lazily, through a ConnectionListener
Consequently, if the broker is not present on startup, it does not matter.
The first time a Connection
is used (for example,
by sending a message) the listener fires and the admin features is applied.
A further benefit of doing the auto declarations in a listener is that, if the connection is dropped for any reason (for example,
broker death, network glitch, and others), they are applied again when the connection is re-established.
Queues declared this way must have fixed names — either explicitly declared or generated by the framework for AnonymousQueue instances.
Anonymous queues are non-durable, exclusive, and auto-deleting.
Automatic declaration is performed only when the CachingConnectionFactory cache mode is CHANNEL (the default).
This limitation exists because exclusive and auto-delete queues are bound to the connection.
Starting with version 2.2.2, the RabbitAdmin
will detect beans of type DeclarableCustomizer
and apply the function before actually processing the declaration.
This is useful, for example, to set a new argument (property) before it has first class support within the framework.
public DeclarableCustomizer customizer() {
return dec -> {
if (dec instanceof Queue && ((Queue) dec).getName().equals("my.queue")) {
dec.addArgument("some.new.queue.argument", true);
return dec;
It is also useful in projects that don’t provide direct access to the Declarable
bean definitions.
Failures in Synchronous Operations and Options for Retry
If you lose your connection to the broker in a synchronous sequence when using RabbitTemplate
(for instance), Spring AMQP throws an AmqpException
(usually, but not always, AmqpIOException
We do not try to hide the fact that there was a problem, so you have to be able to catch and respond to the exception.
The easiest thing to do if you suspect that the connection was lost (and it was not your fault) is to try the operation again.
You can do this manually, or you could look at using Spring Retry to handle the retry (imperatively or declaratively).
Spring Retry provides a couple of AOP interceptors and a great deal of flexibility to specify the parameters of the retry (number of attempts, exception types, backoff algorithm, and others).
Spring AMQP also provides some convenience factory beans for creating Spring Retry interceptors in a convenient form for AMQP use cases, with strongly typed callback interfaces that you can use to implement custom recovery logic.
See the Javadoc and properties of StatefulRetryOperationsInterceptor
and StatelessRetryOperationsInterceptor
for more detail.
Stateless retry is appropriate if there is no transaction or if a transaction is started inside the retry callback.
Note that stateless retry is simpler to configure and analyze than stateful retry, but it is not usually appropriate if there is an ongoing transaction that must be rolled back or definitely is going to roll back.
A dropped connection in the middle of a transaction should have the same effect as a rollback.
Consequently, for reconnections where the transaction is started higher up the stack, stateful retry is usually the best choice.
Stateful retry needs a mechanism to uniquely identify a message.
The simplest approach is to have the sender put a unique value in the MessageId
message property.
The provided message converters provide an option to do this: you can set createMessageIds
to true
Otherwise, you can inject a MessageKeyGenerator
implementation into the interceptor.
The key generator must return a unique key for each message.
In versions prior to version 2.0, a MissingMessageIdAdvice
was provided.
It enabled messages without a messageId
property to be retried exactly once (ignoring the retry settings).
This advice is no longer provided, since, along with spring-retry
version 1.2, its functionality is built into the interceptor and message listener containers.
For backwards compatibility, a message with a null message ID is considered fatal for the consumer (consumer is stopped) by default (after one retry).
To replicate the functionality provided by the MissingMessageIdAdvice , you can set the statefulRetryFatalWithNullMessageId property to false on the listener container.
With that setting, the consumer continues to run and the message is rejected (after one retry).
It is discarded or routed to the dead letter queue (if one is configured).
Starting with version 1.3, a builder API is provided to aid in assembling these interceptors by using Java (in @Configuration
classes).
public StatefulRetryOperationsInterceptor interceptor() {
return RetryInterceptorBuilder.stateful()
.maxAttempts(5)
.backOffOptions(1000, 2.0, 10000) // initialInterval, multiplier, maxInterval
Only a subset of retry capabilities can be configured this way.
More advanced features would need the configuration of a RetryTemplate
as a Spring bean.
See the Spring Retry Javadoc for complete information about available policies and their configuration.
Retry with Batch Listeners
It is not recommended to configure retry with a batch listener, unless the batch was created by the producer, in a single record. See Batched Messages for information about consumer and producer-created batches. With a consumer-created batch, the framework has no knowledge about which message in the batch caused the failure so recovery after the retries are exhausted is not possible. With producer-created batches, since there is only one message that actually failed, the whole message can be recovered. Applications may want to inform a custom recoverer where in the batch the failure occurred, perhaps by setting an index property of the thrown exception.
A retry recoverer for a batch listener must implement MessageBatchRecoverer
If a MessageListener
fails because of a business exception, the exception is handled by the message listener container, which then goes back to listening for another message.
If the failure is caused by a dropped connection (not a business exception), the consumer that is collecting messages for the listener has to be cancelled and restarted.
handles this seamlessly, and it leaves a log to say that the listener is being restarted.
In fact, it loops endlessly, trying to restart the consumer.
Only if the consumer is very badly behaved indeed will it give up.
One side effect is that if the broker is down when the container starts, it keeps trying until a connection can be established.
Business exception handling, as opposed to protocol errors and dropped connections, might need more thought and some custom configuration, especially if transactions or container acks are in use.
Prior to 2.8.x, RabbitMQ had no definition of dead letter behavior.
Consequently, by default, a message that is rejected or rolled back because of a business exception can be redelivered endlessly.
To put a limit on the client on the number of re-deliveries, one choice is a StatefulRetryOperationsInterceptor
in the advice chain of the listener.
The interceptor can have a recovery callback that implements a custom dead letter action — whatever is appropriate for your particular environment.
Another alternative is to set the container’s defaultRequeueRejected
property to false
This causes all failed messages to be discarded.
When using RabbitMQ 2.8.x or higher, this also facilitates delivering the message to a dead letter exchange.
Alternatively, you can throw a AmqpRejectAndDontRequeueException
Doing so prevents message requeuing, regardless of the setting of the defaultRequeueRejected
property.
Starting with version 2.1, an ImmediateRequeueAmqpException
is introduced to perform exactly the opposite logic: the message will be requeued, regardless of the setting of the defaultRequeueRejected
property.
Often, a combination of both techniques is used.
You can use a StatefulRetryOperationsInterceptor
in the advice chain with a MessageRecoverer
that throws an AmqpRejectAndDontRequeueException
The MessageRecover
is called when all retries have been exhausted.
The RejectAndDontRequeueRecoverer
does exactly that.
The default MessageRecoverer
consumes the errant message and emits a WARN
message.
Starting with version 1.3, a new RepublishMessageRecoverer
is provided, to allow publishing of failed messages after retries are exhausted.
When a recoverer consumes the final exception, the message is ack’d and is not sent to the dead letter exchange by the broker, if configured.
When RepublishMessageRecoverer is used on the consumer side, the received message has deliveryMode in the receivedDeliveryMode message property.
In this case the deliveryMode is null .
That means a NON_PERSISTENT delivery mode on the broker.
Starting with version 2.0, you can configure the RepublishMessageRecoverer for the deliveryMode to set into the message to republish if it is null .
By default, it uses MessageProperties default value - MessageDeliveryMode.PERSISTENT .
The following example shows how to set a RepublishMessageRecoverer
as the recoverer:
return RetryInterceptorBuilder.stateless()
.maxAttempts(5)
.recoverer(new RepublishMessageRecoverer(amqpTemplate(), "something", "somethingelse"))
The RepublishMessageRecoverer
publishes the message with additional information in message headers, such as the exception message, stack trace, original exchange, and routing key.
Additional headers can be added by creating a subclass and overriding additionalHeaders()
The deliveryMode
(or any other properties) can also be changed in the additionalHeaders()
RepublishMessageRecoverer recoverer = new RepublishMessageRecoverer(amqpTemplate, "error") {
protected Map<? extends String, ? extends Object> additionalHeaders(Message message, Throwable cause) {
.setDeliveryMode(message.getMessageProperties().getReceivedDeliveryMode());
return null;
Starting with version 2.0.5, the stack trace may be truncated if it is too large; this is because all headers have to fit in a single frame.
By default, if the stack trace would cause less than 20,000 bytes ('headroom') to be available for other headers, it will be truncated.
This can be adjusted by setting the recoverer’s frameMaxHeadroom
property, if you need more or less space for other headers.
Starting with versions 2.1.13, 2.2.3, the exception message is included in this calculation, and the amount of stack trace will be maximized using the following algorithm:
if the stack trace alone would exceed the limit, the exception message header will be truncated to 97 bytes plus
and the stack trace is truncated too. -
if the stack trace is small, the message will be truncated (plus
) to fit in the available bytes (but the message within the stack trace itself is truncated to 97 bytes plus…
Whenever a truncation of any kind occurs, the original exception will be logged to retain the complete information. The evaluation is performed after the headers are enhanced so information such as the exception type can be used in the expressions.
Starting with version 2.4.8, the error exchange and routing key can be provided as SpEL expressions, with the Message
being the root object for the evaluation.
Starting with version 2.3.3, a new subclass RepublishMessageRecovererWithConfirms
is provided; this supports both styles of publisher confirms and will wait for the confirmation before returning (or throw an exception if not confirmed or the message is returned).
If the confirm type is CORRELATED
, the subclass will also detect if a message is returned and throw an AmqpMessageReturnedException
; if the publication is negatively acknowledged, it will throw an AmqpNackReceivedException
If the confirm type is SIMPLE
, the subclass will invoke the waitForConfirmsOrDie
method on the channel.
See Publisher Confirms and Returns for more information about confirms and returns.
Starting with version 2.1, an ImmediateRequeueMessageRecoverer
is added to throw an ImmediateRequeueAmqpException
, which notifies a listener container to requeue the current failed message.
Exception Classification for Spring Retry
Spring Retry has a great deal of flexibility for determining which exceptions can invoke retry.
The default configuration retries for all exceptions.
Given that user exceptions are wrapped in a ListenerExecutionFailedException
, we need to ensure that the classification examines the exception causes.
The default classifier looks only at the top level exception.
Since Spring Retry 1.0.3, the BinaryExceptionClassifier
has a property called traverseCauses
(default: false
When true
, it travers exception causes until it finds a match or there is no cause.
To use this classifier for retry, you can use a SimpleRetryPolicy
created with the constructor that takes the max attempts, the Map
of Exception
instances, and the boolean (traverseCauses
) and inject this policy into the RetryTemplate
4.1.22. Multiple Broker (or Cluster) Support
Version 2.3 added more convenience when communicating between a single application and multiple brokers or broker clusters. The main benefit, on the consumer side, is that the infrastructure can automatically associate auto-declared queues with the appropriate broker.
This is best illustrated with an example:
@SpringBootApplication(exclude = RabbitAutoConfiguration.class)
public class Application {
SpringApplication.run(Application.class, args);
CachingConnectionFactory cf1() {
CachingConnectionFactory cf2() {
return new CachingConnectionFactory("otherHost");
CachingConnectionFactory cf3() {
return new CachingConnectionFactory("thirdHost");
SimpleRoutingConnectionFactory rcf(CachingConnectionFactory cf1,
CachingConnectionFactory cf2, CachingConnectionFactory cf3) {
SimpleRoutingConnectionFactory rcf = new SimpleRoutingConnectionFactory();
rcf.setDefaultTargetConnectionFactory(cf1);
rcf.setTargetConnectionFactories(Map.of("one", cf1, "two", cf2, "three", cf3));
return rcf;
@Bean("factory1-admin")
RabbitAdmin admin1(CachingConnectionFactory cf1) {
return new RabbitAdmin(cf1);
@Bean("factory2-admin")
RabbitAdmin admin2(CachingConnectionFactory cf2) {
return new RabbitAdmin(cf2);
@Bean("factory3-admin")
RabbitAdmin admin3(CachingConnectionFactory cf3) {
return new RabbitAdmin(cf3);
public RabbitListenerEndpointRegistry rabbitListenerEndpointRegistry() {
return new RabbitListenerEndpointRegistry();
public RabbitListenerAnnotationBeanPostProcessor postProcessor(RabbitListenerEndpointRegistry registry) {
MultiRabbitListenerAnnotationBeanPostProcessor postProcessor
= new MultiRabbitListenerAnnotationBeanPostProcessor();
postProcessor.setEndpointRegistry(registry);
postProcessor.setContainerFactoryBeanName("defaultContainerFactory");
return postProcessor;
public SimpleRabbitListenerContainerFactory factory1(CachingConnectionFactory cf1) {
SimpleRabbitListenerContainerFactory factory = new SimpleRabbitListenerContainerFactory();
factory.setConnectionFactory(cf1);
return factory;
public SimpleRabbitListenerContainerFactory factory2(CachingConnectionFactory cf2) {
factory.setConnectionFactory(cf2);
return factory;
public SimpleRabbitListenerContainerFactory factory3(CachingConnectionFactory cf3) {
factory.setConnectionFactory(cf3);
return factory;
RabbitTemplate template(SimpleRoutingConnectionFactory rcf) {
return new RabbitTemplate(rcf);
ConnectionFactoryContextWrapper wrapper(SimpleRoutingConnectionFactory rcf) {
return new ConnectionFactoryContextWrapper(rcf);
@Component
class Listeners {
@RabbitListener(queuesToDeclare = @Queue("q1"), containerFactory = "factory1")
public void listen1(String in) {
@RabbitListener(queuesToDeclare = @Queue("q2"), containerFactory = "factory2")
public void listen2(String in) {
@RabbitListener(queuesToDeclare = @Queue("q3"), containerFactory = "factory3")
public void listen3(String in) {
As you can see, we have declared 3 sets of infrastructure (connection factories, admins, container factories).
As discussed earlier, @RabbitListener
can define which container factory to use; in this case, they also use queuesToDeclare
which causes the queue(s) to be declared on the broker, if it doesn’t exist.
By naming the RabbitAdmin
beans with the convention <container-factory-name>-admin
, the infrastructure is able to determine which admin should declare the queue.
This will also work with bindings = @QueueBinding(…)
whereby the exchange and binding will also be declared.
It will NOT work with queues
, since that expects the queue(s) to already exist.
On the producer side, a convenient ConnectionFactoryContextWrapper
class is provided, to make using the RoutingConnectionFactory
(see Routing Connection Factory) simpler.
As you can see above, a SimpleRoutingConnectionFactory
bean has been added with routing keys one
, two
and three
There is also a RabbitTemplate
that uses that factory.
Here is an example of using that template with the wrapper to route to one of the broker clusters.
public ApplicationRunner runner(RabbitTemplate template, ConnectionFactoryContextWrapper wrapper) {
return args -> {
wrapper.run("one", () -> template.convertAndSend("q1", "toCluster1"));
wrapper.run("two", () -> template.convertAndSend("q2", "toCluster2"));
wrapper.run("three", () -> template.convertAndSend("q3", "toCluster3"));
4.1.23. Debugging
Spring AMQP provides extensive logging, especially at the DEBUG
level.
If you wish to monitor the AMQP protocol between the application and broker, you can use a tool such as WireShark, which has a plugin to decode the protocol.
Alternatively, the RabbitMQ Java client comes with a very useful class called Tracer
When run as a main
, by default, it listens on port 5673 and connects to port 5672 on localhost.
You can run it and change your connection factory configuration to connect to port 5673 on localhost.
It displays the decoded protocol on the console.
Refer to the Tracer
4.2. Using the RabbitMQ Stream Plugin
Version 2.4 introduces initial support for the RabbitMQ Stream Plugin Java Client for the RabbitMQ Stream Plugin.
RabbitStreamTemplate
Add the spring-rabbit-stream
dependency to your project:
<dependency>
<groupId>org.springframework.amqp</groupId>
<artifactId>spring-rabbit-stream</artifactId>
<version>2.4.17</version>
</dependency>
compile 'org.springframework.amqp:spring-rabbit-stream:2.4.17'
You can provision the queues as normal, using a RabbitAdmin
bean, using the QueueBuilder.stream()
method to designate the queue type.
For example:
Queue stream() {
return QueueBuilder.durable("stream.queue1")
.stream()
However, this will only work if you are also using non-stream components (such as the SimpleMessageListenerContainer
or DirectMessageListenerContainer
) because the admin is triggered to declare the defined beans when an AMQP connection is opened.
If your application only uses stream components, or you wish to use advanced stream configuration features, you should configure a StreamAdmin
instead:
StreamAdmin streamAdmin(Environment env) {
return new StreamAdmin(env, sc -> {
sc.stream("stream.queue1").maxAge(Duration.ofHours(2)).create();
sc.stream("stream.queue2").create();
Refer to the RabbitMQ documentation for more information about the StreamCreator
4.2.1. Sending Messages
The RabbitStreamTemplate
provides a subset of the RabbitTemplate
(AMQP) functionality.
public interface RabbitStreamOperations extends AutoCloseable {
ListenableFuture<Boolean> send(Message message);
ListenableFuture<Boolean> convertAndSend(Object message);
ListenableFuture<Boolean> convertAndSend(Object message, @Nullable MessagePostProcessor mpp);
ListenableFuture<Boolean> send(com.rabbitmq.stream.Message message);
MessageBuilder messageBuilder();
MessageConverter messageConverter();
StreamMessageConverter streamMessageConverter();
void close() throws AmqpException;
implementation has the following constructor and properties:
public RabbitStreamTemplate(Environment environment, String streamName) {
public void setMessageConverter(MessageConverter messageConverter) {
public void setStreamConverter(StreamMessageConverter streamConverter) {
public synchronized void setProducerCustomizer(ProducerCustomizer producerCustomizer) {
The MessageConverter
is used in the convertAndSend
methods to convert the object to a Spring AMQP Message
The StreamMessageConverter
is used to convert from a Spring AMQP Message
to a native stream Message
You can also send native stream Message
s directly; with the messageBuilder()
method provding access to the Producer
's message builder.
The ProducerCustomizer
provides a mechanism to customize the producer before it is built.
Refer to the Java Client Documentation about customizing the Environment
and Producer
In version 3.0, the method return types will be CompletableFuture instead of ListenableFuture .
4.2.2. Receiving Messages
Asynchronous message reception is provided by the StreamListenerContainer
(and the StreamRabbitListenerContainerFactory
when using @RabbitListener
The listener container requires an Environment
as well as a single stream name.
You can either receive Spring AMQP Message
s using the classic MessageListener
, or you can receive native stream Message
s using a new interface:
public interface StreamMessageListener extends MessageListener {
void onStreamMessage(Message message, Context context);
See Message Listener Container Configuration for information about supported properties.
Similar the template, the container has a ConsumerCustomizer
property.
and Consumer
When using @RabbitListener
, configure a StreamRabbitListenerContainerFactory
; at this time, most @RabbitListener
properties (concurrency
, etc) are ignored. Only id
, queues
, autoStartup
and containerFactory
are supported.
In addition, queues
can only contain one stream name.
4.2.3. Examples
RabbitStreamTemplate streamTemplate(Environment env) {
RabbitStreamTemplate template = new RabbitStreamTemplate(env, "test.stream.queue1");
template.setProducerCustomizer((name, builder) -> builder.name("test"));
return template;
RabbitListenerContainerFactory<StreamListenerContainer> rabbitListenerContainerFactory(Environment env) {
return new StreamRabbitListenerContainerFactory(env);
@RabbitListener(queues = "test.stream.queue1")
void listen(String in) {
RabbitListenerContainerFactory<StreamListenerContainer> nativeFactory(Environment env) {
StreamRabbitListenerContainerFactory factory = new StreamRabbitListenerContainerFactory(env);
factory.setNativeListener(true);
factory.setConsumerCustomizer((id, builder) -> {
builder.name("myConsumer")
.offset(OffsetSpecification.first())
.manualTrackingStrategy();
return factory;
@RabbitListener(id = "test", queues = "test.stream.queue2", containerFactory = "nativeFactory")
void nativeMsg(Message in, Context context) {
context.storeOffset();
Version 2.4.5 added the adviceChain
property to the StreamListenerContainer
(and its factory).
A new factory bean is also provided to create a stateless retry interceptor with an optional StreamMessageRecoverer
for use when consuming raw stream messages.
public StreamRetryOperationsInterceptorFactoryBean sfb(RetryTemplate retryTemplate) {
StreamRetryOperationsInterceptorFactoryBean rfb =
new StreamRetryOperationsInterceptorFactoryBean();
rfb.setRetryOperations(retryTemplate);
rfb.setStreamMessageRecoverer((msg, context, throwable) -> {
return rfb;
Stateful retry is not supported with this container. |
4.3. Logging Subsystem AMQP Appenders
The framework provides logging appenders for some popular logging subsystems:
logback (since Spring AMQP version 1.4)
log4j2 (since Spring AMQP version 1.6)
The appenders are configured by using the normal mechanisms for the logging subsystem, available properties are specified in the following sections.
4.3.1. Common properties
The following properties are available with all appenders:
Property | Default | Description |
exchangeName |
logs |
Name of the exchange to which to publish log events. |
exchangeType |
topic |
Type of the exchange to which to publish log events — needed only if the appender declares the exchange.
See |
routingKeyPattern |
%c.%p |
Logging subsystem pattern format to use to generate a routing key. |
applicationId |
Application ID — added to the routing key if the pattern includes |
senderPoolSize |
2 |
The number of threads to use to publish log events. |
maxSenderRetries |
30 |
How many times to retry sending a message if the broker is unavailable or there is some other error.
Retries are delayed as follows: |
addresses |
A comma-delimited list of broker addresses in the following form: |
host |
localhost |
RabbitMQ host to which to connect . |
port |
5672 |
RabbitMQ port to which to connect. |
virtualHost |
RabbitMQ virtual host to which to connect. |
username |
guest |
RabbitMQ user to use when connecting. |
password |
guest |
RabbitMQ password for this user. |
useSsl |
false |
Whether to use SSL for the RabbitMQ connection.
See |
verifyHostname |
true |
Enable server hostname verification for TLS connections.
See |
sslAlgorithm |
null |
The SSL algorithm to use. |
sslPropertiesLocation |
null |
Location of the SSL properties file. |
keyStore |
null |
Location of the keystore. |
keyStorePassphrase |
null |
Passphrase for the keystore. |
keyStoreType |
JKS |
The keystore type. |
trustStore |
null |
Location of the truststore. |
trustStorePassphrase |
null |
Passphrase for the truststore. |
trustStoreType |
JKS |
The truststore type. |
saslConfig |
null (RabbitMQ client default applies) |
The |
contentType |
text/plain |
contentEncoding |
declareExchange |
false |
Whether or not to declare the configured exchange when this appender starts.
See also |
durable |
true |
When |
autoDelete |
false |
When |
charset |
null |
Character set to use when converting |
deliveryMode |
PERSISTENT |
generateId |
false |
Used to determine whether the |
clientConnectionProperties |
null |
A comma-delimited list of |
addMdcAsHeaders |
true |
MDC properties were always added into RabbitMQ message headers until this property was introduced.
It can lead to issues for big MDC as while RabbitMQ has limited buffer size for all headers and this buffer is pretty small.
This property was introduced to avoid issues in cases of big MDC.
By default this value set to |
4.3.2. Log4j 2 Appender
The following example shows how to configure a Log4j 2 appender:
<Appenders>
<RabbitMQ name="rabbitmq"
addresses="foo:5672,bar:5672" user="guest" password="guest" virtualHost="/"
exchange="log4j2" exchangeType="topic" declareExchange="true" durable="true" autoDelete="false"
applicationId="myAppId" routingKeyPattern="%X{applicationId}.%c.%p"
contentType="text/plain" contentEncoding="UTF-8" generateId="true" deliveryMode="NON_PERSISTENT"
charset="UTF-8"
senderPoolSize="3" maxSenderRetries="5"
addMdcAsHeaders="false">
</RabbitMQ>
</Appenders>
Starting with versions 1.6.10 and 1.7.3, by default, the log4j2 appender publishes the messages to RabbitMQ on the calling thread.
This is because Log4j 2 does not, by default, create thread-safe events.
If the broker is down, the |
4.3.3. Logback Appender
The following example shows how to configure a logback appender:
<appender name="AMQP" class="org.springframework.amqp.rabbit.logback.AmqpAppender">
<layout>
<pattern><![CDATA[ %d %p %t [%c] - <%m>%n ]]></pattern>
</layout>
<addresses>foo:5672,bar:5672</addresses>
<abbreviation>36</abbreviation>
<includeCallerData>false</includeCallerData>
<applicationId>myApplication</applicationId>
<routingKeyPattern>%property{applicationId}.%c.%p</routingKeyPattern>
<generateId>true</generateId>
<charset>UTF-8</charset>
<durable>false</durable>
<deliveryMode>NON_PERSISTENT</deliveryMode>
<declareExchange>true</declareExchange>
<addMdcAsHeaders>false</addMdcAsHeaders>
</appender>
Starting with version 1.7.1, the Logback AmqpAppender
provides an includeCallerData
option, which is false
by default.
Extracting caller data can be rather expensive, because the log event has to create a throwable and inspect it to determine the calling location.
Therefore, by default, caller data associated with an event is not extracted when the event is added to the event queue.
You can configure the appender to include caller data by setting the includeCallerData
property to true
Starting with version 2.0.0, the Logback AmqpAppender
supports Logback encoders with the encoder
option.
The encoder
and layout
options are mutually exclusive.
4.3.4. Customizing the Messages
By default, AMQP appenders populate the following message properties:
deliveryMode
contentType
contentEncoding
, if configured -
messageId
, ifgenerateId
is configured -
timestamp
of the log event -
appId
, if applicationId is configured
In addition they populate headers with the following values:
categoryName
of the log event -
The level of the log event
thread
: the name of the thread where log event happened -
The location of the stack trace of the log event call
A copy of all the MDC properties (unless
addMdcAsHeaders
is set tofalse
Each of the appenders can be subclassed, letting you modify the messages before publishing. The following example shows how to customize log messages:
public class MyEnhancedAppender extends AmqpAppender {
public Message postProcessMessageBeforeSend(Message message, Event event) {
message.getMessageProperties().setHeader("foo", "bar");
return message;
Starting with 2.2.4, the log4j2 AmqpAppender
can be extended using @PluginBuilderFactory
and extending also AmqpAppender.Builder
@Plugin(name = "MyEnhancedAppender", category = "Core", elementType = "appender", printObject = true)
public MyEnhancedAppender(String name, Filter filter, Layout<? extends Serializable> layout,
boolean ignoreExceptions, AmqpManager manager, BlockingQueue<Event> eventQueue, String foo, String bar) {
super(name, filter, layout, ignoreExceptions, manager, eventQueue);
return message;
public static Builder newBuilder() {
return new Builder();
protected static class Builder extends AmqpAppender.Builder {
protected AmqpAppender buildInstance(String name, Filter filter, Layout<? extends Serializable> layout,
boolean ignoreExceptions, AmqpManager manager, BlockingQueue<Event> eventQueue) {
return new MyEnhancedAppender(name, filter, layout, ignoreExceptions, manager, eventQueue);
4.3.5. Customizing the Client Properties
You can add custom client properties by adding either string properties or more complex properties.
Simple String Properties
Each appender supports adding client properties to the RabbitMQ connection.
The following example shows how to add a custom client property for logback:
<appender name="AMQP" ...>
<clientConnectionProperties>thing1:thing2,cat:hat</clientConnectionProperties>
</appender>
<Appenders>
clientConnectionProperties="thing1:thing2,cat:hat"
</RabbitMQ>
</Appenders>
The properties are a comma-delimited list of key:value
pairs.
Keys and values cannot contain commas or colons.
These properties appear on the RabbitMQ Admin UI when the connection is viewed.
Advanced Technique for Logback
You can subclass the Logback appender. Doing so lets you modify the client connection properties before the connection is established. The following example shows how to do so:
private String thing1;
protected void updateConnectionClientProperties(Map<String, Object> clientProperties) {
clientProperties.put("thing1", this.thing1);
public void setThing1(String thing1) {
this.thing1 = thing1;
Then you can add <thing1>thing2</thing1>
to logback.xml.
For String properties such as those shown in the preceding example, the previous technique can be used.
Subclasses allow for adding richer properties (such as adding a Map
or numeric property).
4.3.6. Providing a Custom Queue Implementation
The AmqpAppenders
use a BlockingQueue
to asynchronously publish logging events to RabbitMQ.
By default, a LinkedBlockingQueue
is used.
However, you can supply any kind of custom BlockingQueue
implementation.
The following example shows how to do so for Logback:
protected BlockingQueue<Event> createEventQueue() {
return new ArrayBlockingQueue();
The Log4j 2 appender supports using a BlockingQueueFactory
, as the following example shows:
<Appenders>
bufferSize="10" ... >
<ArrayBlockingQueue/>
</RabbitMQ>
</Appenders>
4.4. Sample Applications
The Spring AMQP Samples project includes two sample applications. The first is a simple “Hello World” example that demonstrates both synchronous and asynchronous message reception. It provides an excellent starting point for acquiring an understanding of the essential components. The second sample is based on a stock-trading use case to demonstrate the types of interaction that would be common in real world applications. In this chapter, we provide a quick walk-through of each sample so that you can focus on the most important components. The samples are both Maven-based, so you should be able to import them directly into any Maven-aware IDE (such as SpringSource Tool Suite).
4.4.1. The “Hello World” Sample
The “Hello World” sample demonstrates both synchronous and asynchronous message reception.
You can import the spring-rabbit-helloworld
sample into the IDE and then follow the discussion below.
Synchronous Example
Within the src/main/java
directory, navigate to the org.springframework.amqp.helloworld
package.
Open the HelloWorldConfiguration
class and notice that it contains the @Configuration
annotation at the class level and notice some @Bean
annotations at method-level.
This is an example of Spring’s Java-based configuration.
You can read more about that here.
The following listing shows how the connection factory is created:
public CachingConnectionFactory connectionFactory() {
CachingConnectionFactory connectionFactory =
new CachingConnectionFactory("localhost");
connectionFactory.setUsername("guest");
connectionFactory.setPassword("guest");
return connectionFactory;
The configuration also contains an instance of RabbitAdmin
, which, by default, looks for any beans of type exchange, queue, or binding and then declares them on the broker.
In fact, the helloWorldQueue
bean that is generated in HelloWorldConfiguration
is an example because it is an instance of Queue
The following listing shows the helloWorldQueue
bean definition:
public Queue helloWorldQueue() {
return new Queue(this.helloWorldQueueName);
Looking back at the rabbitTemplate
bean configuration, you can see that it has the name of helloWorldQueue
set as its queue
property (for receiving messages) and for its routingKey
property (for sending messages).
Now that we have explored the configuration, we can look at the code that actually uses these components.
First, open the Producer
class from within the same package.
It contains a main()
method where the Spring ApplicationContext
is created.
The following listing shows the main
method:
ApplicationContext context =
new AnnotationConfigApplicationContext(RabbitConfiguration.class);
AmqpTemplate amqpTemplate = context.getBean(AmqpTemplate.class);
amqpTemplate.convertAndSend("Hello World");
System.out.println("Sent: Hello World");
In the preceding example, the AmqpTemplate
bean is retrieved and used for sending a Message
Since the client code should rely on interfaces whenever possible, the type is AmqpTemplate
rather than RabbitTemplate
Even though the bean created in HelloWorldConfiguration
is an instance of RabbitTemplate
, relying on the interface means that this code is more portable (you can change the configuration independently of the code).
Since the convertAndSend()
method is invoked, the template delegates to its MessageConverter
instance.
In this case, it uses the default SimpleMessageConverter
, but a different implementation could be provided to the rabbitTemplate
bean, as defined in HelloWorldConfiguration
Now open the Consumer
class.
It actually shares the same configuration base class, which means it shares the rabbitTemplate
bean.
That is why we configured that template with both a routingKey
(for sending) and a queue
(for receiving).
As we describe in AmqpTemplate
, you could instead pass the 'routingKey' argument to the send method and the 'queue' argument to the receive method.
The Consumer
code is basically a mirror image of the Producer, calling receiveAndConvert()
rather than convertAndSend()
The following listing shows the main method for the Consumer
System.out.println("Received: " + amqpTemplate.receiveAndConvert());
If you run the Producer
and then run the Consumer
, you should see Received: Hello World
in the console output.
Asynchronous Example
Synchronous Example walked through the synchronous Hello World sample.
This section describes a slightly more advanced but significantly more powerful option.
With a few modifications, the Hello World sample can provide an example of asynchronous reception, also known as message-driven POJOs.
In fact, there is a sub-package that provides exactly that: org.springframework.amqp.samples.helloworld.async
Again, we start with the sending side.
Open the ProducerConfiguration
class and notice that it creates a connectionFactory
and a rabbitTemplate
bean.
This time, since the configuration is dedicated to the message sending side, we do not even need any queue definitions, and the RabbitTemplate
has only the 'routingKey' property set.
Recall that messages are sent to an exchange rather than being sent directly to a queue.
The AMQP default exchange is a direct exchange with no name.
All queues are bound to that default exchange with their name as the routing key.
That is why we only need to provide the routing key here.
The following listing shows the rabbitTemplate
definition:
public RabbitTemplate rabbitTemplate() {
RabbitTemplate template = new RabbitTemplate(connectionFactory());
template.setRoutingKey(this.helloWorldQueueName);
return template;
Since this sample demonstrates asynchronous message reception, the producing side is designed to continuously send messages (if it were a message-per-execution model like the synchronous version, it would not be quite so obvious that it is, in fact, a message-driven consumer).
The component responsible for continuously sending messages is defined as an inner class within the ProducerConfiguration
It is configured to run every three seconds.
The following listing shows the component:
static class ScheduledProducer {
@Autowired
private volatile RabbitTemplate rabbitTemplate;
private final AtomicInteger counter = new AtomicInteger();
@Scheduled(fixedRate = 3000)
public void sendMessage() {
rabbitTemplate.convertAndSend("Hello World " + counter.incrementAndGet());
You do not need to understand all of the details, since the real focus should be on the receiving side (which we cover next).
However, if you are not yet familiar with Spring task scheduling support, you can learn more here.
The short story is that the postProcessor
bean in the ProducerConfiguration
registers the task with a scheduler.
Now we can turn to the receiving side.
To emphasize the message-driven POJO behavior, we start with the component that react to the messages.
The class is called HelloWorldHandler
and is shown in the following listing:
public class HelloWorldHandler {
public void handleMessage(String text) {
System.out.println("Received: " + text);
That class is a POJO.
It does not extend any base class, it does not implement any interfaces, and it does not even contain any imports.
It is being “adapted” to the MessageListener
interface by the Spring AMQP MessageListenerAdapter
You can then configure that adapter on a SimpleMessageListenerContainer
For this sample, the container is created in the ConsumerConfiguration
class.
You can see the POJO wrapped in the adapter there.
The following listing shows how the listenerContainer
is defined:
public SimpleMessageListenerContainer listenerContainer() {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer();
container.setConnectionFactory(connectionFactory());
container.setQueueName(this.helloWorldQueueName);
container.setMessageListener(new MessageListenerAdapter(new HelloWorldHandler()));
return container;
is a Spring lifecycle component and, by default, starts automatically.
If you look in the Consumer
class, you can see that its main()
method consists of nothing more than a one-line bootstrap to create the ApplicationContext
The Producer’s main()
method is also a one-line bootstrap, since the component whose method is annotated with @Scheduled
also starts automatically.
You can start the Producer
and Consumer
in any order, and you should see messages being sent and received every three seconds.
4.4.2. Stock Trading
The Stock Trading sample demonstrates more advanced messaging scenarios than the Hello World sample.
However, the configuration is very similar, if a bit more involved.
Since we walked through the Hello World configuration in detail, here, we focus on what makes this sample different.
There is a server that pushes market data (stock quotations) to a topic exchange.
Then, clients can subscribe to the market data feed by binding a queue with a routing pattern (for example,
app.stock.quotes.nasdaq.*
The other main feature of this demo is a request-reply “stock trade” interaction that is initiated by the client and handled by the server.
That involves a private replyTo
queue that is sent by the client within the order request message itself.
The server’s core configuration is in the RabbitServerConfiguration
class within the org.springframework.amqp.rabbit.stocks.config.server
package.
It extends the AbstractStockAppRabbitConfiguration
That is where the resources common to the server and client are defined, including the market data topic exchange (whose name is 'app.stock.marketdata') and the queue that the server exposes for stock trades (whose name is 'app.stock.request').
In that common configuration file, you also see that a Jackson2JsonMessageConverter
is configured on the RabbitTemplate
The server-specific configuration consists of two things.
First, it configures the market data exchange on the RabbitTemplate
so that it does not need to provide that exchange name with every call to send a Message
It does this within an abstract callback method defined in the base configuration class.
The following listing shows that method:
public void configureRabbitTemplate(RabbitTemplate rabbitTemplate) {
rabbitTemplate.setExchange(MARKET_DATA_EXCHANGE_NAME);
Second, the stock request queue is declared.
It does not require any explicit bindings in this case, because it is bound to the default no-name exchange with its own name as the routing key.
As mentioned earlier, the AMQP specification defines that behavior.
The following listing shows the definition of the stockRequestQueue
bean:
public Queue stockRequestQueue() {
return new Queue(STOCK_REQUEST_QUEUE_NAME);
Now that you have seen the configuration of the server’s AMQP resources, navigate to the org.springframework.amqp.rabbit.stocks
package under the src/test/java
directory.
There, you can see the actual Server
class that provides a main()
method.
It creates an ApplicationContext
based on the server-bootstrap.xml
config file.
There, you can see the scheduled task that publishes dummy market data.
That configuration relies upon Spring’s task
namespace support.
The bootstrap config file also imports a few other files.
The most interesting one is server-messaging.xml
, which is directly under src/main/resources
There, you can see the messageListenerContainer
bean that is responsible for handling the stock trade requests.
Finally, have a look at the serverHandler
bean that is defined in server-handlers.xml
(which is also in 'src/main/resources').
That bean is an instance of the ServerHandler
class and is a good example of a message-driven POJO that can also send reply messages.
Notice that it is not itself coupled to the framework or any of the AMQP concepts.
It accepts a TradeRequest
and returns a TradeResponse
The following listing shows the definition of the handleMessage
method:
public TradeResponse handleMessage(TradeRequest tradeRequest) { ...
Now that we have seen the most important configuration and code for the server, we can turn to the client.
The best starting point is probably RabbitClientConfiguration
, in the org.springframework.amqp.rabbit.stocks.config.client
package.
Notice that it declares two queues without providing explicit names.
The following listing shows the bean definitions for the two queues:
public Queue marketDataQueue() {
return amqpAdmin().declareQueue();
public Queue traderJoeQueue() {
Those are private queues, and unique names are generated automatically.
The first generated queue is used by the client to bind to the market data exchange that has been exposed by the server.
Recall that, in AMQP, consumers interact with queues while producers interact with exchanges.
The “binding” of queues to exchanges is what tells the broker to deliver (or route) messages from a given exchange to a queue.
Since the market data exchange is a topic exchange, the binding can be expressed with a routing pattern.
The RabbitClientConfiguration
does so with a Binding
object, and that object is generated with the BindingBuilder
fluent API.
The following listing shows the Binding
@Value("${stocks.quote.pattern}")
private String marketDataRoutingKey;
public Binding marketDataBinding() {
return BindingBuilder.bind(
marketDataQueue()).to(marketDataExchange()).with(marketDataRoutingKey);
Notice that the actual value has been externalized in a properties file (client.properties
), and that we use Spring’s @Value
annotation to inject that value.
This is generally a good idea.
Otherwise, the value would have been hardcoded in a class and unmodifiable without recompilation.
In this case, it is much easier to run multiple versions of the client while making changes to the routing pattern used for binding.
We can try that now.
Start by running org.springframework.amqp.rabbit.stocks.Server
and then org.springframework.amqp.rabbit.stocks.Client
You should see dummy quotations for NASDAQ
stocks, because the current value associated with the 'stocks.quote.pattern' key in client.properties is 'app.stock.quotes.nasdaq.'.
Now, while keeping the existing Server
and Client
running, change that property value to 'app.stock.quotes.nyse.' and start a second Client
instance.
You should see that the first client still receives NASDAQ quotes while the second client receives NYSE quotes.
You could instead change the pattern to get all stocks or even an individual ticker.
The final feature we explore is the request-reply interaction from the client’s perspective.
Recall that we have already seen the ServerHandler
that accepts TradeRequest
objects and returns TradeResponse
objects.
The corresponding code on the Client
side is RabbitStockServiceGateway
in the org.springframework.amqp.rabbit.stocks.gateway
package.
It delegates to the RabbitTemplate
in order to send messages.
The following listing shows the send
method:
public void send(TradeRequest tradeRequest) {
getRabbitTemplate().convertAndSend(tradeRequest, new MessagePostProcessor() {
public Message postProcessMessage(Message message) throws AmqpException {
message.getMessageProperties().setReplyTo(new Address(defaultReplyToQueue));
try {
message.getMessageProperties().setCorrelationId(
UUID.randomUUID().toString().getBytes("UTF-8"));
catch (UnsupportedEncodingException e) {
throw new AmqpException(e);
return message;
Notice that, prior to sending the message, it sets the replyTo
address.
It provides the queue that was generated by the traderJoeQueue
bean definition (shown earlier).
The following listing shows the @Bean
definition for the StockServiceGateway
class itself:
public StockServiceGateway stockServiceGateway() {
RabbitStockServiceGateway gateway = new RabbitStockServiceGateway();
gateway.setRabbitTemplate(rabbitTemplate());
gateway.setDefaultReplyToQueue(traderJoeQueue());
return gateway;
If you are no longer running the server and client, start them now. Try sending a request with the format of '100 TCKR'. After a brief artificial delay that simulates “processing” of the request, you should see a confirmation message appear on the client.
4.4.3. Receiving JSON from Non-Spring Applications
Spring applications, when sending JSON, set the TypeId
header to the fully qualified class name to assist the receiving application in converting the JSON back to a Java object.
The spring-rabbit-json
sample explores several techniques to convert the JSON from a non-Spring application.
See also Jackson2JsonMessageConverter as well as the Javadoc for the DefaultClassMapper
4.5. Testing Support
Writing integration for asynchronous applications is necessarily more complex than testing simpler applications.
This is made more complex when abstractions such as the @RabbitListener
annotations come into the picture.
The question is how to verify that, after sending a message, the listener received the message as expected.
The framework itself has many unit and integration tests. Some using mocks while, others use integration testing with a live RabbitMQ broker. You can consult those tests for some ideas for testing scenarios.
Spring AMQP version 1.6 introduced the spring-rabbit-test
jar, which provides support for testing some of these more complex scenarios.
It is anticipated that this project will expand over time, but we need community feedback to make suggestions for the features needed to help with testing.
Please use JIRA or GitHub Issues to provide such feedback.
4.5.1. @SpringRabbitTest
Use this annotation to add infrastructure beans to the Spring test ApplicationContext
This is not necessary when using, for example @SpringBootTest
since Spring Boot’s auto configuration will add the beans.
Beans that are registered are:
(autoConnectionFactory
). If@RabbitEnabled
is present, its connectionn factory is used. -
RabbitTemplate
(autoRabbitTemplate
RabbitAdmin
(autoRabbitAdmin
(autoContainerFactory
In addition, the beans associated with @EnableRabbit
(to support @RabbitListener
) are added.
@SpringJunitConfig
@SpringRabbitTest
public class MyRabbitTests {
@Autowired
private RabbitTemplate template;
@Autowired
private RabbitAdmin admin;
@Autowired
private RabbitListenerEndpointRegistry registry;
@Test
void test() {
public static class Config {
With JUnit4, replace @SpringJunitConfig
with @RunWith(SpringRunnner.class)
4.5.2. Mockito Answer<?>
Implementations
There are currently two Answer<?>
implementations to help with testing.
The first, LatchCountDownAndCallRealMethodAnswer
, provides an Answer<Void>
that returns null
and counts down a latch.
The following example shows how to use LatchCountDownAndCallRealMethodAnswer
LatchCountDownAndCallRealMethodAnswer answer = this.harness.getLatchAnswerFor("myListener", 2);
doAnswer(answer)
.when(listener).foo(anyString(), anyString());
assertThat(answer.await(10)).isTrue();
The second, LambdaAnswer<T>
provides a mechanism to optionally call the real method and provides an opportunity
to return a custom result, based on the InvocationOnMock
and the result (if any).
Consider the following POJO:
public class Thing {
public String thing(String thing) {
return thing.toUpperCase();
The following class tests the Thing
POJO:
Thing thing = spy(new Thing());
doAnswer(new LambdaAnswer<String>(true, (i, r) -> r + r))
.when(thing).thing(anyString());
assertEquals("THINGTHING", thing.thing("thing"));
doAnswer(new LambdaAnswer<String>(true, (i, r) -> r + i.getArguments()[0]))
assertEquals("THINGthing", thing.thing("thing"));
doAnswer(new LambdaAnswer<String>(false, (i, r) ->
"" + i.getArguments()[0] + i.getArguments()[0])).when(thing).thing(anyString());
assertEquals("thingthing", thing.thing("thing"));
Starting with version 2.2.3, the answers capture any exceptions thrown by the method under test.
Use answer.getExceptions()
to get a reference to them.
When used in conjunction with the @RabbitListenerTest
and RabbitListenerTestHarness
use harness.getLambdaAnswerFor("listenerId", true, …)
to get a properly constructed answer for the listener.
4.5.3. @RabbitListenerTest
Annotating one of your @Configuration
classes with @RabbitListenerTest
causes the framework to replace the
standard RabbitListenerAnnotationBeanPostProcessor
with a subclass called RabbitListenerTestHarness
(it also enables
@RabbitListener
detection through @EnableRabbit
The RabbitListenerTestHarness
enhances the listener in two ways.
First, it wraps the listener in a Mockito Spy
, enabling normal Mockito
stubbing and verification operations.
It can also add an Advice
to the listener, enabling access to the arguments, result, and any exceptions that are thrown.
You can control which (or both) of these are enabled with attributes on the @RabbitListenerTest
The latter is provided for access to lower-level data about the invocation.
It also supports blocking the test thread until the async listener is called.
final @RabbitListener methods cannot be spied or advised.
Also, only listeners with an id attribute can be spied or advised.
Consider some examples.
The following example uses spy:
@RabbitListenerTest
public class Config {
public Listener listener() {
return new Listener();
public class Listener {
@RabbitListener(id="foo", queues="#{queue1.name}")
public String foo(String foo) {
return foo.toUpperCase();
@RabbitListener(id="bar", queues="#{queue2.name}")
public void foo(@Payload String foo, @Header("amqp_receivedRoutingKey") String rk) {
public class MyTests {
@Autowired
private RabbitListenerTestHarness harness; (1)
@Test
public void testTwoWay() throws Exception {
assertEquals("FOO", this.rabbitTemplate.convertSendAndReceive(this.queue1.getName(), "foo"));
Listener listener = this.harness.getSpy("foo"); (2)
assertNotNull(listener);
verify(listener).foo("foo");
@Test
public void testOneWay() throws Exception {
Listener listener = this.harness.getSpy("bar");
LatchCountDownAndCallRealMethodAnswer answer = this.harness.getLatchAnswerFor("bar", 2); (3)
doAnswer(answer).when(listener).foo(anyString(), anyString()); (4)
this.rabbitTemplate.convertAndSend(this.queue2.getName(), "bar");
this.rabbitTemplate.convertAndSend(this.queue2.getName(), "baz");
assertTrue(answer.await(10));
verify(listener).foo("bar", this.queue2.getName());
verify(listener).foo("baz", this.queue2.getName());
1 | Inject the harness into the test case so we can get access to the spy. |
2 | Get a reference to the spy so we can verify it was invoked as expected.
Since this is a send and receive operation, there is no need to suspend the test thread because it was already
suspended in the RabbitTemplate waiting for the reply. |
3 | In this case, we’re only using a send operation so we need a latch to wait for the asynchronous call to the listener
on the container thread.
We use one of the Answer<?> implementations to help with that.
IMPORTANT: Due to the way the listener is spied, it is important to use harness.getLatchAnswerFor() to get a properly configured answer for the spy. |
4 | Configure the spy to invoke the Answer . |
The following example uses the capture advice:
@ComponentScan
@RabbitListenerTest(spy = false, capture = true)
@Service
private boolean failed;
if (!failed && foo.equals("ex")) {
failed = true;
throw new RuntimeException(foo);
failed = false;
@Autowired
@Test
InvocationData invocationData =
this.harness.getNextInvocationDataFor("foo", 0, TimeUnit.SECONDS); (2)
assertThat(invocationData.getArguments()[0], equalTo("foo")); (3)
assertThat((String) invocationData.getResult(), equalTo("FOO"));
@Test
this.rabbitTemplate.convertAndSend(this.queue2.getName(), "ex");
this.harness.getNextInvocationDataFor("bar", 10, TimeUnit.SECONDS); (4)
Object[] args = invocationData.getArguments();
assertThat((String) args[0], equalTo("bar"));
assertThat((String) args[1], equalTo(queue2.getName()));
invocationData = this.harness.getNextInvocationDataFor("bar", 10, TimeUnit.SECONDS);
assertThat((String) args[0], equalTo("baz"));
assertThat((String) args[0], equalTo("ex"));
assertEquals("ex", invocationData.getThrowable().getMessage()); (5)
2 | Use harness.getNextInvocationDataFor() to retrieve the invocation data - in this case since it was a request/reply
scenario there is no need to wait for any time because the test thread was suspended in the RabbitTemplate waiting
for the result. |
3 | We can then verify that the argument and result was as expected. |
4 | This time we need some time to wait for the data, since it’s an async operation on the container thread and we need to suspend the test thread. |
5 | When the listener throws an exception, it is available in the throwable property of the invocation data. |
When using custom Answer<?> s with the harness, in order to operate properly, such answers should subclass ForwardsInvocation and get the actual listener (not the spy) from the harness (getDelegate("myListener") ) and call super.answer(invocation) .
See the provided Mockito Answer<?> Implementations source code for examples.
4.5.4. Using TestRabbitTemplate
The TestRabbitTemplate
is provided to perform some basic integration testing without the need for a broker.
When you add it as a @Bean
in your test case, it discovers all the listener containers in the context, whether declared as @Bean
or <bean/>
or using the @RabbitListener
annotation.
It currently only supports routing by queue name.
The template extracts the message listener from the container and invokes it directly on the test thread.
Request-reply messaging (sendAndReceive
methods) is supported for listeners that return replies.
The following test case uses the template:
@RunWith(SpringRunner.class)
public class TestRabbitTemplateTests {
@Autowired
private TestRabbitTemplate template;
@Autowired
private Config config;
@Test
public void testSimpleSends() {
this.template.convertAndSend("foo", "hello1");
assertThat(this.config.fooIn, equalTo("foo:hello1"));
this.template.convertAndSend("bar", "hello2");
assertThat(this.config.barIn, equalTo("bar:hello2"));
assertThat(this.config.smlc1In, equalTo("smlc1:"));
this.template.convertAndSend("foo", "hello3");
this.template.convertAndSend("bar", "hello4");
assertThat(this.config.smlc1In, equalTo("smlc1:hello3hello4"));
this.template.setBroadcast(true);
this.template.convertAndSend("foo", "hello5");
assertThat(this.config.fooIn, equalTo("foo:hello1foo:hello5"));
this.template.convertAndSend("bar", "hello6");
assertThat(this.config.barIn, equalTo("bar:hello2bar:hello6"));
assertThat(this.config.smlc1In, equalTo("smlc1:hello3hello4hello5hello6"));
@Test
public void testSendAndReceive() {
assertThat(this.template.convertSendAndReceive("baz", "hello"), equalTo("baz:hello"));
@EnableRabbit
public String fooIn = "";
public String barIn = "";
public String smlc1In = "smlc1:";
public TestRabbitTemplate template() throws IOException {
return new TestRabbitTemplate(connectionFactory());
public ConnectionFactory connectionFactory() throws IOException {
ConnectionFactory factory = mock(ConnectionFactory.class);
Connection connection = mock(Connection.class);
Channel channel = mock(Channel.class);
willReturn(connection).given(factory).createConnection();
willReturn(channel).given(connection).createChannel(anyBoolean());
given(channel.isOpen()).willReturn(true);
return factory;
public SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory() throws IOException {
factory.setConnectionFactory(connectionFactory());
return factory;
@RabbitListener(queues = "foo")
public void foo(String in) {
this.fooIn += "foo:" + in;
@RabbitListener(queues = "bar")
public void bar(String in) {
this.barIn += "bar:" + in;
@RabbitListener(queues = "baz")
public String baz(String in) {
return "baz:" + in;
public SimpleMessageListenerContainer smlc1() throws IOException {
SimpleMessageListenerContainer container = new SimpleMessageListenerContainer(connectionFactory());
container.setQueueNames("foo", "bar");
container.setMessageListener(new MessageListenerAdapter(new Object() {
@SuppressWarnings("unused")
public void handleMessage(String in) {
smlc1In += in;
return container;
4.5.5. JUnit4 @Rules
Spring AMQP version 1.7 and later provide an additional jar called spring-rabbit-junit
This jar contains a couple of utility @Rule
instances for use when running JUnit4 tests.
See JUnit5 Conditions for JUnit5 testing.
Using BrokerRunning
BrokerRunning
provides a mechanism to let tests succeed when a broker is not running (on localhost
, by default).
It also has utility methods to initialize and empty queues and delete queues and exchanges.
The following example shows its usage:
@ClassRule
public static BrokerRunning brokerRunning = BrokerRunning.isRunningWithEmptyQueues("foo", "bar");
@AfterClass
public static void tearDown() {
brokerRunning.removeTestQueues("some.other.queue.too") // removes foo, bar as well
There are several isRunning…
static methods, such as isBrokerAndManagementRunning()
, which verifies the broker has the management plugin enabled.
Configuring the Rule
There are times when you want tests to fail if there is no broker, such as a nightly CI build.
To disable the rule at runtime, set an environment variable called RABBITMQ_SERVER_REQUIRED
to true
You can override the broker properties, such as hostname with either setters or environment variables:
The following example shows how to override properties with setters:
@ClassRule
static {
brokerRunning.setHostName("10.0.0.1")
@AfterClass
You can also override properties by setting the following environment variables:
public static final String BROKER_ADMIN_URI = "RABBITMQ_TEST_ADMIN_URI";
public static final String BROKER_HOSTNAME = "RABBITMQ_TEST_HOSTNAME";
public static final String BROKER_PORT = "RABBITMQ_TEST_PORT";
public static final String BROKER_USER = "RABBITMQ_TEST_USER";
public static final String BROKER_PW = "RABBITMQ_TEST_PASSWORD";
public static final String BROKER_ADMIN_USER = "RABBITMQ_TEST_ADMIN_USER";
public static final String BROKER_ADMIN_PW = "RABBITMQ_TEST_ADMIN_PASSWORD";
These environment variables override the default settings (localhost:5672
for amqp and localhost:15672/api/
for the management REST API).
Changing the host name affects both the amqp
and management
REST API connection (unless the admin uri is explicitly set).
BrokerRunning
also provides a static
method called setEnvironmentVariableOverrides
that lets you can pass in a map containing these variables.
They override system environment variables.
This might be useful if you wish to use different configuration for tests in multiple test suites.
IMPORTANT: The method must be called before invoking any of the isRunning()
static methods that create the rule instance.
Variable values are applied to all instances created after this invocation.
Invoke clearEnvironmentVariableOverrides()
to reset the rule to use defaults (including any actual environment variables).
In your test cases, you can use the brokerRunning
when creating the connection factory; getConnectionFactory()
returns the rule’s RabbitMQ ConnectionFactory
public CachingConnectionFactory rabbitConnectionFactory() {
return new CachingConnectionFactory(brokerRunning.getConnectionFactory());
Using LongRunningIntegrationTest
is a rule that disables long running tests.
You might want to use this on a developer system but ensure that the rule is disabled on, for example, nightly CI builds.
@Rule
public LongRunningIntegrationTest longTests = new LongRunningIntegrationTest();
To disable the rule at runtime, set an environment variable called RUN_LONG_INTEGRATION_TESTS
to true
4.5.6. JUnit5 Conditions
Version 2.0.2 introduced support for JUnit5.
Using the @RabbitAvailable
Annotation
This class-level annotation is similar to the BrokerRunning
@Rule
discussed in JUnit4 @Rules
It is processed by the RabbitAvailableCondition
The annotation has three properties:
queues
: An array of queues that are declared (and purged) before each test and deleted when all tests are complete. -
management
: Set this totrue
if your tests also require the management plugin installed on the broker. -
purgeAfterEach
: (Since version 2.2) whentrue
(default), thequeues
will be purged between tests.
It is used to check whether the broker is available and skip the tests if not.
As discussed in Configuring the Rule, the environment variable called RABBITMQ_SERVER_REQUIRED
, if true
, causes the tests to fail fast if there is no broker.
You can configure the condition by using environment variables as discussed in Configuring the Rule.
In addition, the RabbitAvailableCondition
supports argument resolution for parameterized test constructors and methods.
Two argument types are supported:
BrokerRunningSupport
: The instance (before 2.2, this was a JUnit 4BrokerRunning
instance) -
ConnectionFactory
: TheBrokerRunningSupport
instance’s RabbitMQ connection factory
The following example shows both:
@RabbitAvailable(queues = "rabbitAvailableTests.queue")
public class RabbitAvailableCTORInjectionTests {
private final ConnectionFactory connectionFactory;
public RabbitAvailableCTORInjectionTests(BrokerRunningSupport brokerRunning) {
this.connectionFactory = brokerRunning.getConnectionFactory();
@Test
public void test(ConnectionFactory cf) throws Exception {
assertSame(cf, this.connectionFactory);
Connection conn = this.connectionFactory.newConnection();
Channel channel = conn.createChannel();
DeclareOk declareOk = channel.queueDeclarePassive("rabbitAvailableTests.queue");
assertEquals(0, declareOk.getConsumerCount());
channel.close();
conn.close();
The preceding test is in the framework itself and verifies the argument injection and that the condition created the queue properly.
A practical user test might be as follows:
private final CachingConnectionFactory connectionFactory;
@Test
public void test() throws Exception {
RabbitTemplate template = new RabbitTemplate(this.connectionFactory);
When you use a Spring annotation application context within a test class, you can get a reference to the condition’s connection factory through a static method called RabbitAvailableCondition.getBrokerRunning()
Starting with version 2.2, getBrokerRunning() returns a BrokerRunningSupport object; previously, the JUnit 4 BrokerRunnning instance was returned.
The new class has the same API as BrokerRunning .
The following test comes from the framework and demonstrates the usage:
@RabbitAvailable(queues = {
RabbitTemplateMPPIntegrationTests.QUEUE,
RabbitTemplateMPPIntegrationTests.REPLIES })
@SpringJUnitConfig
@DirtiesContext(classMode = ClassMode.AFTER_EACH_TEST_METHOD)
public class RabbitTemplateMPPIntegrationTests {
public static final String QUEUE = "mpp.tests";
public static final String REPLIES = "mpp.tests.replies";
@Autowired
@Autowired
@Test
public void test() {
@EnableRabbit
public CachingConnectionFactory cf() {
return new CachingConnectionFactory(RabbitAvailableCondition
.getBrokerRunning()
public RabbitTemplate template() {
rabbitListenerContainerFactory() {
@RabbitListener(queues = QUEUE)
public byte[] foo(byte[] in) {
return in;
Using the @LongRunning
Annotation
Similar to the LongRunningIntegrationTest
JUnit4 @Rule
, this annotation causes tests to be skipped unless an environment variable (or system property) is set to true
The following example shows how to use it:
@RabbitAvailable(queues = SimpleMessageListenerContainerLongTests.QUEUE)
@LongRunning
public class SimpleMessageListenerContainerLongTests {
public static final String QUEUE = "SimpleMessageListenerContainerLongTests.queue";
By default, the variable is RUN_LONG_INTEGRATION_TESTS
, but you can specify the variable name in the annotation’s value
attribute.
